View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Tuner in Delaware
  2. Dtc P0137
  3. Plug and Play? (which handheld tuner)
  4. Beginner questions about tuning
  5. staring problem
  6. need tuner in El Paso, Texas
  7. Reques to evaluation of CarChip data log...
  8. Feedback requested on LTFT's
  9. Any Tuners in Nebraska????
  10. Predator custom tune
  11. Looking for qualified tuner.
  12. Those with HP tuners
  13. Repeated DTC1571
  14. Calibrating the MAF
  15. Stock O2 Sensors
  16. C5 Vette Mail Order Tuning Special $175!!
  17. 99 Supercharged LTFT's off, and KR
  18. Tuners
  19. Engine power falls flat about 4800-5000 to redline
  20. Tuner in C. Fla.
  21. Torque Management
  22. Scanner reaction times
  23. Do I need a tune?
  24. BCM Replacement
  25. Do my mods warrant a tune? If so, what type?
  26. St. Louis Mo Tuners?
  27. Tip-in stumble with FAST 90/Ported LS2 90
  28. Head and Cam tune
  29. anyone used hpe in
  30. Got the vette Tuned today (TJ WONG)
  31. Afr For Nitrous Efilive
  32. EFI fan settings
  33. Tuners?
  34. Someone in Bend, Or needed PCM tuning?
  35. Predator for 02' Z06??
  36. So what is the best scanning setup for diagnosing problems?
  37. Having problems with Vararam + custom dyno tune
  38. question about tuning with bolt ons.........
  39. I'm getting zero response on this in C5 Tech
  40. RevXtreme Tuning in Ft Meyers..
  41. "Married" Predator question
  42. Downside to tuning daily driver?
  43. Emission Help - codes not ready
  44. Where to buy new PCM
  45. bad PCM??
  46. A4 Downshift Adjustment
  47. Predator or Hypertech?
  48. Best Tuners in or near Kentucky
  49. Efi Live
  50. Is there some kind of recorder to check my problem
  51. P1571 and C1277.. Any ideas?
  52. Should I be worried about DCM and TCS codes?
  53. PCM and oil pressure gauge question
  54. Tuner Needed!!
  55. Weird 2nd gear rev limiter problem
  56. Tune needed?
  57. How to Correct Fuel Economy Calculation
  58. Can't read my original LS1-Edit Tune File...
  59. tuning for NOS
  60. Who has used HPT w/ RTT
  61. Check Engine Light PC Code
  62. Which is better; street tune or dyno tune?
  63. HP Tuners: VCM Suite 2.1.12 now available!
  64. LS1 EDIT/HPTuners/SD TUNING..WHICH ONE?
  65. Tuner for do it yourselfer
  66. PLEEEAAASE HELP with codes
  67. DTC P0172 has shown up
  68. Looking for advice. hard info.
  69. colum lock relay location?
  70. Ft Meyers FL Tuner...
  71. Dyno tuner.
  72. predator problem!!
  73. 2K vette w/stumbling starts
  74. Injector Tuning
  75. Best tuning in TX
  76. C.E.L. code P0134 which o2 sensor do i replace?
  77. Question on new motor install and tuning.
  78. Tuning for New 402.....
  79. What do I look for when buying a used MM6?
  80. new cam tune
  81. efi live?
  82. EFI Live Help Please
  83. Check out my scan, suggestions for tuning needed
  84. Elevation Changes
  85. lc-1 wideband hookup help plz
  86. SD tune with Vararam on the dyno?
  87. EASE or AutoEnginuity Scan Tool
  88. Anyone know a good tuner in KY?
  89. Car back from NC tuner
  90. If your looking for the best tuner in DC area
  91. Other C1214 Code Questions - What is SWbatt(v)?
  92. Stock LS1 with longtubes, happy around 12.5:1
  93. Experience with VHP Tuner?
  94. Predator performance tune
  95. Predator for 99 6 speed?
  96. I'm too Rich!!
  97. hypertech basic question
  98. help help help installed cam lost 40RWHP
  99. 1514 code
  100. OBDII Scan kit available
  101. Is there such a product out there called "tuning for dummies"?
  102. need to locate map sensor wire
  103. Austin, TX Tuner recommendations
  104. please help me with this problem??
  105. need a tuner/mechanic in okc
  106. c5 z06 tranmission problem
  107. VE LTFT tuning after Longtubes
  108. Cam is in. tune elp plz EFILIVE
  109. Predator - Adjust part throttle downshift?
  110. How Is Mti For Mods???
  111. Can a tune mess with the TCS
  112. predator power supply...
  113. anyone got anything good or bad to say
  114. Installed a Stage 2 Jet Performance Chip
  115. Best tuner close to Southwest Va??
  116. Codes
  117. Low octane table
  118. Kudos to New Era Performance
  119. MS3 cam tuning helpplz
  120. Need tuner in NC for new motor and suspension codes...
  121. C1293 code
  122. Jeremy Formato
  123. Question about knock at high RPM
  124. Thanks all!
  125. BLOWN Z06 fuel issue...????
  126. fs: 97/98 LS1 edit cable
  127. Adding timing back in
  128. EFI Live FlashScan V1, Scan only $249 June 3rd
  129. need help asap
  130. Handheld programmer, fuel question
  131. Just installed my predator
  132. Anyone try WB 02 Sensor in tailpipe?
  133. lc1 wideband install
  134. How to read SES codes ?
  135. someone please help what do these mean
  136. Norris Motorsports
  137. Watch your tune being done
  138. Safe A/F Ratio on Turbocharged Application
  139. What is LS1 Edit??
  140. FS: Autotap OBDII cable/software $125 shipped
  141. new to tuning... tuning it for the first time??
