- Tech 2 Please
- Need answers about tuning.
- Corvette Specialist in St. Louis?
- WTB: Tech II programmer
- Used HP Tuner?
- Trouble Code B1061 Any Ideas
- Question on code 0068?
- P0161 and P0141
- Tuners, mechanics and body shops in Florida?
- Eddy Current dyno vs. Dynojet
- I need some tuning help...HP tuner guys!
- Best choice for stock+ATI
- a question from an old thread on C5 mods
- Need help with which O2 wire to tap...
- PCM Tuning
- Dyno and Tune
- Trouble Code Help
- P0410 AIR System-B...
- Rear 02 sensor
- Anyone have a HP tuners bin file for 60lb injctors?
- tuner in portland oregon????
- Cam Thoughts
- Ed Wright tuning
- Mail order tuning
- No tuners in Seattle
- new headers
- PCM Learning
- Torque Management
- Diablosport and turning off DRL
- wideband
- P0343 on supercharged C5s
- Predator Handheld Programmers Shipped Overnight For $399.99!
- How to retrieve codes
- keep getting code 160
- Which tuning program should I use for a nitroused z?
- G-Tech
- Need LS1 edit file
- Nitrous+Timing
- N/W Florida Tuners
- Excellent Tuner in NEW YORK
- How do you remove the computer to send it off for a mail order tune?
- Coil Wiring...Need Help Here.. Project
- hard water spots on windows
- Service column lock
- code scanner / sensor reader wanted.
- can part of the programming get corrupted?
- Lean Codes after Haltech Install
- Diablosport Predator?
- Any EFI/ Live users in ARKANSAS,or MEMPHIS.
- FICHTNER CHEVROLET CHRISTMAS & YEAR END SPECIALS
- Need Input
- P1516...any ideas?
- codes
- Best tunner in Oregon
- Speed Demon ??
- Convince me that I want to continue with HPTuners
- anyone ever have a bad experience with a mail order tune?
- Synergy & ZO6 12 HP
- Tuner in Ky, Tn
- Innovate LC-1 WB O2 - Appearance of output when graphed
- P0803, but only when it's cold outside?
- Tuning Classes???
- Anyone have a stock 2001 Z06 .bin file?
- Dialing in new injectors and Procharger
- DiabloSport Predator tuner...in the uk
- Clutch slipped first time, please advise
- new gears and shifting is off HELP!!!
- Best Tuner In Virginia?
- Tuner recommendation in So Cali?
- Best Tuner in Illinois ?
- Help with tuning concept!!!!!!!!!!!!!!!!!!!!!!!
- Help! those with experience, please reply..
- Was driving along and then no lights
- Multiple tunes/programmers common?
- Wideband tuning on a dyno for sealed "Ram air kits"
- LTFT at 9.0 after LS1 Edit?
- Tail Pipes Truning All Black????
- P0128 H C code/ help please
- Tech II
- Codes:P0443,P0449,P0740,P0753,P1860....H ELP!
- Happy Thanksgiving
- hypertech controller????
- Tuner in KY
- Tuners in/near Reno, NV?
- does a tune go bad or change
- Is HP Tuners Offering USB Cables Now?
- Which Scan / Rest tool do I buy ?
- So how did you get started..
- Dyno Day @ Carolina Auto Masters 14 Jan
- Part throttle timing? WIth HP tuners
- Car running bad after using old Torco
- V/E Changes After H/C Install ?
- Getting Code P1516 after Shaner TB and Halltech Stinger
- Drag Racing A4 using lockup Question!
- Tuning options for 04 Z06???
- AC Delco or NGK TR-55
- Can this be tuned away?
- Codes 0410 and 1153
- New to EFI tuning where to start
- Air Fuel ratio
- Installed Convertor and 3.73's
- Dyno And Ls1 Edit So Calif ?
- Need predator help
- Z06 Dyno graph...nice gain.
- Is there any software out there that will emulate the TECH 2?
- HP Tuners VCM Suite 2.0.17 Released
- Any good Twin Turbo guys in central Alabama?
- Professional Dyno tuning in PA by Jeremy Formato
- I May Have Found Some Ky Tuners.....
- Tuners in Arizona
- Rockless in cali
- Looking for tuner in ky
- Hot Start Problem
- Very Simple NEWBIE question. LOL
- Help with HPTuner 2.0
- Will Diablo Hurt a A4?
- code c1282
- Weird problem, timing related??
- Where the hech is the EBTCM located?
- Can anyone recommend a good tuner for Houston TX area
- Tune Detection
- Tuners near Madison, WI?
- Bank 1... Drivers side or..
- Explain: Why I got P1516 DURING a race yesterday
- Help Needed!!!
- Gas and Trunk Latch Problems...
