View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Lc1 narrow band problems
  2. SCM Code..Help
  3. Tuner with Intake Support?
  4. Charlotte, NC Pro Dyno Tuners???
  5. Dyno Results After 228/228 and 5.3l Heads
  6. d
  7. Tuning questions
  8. Tuner Advice Needed: MPH vs RPM
  9. Need Help With HPTuners
  10. Chuck CoW TUNING - ORLANDO, Florida - JUNE 5 & 6
  11. mail order ECU programming???
  12. calling foff67
  13. Split fuel trim issue
  14. Hey guys need help with a code P0171
  15. Code P043. Newly installed LS3 416 in a 02 Z06. WTF
  16. Which side is Bank 2
  17. Name my plate....
  18. air filter question
  19. Tune Only Question
  20. Best tuner?
  21. Tuner needed in Atlanta GA
  22. MAF tune
  23. new fuel
  24. Recommended tuners within 6 hours of Greenville, SC
  25. Help Me Please My Transmission Went Out
  26. Does anyone tune only for fuel mileage?
  27. DTC-P0106 after heads/cam/fast 90 install??
  28. Please help me with these codes on my sisters Z28
  29. What is happening to my AFR?
  30. LC1 and HPTuners picture request
  31. Help with Codes
  32. Shift Point Recommendation help!!!!!!!!
  33. timing and afr
  34. c5 select ride bilstein? 95225
  35. Chuck CoW is in DALLAS, TEXAS TODAY!
  36. Shutting off traction control
  37. P1514 reduced eng pwr vs C6101 table
  38. Laptop suggestions
  39. DIY Tuning an already 'tuned' car
  40. need a turner
  41. manifold AIT vs air bridge AIT on maggie?
  42. Wideband o2 Sensor replacement
  43. '03 Z06 Stock O2 Sensor Wiring, LC-1 Install
  44. Where did you ground your LC-1 Wideband?
  45. SD tune & RPM Tranny
  46. C5 turbo.Tunning problem.
  47. ls1 tuning and expected hp?
  48. Need help selecting mods
  49. Hell Yeah, I tried my new HP Tuners PRO today..
  50. EFI Live / LC1 wireing question
  51. Someone help!!! Tuning issue???
  52. Vehicle speed sensor question
  53. Are there any recommended tuners in the Reno area?
  54. Revving up to 2000-3000 rpm when i put the clutch in??
  55. ^^Best Wideband O2 Setup^^
  56. Computer & Sensor Testing Tool -vs- Handheld Tuners?
  57. Problems with a 402 + blower
  58. What should I do first!
  59. How can i toggle between 2 maps/tunes easily?
  60. Local shop
  61. tuner in minnesota??
  62. tuner
  63. Unlock a Diablo ?
  64. Who has HP Tuners in stock ready to ship?
  65. help with vette tuning in the gulf coast area
  66. A/F ratio with HPTuners?
  67. P0101 and P0300 codes. Friend needs help.
  68. Get rid of CAGS with a retune?
  69. USB to serial adapter: Which one to use?
  70. Can anyone help w/Innovate Wideband calibration?
  71. Cant reads codes in a 2004 vette????
  72. 1997 pcv valve location??
  73. Tuner in the Buffalo NY Area
  74. Stock Settings?
  75. Anyone tuning a 97 vette with HPT?
  76. diablo predator tuning questions
  77. Baby Steps…
  78. Diablo U7198 Predator Tune (Knocking/Pinging)
  79. Tune your own car, save $100 on a package!
  80. Gm Tecii
  81. Disable column lock? With pic.
  82. popping at WOT
  83. HP Tuners?
  84. tuner in Illinois?
  85. Failed smog, w/ Hurricane intake in Cali!!
  86. Predator updates
  87. WTB: HP Tuners
  88. Pulled the trigger on HP Tuners Pro
  89. displacement on demand how too
  90. About to FIRE new motor - Fuel Injector Question
  91. headers poor m.p.g.
  92. Tuner recommendations in PA?
  93. Emissions Help!!!
  94. Just had her tuned
  95. Dyno Tune
  96. Fuel trims reading 0.00 at WOT???
  97. The last of my tuning questions..
  98. Do I need a tune? Will it help? 97 Vette
  99. please help me with table D0801 and D0301 torque reduction
  100. Anyone know the stock settings for A4 TC lock/unlock in 3rd and 4th gears?
  101. Where to weld wide band bung on stock exhaust?
  102. Gettysburg PA Tune and Port Session 5/9-10, 5/12-15
  103. Predator New Tune
  104. Question about painless harness and ecm
  105. Convince me to buy a Diablo U7198
  106. Can a WB 02 be used as a narrow band?
  107. Halltech Venom install - now SUPER lean - HELP!
  108. Apsis' C5 Splash Guard (C6 Z06 Style) Finally Done & Now You Can Order, *PICS*
  109. Apsis' C5 Front Splitter (C6 Z06 Style) Finally Done & Installed, *NEW PICS*
  110. 2 Step Launch Control
  111. 98 C-5 Programer?
