View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. help with tech 2 and changing the vtd
  2. Reduce Engine Power
  3. Need "Excellent" Tuner in the Johnstown, PA area
  4. anyone know a good tuner in the houston area??
  5. Too much advance???
  6. C5 Trouble shooting question, Help me
  7. Corvettes of Westchester @ New York Auto Show!
  8. Made And Exhaust Change...so, Should I Dyno Tune Again Or?
  9. Battery Help!
  10. Self tuning caused misfire when shifting, problem solved!
  11. Afr??
  12. BCM 1 not communicating?
  13. EASE Scanning Software
  14. EFI101....I want to learn to tune my own car.
  15. need tuned bad... im in va bch, va..how in a 97
  16. O2 codes after header install-help
  17. thought on a good cam for a4
  18. Gas Mileage dropped after installs.
  19. HELP! I think I fried my PCM....
  20. pcm for less anybody?
  21. what should i change?
  22. D.I.C. help please!
  23. Aft Jumping All Over The Place???
  24. Dyno and Tune in Richmond, VA?
  25. Going from 42lb injectors to 60lb
  26. how much to expect with this set up with HP tuners
  27. New TC won't lock up over 1700rpm...tuner edited some table but still no luck
  28. Can you modify an LS1edit tune w/ a Predator?
  29. LS6 Engine
  30. Need H/C base tune!!! HELP!
  31. Need stock 2004 Z06 tune for HP Tuners
  32. Best Place to Buy EFILive???
  33. ls1 Edit - AFR question
  34. predator question
  35. Pa Tuner
  36. Oklahoma City tuners???
  37. Pre Tuned Computer???
  38. Can you copy a tune?
  39. Need Advice For Someone New To Tuning
  40. anyone
  41. Dynomite 2000 problems?
  42. Minor problems after H/C setup and tune
  43. SuperChip
  44. tune repository for predator
  45. Replace 1999 computer to 2002 Z06?
  46. hptuners??? help???
  47. Is There One
  48. HELP?!? tune needed?!?
  49. Flashed Computer????
  50. Tunning with water and meth
  51. PCM locking???
  52. Superchips tuner - Locked - what's it worth
  53. Any Tuners in DC. area
  54. C1214 grrrr
  55. ls1 edit flash file tuner.
  56. Anybody have HPTuners for an 00
  57. hptuners ????
  58. HPT's Dyno
  59. New LS1 live tuning tool
  60. Still unclear, what can I use at the track to datalog my run?
  61. MTI and my mods
  62. Anybody have HPTuners for an 00 F-body
  63. Replacement Computer?
  64. Hptuners
  65. AFR WB readings LM-1 vs HPtuners?
  66. HP Tuners VCM Suite 2.1.6 is now available
  67. 5 years ago my car was tuned for 418 rwhp. Would a new tune (LS1 Edit) help?
  68. Help with hp tuner
  69. Best Handheld Tuner??
  70. code P0410 AIR System-B
  71. Did I waste my money with a Predator?
  72. Tune for procharged Vette
  73. Lean Cruise Mode in HP tuners ??
  74. EFI Live anyone tuners using it?
  75. Stop The Pinging
  76. Chuck CoW Tuning in MIAMI this weekend - MUST COMMIT TODAY
  77. Mail Order Calibrations Available
  78. Tuning out Rear O2 sensors
  79. HPT for a 2000
  80. Looking for Mod Install Help
  81. Need Help in St Louis Mo
  82. street tune by vette mech. vs. dyno tune by local shop
  83. Street tune by experienced vette mech vs. dyno tune by general tuner??
  84. UPS Package arrived today
  85. CHUCK CoW TUNING IN MIAMI FLORIDA - This WEEK
  86. Bin file
  87. Wanted: Stock 2000 Corvette A4 BIN/HPT
  88. 98 A4 shift points
  89. Wideband controller: SUPER DEAL!!!
  90. P-0068 Code...
  91. Using LS1 edit
  92. Code Help Code C1217C BPSM problems.
  93. Code Help--p 1415 H
  94. CHUCK CoW TUNING IN MIAMI FLORIDA - This WEEK
  95. LAPD 10% Off Custom Dyno Tuning Special Until April 30, 2006!!!!
  96. C5 programming options
  97. PLXR500 and Hp Tuners
  98. Will I lose my tune if I disconnect the battery?
  99. ECS Paxton Novi Tune
  100. Seeking Cory in New Braunfels, Tx
  101. Speed Density tune and low MPG...
  102. A/F Ratio Problem
  103. Difference in tuning a C5 over others
  104. 6 Speed trouble "Help"
  105. Predator and dyno tune Co-exit???
  106. MAF table swap
  107. injectors rwhp vs duty cycle
  108. Pinging at WOT, 91 octane and 5300FT.
  109. HP Tuners updated VCM Suite Feature List
  110. "The Wrench"
  111. Scan Experts - Need Help With Steering Fix!
  112. HP Tuners VCM Suite Help Files Are Now Online!!!
  113. HP Tuners VCM Suite Demos
  114. How much timing do you run with HC + stock cats on 91 octane?
  115. Will I be able to drive my car to get a tune?
  116. Predator Problems
  117. What would I need to tune to get an A4 to run? (mods inside)
  118. Ok, so what is the best way to learn how to tune?
  119. So many codes popping up! Help!
  120. Pcm$?
  121. Guide to LS1 Edit?
  122. What can you expect to gain from 03 LS6 tune?
  123. Anyone has a good HPTuners tuned file for a stock 03, Z06?
  124. Wisconsin Corvette Guys Help
  125. Need Tune after Headers?
  126. 2 Bar Map part number...
