- PM-FL Tuning Package Sale!!!
- A little help would be appreciated....
- HP Tuners (Tuning School package) f/s in parts section
- Help '02 z06 stopped running
- APP codes and temp gage spike after engine swap ..HELP!!
- Power Commander
- Formato Tuning and Porting Gettysburg PA from Nov 6th thru the 14th
- Hp Tuners Pro now in stock!!!
- Greg Banish Calibrated Success Tuning DVD for sale
- Female Tuners
- VE table ?
- Misfire problem
- P4 Dell inspiron laptop 2650 Perfect for data logging $150 HPTUNERS installed
- Ultimate intake & fuel system for N/A stock LS1/LS6 motor?
- Who's the best tuner in Cinn OH or northern KY
- Need SDM information, does it trigger air bags of just record information?
- What is your stock horse power?
- tuners
- 180 Thermostat and Closed Loop/Fan Tuning
- How will dyno results change after gears?
- Any corvette tuners in TN
- Help!
- Engine stalls when cold coming to a stop and randomly when hot
- ??? on LS1 edit
- Predator tuning with long tube headers
- Selling Greg Banish Tuning DVD
- Burst caps for the Fast intake
- Help with the LC1 Innovate AFR Gauge
- Best tuner in TX?
- Superchips flashpaq question..
- New pcm
- any dyno tuning going on at Eureka springs?
- Engine Light Issue - Air System Band Fault
- Breathless Vortex Air Rammer a proven winner again
- Gainesville Area Tuning
- Logging Speed vs RPM to show clutch slip
- Tuning tips for ported manifolds and TBs
- Best Source/Price on DiabloSport Predator
- Formato tuning and porting in S. FL (Davie) Sept 10-11-12
- clutch fluid
- Need to verify sn on my EFI Live cable, prepping to sell
- Best tuner around atlanta
- Turn off CCP with HP Tuners??
- Whats the bucking problem with my car
- How to post an HPTuners file
- codes
- codes
- Basetune/stock tune idle issues after SC & other goodies install
- Need some help
- OBD II PC based scan tools
- Apsis' C5 Waterfall + Armrest in all Nappa Black Leather..... new pic
- In dash display for HP Tuners.
- where is the RR Outlet Valve Solenoid
- Innovate Motorsports Wideband Controller Sale!!!
- Tuners in W. Mich
- Dropped a valve in #7 cylinder
- New Magnuson Tune Question
- DIC codes
- "chuck cow" tune
- Fast Intake broken at 16 psi
- '98 c5 no start
- what would trigger this code? misfire? or crank sensor?
- Problem after PCM retune - runs 1-2 sec and dies
- ***HP Tuners Pro and Standard Versions***
- Innovate LM-2 basic group purchase
- Not Starting very well Here are my codes
- E3 spark plus
- Tune after mods.......
- Can the cycle time to Competition mode be shortened?
- To tune and from whom?
- "OLD" codes back
- What gear is used for dyno pulls??
- C5 VARARAMs INSTALLED at CARLISLE by CORVETTES OF WESTCHESTER
- new to this game
- L o w e s t . . P r i c e s . . E v e r !! MONSTER CLUTCHES
- HP Tuners question before purchase
- Anyone on here know HP Tuners in DFW Area?
- Need Help ASAP
- Tune and checked out
- how hp????
- Fuel Dumping at Idle
- HUD problem
- got a quote from 2 places for a tune!!!
- EFI Live B4317 to drop idle faster when coming to a stop?
- ******Gettysburg Tuning and Porting Aug 21-29******
- IAT problems
- Any before and after dyno numbers with mail order tunes?
- ABS Code Scanner??
- column lock bypass and Skip shift eliminator
- Miami area tuners
- Spark plug torque
- >>>>St Jude Auction #55 Get Stung! Halltech C5 Stinger for 97-00 C5 <<<
- Tune needed in Chicagoland NW Indiana area!
- Apsis' C5 D-Type SW w/Torch Red on Top available now...anybody wants to take it? pix
- vararam surge
- The Tuning School Tuning Packages
- calling all those that have cams,heads etc.
- Reset Airbag Light!
- Active handling warming up/Reduced power
- REDEUX ## St Jude Auction #48 American Racing Headers C5 / C6 / C6Z06 / C6ZR1 ##
- Apsis' Driver Door Panel in Premium Italian Nappa Leather...got to see...pix
- alz
- Diablo predator
- Anyone use EFI-Live with Zeitronix Wideband?
- E3 Diamondfire plugs....anyone run/have experience??
- Apsis' Waterfall+Armrest in Premium Italian Nappa Leather...look FANTASTIC...pix
- Cheapest way to edit onboard computer
- My ECS Tune
- Apsis' Premium Italian Nappa Leather Door Panel.....look FANTASTIC...pix
- Need Help!!
- New Engine Blues
- SE & FL LSx Tune Check Up - $89 w/ Dyno, Scan & Consult
- Surging while driving...help
- heater install guestion
- fast 90 without tune...debating on installing
- Noticable miss at idle
- Results of my ECS Mail Order Tune....
- Apsis' D-type Carbon Steering Wheel installed..... pic
- Tweaking tune to sneak thru smog test.
