- Tail Pipes Truning All Black????
- P0128 H C code/ help please
- Tech II
- Codes:P0443,P0449,P0740,P0753,P1860....H ELP!
- Happy Thanksgiving
- hypertech controller????
- Tuner in KY
- Tuners in/near Reno, NV?
- does a tune go bad or change
- Is HP Tuners Offering USB Cables Now?
- Which Scan / Rest tool do I buy ?
- So how did you get started..
- Dyno Day @ Carolina Auto Masters 14 Jan
- Part throttle timing? WIth HP tuners
- Car running bad after using old Torco
- V/E Changes After H/C Install ?
- Getting Code P1516 after Shaner TB and Halltech Stinger
- Drag Racing A4 using lockup Question!
- Tuning options for 04 Z06???
- AC Delco or NGK TR-55
- Can this be tuned away?
- Codes 0410 and 1153
- New to EFI tuning where to start
- Air Fuel ratio
- Installed Convertor and 3.73's
- Dyno And Ls1 Edit So Calif ?
- Need predator help
- Z06 Dyno graph...nice gain.
- Is there any software out there that will emulate the TECH 2?
- HP Tuners VCM Suite 2.0.17 Released
- Any good Twin Turbo guys in central Alabama?
- Professional Dyno tuning in PA by Jeremy Formato
- I May Have Found Some Ky Tuners.....
- Tuners in Arizona
- Rockless in cali
- Looking for tuner in ky
- Hot Start Problem
- Very Simple NEWBIE question. LOL
- Help with HPTuner 2.0
- Will Diablo Hurt a A4?
- code c1282
- Weird problem, timing related??
- Where the hech is the EBTCM located?
- Can anyone recommend a good tuner for Houston TX area
- Tune Detection
- Tuners near Madison, WI?
- Bank 1... Drivers side or..
- Explain: Why I got P1516 DURING a race yesterday
- Help Needed!!!
- Gas and Trunk Latch Problems...
- MAF and Lean condition question
- A Little Help with EFILive Please.
- Need help, what to get to track a 98 C5?
- Low octane tables relation to MAF
- Anyone get good results with...
- HP tuners buyers
- Gents I need help please......
- Anyone offering LS-2 edit on the Dyno in New England?
- Running without O2 sensors? good or bad?
- For those needs a TPS or TAC module
- Help Understanding Logged Data
- Turn off 'Service Tire Monitor' msg on a 99?
- Dyno/Tune experts, please step in..
- Magnecor wires
- Dyno tune in Kentucky?
- Torque Management with Hp Tuners
- Predator for sale relatively cheap
- Need help with a check engine light
- Anyone with HPTuners in the Corpus Christi Area?
- EFILive : My first tune!
- LS2 Edit "Locking" and "Unlocking" Official Word
- need tuner
- Drag Racing help
- Any EFILive FlashScanners in the Boise area?
- LC-1 for sale at $175 a peice + O2 sensor, too
- Alterant Alternater
- Suggest uses for Predator?
- Need Dyno Hp Tuner Help
- questions about the ls1 edit
- Help with EFILive
- '01 - '03 LS1 and Z06 Hypertech III Power Programmer - Tuning
- HP Tuners VCM Suite 2.0 Screenshots
- Max Rev Limit on Stock Ls1
- Just bought EFI Live 7.3
- C5 tuners in the Ft Lauderdale/Miami area???
- Anyone using the "Predator" on a Z06?
- Can Anyone explain this??
- Just finished VE tuning...
- Best tuning programer for 98
- VE tuning is not as easy as people think..
- HP Tuners Warranty
- Would a tune be helpful?
- AutoEnginuity?
- Help: Code P0300 H C
- LS1 engine problem
- Buying HP Tuner
- oil sending unit help
- Hand Held Tuners vs. Software Package
- Wideband and O2 don't agree???
- Steering Recall
- Do I need a tune with these Mods?
- Torque Converter Lock Up ?
- Tuner around Flagstaff, Az.
- LS1 Edit?
- Tuning Info
- Predator Programmers $399.99 + FREE Overnight Shipping!
- Wires
- Shift light and editing ?s
- Suggestions on programmer to gain HP
- Question for the Tuner Guru's -- Vararam Foam Filter vs. K&N
- GM Tech help needed w/ PCM code 1626
- PLX Devics R500
- Speed Density Tune
- Rev. limiter problem
- Low Idle after installing Predator Perf. Tune
- Question About Hp Tuners
- Any good tuners in North California.
- getting lean codes a few ?s
- how to do cam tune
- what do these codes mean
- ls2 knock sensors tunning
- wtb programmer
- C5 Water Pump Replacement
- tuner in indiana
- Suggestion for those with C1243 - ABS Pump Stall
- Help me please :)
- Need a dyno tune within driving distance from Wash. DC
- Z06 Pinging Like Mad! California Fuel Garbage ? Torco?
