- Predator Question
- Headers&x-pipe
- Emmissions Help
- C5 Tuner in Virginia/Maryland
- Ls2 Tb
- Hypertech programmer III
- what do these codes mean?
- Help with using Diablo tuner
- Formato tuning and Porting in Gettysburg PA 10/17-10/20
- Thinking of buying Ls1Edit or Hptuners
- "reduced power" after hitting revlimiter?
- retuning?
- Just went to Dealer for some code clearing = Gouging
- EFILive or Diablo Predator?
- Help Help Help Plz!!
- Best way to view data/which scan tool help!
- Eureka Springs Corvette Meet - TUNING by CHUCK COW - THIS WEEKEND
- Diablo Predator HELP from Experienced Users...
- Force Motor Current. What does it really do?
- Rev Limit
- Predator for 98 C5?
- best oil for a 98 c5 with 45k miles
- Experienced Predator Users, Question for you...
- What about lowering the RPM that PE comes in
- LS1/LS6 swap
- needed hpt bin file for 2002 vert.
- Tuning C5Z for over 500 HP levels
- Chuck CoW - TUNING @ Eureka Springs CORVETTE MEET - BOOKED!
- Hypertech Problem with my 98, please help car wont start
- FAST xfi first time tuning tips for a 427 sbc
- Apsis C5 Burlwood Dashes for C5 50th Anniversary Edition
- Wideband logging through the EGR.
- A Big Thanks To The Vette Doctors
- Anyone find a way to disable the automatic headlights?
- HP Tuners VCM Suite v2.2.0 is Now Available!
- Trying to use an LC-1 as a narrowband and a wideband
- Jeremy Formato Tuning in Gville 9/27
- FAST xfi startup on a 427 sbc timing/spark issues.
- What is a good cheap WB AF gauge to use with a LC1???
- HPTuners or EFI Live?
- Cleaning 02 Sensors?????
- My 2 cents on Vararam, whats your's?
- ? for you guys about an LS1 swap into an older car, regarding the wiring harness.
- Dyno vs. street tune
- Experiences with Predator Diablo Sport?
- Mail Order Tune Needed??? Recommendations???
- Tuned on a hot day Retune on a cooler day?
- Why does it take so long to receive credits from HP Tuners
- Plastic covers near fog lights
- C5 Dyno Tune
- Apsis' C5 Front Bumper Valance (C6 Z Style) Finished Prototype, Welcome Your Comments
- wiped out hand held tune
- 18 Gage conx female pin Where to find
- Check engine light is on with no codes
- ecs tune at carlisle
- anyone run water injector on a N/A engine?
- Will codes change tune?
- Corvettes Of Westchester - Carlisle Overstock Blowout Sale
- Dyno Tuning -- Stock Car
- Code 10pcm 1153 H C
- Need help from HP tuners expert, foff you there?
- Bosch IR
- DO heads need tuning ?
- Car starting problem and 1-2 shift hard
- unlocking a predator
- tuners, head cam cars, and ppl running rich
- Chuck CoW Interest List Phoenix Arizona Mid October
- can somebody look at my trans am tune?
- Announcement: RevXtreme Name Change
- What laptop mount for C5?
- Apsis' C5 Splash Guards (Z Style) Prototype Done, *Pics Shown*
- Vinci Programmer "WOW"
- Engine stall after high RPM
- high temp ??? plz help
- HPTuners viewer?
- Tuners.... what do I need
- Oxygen Sensors And Tuning
- HP Tuner ?
- Street Tune
- Tuner Needed
- Experienced Tuners in SLC UT area?
- Can someone help me with a predator tune?
- FS - Laptop (great for tuning)
- 160 degrees thermostat and fan temps
- MAF problems
- Need help finding a tuner!!
- p0327 Knock sensor Imput code. #1
- What are my Tuning options with a 97 M6??
- Norris Motorsports Official Grand Re-Opening Dyno/BBQ Sept 29th & Some 1999 Pricing
- Installed Predator
- back oil seal kit for a 2001 C5
- Employee Pricing Special!
- Help w/code po300 c
- Do you need retune for gears??
- RevXtreme Press Release:
- Heads and cam
- dfw tuner needed!!!
- ***VetteDrs Extend 99.00 Carlisle Tune***
- tuned from doctors
- Best price for HP Tuners?
- hitting rev-limiter, don't want to...
- HELP with TCC slip P1870
- Help with code P0101?
- help with engine code PCM 0420
- Ill running after header install.
- My bad experience @Carlisle
- Service Vehicle Soon - No codes
- I think Charlie @ RPM made a deal with devil
- Tune review?
- Free $500 Dyno Tune w/Headers&Honker package!
- Help! Need a LS1-edit file for a SC LS1
- Looking for a tune for my 98 in vancouver??
- Predator Help
- Fan Temp change
- HOLY COW 4.10 rear for 06/07 C6 at CARLISLE
- B&M SHIFTERS INSTALLED IN YOUR C5 or C6 CORVETTE @ CARLISLE THIS WEEK! by Chuck CoW
- Column Lock Problems Gone Forever!!! @ Carlisle This Week!