- Great tuner in Midwest
- Cold Air Intake and Headers going rich?
- in need of a good tuner in or around Katy-Houston Texas
- car bogs after tune
- Effect of weather on tune
- my new ls2 402 ???????
- A/C hot on driver side and cold on pass side
- 98 ecm upgrade
- bolt on c5z worth tunning?
- Superchip question.
- IAT sensor reading 199deg at end of 1/4 mile!!!!!
- Tuners: Anyone Willing To Share 60# Motron Info
- 02 codes
- Reduced Engine Power - A1-RDCM NO COMM
- LC1 simulating narrow band throwing error
- JW Motoring is now an authorized dealer for HP Tuners!
- any help on code 153
- Info on DynoSport / Lincoln Neb.
- Diablo not disabling CAGS???
- ABACO DBX flowmeters
- Resetting 'Service TPMS' code if I dont have sensors
- **MSD coil pack yes or no**
- Just purchased a 97 w/o cats
- 1514 code and "reduced engine power" = won't start
- Idle problem after Head, Cam & Tune
- LM1 and HPtuners ?
- Need an opinion from someone about DIC Codes I found
- Predator
- Installing Longtube Headers (no cats)...
- Mail order tunes $150 cdn!!!!!!!!!!!
- Best Tuner to buy?
- a tune
- 98 C5 tune questions.
- tuning out p0410
- Injector Epiphany ( Help Tuning )
- How do I know what my injectors are?
- Who's Tune is Least Expensive?
- C5 Air-Conditioning
- LTFT Imbalance
- Misfire on my 98
- ADLC fuse?
- logging boost in efi live
- Caution before buying from Hypertech
- Looking to buy a diablo tuner
- Just added resonators in place of cats, now car stalls at first in Open loop,
- Best way to tune out 1 to 4 shift, and fuel shut off from 2 to 250?
- Should I try this?? Fueling fix...
- can hptuners adjust Idle speed.
- looking for best handheld tuner
- Thumbs up, Jeremy Formato
- Intermitant no start issue
- Apsis Beautiful C5 D-Type Steering Wheel w/torch red on top.... pixs
- need help
- Need help with codes please.
- 2004 Z06 Misfire Problem after Longtubes
- Laptops?
- Scan tool pulling BCM codes?
- Throttle position input vs. commanded, are people really messing w/ this????
- Thumbs up for ECS
- should i get the HP tuner program?
- Got ? about open loop tune
- can i get this to pass PA emissions
- Tuning out drone
- Long Tube Header tune and code fixing.
- Air/Fuel help
- Anybody out there interested in in providing track support for 2 C6 Z06 Corvettes at
- Disabling LTFT's with MAF still enabled
- To Tune, or not to Tune?
- Need tune for LS7 installed in 02 z06
- Tuning question on my vette about commanded AFR
- Logging through EGR Unable to parse log?
- HP Tuners Sale @ KY Speed
- codes c1232,c1233,c1248
- 250 mph fuel shut off
- Lost HP But Gained Torque, is that good?
- Happy with shop in West Florida...
- Racing Gas?
- Tuning by east coast supercharing
- What's Tune?
- Thanks BLOWNBLUEZ06!!!
- Knock, Knock, Knock..
- Need a good tuner in NC or SC
- The Tuning School Live Seminar Beginners HP Tuners June 27-28th Tampa, FL
- Tuning 04 Z06 for Vram and LTs
- Amazing C5 Red Carbon Dashes..... how do you like it?
- Is a Cam only (MS3) swap with a tune worth it with no other mods planned?
- ECS Mail order tunes, still only $149!
- Need a GREAT tuner in North Ga?
- Would you road tune on a mountain pass?
- Changing MAF possible with Predator ?
- need tuner knoxville tn
- Looking for tuner in Wichita, KS area for fuel cutoff reset
- Need a tuner
- Fuel Gauge?
- Good Tune Read (LONG) Tuners Input Desired
- Question about a power programer
- Need spark plug Gap for 99 FRC
- My Chuck CoW tuning day pics
- Switched power source for wideband
- need a source for PCM harness pins
- IAT sensor malfunction - how does this affect how my car runs?
- Car dies
- Tune
- New to the Vette world
- Need help with error code c1214
- Problem with spark advance, any know about this?
- SKF Hubs
- tuner?
- Question about how an A4 car is dynoed?
- GP Special: C5 D-Type SW .... *PIC*
- Did I kill my Gas Gauge?
- Need Some Pro Tuner Help
- Help with (hypertech) programmer
- I got a Check engine light today!!!
- MTI Heads and x1 Cam Tune question
- another weird problem after tune
- New Vette for me - Tune question
- A Good tuner
- stock 03 z06 will tune help?
- Logging Wideband through EGR on 98
- Jeremy Formato Tuning and Porting in Gettysburg PA June 13-20th
- NEED a good tuner in San Diego, CA
- Weird Problem after tune
- problems after tune
- what will a tune do for me?
- Experience with MC Racing in KC area
- new exhaust/no CATS/ O-2 issues HELP
- Innovative LC-1 users
- Are there any good handheld tuners?
- idles but dies
- Upgraded to a Z06 85mm MAF do I need to change anything other than the MAF Table?
