View Full Version : C4 Forced Induction/Nitrous
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. PCV oil catch cans..,, any recommendations?
  2. PCV oil catch cans..,, any recommendations?
  3. C4 Intake U Pipe with Vortech BOV
  4. inside of my 93 lt1 after 5000 miles of supercharger
  5. IHI RHB52W Questions
  6. F/S: Oil Scavenge Pump
  7. Corvette Turbo with hot engine.
  8. Vette Doctors Performance New Years message
  9. Any forced induction ideas for around $1,000?
  10. Procharger set up
  11. Supercharger kit up for grabs! v-2 T-trim
  12. WTB: blowerworks setup
  13. procharger vs supercharger vs turbo
  14. turbo question
  15. turbo oil feed
  16. Supercharged motor build
  17. 1991 Callaway on the Auction Block...
  18. how many have supercharged a stock lt1 10:1 motor and how safe is it to do it?
  19. 1991 l98 and thinking about playin with nitrous
  20. Mufflers
  21. found on net (will this work?)
  22. LT1 nitrous plate?
  23. Turning on the juice
  24. How many miles on supercharger?
  25. Hyperyouwhatsit? pistons verses on boost
  26. thick cylinder head gasket possible
  27. Turbo 4 in a C4
  28. Oil catch can
  29. Dyno tuner in Oregon
  30. rear mount turbo general questions
  31. Not enough nitrous?
  32. Callaway TT MAP sensor location
  33. Forced Induction/Nitrous a sticky free zone?
  34. boost
  35. TPS..which wire?
  36. Window switch, where to set...?
  37. Taking off the supercharger questions
  38. looking for advice on a mild turbo build with stock injectors
  39. N20 jet flow ?
  40. Thinking I'm going to boost
  41. ***AUTOMETER Electric Boost Gauge Model 3376***
  42. Oil fill cap supercharged 1995 LT1 Corvette
  43. C4 Outlaw Drag car
  44. ProCharger build
  45. 3dyno charts: NA, 100 shot nitrous, 10 psi boost w/ meth..same car, same dyno
  46. Reinforced tranny is waiting for horse power
  47. dyno run results, p600b, blowerworks 8 rib bracket, meth/H2O injection, heads/cam LT1
  48. Sn2000?
  49. Helical Cut Gears where to get straight cut?
  50. Supercharger for 383
  51. Nitrous Stuff, Injectors, KB BAP, DRM Trans cooler, DRM Shocks, O2Alert, MORE!
  52. nitrous injector plate
  53. YSi on an LT1
  54. N2O and timing
  55. Wideband O2 question
  56. Finally put nitrous back on the car
  57. fuel rail fitting question
  58. A few basic questions concerning supercharging.
  59. C4 Superchargers
  60. supercharger location
  61. Procharger C4 Corvette Post your 1/4 Times
  62. Procharger L98 Cam Selection Help!
  63. Too much pressure
  64. @@@ St Jude Auction #76 Case of Royal Purple and a K&N Filter @@@
  65. Carlisle BPP Going after Business Specials
  66. Too low trap speed (down on hp) ?
  67. excellent discussion thread on 100% methanol vs. 50/50 methanol/water injection
  68. Blower cam
  69. 96 lt4
  70. Will need refills
  71. anybody have any experience with FI and c4 zr1 twin fuel pump sending unit?
  72. turbo c4 build almost done!
  73. For Sale: 4.25" 6 Rib Procharger Pulley(P1.D1 etc.)-(Pics)
  74. Twin turbo cars only!
  75. Throttle Body Recommendations for L98 Turbo Motor
  76. Does this run off the serpintine belt?
  77. No Boost??
  78. who's injectors for boosted L98?? opinions wanted please
  79. Turbo Question
  80. I thought electric superchargers were a joke
  81. 1985 supercharged
  82. Bolt-Ons + Tune
  83. Nitrous on Crossfire
  84. Procharged C4
  85. Need some advice.
  86. Cool video from lst night
  87. Does forced air really make a difference
  88. Paxton S/C question
  89. Putting all the answers in one place
  90. 785rwhp and 1137rwnm @ 16.5psi with "stock" heads.
  91. Dyno results
  92. E85 in a C4?
  93. Exhaust sizing - supercharged engines
  94. how do i go about putting a turbo on my 84 corvette?
