View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. 224 on a 114lsa on a stock stall converter?
  2. For those of you simulating a narrowband with an LC1
  3. Power Enrichment mode question
  4. **tuning?!**
  5. Logging with LS1 edit.
  6. Where can I find a Dyno Tuner near NorthEast Kansas
  7. Tune?
  8. C2120 TPM Code Question and some others
  9. Long list of codes. Check it out.
  10. 98 Fuel Enrichment Problems...help needed!
  11. LS-1 Edit
  12. **** St Jude Auction 10 Mail order tuning package from Chuck Cow*****
  13. Predator Help/Question
  14. Predator and Logging
  15. Birthday Dilemma...
  16. Chuck CoW - TUNING in TAMPA, FLORIDA @ REV-XTREME
  17. Can someone copy my friends tune?
  18. po343 code ?
  19. Fast-Flash programmer
  20. FAST Intake, 90mm TB, LG headers estimate
  21. Dead after new PCM
  22. heater /air conditioner
  23. Mike Norris Motorsports LSx Tuning in Ft Myers Friday Feb 15th - $450 Total
  24. Does anyone know what P0000 PCM DTC is?
  25. 42 Lb fuel injector recommendations please
  26. code 1283 and Tech 2
  27. New Owner C5 Tune up Question!
  28. Torque Converter Lockup - adjustable? Predator Custom tuning
  29. Hot start issue after cam install
  30. ever here of this tune
  31. Apsis' C5 Center Console in Silver Carbon Overstock Sale
  32. Crane Cams/Vinci Performance Tuner vs Unichip Piggy-back ECU
  33. Im going to be getting my 98 c5 tuned with hp tuners. What will i notice???POWER???
  34. PCM's
  35. Only 80 Mph ....HELPPPPPPP!!!!!
  36. Apsis' C5 Front Bmper Valance New Fitting Sample *PIC SHOWN*
  37. 98 PCM upgrade??