- 2001 ZO6 Tune
- Performance Specialties in Glen Burnie, MD
- po172 & po175
- Check engine light after dyno tuning...
- Disappointing Dyno Results
- Tuner in Little Rock, AR
- Wideband Stability with LC-1 and HP Tuners IO Interface
- What does this PCM code mean??
- Gear Predator question
- code 357, #7 coil
- 03 Z06 bogging down off the line at drag strip???
- HP Tuners vs EFILive
- Help. Does anyone know of a good turbo tuner in South Carolina
- P0138 C and P0158 C with no Check Engine Light
- Anyone in ABQ,NM have HP Tuners for 99 C5?
- HP Tuners and Superchips partnership
- basic scanner
- Cloumn Lock recall, Now ECM back to stock??
- 1999 coupe A/C controller problems
- throttle delay 1999 coupe
- P0160 Code on 97 Coupe! HELP!
- 2000 C5 Maf
- LS1 Edit question
- where do I start with my 02
- Scanned my near-stock car - Are these results the norm?
- PCM code 1120 ?
- LS1 Edit, can someone get me a file list of the CD?
- Autotap software - 5% off and free shipping
- Logging Oil Temp with HPTuners EIO Interface?
- ABS/Traction Control Problems
- Looking for a Tuner in Idaho....
- Engine Miss with Fidanza Flywheel
- Tuner in Missouri
- Help using LC-1 to simulate Narrow Band O2
- Miss with no codes found
- Is there anybody here with a 99 or 00 C5 that has upgraded their OS?
- Misfire detected
- Jeremy Formato, FL Tuner ??
- Thinking about buying HP Tuner. Good idea?
- please help with codes
- Which Programmer to get?
- HPT Company Observation
- best programer for the money
- Needing a Corvette Specialist in Tampa...
- engine codes 155 160
- BEST price on LC1s??
- Which Injectors To Use 30lbs Or 42lbs
- [EFILive] Anybody have a stock 2001/02 C5 TUN file?
- Code P0140 and P0161
- 5th gear problem
- code pcm p0751
- Scantool Question
- Michigan tuner
- Predator fan setting and tourque management question
- Dallas Tuners???
- Shift Pressures ?
- code p0113 & p1111 after new IAT sensor
- How do Longtube headers affect stock tune?
- 2001 w/Computer or Wiring Problems...
- Tuner near San Antonio Tx
- Tuning Gurus Step In
- Scan Tools
- Tuner ???
- code questions
- Getting PRO Yank 3600 TC and 3.42 Gears
- Scanmaster for LS6?
- My Latest Performance MODS
- Excessive exhaust popping and crackling after tune...
- Best Tuner in San Francisco Bay Area
- tuning for dummies?
- tuner near Pittsburgh?
- Question about Vararam
- Tuner help in Geneva, Illinois
- Looking For Turner In Washington St.
- Delivered Torque
- P0343 Camshaft position sensor high voltage?
- LS1 edit questions
- Another stupid question
- hp tuner
- LS1 Edit and O2 simms
- What is involved in tuning a car?
- Tuner in Charlotte NC
- TR 224/224 Installed, what do I tune for first...LTFT or STFT???
- Codes P0113 and P0751
- Need HP tuner help in Lubbock, TX.....
- Tuners in Portland, Oregon
- Surging w/TR 224/224
- What's wrong THIS time? More codes
- Predator...interesting findings after perf. tune
- DTC's online?
- PCM Documentation?
- Check Engine Light,can't find code!
- Tuner in Washington?
- "axle abuse enabled" ??
- Switched from Predator to LS1-edit
- Looking for installer/tuner in Mich.
- Any experience with DynoTech in Ft. Wayne
- A4 shift RPM
- need advice-computor @ tune
- Predator programmers - $399.99 with FREE overnight shipping!
- Need advice on Tuning
- Need a Tuner
- MAF Help
- Throttle Response Problems...
- LS2 90mm tunning
- AC Pressure (psi/volt)
- What should my Air-Fuel ratios be spraying a 100 shot ???
- Turbo & Tuning
- predator advice
- Can I just change the fan settings on a Predator?
- Help with knock codes 0327 and 0332
- Car stalls when logging only
- Help with Remote Function Actuation code
- Tuning Help
- Anyone cruising to Carlisle Saturday morning?
- What would happen - LS1 to 02 LS6 MAF swap
- Just received my Predator today!
- How do I Jack Up My 02 Z06 and Put it on Jack Stands? Wondering what the procedure is
- Predator Shift points
- Handheld programmer????
- Does anyone have any leads as to where to purchase an extended warranty for 2002 Z06?
- {VA} dyno tuning for LS1/LS6 & LT1/LT4 with Jeff Creech from C.A.M. at ABACUS 9/12/05