  112. Torque Converter sometimes fails to lockup. What to check? Help!
  113. rough ride problem, help please
  114. Looking for a tuner in Northern KY
  115. help me!need a tuner,tuner package,in mobile
  116. help me!need a tuner,tuner package,in mobile
  117. ELM OBD2 scanner, work on earlier cars?
  118. Looking for a tuner in thornwood New York
  119. Need help with part throttle torque convertor settings
  120. Trouble tuning, anyone have a setup like this?
  121. High LT trim causes?
  122. Is Diablo VIN locked or ?
  123. Best price on a Predator? (Post Tbyrne era)
  124. Need mechanic recomendation
  125. Sarasota Bradenton Tune Special!!!
  126. CHUCK CoW TUNING @ C5 C6 BASH - CORVETTE MUSEUM - BOWLING GREEN, KENTUCKY
  127. HPE Chuck Anders info.
  128. White Vapor, lots of codes
  129. P0300 Problem??
  130. Not running right after cam install
  131. Relocate MAF sensor
  132. How does a bad MAF sensor act
  133. EGR voltage for WB: <unsupported parameter>
  134. Got the lc1 unit with dynotune A/R guage.. reading is off
  135. LC1 Wideband Help ..
  136. Tuner program, what kind?
  137. Tach problem..need some help!!!
  138. Check engine light
  139. Can the 2nd Gear Lockout be programed for use when RAcing?
  140. My C5 didnt pass emissions!!!!! Please help!!!
  141. What is the Optimal Air Fuel Ratio?
  142. Just upgraded to MPVI Pro...
  143. ? About hypertech tuner
  144. How to get a good tune up job.
  145. Anyone of heard of:
  146. Save HPtuner program into Diablo ?
  147. Wideband power - cigarette lighter ?
  148. Atlanta Performance & Fabrication ????????
  149. Upgrade to LS1Edit 1.21 to 1.5?
  150. Help with passing Calif smog/Hydrocarbons
  151. efi live question?
  152. HP Tuners with STS Turbo ???
  153. Baseline Dyno Results, Need your input please.
  154. My clutch Issue. Need help. im unsure?
  155. changing gears
  156. Anyone have experience with DRM?
  157. 3.73s, A4....ideal torque converter lockup speeds?
  158. Inexpensive mail order tune?
  159. "Econo Tune"
  160. California tune vs. other states
  161. P0160 Bank2 Sensor2 Code with SES turned Off !!!
  162. had a tune after gear change, still getting p1870
  163. what is the cheapest route to doing your own tuning?
  164. couple of new efilive tuning questions....
  165. Need a tuner in central PA.
  166. What's better....
  167. New Supporting Vendor - Carbon Fiber Hydrographic Finishing
  168. Callin ECS
  169. p1514
  170. Please try and help sort this out
  171. Was my car lean?? Pics!!
  172. Tuner in Scottsdale???
  173. Fichtners Spring Special Is Back!
  174. Vararam & Tune
  175. P0410U - I know the horse is mush now.
  176. How many mods before tuning is beneficial?
  177. Vararam installed and Tuned
  178. SCT Xcalibrator
  179. Disabled EGR and still getting light and code."F body"
  180. Need Help Tuning a 98 with H/C
  181. Rumors about CT emissions...
  182. want to get a dyno tune in philly nj area
  183. HPT log file not reading knock
  184. spark knock on 98 LS1
  185. Can a tune be externally "stored" and partially or fully re-downloaded back to PCM?
  186. Electrical drain
  187. Exclusive photo's of the new home of The Vette Doctors...nice digs for sure
  188. Explain the "tuning" process...
  189. Custom Tune Stored In Ram Or Rom ?
  190. Jeff Creech is at it again!!! Carolina Auto Masters
  191. Diablo Predetor...help
  192. Help needed with Predator tuning
  193. South Carolina Tuners
  194. HP Tuners help is available!
  195. RevXtreme's New Shop!!!
  196. Help..misfire on one cylinder and tried everything
  197. Several codes P0300, P0443, P0101, P1637
  198. More praise for Diablo Sport and Predator
  199. Looking for a copy of HP Tuners for an 03. Anyone?
  200. Timing- advance or retard
  201. some tune questions
  202. HP tuner or LS1edit ???
  203. Burst knock
  204. Two types of Predators: what's the difference?
  205. Mail Order Tuning From Chuck CoW
  206. Best way to spend your Mod money......
  207. Recommendation - Gears - Reputable Shop - IVO VA
  208. Could to much fuel pressure cause miss?
  209. Any that can recommend a good tuner in SE Michigan?
  210. Safe Rev Limit
  211. Gulf Coast Tuner
  212. HP Tuner Help
  213. ***** St Jude Auction # 13...C5 / C6 Tune from RPM Motors Inc.****
  214. Power Enrichment Mode question.
  215. want to go faster
  216. Automatic Electronic Duel Climate Control
  217. code?
  218. missing bad all the time help
  219. Can a 1998 be tuned as well as a 2000?
  220. Rich Codes What the Heck?
  221. Rear O2s tuned out..do I still need sims?
  222. Buying HP Tuners ?'s
  223. ALDL (CAN) Bus Hacked?
  224. turn off air pump on 97 vette
  225. Jeremy Formato Tuning & Porting in S FL.3/20-22
  226. HorsePower House in Bowling Green, KY?
  227. Melrose Headers
  228. looking for a tuner in nashville area
  229. What tuners are planning to visit KY this year??
  230. FOB remote losing signal
  231. FOB remote losing signal
  232. P 0420 Code any solution???
  233. PCM...Code P0420
  234. Powder coated RevX Catch cans!!!!!
  235. dyno tuner in western ma or ct
  236. HELP! Can't write calibration due to VSS problem. Car is Immobilized!
  237. Where did mount your LC-1 wideband??
  238. Diablo : adjusting custom tune ??
  239. C-5 Targa Top
  240. HELP! P1631 code and VATS HELP!
  241. o2 sensor code 1153 won't go away???
  242. Xtreme Auto Dyno Memphis, Tn
  243. Service TCS...Engine Power Reduced...
  244. Dyno tune vs tune and onsite vs offsite?
  245. Tech II or similiar scanner
  246. Louisiana Checking In!!!
  247. Which Tuner to Use?? Northern IL.
  248. Air pump problems...
  249. tuner ? Procharger please look inside
  250. Looking for a good logging program