- MAF and Lean condition question
- A Little Help with EFILive Please.
- Need help, what to get to track a 98 C5?
- Low octane tables relation to MAF
- Anyone get good results with...
- HP tuners buyers
- Gents I need help please......
- Anyone offering LS-2 edit on the Dyno in New England?
- Running without O2 sensors? good or bad?
- For those needs a TPS or TAC module
- Help Understanding Logged Data
- Turn off 'Service Tire Monitor' msg on a 99?
- Dyno/Tune experts, please step in..
- Magnecor wires
- Dyno tune in Kentucky?
- Torque Management with Hp Tuners
- Predator for sale relatively cheap
- Need help with a check engine light
- Anyone with HPTuners in the Corpus Christi Area?
- EFILive : My first tune!
- LS2 Edit "Locking" and "Unlocking" Official Word
- need tuner
- Drag Racing help
- Any EFILive FlashScanners in the Boise area?
- LC-1 for sale at $175 a peice + O2 sensor, too
- Alterant Alternater
- Suggest uses for Predator?
- Need Dyno Hp Tuner Help
- questions about the ls1 edit
- Help with EFILive
- '01 - '03 LS1 and Z06 Hypertech III Power Programmer - Tuning
- HP Tuners VCM Suite 2.0 Screenshots
- Max Rev Limit on Stock Ls1
- Just bought EFI Live 7.3
- C5 tuners in the Ft Lauderdale/Miami area???
- Anyone using the "Predator" on a Z06?
- Can Anyone explain this??
- Just finished VE tuning...
- Best tuning programer for 98
- VE tuning is not as easy as people think..
- HP Tuners Warranty
- Would a tune be helpful?
- AutoEnginuity?
- Help: Code P0300 H C
- LS1 engine problem
- Buying HP Tuner
- oil sending unit help
- Hand Held Tuners vs. Software Package
- Wideband and O2 don't agree???
- Steering Recall
- Do I need a tune with these Mods?
- Torque Converter Lock Up ?
- Tuner around Flagstaff, Az.
- LS1 Edit?
- Tuning Info
- Predator Programmers $399.99 + FREE Overnight Shipping!
- Wires
- Shift light and editing ?s
- Suggestions on programmer to gain HP
- Question for the Tuner Guru's -- Vararam Foam Filter vs. K&N
- GM Tech help needed w/ PCM code 1626
- PLX Devics R500
- Speed Density Tune
- Rev. limiter problem
- Low Idle after installing Predator Perf. Tune
- Question About Hp Tuners
- Any good tuners in North California.
- getting lean codes a few ?s
- how to do cam tune
- what do these codes mean
- ls2 knock sensors tunning
- wtb programmer
- C5 Water Pump Replacement
- tuner in indiana
- Suggestion for those with C1243 - ABS Pump Stall
- Help me please :)
- Need a dyno tune within driving distance from Wash. DC
- Z06 Pinging Like Mad! California Fuel Garbage ? Torco?
- 2001 ZO6 Tune
- Performance Specialties in Glen Burnie, MD
- po172 & po175
- Check engine light after dyno tuning...
- Disappointing Dyno Results
- Tuner in Little Rock, AR
- Wideband Stability with LC-1 and HP Tuners IO Interface
- What does this PCM code mean??
- Gear Predator question
- code 357, #7 coil
- 03 Z06 bogging down off the line at drag strip???
- HP Tuners vs EFILive
- Help. Does anyone know of a good turbo tuner in South Carolina
- P0138 C and P0158 C with no Check Engine Light
- Anyone in ABQ,NM have HP Tuners for 99 C5?
- HP Tuners and Superchips partnership
- basic scanner
- Cloumn Lock recall, Now ECM back to stock??
- 1999 coupe A/C controller problems
- throttle delay 1999 coupe
- P0160 Code on 97 Coupe! HELP!
- 2000 C5 Maf
- LS1 Edit question
- where do I start with my 02
- Scanned my near-stock car - Are these results the norm?
- PCM code 1120 ?
- LS1 Edit, can someone get me a file list of the CD?
- Autotap software - 5% off and free shipping
- Logging Oil Temp with HPTuners EIO Interface?
- ABS/Traction Control Problems
- Looking for a Tuner in Idaho....
- Engine Miss with Fidanza Flywheel
- Tuner in Missouri
- Help using LC-1 to simulate Narrow Band O2
- Miss with no codes found
- Is there anybody here with a 99 or 00 C5 that has upgraded their OS?
- Misfire detected
- Jeremy Formato, FL Tuner ??
- Thinking about buying HP Tuner. Good idea?
- please help with codes
- Which Programmer to get?
- HPT Company Observation
- best programer for the money
- Needing a Corvette Specialist in Tampa...
- engine codes 155 160
- BEST price on LC1s??