  38. Jeremy Formato Gettysburg Tune/Port Session 3/6-3/11
  39. Cable
  40. predator file question
  41. 98 vette
  42. Hp tuners, simple question
  43. Glowing praise for Predator..
  44. KR question
  45. torque management and shift firmness 97 A4
  46. Vengeance Motorsports, in Georgia
  47. What airflow calculations need changed when switching to a 90mm TB?
  48. LS1 Edit vs. HP Tuners vs. EFILive
  49. WARNING: new C5 owner dummy question....
  50. Oil consumption
  51. Are LTFT a % or an absolute value
  52. Mustang Dyno VS the others
  53. Diablo performance gains A4 3.15,please
  54. Hp tuners, is that a good tune.
  55. 2005 C6 Tune
  56. tuner
  57. Tune??
  58. Your opinion of the INNOVATE LC-1 / XD-16 Wideband O2 Standalone Gauge Kit
  59. Loading Stock Tune
  60. Does any one know about Revtronix tuning????Help..Hlep
  61. New Corvette Forum supporting tuner
  62. 800 RWHP tune
  63. Revtronix tuning...IS that a good tune.
  64. MS4 Tune
  65. Recurring 0430 code
  66. Need reference materials for basic understanding about how a tune works
  67. Anyone Tuning With Hp Tuners
  68. New vette owner needs help with codes
  69. How did you wire your PLX Sensor Module for narrow band?
  70. Torque Management / HP Tuners - How Do I Get Around The 640 ft-lbf Limit?
  71. Codes??
  72. superchips flashpaq
  73. What Diablo "version" am I shopping for....
  74. Help! New to C5 Diagnostics.
  75. Help with codes
  76. Help change light
  77. Which seller best Diablo price ?
  78. zo6 tuning question
  79. high trans temp warning
  80. San Diego tune group purchase....
  81. How to wipe out the column lock recall
  82. What should i expect?
  83. Sarasota or Charlotte tuner/shops?
  84. need help w/ my tune
  85. Hp Tuners or Dyno Tune from shop.
  86. C5 Remote problem
  87. Fan reprogramming...cheapest route?
  88. window scratching rubbing noise
  89. Dyno Question
  90. Cold & Hot Start Up
  91. Tuner help.
  92. Which Way to Go?????
  93. Emissions : Might possibly need a tune
  94. Crankcase pressure?
  95. Diablo and 02 sensors
  96. changing VIN's on a convertable
  97. Timeing Help
  98. AFR Goes Lean .... Sometimes.
  99. Recieved error code need help
  100. Predator Sport Tuner for a mn 6
  101. help with ls1 edit
  102. p0756 code on newly rebuilt tranny
  103. 06MonteSS - Predator questions
  104. Easist MAF To Tune?
  105. Question about intake and MAF...
  106. Dynosport
  107. New to the Predator
  108. Having a hard time with Reduced Engine Power
  109. Granatelli MAF's
  110. Predator on its way!
  111. Attention: TX, NM, AZ members
  112. You all are going to love me [obdII stuff]
  113. Didn't Get What You Wanted!
  114. Tuning Software- How Hard to >>
  115. P0430 code
  116. A little of what I know
  117. Apsis' C5 E-Brake Handle Now Available in Burlwood, Black or Silver Carbon, *PIC SHOW
  118. Finally
  119. Proper Compression?
  120. Anyone Selling EFI Live?
  121. Tuning for the road course: what A/F? trims by Cyl?
  122. DTC Codes after Hypertech Instillation
  123. Should my tune give more power?
  124. Owners with their own HP Tuners...
  125. Scan Tool
  126. Need INFO on GM TECH 2
  127. Christmas Specials
  128. NEED HELP: predator or HYPERTECH?
  129. new member needs help
  130. Cam shaft experts step inside please..would like your opinion on "Ramp Rate"
  131. Door ajar error message on dash console
  132. New - Predator Log File Analyzer Available For Download!
  133. lc-1 o2 sensor at Autozone
  134. Autoenginuity Scan Tool
  135. P0507C....Incorrect Idle Speed (high)
  136. Gauging intrest in a South FL tune session
  137. HP tuners and locked PCM's
  138. Anyone near Charlotte, NC?
  139. Will need a tune, Recommendations?
  140. Central Texas Tuners?
  141. Programer
  142. Tune Questions
  143. PCM for less experience, baseline tune help!
  144. California Diablo drivers, please help...
  145. EFI Live now what
  146. Dyno today
  147. RevXtreme Holiday Tune Special!!!!
  148. 2001
  149. 2001
  150. Diablo 93 octane ok with 91 octane or ?
  151. Predator Programmer Discounts Available!
  152. +35hp chip?? Is it so???
  153. Halltech Cyber Monday 10% Off Sale!
  154. Installing Headers????
  155. change gear ratio(diablo help)
  156. Code reader question
  157. Tuner in Huntsville, AL ?
  158. I think I need a tune, what do you say?
  159. $100 off tuning this Saturday only!!
  160. HP tuner: SD tuning question
  161. Superchip Cortex or Flashpaq?? and/or Predator
  162. Ecm Change Question?
  163. Jeremy Formato Tuning and Porting in Gettysburg PA 11/29-12/4
  164. HP Tuners group buy....
  165. dyno tune vs street tune
  166. what is actually getting tuned?
  167. service engine soon ? WTF
  168. Thanks Don AKA Slowhawk
  169. Has anyone had ECS do a mail order tune for them?
  170. Jeremy Formato Tuning and Porting in Tampa 11/17
  171. Why did I have to lower my VE table
  172. Trying To a Buy USB Programmer
  173. Chuck CoW MAIL ORDER TUNING!!!
  174. check light came on - p0757
  175. Super Tuner - Ed Hutchings
  176. Tuning 101
  177. LS2 402 & 236/240 Cam - Idle Transition
  178. $399 Dyno Tune Special!
  179. Tuning with wideband
  180. LM-1 WIDE BAND connections to EFI Live Flash Scan
  181. Help on wideband wiring installation, please
  182. tune
  183. E85 Esp. From Andy @ Dyntune America People --> Step in!
  184. Need help setting up tune numbers for 60lb Mototrons
  185. Looking for tuner in Colorado Springs area
  186. Diablosport Predator help
  187. Hyperech III programming
  188. Need some serious diagnosing on my car....
  189. 3.42s and Pred
  190. Just installed Wideband need Tuner DFW for a Touch-up Tune
  191. Vortex Ram Air w/Carbon Fiber Power Duct Intake Package
  192. Looking for a car tuner
  193. Thanks Chuck COW! Vegas tune....
  194. Looking for a Good Tuner in the Midwest
  195. C-5 Vette will not start after 1 yr storage
  196. looking for a stock 97 C5 tune file
  197. Just bought weiand intake
  198. Autometer wideband sensor narrow signal?
  199. installing a differant pcm in my vette. What needs to be done?
  200. Running Rich?.......Help
  201. Need Advice
  202. Cheap laptop HP DV1010 $250.00 shipped
  203. Severe Bucking/Surging P0102 code - changed MAF no change
  204. What is wrong with my preditor
  205. Speed density or maf tune ?
  206. Tuners in the Murfreesboro/Smyrna/Nashville TN area?
  207. help with po410 code
  208. LC-1 install?? With HPTuners?
  209. need a tune and dyno run in NJ area
  210. Headers and X-pipe
  211. Who sales the best hand held tuner?
  212. B1001, P0172/P0175...did search...any ideas?
  213. New Predator for sale.
  214. do i need a retune
  215. What's the story on Seafoam?
  216. $399 full dyno tune special!!!
  217. Looking For a Dyno Tune 250 to 300 miles From Mbil,al or Pcola,fl
  218. Bpp Dyno Tuning Special
  219. Anybody use the Jet DST?
  220. Tuner Type
  221. Predator Programmer Discounts Available Here!
  222. HP Tuners Tuning Links, Help files & Demo's
  223. EFI Live V1 or V2 ??
  224. Has anyone turned off P1637?
  225. Predator Question
  226. Traction control delete
  227. Anyone tried mail order tune?
  228. Diablo help plz
  229. Looking for tuner in NH area
  230. Anyone Want HPtuners?
  231. AEM Gauge with HPTuners Question
  232. Fairly new Low comp 408 motor throwing knock codes!
  233. Exhaust manifold bolt torque
  234. Anybody have a wide-band O2 they can loan me??
  235. Lil Diablosport help....
  236. P0430 on 2000 Corvette
  237. Switching to ls6 intake. few questions
  238. Oil not synthetic
  239. Applying & Using HP Tuners Real Time Tuning Custom Operating Systems
  240. No mufflers
  241. MAIL ORDER TUNING by Chuck CoW
  242. 98 C5 Ls1 tune in Tucson AZ
  243. Injector Duty Cycle question,... max practical duty cycle limits?
  244. C5 Tuning Specials!! In Florida.
  245. What do these codes mean?
  246. HELP!!! Car is running terrible. Installed new MAF and Throttle body
  247. Where is the best place to get dyno tuned in San Diego?
  248. Norris Motorsports LSx Tuning Starting @ $300 (Southeast)
  249. 98 pcm... different than 99up ?
  250. Delete o2 sensors