- Blinking DIC?
- Scanner
- Tune general info needed
- Charlie @ RPM is the best (long but please read)
- Help w/Code
- Computer tune question???
- Newbie needs help
- Check engine light on
- P0141C Heated Oxygen Sensor code - what to do?
- I need a good tuner in Salt Lake City,Ut
- Torq converter locking unlocking again...
- need some help from pcm tuners
- Performance add ons
- erratic HUD DISPLAY 2003 COUPE
- Are HP Tuners on back order?
- Need a stock 1999 M6 corvette file
- C5 Dyno Results with FIPK and Headers
- New Code....Help....
- THE OFFICIAL TUNER OF 2007 CORVETTES @ CARLISLE is CORVETTES OF WESTCHESTER
- Predator, Superchip, other?
- help me on my problem plz
- HP Tuners Software
- Tuning my FRC
- Thanks to Doug Rippie!
- ***Failed a pre-smog***
- what should i do burnt computer
- Is it good or bad for the car???
- DiabloSport Predator Programmers On Sale!
- Kudos to ECS
- That Norris guy
- Do speed/odometer care what rear gear size is in the PCM?
- Tampa Vettes, need a tune? Dyno or street!
- Street/Dyno Tune?
- What tuning is requred with header install
- ~~~St Judes Auction #25 ...Mail order tuning package from Chuck Cow~~~
- chassie control module
- tuner in south jersey area
- question on Predator serving as a scanner tool for monitoring shifting
- Fouling of Oxygen Sensors...
- preditor question
- Need stock '02 LS-1 M6 .hpt file
- TM delete & COT Turn off..pros & cons are?
- 03 Z06 Clutch
- Gauging Intrest in a Las Vegas tuning session
- help with alarm not letting the car start
- Jeremy Formato Tuning and Porting in Gainsville 8/9 and Jacksonville 8/10
- predator downshifting not the same
- I had questions on converter issues....
- FYI , VMP Tuning
- 97 C5 tuning problems with newly installed 07 L92
- Daiblo And Nitrous
- Daiblo And Nirtous
- Dyno-Tune Help!
- Tuners Step in and Answer these questions for me. Fast Install.
- p0606 and p1518
- throwing codes B0361 and B0441
- News from Precision Industries on trans
- 21st Century Muscle Cars $149. Tuning Special
- fan temps
- *** ECS Summer Half Over Deal ***
- General question about hp tuners
- Superchips Flashpaqs - $50.00 Mail-in Rebate!!!
- anybody running a converter????
- car has a code, need Vitamin C
- Rev-Limiter on 2004 Vette..(Predator)
- Which Wideband??
- Need a Stock '00 A4 Tune
- Where and when is AUTO CAL being released
- Headers installed --> check engine light
- EFI Live for dummies
- Only need to change my ratio for bigger rims, best way?
- Simply the Best Email Tunes - Based off Current Dyno Testing – and Still only $150
- do obd II tuners scan too?
- got vcm suite, need to remove hypertech?
- WTF: car won't go into closed loop?
- MAIL ORDER TUNING by Chuck CoW
- Vararam! -A-Rama @ Corvettes of Westchester
- Good northern California tuner?
- Laptop
- EG Birthday Madness : 44% OFF, Today only!!!!
- Maxed out MAF question
- big thanks to chuck cow
- Thanks Diablosport
- Question about MAP Sensor..
- PLEASE help me set up my EFI Live log maps
- 24 MPG on tune?
- EFI Live 2 VIN question
- looking for a tune in cleveland, oh
- O2 sensor code already ?
- Shifting into OD too soon.
- which fuse for ODB II port
- I'm in need of tuner in Allentown for stock C5
- diablo and nitrous
- Detuning a 2001 (Not kidding)
- best program for 98?
- reprogram radiator fans?
- Tuner Information
- Headers Survey
- Tuner in Minneapolis area to handle a fast 90/90 setup?
- A4 after tuning question
- Mike Norris tune and rev limiter... help
- tune through computer?
- surprising dyno results
- Opinion on shift RPM & MPH
- Looking For A Tuner In South Florida...
- dynoed it today
- QA1 C series
- Check engine light help
- What Is P0492 H C?
- Sarasota tuner??
- How does this dyno sheet look?
- Some really good guys at New Era Performance!
- Looking For Corvette Mechanics In Miami Area .
- EFI Live and A4 gear change tuning
- Question about installing aftermarket headunit with bose
- no start after new PCM / ECM
- Stalls when put in gear
- Hypertech Tuners
- ABS/Traction Control Warning Light
- Headers = Blinking SES light
- Question
- HP Tuners or EFI Live?
- Emission Question: Not Ready Codes
- Jeremy Formato Tuning and Porting in PA 7/23-7/28
- "HOLY COW" HD 4.10 rear ends IN STOCK - other ratios also available
- Vararam! - A - Rama @ Corvettes Of Westchester
- Chuck CoW - CHINA TUNING TRIP - SLIDESHOW
- Spark Dwell Time LS7 v LS1
- Tuner locked my PCM