  127. Wisconsin Tuners?
  128. Please help me with DTC codes....
  129. CheeseHead Speed
  130. Any good LS6 tuning programs?
  131. Codes P0172 and P0175
  132. Knock Sensor Sensitivity
  133. Looking For Tuner in St Louis/St Charles Mo
  134. Looking for a 383, heads, cam HP Tuners file
  135. How to program for tire size on HPtuners
  136. Tuners
  137. LS1 edit update ver 1.5 needed
  138. Help with Lm-2 Innovate wide band
  139. traction control
  140. ***Realtime LSx PCM Tuning Available Soon!*** (photos & details)
  141. Download and Save PCM Program, Scan Then Upload Back
  142. communication problem between pcm and tcm
  143. Anybody have a wire diagram, converter clutch over-ride?
  144. Diablo Sport Phone Number
  145. Tuner in upstate New York
  146. boo26 code?
  147. boo26 code?
  148. New Torq Converter...jumping Rpms?
  149. Tuner
  150. LS1 Edit info?
  151. Who In Central Jersey Does Oil/Filter Change?
  152. Gear Change/PCM Tune in SoCal
  153. Small Cam
  154. Any EASE scan tool users
  155. Limits of MAF...
  156. Just bought a Tech II
  157. New Intake / New Exaust
  158. Tuners in Oregon? A/F?
  159. Silverado ECU???
  160. $480 for a tune/dyno?????
  161. Anybody using crane cams programmer?
  162. How about an "idiot's guide to tuning" for a sticky here?
  163. Any tuners near Tallahassee, FL?
  164. 2:73 to 3:15 gears
  165. Predator What?
  166. Silly question, but I'll ask anyway???
  167. What do I need....
  168. Tuners in Las Vegas?
  169. Autotap system
  170. Mail Order Vette Tunes $150!!
  171. Cuttin the Cats!!
  172. Glut of Diablo Predators?
  173. Code after engine swap MAF
  174. Any Tuners in Nashville?
  175. A/F & Timing
  176. Tuner near Columbus Ohio...
  177. Check engine light and codes.......
  178. Dyno Differences
  179. EFI Live, anyone have it, use it?
  180. Front Spring Cracked?
  181. 02 sims
  182. Anyone have DTE tune their vette?
  183. ANyone use DTE to tune their vette?
  184. Taking pools/looking for Advice on Tuners in the greater Tampa Area
  185. need help: fuel cutoff acting crazy!!! :-(
  186. Anybody have this GM cam?
  187. EFI LIVE vs HP TUNER! Any pros or cons?
  188. Wideband O2 sensors
  189. Tuner in SoCal
  190. Emergency - Need Help Please
  191. Best Handheld Programmer?
  192. '97 dyno tunned
  193. How do you get to codes?
  194. MAF Dyno Tune vs Speed Density ... Pro/Cons
  195. Who tunes in South Florida
  196. Where's Werx in NC?
  197. Tekmate or other scan converter cables
  198. 02 sims
  199. Special Policy Adjustment Electronic Column Lock System
  200. RPM signal
  201. Rich Fuel Trim Code
  202. Are files interchangable between software programs?
  203. Unknown Fault PO492???
  204. some tune basic questions
  205. Defeating CAGS electronically - 1998 Corvette
  206. HPTuners
  207. Performance Chip?
  208. Auto shift points on a Predator?
  209. Dan at FLP does it again
  210. P0420 H C Code
  211. Code P0491 Secondary Air Injection System (Right Bank)
  212. adjusting torque converter settings
  213. LG MotorSports..WOW....AWESOME
  214. What mph is needed for 6200rpm shift points?
  215. mail-order tunes
  216. wiring diagram
  217. Announcing Pre-Orders for VCM Suite 2.1 and MPVI (USB)!!
  218. need help with gear choice
  219. Utah tuners
  220. Dynotune Virginia
  221. LS1Edit file - Procharger/stock 2000
  222. Blowing Fuses & Code P0410
  223. HO2S Codes
  224. K&N FIPK causing code 492
  225. Worth it to do a tune?
  226. Underdrive Pully or Not
  227. New to Thread...Got some questions
  228. PCM Swap??
  229. Just did a Vinci tune on my FRC
  230. code bo-raf-1096.1064.1016
  231. Dyno-Tune Cost
  232. can my t/c be edited to be turned off?
  233. Predator and an injector swap
  234. hptuners
  235. Texas Tuner?
  236. 3000 RPM startup
  237. Speed Density and Reduce Engine Power, 01 Z06???
  238. Tuning? longtubes,3"xpipe,no cats,straight pipes, intake, heads
  239. paging mike mercury....
  240. torque management-pre 04 cars
  241. Poor fuel consumption; reason?
  242. County Corvette, PA - Basic Modifications
  243. Codes
  244. Help! I gots an issue!! I loaded the Predator tune back onto the Predator
  245. EFI PLX logging
  246. {VA} Feb Dyno tuning for LS1,2,6/LT1/LT4 & GM trucks with Jeff Creech from C.A.M.
  247. Free/Inexpensive Datalogging and Scanning software
  248. Knock Retard
  249. Texas Speed Mail Order LS2 Tuning $150!! 1 week left!!
  250. Closest tuner to utah..
