- Tuner locked my PCM
- Is There Any HP Tuners Near Springfeild IL?
- Looking for a Computer Tuning Location in South Carolina area
- Best OBDII scanning software?
- Calculating gear changes with Dyno tune.
- Engine Pings
- Predator Must have stock tune??
- Looking for tuner near western MD
- Need good trans mechanic in Albany NY area
- Cant adjust Timing at WOT
- Tuner needed in Wash DC area
- Can I run an 01 or 02 PCM OS on a 2000 Vette?
- lost tune?
- Which programmer for my c5
- Where to get a tune in los angeles area?
- 58-sdm B1001h?
- Quick Question for the tuners
- check my dyno numbers
- Ls1edit Injector Flow rate for accel 30lb
- MAIL ORDER TUNING by Chuck CoW
- diablo predator
- Engine Pinging... Advice Please!
- do i need a retune?
- Replace spark plugs?
- exchanging auto for manual how hard is it?
- '98 ECM data logging baud rate.
- Hypertech help please!!
- Good results on dyno
- AFR numbers
- how to remove my pcm for mail order tune
- Looking for a tuner, FL/GA area
- HPT tuners, does this look like crossed 02's?
- Front driver's side O2 not working.
- Formato tuning and porting in Ft Lauderdale 6/21-23
- tuner/software
- Lost power to the MPVI
- Anyone Tuned an APS TT Kit on a HP Tuner
- CEL: isufficient switching
- Snap-on Modis, what can it do?
- Thumbs up for Chuck @ COW!!!
- Chuck Cow
- AC Idler Pulley Replacement Photos
- Manifold Air Temp Sensor
- Any good tuners in Ky
- IAT Question ??
- 3.42 Rear End Need tune?
- Tune by Chuck Cow at Bloomington Gold
- OS versions for 2000 C5 Coupe. RTT Related.
- Hesitation when cracking throttle. 1400 rpm
- S. CAL or Phoenix service shop for C5? Any recommendations?
- MS4 cam diablo tune?
- p0154 code help
- Can a tune change the size of the front tires?
- Want to learn more
- How important are cruise LTFT's
- PCM Logfile Please help!
- Torque Management & you ....
- ***Warning***98 PCM Fried-2 Bar Speed density tune
- doing heads and cam, what will happen if no tune?
- code C1225
- Need a favor,Someone w/EFILive
- PCM and key programming?
- a few ?'s
- Thumbs Up For Jeff Creech At CAM
- Will a tune help
- Need Help - Need a Tuner
- Tuner needed in SW Missouri
- CHUCK CoW TUNING @ BLOOMINGTON GOLD - CHICAGO AREA - JUNE 14 - 17
- What is best ODBII Scanner or data logger?
- My car is sick...throwing codes, need help
- I asked a for some help?
- WOT Missing
- Engine ping
- Wot problems
- RevXtreme Dyno Tune Special: $399!!!
- Any one willing to educate me about tune
- Help in tuning my 3.43 @ 3200 TC whith DIABLO
- CT Tuner needed?
- need a new clutch
- Tuning for 90/90
- price for clutch install?
- I need your imput
- Aem O2 Wideband
- Should Check Engine Disappear on its own?
- Passing emissions with modified motor
- Vancouver BC
- looking for dyno tune
- Can HPTuners do anything for the "Service Column Lock" or "Pull Key Wait 10 Seconds"
- Possible Conflict Between the Predator and the Vararam B-2
- #2 fuel trim is reading -100
- Corvette Tuner
- P0410 won't go away! Replaced check valve...
- mail in PCM or buy tuner and get a mail in Tune?
- Information Center
- Can I use the Diablo to fix a Vararam Lean Surge on My Z06?
- Can't Change Timing??
- P0405
- Need help installing a Innovative LC1 and NB gauge
- Tuning Help
- Need Stock 02 file
- HP Tuner Question
- Which mods to do first???
- LC1 Help
- 40# Injectors
- predator - how to adjust shift points
- Tuner around Huntsville, AL ???
- OBD II baud rate?
- Memorial Day Specials
- Can a Dynotune control shifting, TC lockup/slipping, etc....
- When using aftermarket ECU, is the PCM still needed?
- Help...Rough Idle
- One more WB02 question.................
- how many horsepower with tune 04 stock z06
- Looking for someone in Central VA to program out P0410/P0480 after AIR pump removal
- New hear have a queshtion about wheels
- A4 wideband cable routing question.................
- codes 1016 and P1635
- Code PO137???
- Tune back to stock
- LS1 Edit
- Z06 Mods
- Any good tuning shops in New Hampshire?
- Any Good Tuners In Las Vegas?
- Autoxray Ezlink Update?
- Is my pcm fried? Please Help
- popping sound while tunning?
- Can a custom tune change on its own?
