- BEST price on LC1s??
- Which Injectors To Use 30lbs Or 42lbs
- [EFILive] Anybody have a stock 2001/02 C5 TUN file?
- Code P0140 and P0161
- 5th gear problem
- code pcm p0751
- Scantool Question
- Michigan tuner
- Predator fan setting and tourque management question
- Dallas Tuners???
- Shift Pressures ?
- code p0113 & p1111 after new IAT sensor
- How do Longtube headers affect stock tune?
- 2001 w/Computer or Wiring Problems...
- Tuner near San Antonio Tx
- Tuning Gurus Step In
- Scan Tools
- Tuner ???
- code questions
- Getting PRO Yank 3600 TC and 3.42 Gears
- Scanmaster for LS6?
- My Latest Performance MODS
- Excessive exhaust popping and crackling after tune...
- Best Tuner in San Francisco Bay Area
- tuning for dummies?
- tuner near Pittsburgh?
- Question about Vararam
- Tuner help in Geneva, Illinois
- Looking For Turner In Washington St.
- Delivered Torque
- P0343 Camshaft position sensor high voltage?
- LS1 edit questions
- Another stupid question
- hp tuner
- LS1 Edit and O2 simms
- What is involved in tuning a car?
- Tuner in Charlotte NC
- TR 224/224 Installed, what do I tune for first...LTFT or STFT???
- Codes P0113 and P0751
- Need HP tuner help in Lubbock, TX.....
- Tuners in Portland, Oregon
- Surging w/TR 224/224
- What's wrong THIS time? More codes
- Predator...interesting findings after perf. tune
- DTC's online?
- PCM Documentation?
- Check Engine Light,can't find code!
- Tuner in Washington?
- "axle abuse enabled" ??
- Switched from Predator to LS1-edit
- Looking for installer/tuner in Mich.
- Any experience with DynoTech in Ft. Wayne
- A4 shift RPM
- need advice-computor @ tune
- Predator programmers - $399.99 with FREE overnight shipping!
- Need advice on Tuning
- Need a Tuner
- MAF Help
- Throttle Response Problems...
- LS2 90mm tunning
- AC Pressure (psi/volt)
- What should my Air-Fuel ratios be spraying a 100 shot ???
- Turbo & Tuning
- predator advice
- Can I just change the fan settings on a Predator?
- Help with knock codes 0327 and 0332
- Car stalls when logging only
- Help with Remote Function Actuation code
- Tuning Help
- Anyone cruising to Carlisle Saturday morning?
- What would happen - LS1 to 02 LS6 MAF swap
- Just received my Predator today!
- How do I Jack Up My 02 Z06 and Put it on Jack Stands? Wondering what the procedure is
- Predator Shift points
- Handheld programmer????
- Does anyone have any leads as to where to purchase an extended warranty for 2002 Z06?
- {VA} dyno tuning for LS1/LS6 & LT1/LT4 with Jeff Creech from C.A.M. at ABACUS 9/12/05
- Has anyone had this problem?
- Corvettes @ Carlisle 23rd-27th tuning?
- Anyone with LS1 Edit in Greenville, SC Area ???
- HP Tuner
- Need Scanner Logfile
- HP Tuner Bin for 99 MN6 with Non-IC Mag
- AFR guage wired into stock system
- I got a code that's not on the code list???
- Just ordered the Predator
- Dyno Tuning for Dummies
- Pay for Tune or Buy a Hand Held
- Turning off Running lights before tune
- Predator Tuners
- OBD II and Va. Emissions Inspection
- LC-1 with HP Tuners?
- need a scanner???
- '99 HP Tuner or LS1Edit help needed (Austin, TX)
- Tuning Tool Prices
- Edit out rear 02's
- Need fan settings changed
- Need HELP, Tuning STFT and Reduced Engine Power??????
- Codes P 0420 & P o430 Catalyst System
- Gains from after a market Air Bridge?
- Making changes to a "locked" computer
- Disappointed after predator tune/dyno?!
- Installed maf translator.Runs Great but ltft's are high
- A&A z06...is LS1 edit tuning enough or HPtuners
- code 0410
- New to tuning few questions???
- Open Loop Required
- Cam Specs
- Do I need a Tune
- Lean codes p0171 & p0174
- Looking for stock A4 HPTuners logs
- predator question
- LS1 to LS2 Conversion Harnesses
- C 1283 C code
- LTFT bank1 & bank2 15% & 25% @ 2500-3000 rpm
- Someone Please help, predator is locked up
- Should I get a 160* w/ my Predator?
- Jon's <Xceler8n> Tuning and scanning files!
- mass air flow meter and throttle body mods
- Anyone have pics of there LM-1 install?
- Please help fast. What tuner do I buy
- throttle body spacer (please read)
- HP Tuners/EFI Live ?????
- ODBII Scanner Recommendation
- Stock Z06 EFI Flashscan File?
