- KY Tuner
- HELP! Engine Light on DTC showing P0442HC Code
- low dyno tune numbers
- 50 trouble codes!(really)
- torque converter locking/unlocking after tune
- Neophyte - Dyno Procedures?
- need tuner in north carolina?
- Predator Question?? HELP !!
- New H/c Need Help
- Stalling Vette, please help..
- Long Term Fuel Trim question
- Simple Tuner
- Any tuners in Omaha
- WTB 2003 tuner
- Anyone else have EFILive FlashScan V2? Problems upgrading...
- Good first "stock" dyno?
- How to read a Dyno Chart
- tuner in cincinnati/columbus area?
- C5/C6 Tuner in Knoxville, TN 11/25-26
- FS: HPT for '99 and '04 Model Years
- Tuner in central Pa
- 97 new injector & Adj Fuel PSI reg ?
- stock fuel calibration - observations and questions
- MTI in Houston, TX
- LG PRO LONG TUBES @ Corvettes of Westchester
- mail order tune
- Lower Numbers after MODS
- Tuners in san jose, bay area?
- 2.73 to 3.42s tuning w/ Hypertech -WTF?
- For Sale: LS1 Edit and LS2 Edit- pro version
- MAIL ORDER TUNING by Chuck @ CoW
- Stock z06 timing table in EXCEL format please
- Crane Hand Held Tuner Question
- Any good ref's for a tuner in Rochester,NY ?
- Individual Tuner DFW AREA - Beer Barter
- 97' code reader/tuner
- Can Anyone Look Over My Bin File?
- tuner for 98 coupe
- Any real benefit to running dual widebands?
- Where has everyone mounted their LC-1 module?
- tuner in s.w mo
- Where do you adjust the ETC for A4 shifts?
- turn signals and fuel range
- Tuner in NO VA
- '97 PCM failure and replacement
- Cleveland Ohio area tuner needed
- Whos our vendor for HP Tuners?
- HP Tuners - Outstanding Service
- TCS code c1288 anyone seen this?
- serious electrical/running issues?
- Need help with my 01 ZO6 dyno info.
- Who has the best mail order tune?
- 1997 C5 Need Help With Or What To Do
- Tuner in Hampton Roads Virginia
- Am I at a disadvantage running a 98 PCM?
- Error Code B2578 and B2583
- Anyone running a G2 G5x2 cam?
- need a tuner in st louis area
- Chuck CoW TUNING in VEGAS @ SEMA
- thinking of purchasing hp or efi live
- A4 Damper pulley removal
- Pred/Nitrous Question
- Can a dyno-tune "learn/change" over time at all?
- New England onwers: looking for the best possible tune for your C5?
- Mustang Dyno vs. Dynojet???
- Please Define These Abbreviations...
- Fuel filter
- major confusion!! PLEASE HELP
- 96 Lt4 Obdii
- Best setup to allow data logging/tweaks at the track, on the road or on the Dyno
- tuners in lubbock texas
- H/C mod impending - Tuning suggestions
- Re-built 4.10 GETRAG DIFF for SALE w/ HARDENED DRIVER SHAFT
- Check engine light
- Tune or not to Tune?
- New EFI Live vs. HPTuner
- EFILive V1 vs. V2
- need an untouch 99 auto HP tuners file
- Lean Cruise
- What's The Purpose Of This Forum?
- My best SD Tune Yet
- Disconecting problem
- HELP! Throttle Sticking on my 99 Stroker
- Hypertech-Hyperpac
- scan and tune in atlanta
- CORVETTES of WESTCHESTER - COLUMN LOCK MOD PARTY - SUN OCT 22 (today)
- Tuning Transmission Shift Speeds
- Check Out Corvette Central’s New C5 Catalog
- Help me out! ETC + A4
- Need Help with these codes
- tuner in south west fl
- When is it neccessary to get a tune?
- Anybody had tune done by Ellis at Speed Secrets
- CL AFR is 16; Bad O2's?
- help to tune out code pensacola fl area
- COLUMN LOCK Mod PARTY @ CORVETTES of WESTCHESTER - SUN Oct 22
- Scan Code P1441
- Rev Limiter
- HP Tuners VCM Suite v2.1.14 is Now Available!
- Tuner in washington?
- Keith Craft tune
- Afr Spikes
- code po654
- code P0410
- SAE J1962 Compatible with SAE J2534??
- Column Lock DISASTER AVOIDED!!! A close Call...
- Throttle cracker screwed
- Tune for Honker? Washington Tuners?
- Help!! Funny Noise Between 1100-1200RPM
- Compression and Pinging
- Question On New Tranny/tc
- smog problem??..
- Chip w/ Headers?
- service traction control again on a 2000
- Tuner lock?
- Predator problems
- HP Tuners has a new website!