- Actron CP9190
- Results of a ported LS6 vs a LS2 intake
- Riddle me this : Bassini full exhaust & false lean
- TCS code C1226 - Caused by my CCWs?
- bassini header ?ss
- Stock Flash both auto and 6sp info?
- $199 Street Tune special continues!
- How to wire LC 1 to oem narowband connector?
- C5 vortech Supercharger
- Connecting wideband via EGR or A/C Pressure in HP Tuners
- HElp with idle
- Post Sea Foam Tune!
- any one here running a Crane Cams programmer
- Tuner Near Redding,CA?
- Anyone have any advice? Car is lurching back & forth when I decel below 2,000 RPM's
- Help! Big trouble with Hypertech Tuner!
- Throwing P0102 After Z06 MAF install?
- Found 10 HP in Chattsworth
- o2 sensors need help
- Show me your laptop mounts!
- LTFT variance between bank 1 and 2?
- Can you tune out the fuel shut-off?
- Is anyone run a Innovate LC-1
- Tune shop In Knoxville, Tennessee
- $199 street tune this Sat at BMP in FL!
- HP tuners Pro: turn off knock sensors?
- Wot tuning questions
- LS6 intake with or without 28lbs injectors (currently have the 26lbs injectors)???
- upgrade Predator version - where's RWTD?
- Which Programer? Hyerteck or Granatelli Big G
- Mailorder BCM programming
- Diablo
- Car won't start after Diablo Predator Tune
- Need tuner/shop
- Analyze this Dyno Sheet...
- Mods
- Ignorance is [not] Bliss: Q About Tune
- Thanks Charlie
- Best wideband w/ HP Tuners
- New LS2 90mm throttle body install, getting P1635 code, no throttle control
- Wideband install
- 734 rwhp / 680 rwtq - No Meth!!!
- Some help?
- Those of you with an AEM Wideband come in
- scanmaster help
- Can a 99+ PCM be fitted to a 97 C5?
- Can you tune out Tire pressure monitors?
- Poor dyno and KR with my American Racing Headers:(
- Normal Iat Temps...
- PARTS need to go from 2000 C5 MANIFOLDS to 02-04 Z06 MANIFOLDS...HELP!!!
- New PCM now bad misfire
- P0343 Code
- In need of a GOOD tuner in so. cal or nev
- Windows Vista and tuning
- Hypertech help
- HPtuners vs. EFI Live, which one to purchase? (May 2007 Update)
- Mustang dyno V/S Dynojet ??
- Is it worth getting a tune if my a/f is perfect?
- Spark Retard
- Wideband 02 LC1
- Going from a 2000C5 74mm MAF to a 2002 Z06 MAF (unscreened from factory)
- Check engine....what do these codes mean?
- Fried PCM now what?
- Diablo Predator Help/Advice
- TPS Voltage staying at 2.x
- Pulling suspension codes with EFI Live
- tuing suite for codes etc.
- P1415
- Which Hand Held for C5???
- C5 Tune at OCC - results
- looking for tuners
- Dialbo Sport U7198
- Diablo Sport U7198
- tuner in the Jacksonville FL area
- start up idle surge
- EGR equipment on 2000 C5?? Different stock headers??? PLEASE COME IN
- part throttle tuning - Is it important?
- Experience with Chuck "Tuner" Cow in NYC
- Tune on stock 2001 vette
- how are you guys wiring the lc1?
- 1226 Code Step Inside Not What You Think
- where to start
- Startup tune?
- Review of my experience with HPE in Houston.
- Programmers
- Tuner in St. Louis,MO
- Central Florida Tuner
- Please Help with code? Headers?
- CHUCK COW - TRAVEL n- TUNE - CHICAGO AREA - THIS WEEKEND!!!
- Need some Help
- Will i need TUNING if im upgrading from a stock to a 85mm BBK Throttle body???
- Timing
- A4 WOT shift point settings
- Need help with Initial Tune
- Problem with predator programmer
- Predator C5 specific literature available?
- where to mount a wideband
- Predator Question
- A&A in Oxnard Ca saved me...........
- Emissions - Expert Help Needed
- Play in my throttle body plate???? NEED ADVICE!!!
- fixed glowing headers& hesitation
- LS7 injector flow rate (base) table?
- Can I be sure the "Predator" is safe?
- Mail Order Tunes...Pricing Difference....
- First Tune asking for recommendations
- Losing RWHP with MODS
- these ford injectors work on a Z06?
- c-5 glowing headers
- predator question for Mike
- high speed hesitation
- Wheel/tire size part of tune?
- Kooks Headers
- Code Issue
- Clearing engine and skip shift...
- P0654 Engine RPM Output Circuit Malfunction
- HP Tuners phone number??????
- Knock Sensors & Jesel Rockers
- 99 FRC need tuner in MPLS