- predator settings help
- A4 pressures and limits question
- I need an intercooled Maqqie bin file for a 01'-04' LS1...
- H/C and now P0332 code !?
- Predator users, check your performance tune gear ratios...
- Software Scan Compatability
- Superchips Sold Again
- 98 Coupe with PO172 & PO175
- Anyone have a LS1Edit or HPtuners file of a tuned G5X3 car?
- 98 coupe auto with p0410
- LS1Edit Stock 2000 A4 File
- Predator Fan settings for Las Vegas
- EFiLive Scan/Tune Question
- Just wanted put a thanks to vette Doctors
- Hypertech Programmer III
- What's the correct choice of mufflers?
- All Predator programmers $399.99 with free overnight shipping (includes LS2)!
- reset oil change on computer
- Need A Super Charger Tuner/Mechanic -DC METRO AREA
- I have this code QC 2244411....?
- AFR Head ???
- Help w/ Predator
- A&A builds N/A BEAST-530/540 Rear Wheel!
- Tuning for altitude?
- Headlights Are UP and Will Not Go DOWN
- Utah C5 Guys
- Predator Question
- please advise Newbie here!
- Predator available for 98's?
- EFILive
- Best Handheld for me - 98 A4 2.73
- LS1 Edit -> Predator Tune
- cam only HELP PLEASE
- Mysterous flashing check engine light
- South Florida/Kelley Performance Tuning Special!!
- Looking for a tuner in the Kansas City Area
- DiabloSport custom tune
- TCS Codes & Reduced Engine Power
- Got codes know what should i do? TCS,ABS problem
- Pinging in Las Vegas-Help needed
- 402 LS2 Stroker tuner in Texas
- cruise control not working help!!
- Fan temps, hypertech III
- charging system fault after alternator install
- Speed limiter on a 98A4??
- Innovate LC-1 instock for $185
- predator pros this way
- laptop holder for the car
- Does the IFR table changes affect PE table?
- Flywheel Causing Miss?
- Which WB02 for EFILive?
- LS1Edit file for 2002 Z06 w/ A&A supercharger
- any tuners in Ohio...Columbus preferably
- Warranty Question relating to tuning
- No changes but car died in the middle of the highway...
- C5 Speedometer Calibration
- How much flexability for different injectors?
- Insalled veraram now have these codes
- Anybody know what these codes are?
- Hey Gents, is the Hypertech Power Programmer III
- Need a helping hand
- What needs to be done to turn off SRTD System F-45?
- Question about Hp Tuner files?
- Will Ls1 Edit get me more Hp than the Predator?
- Can I purchase LS1 Edit?
- Vortech Safe Tune file?
- HpTuners and CLB recall???
- Data Logging....How Do I???? HELP!!!
- Removing "reduced engine power" display
- Bad Idle
- need input please!!! TC/ AH codes afer reflash
- hitting rev limiter
- Intake/exhaust ZO6 question
- Stock 03 A4 BIN file?
- EFILive Best Dash Contest
- Tuning no no's...
- C1221 over and over...
- Question about HP tuner
- Has Anyone Installed an LC-1 for Wideband Measurements
- Predator tune with LT headers? Question?
- Understanding short and long term fuel curves
- tuner in west virginia
- Regarding Predator tune and disconnecting the batt Q for u gents->
- PCM Pinout TPS & IAT :: Wire experts only
- My TT Tuning is off...
- What engine temp is the fan supposed to turn on at? on a 97 C5
- Can anyone here compare LS1-Edit files and tell whats diff?
- If its not broken dont fix it
- Read me, Read me
- Getting lean cruise around town!
- tuning file, compatibilty?
- custom 04 A4 Predator program
- Torque Management
- Upgraded 38 to 42Lb injectors - HPTuners help needed
- Replacing Computer
- how much timing with cam/heads?
- throwing a code...please help
- Fuel Enrichment ajustment on Predator
- 3.42 + 800 miles= Hard shifts.
- Tuners in the DFW area?
- Looking for HP tuner owner with 99FRC
- P1626H - Anyone know how to diagnose?
- Who’s actually running SD tune?
- Installing a shift kit. Anything I should know in advance?
- will a Predator.....
- LTFT - LS1 Edit
- AC - low pressure port?
- Recommendation on an OBD II Scanner?
- Indy Tuning
- Hypertech III OR what???
- Good MAF?
- Need a little help with my tranny & rear-end experiment…
- 04' rich condition???
- Need load-bearing dyno tuner near Wash DC
- curious vs a Porsche 911...
- 427 LS1edit copy needed w/these mods...
- Can Predator help an '04
- IAT check engine code need help
- reset problem
- Question about a/f ratios
- Dyno Day for the New Vette
- WTF is wrong?
- 90mm Correction factor/table
- GP for LM-1 or LC-1?
- Cant Find Problem, Woho Can Solve This