- MAIL ORDER TUNING By Chuck CoW
- Vette Doctors Tune
- LTFT's and injector slope question
- my bass doesnt work, wiring harness
- WANTED: Stock CATS BIN for 2000 MN6
- little info and or help needed please
- Looking for MUstang dyno
- LS2 TB wiring harness problems
- Vararam help
- Jerking When Giving it Gas
- Tuner in Maryland
- MAIL ORDER TUNING @ CORVETTES of WESTCHESTER
- OBDII Says Port 2 Lean? HELP
- SE Pennsylvania area tuners/installers
- PCM speedo pulses per mile?
- C5 Vararam Vrb2 Install; Now Seems To Ping
- Cookie cutter tunes.. Who here has analyzed one?
- LC-1 + HPT users not using NB simulation
- Tune Help, Tune me in...
- Speed Density MAF Question???
- Help Locating A Pro Tuner
- Go to Tuner or buy handheld ??
- SERVICE ABS/Actie HAND/ Traction control????
- need computer tuning help
- anyway to pass emissions with this cam
- WB emulating NB
- what are the pro's & con's of (SD) tune
- newbie needs info on device to program shift points, and performace
- For Sale: U7198 Predator Programmer for 99-03 C5's
- Tuning by Chuck at COW!!!!!!
- Chicago area tuner
- Tuning Question
- Wiring Wide Band into EGR or AC Output
- code : po430
- TC issue
- Tunner for hire
- Cincinnati Ohio - Eddy Current Dyno??
- CTCorvette now offers EFI-Live tuning in New England
- A04 Tune by Corvettes of Westchester
- LG Pro Long Tube Headers - SPECIAL DEAL @ CoW
- anyone us ls1beta scanning
- what is code po141
- Is my Predator worth anything???
- Ongoing illness
- Southeast Tuners?
- Recommend A Tunner Fort Lauderdale
- Looking for a Reputable Tuner
- tune vs gear upgrade vs both???
- Superchips
- 2000 Corvette running very rough - need help
- LC-1 Trouble
- Predator Settings Help !!!!
- TUNE STYLES...Which do you prefer.
- tuner or programer
- LS1Edit tune for differential swap
- Crank and fire, but then dies, possible causes?
- Dyno run chart, your opinion on low reading
- What kind of problem does my car have....
- I just got a tune and......
- TUNING ISSUES...Could it be this?
- Tuner in Middle Tennessee
- Tune issues
- Shift point question
- Dyno Locator Website
- How much gain?
- Tuning LS2's @ Corvettes of Westchester with EFI LIVE V2
- diagram
- P0160 & P0161 dic code
- PCM and fuel cut off
- service manual
- Re-Tune?
- need help, throttle position question
- Got to be proud
- Bassani Headers?
- tuning question
- Hand held tuners
- Breathless at Carlisle providing Tuning and product installs
- Heading back to the track friday
- switching ls1 injection to caburator is it possible?
- How come there isn't no stickeys for tuning?
- Carlisle tuner questions
- exhaust soot
- Chuck CoW @ Carlisle LATE BREAKING NEWS
- Looking for Tuner in Denver metro area!
- AZ Power and Sound--A little info about the CF newest vendor/tuner shop
- Looking for Ref on Tuner in Cincinnati
- column lock confussing
- how easy is LS1 Edit to use
- Tuner near Columbus, Ohio?
- another wideband question
- what is an SD tune?
- Should I turn off TM
- Efi Live OS update...
- 402ci 242/250 112 60# Motrons Drivability Issues
- Code C1296
- Roadrunner question
- Tuner in (near) Norther Virginia
- Are there any DiabloSport (Predator Programmer) employees on this forum?
- TC and Hp tuners
- LC1 + Analog Gauge + EFI-Live
- should I get a tune?
- New Ease Personal PC Scan Tool for Vette's
- Looking for tuner in Tampa area
- Chassis Dyno And Tuning Service Available
- LS7 Stock Tune(file)
- Pros\Cons - Underdrive pulley
- Tuner in the Peoria, IL area?
- Predator Definitions
- Has Anyone Seen This Before
- Had Tune Done
- Failed Emissions-help!!!!!!!!!!!!!!!!!!!!
- Any problems with driving the car with LT until I get a tune.
- tuners in arkansas
- best tune choice for a 97
- Need a Tuner in Northern VT...
- Anybody Know A Good Tuner In Nor Cal?
- What should a tune include?
- Does any one know a tuner in Michigan!!
- PE - IAT table - Safety net for alky system
- Help w/ ???'s
- Changing Tune Maps w/ Laptop: Race & Econo
- Who here replaced their narrow band w/wide band sensor-LC-1 NB output to PCM?
- A:F results from Z06 for anyone interested
- running C5 corvette auto trans and Big Stuff 3 engine managment??
- Z06 Power Band AFR settings?
- Service Vehicle Soon
- "OVERTEMP" for split second, need help!
- Codes HELP!
- Is a tune mandatory.....
- EFIlive users:have you upgraded your operating system from 99 to ???
- Noobie Wants to buy a Tuner
- P0410: Malfunction in Secondary Air Injection System