  142. Shift Time vs Shift Pressure
  143. ABS fault from Predator?
  144. Need A Good Tuner In The South Florida Area
  145. LS1 Edit Tuning Questions
  146. Chuck Cow Tuning in ORLANDO FLORIDA - JUNE 2nd - 5th
  147. Installing a Predator tune over a non-stock tune
  148. SC, Belts & Traction Control
  149. P1637 H - Generator L - Terminal Circuit
  150. Fichtner Early Summer Specials
  151. 42 lb injectors for stock motor with alot of mods.
  152. Custom tune, can adjust with predator?
  153. help with tuning
  154. Obd Ii
  155. How can I save my tune from a Colum Lock reflash?
  156. Tuning Options for 98 C5...
  157. location of OBD II ground source for LC1?
  158. predator setup for headers?
  159. [ newbie to tuning ] .. need some help
  160. noob question
  161. Emissions Help
  162. MAFless IAT
  163. Baro sensor
  164. anyone using a RoadRunner pcm?
  165. Has Anyone Used The New Fast Wide Band?
  166. Wide band cable to interior
  167. Please Recommend OBD-II Scan set-up
  168. Heres a newbie question for the collective
  169. Converting 98 PCM to 99 or later?????
  170. Service ABS, Service Active Handing System, Service Traction Control System
  171. need tuner info for NC or SC.
  172. Unlimited LS1 edit for 97-03 cars for sale
  173. why i cant reprograming the new pcm ?
  174. Opinions on tuning techniques?
  175. Getting "Change Oil Soon" error
  176. high flow cats versus no cats?
  177. Tri State Tuner
  178. Chuck @ COW is the man!!
  179. First Dyno Run and only 298 RWHP ?
  180. CORVETTES OF WESTCHESTER's CORVETTE "SHOW OFF"
  181. need advice! Service vehicile soon warning
  182. should i clear out historical codes?
  183. quick question. IAT readings and timing?
  184. trouble code p1416
  185. HP Tuners: VCM Suite 2.1.10 Now Available!
  186. Shutting off O2's and running in open loop
  187. Dyno in N/E Ohio?
  188. Programmer Ideas
  189. Hypertech Shift Points
  190. EFI LIVE Tunner Might Come to Wichita
  191. Do I need a tune?
  192. How do I get (drivable) 415hp in a 98 c5??
  193. Look for some code help
  194. Halltech Tune
  195. Anybody remembers Morgan Motor Sports
  196. Problems after Using superchips for DTC reader.
  197. Just completed headers and cam install- should I get a " dyno tune"?
  198. wait4meperformance...anyone use them?
  199. LS1 Edit Help
  200. MAF ends question
  201. stock tune?
  202. High idle when car is moving only
  203. new haltech stinger + corsa...now tune!?
  204. I've asked this CEL question before; one more time...
  205. Just ordered EFILive
  206. 2K A4 3.15 Hypertech inital results
  207. Fan On temp and stock thermostat
  208. Needs smog, help me,
  209. Just got my EFI live
  210. Tuners in Kansas?
  211. 1999 C5 increase proformance?
  212. Looking to buy HPT but dunno if it will read current tune
  213. What settings to change on stock A4 with EFI live?
  214. Tuning with a Vararam Intake
  215. Diablo vs Hypertech
  216. Data logger ?
  217. Any good tuners in CANADA BC???
  218. Spark Plugs..
  219. HPtuners vs. EFI Live, which one to purchase?
  220. Hand Held Programer Question
  221. Z06 Tuning
  222. FOBS quit working
  223. Superchips 2241 "Star Adapter"
  224. Whats the latest on Predator?
  225. pcm. no comm.
  226. Pinging...
  227. Headers installed, need tune....Please Advise
  228. Lingenfelter HP Package
  229. How many miles before you should replace the 02 sensors?
  230. HP tuner PID help
  231. just installed ls2 tb and fast 90mm, unexpected probs
  232. RAIN or SHINE! CORVETTES OF WESTCHESTER @ NEW YORK INTERNATIONAL AUTO SHOW - JAVITS
  233. Reformulated gasoline (RFG)..........tuning issues?
  234. No more sticks and stones
  235. Corvettes Of Westchester @ New York International Auto Show - Javits Center
  236. Cat Removal
  237. Jerking on part throttle
  238. Buying EFILive w/ LC-1 .... Brand New to Tuning, Need Help
  239. Can't spin my tires from a stop w/ 400hp
  240. HP Tuners: 98 2bar Speed Density
  241. Corvettes of Westchester & NEW YORK INTERNATIONAL AUTO SHOW @ JAVITS CENTER NYC!!!
  242. redefining stochiometry in EFIlive
  243. Head Install - P0300 Misfire Error
  244. Help me with my idle please!
  245. Headers & Tune, now I have CODES
  246. Corvettes of Westchester display at the NEW YORK AUTO SHOW!
  247. Computer crashed -lost ls1 edit need help
  248. Florida Tuner Needed Asap
  249. dumb? question about ls1 edit
  250. help with tech 2 and changing the vtd