  95. Possible to add HATCH break-light to an 84?
  96. Selling my Vortech V-1 supercharger
  97. Running better
  98. FPR - Fuel Pressure Regulator
  99. need some help with my s/c 95
  100. Vortech LTx Air Discharge Tube
  101. Race Fuel and Mix Fuel yourself Peeps - please help
  102. Retard boxes
  103. has anyone seen the may 2011 HOT ROD issue?
  104. Bolt on n2o kits
  105. Best C4 to buy for F/I setup
  106. Procharger intercooler
  107. Pulley sizes
  108. Types of NOS injection
  109. Force-Fed V6 C4
  110. more issues..
  111. PT 91.5 mm Turbo... FS
  112. L98 rear mount turbo setup?
  113. Supercharger plumbing and mass air
  114. Supply/demand or what?
  115. Blow-Off Valve
  116. Newly supercharged 2003 Z06!
  117. Intercooler help
  118. Who is running a D1 or F1 Procharger?
  119. Vortech supercharger help
  120. 1990 Calloway Sledgehammer - Problems
  121. Carrol supercharger bracket mods for sale...
  122. High rpm blower stroker motor questions..
  123. Dampener removal
  124. nitrious/supercharge help
  125. highest hp s/c c 4
  126. Empty N20 Bottle Safe?
  127. Vortech V-1 Serial #04342
  128. Anyone have the part number for LS9 oil squirters?
  129. Super Charger Vs Turbo?
  130. FS: Comp Cams Fi Cam
  131. need a dyno tuner for a 95 vette
  132. Start of Turbo Project
  133. Is Coated Mild Steel for turbo exhaust ok?
  134. I'm doing some research for a friend..
  135. Nitrous in On!
  136. Progressive PCM enriched dry nitrous update
  137. what clutch do you FI guys run?
  138. any reason not to run a high RPM solid-lifter screamer with forced induction?
  139. Roots blower 1985 c4
  140. FAQ page
  141. Winter Upgrades 2010....
  142. JET Technologies Super Charger...Can it work?
  143. Fastest stock B2K
  144. ac for intercooler???
  145. stuff for sale
  146. Looking for DFI GEN VII Tuner with dyno in Houston, TX
  147. max booost, stock lt
  148. Great Winter Project From RSD
  149. Stall Converter Help Choosing One
  150. 91 L-98 looking for a good setup to add hp
  151. FAST Classic B2B for sale!
  152. tune with a restrictor plate
  153. Sn2000 supercharger NEW for 900? Good deal?
  154. 115 mph traps on conservative set-up.
  155. C4 Supercharger kits
  156. Champion dyno devirginization 1000+ RWHP
  157. Tuning a 87 supercharged corvette
  158. Vented gas cap?
  159. airdam pieces for procharger intercooler
  160. Correct Spark plug , muffler and head gaskets for Supercharged 86
  161. l98 turbo?
  162. Which Blower.
  163. Selling my T-Trim
  164. CCW Drag Pack offset.
  165. Which N2O kit for '96 LT1?
  166. MSD 6 BTM to retard timing under boost. yay or nay?
  167. video of my blowerworks build c4.
  168. Turbo+carburetor noob here
  169. how much spark advance under boost?
  170. 1990 6 speed.has anyone used sts turbo
  171. Simple 89 Maf turbo question
  172. do i have dana 44?
  173. scantool/how to monitor knock question
  174. Fuel Source for N2O?
  175. to n02 or not to n02 that is the question
  176. need some ideas
  177. Intercooler question
  178. Any high HP C4's drving around on the street? (cooling system)
  179. Surging Off Throttle to 15 MPH
  180. Pump oil from low mounted turbo
  181. Single Turbo Pics Needed
  182. popping in exhaust
  183. is it poss to piece together a Nitrous kit?
  184. New Toy to Play With!!
  185. Finally broke into the 12's
  186. Do I have a good C4 candidate for a supercharger?
  187. gauge selection
  188. intake prep
  189. 10 second 94 on the block
  190. turbo charged with electric cut outs, anyone have?
  191. Turbocharger
  192. it's a C3...
  193. New to this end of the forum
  194. Magnacharger for Gen 1 SBC
  195. Wont Rev over 3000 rpm Procharger L98
  196. Minor Fuel System Change- Dual Walbro pumps
  197. any interest in vortech lt1 discharge tubes ?
  198. Turbo/SC with a MiniRam
  199. nitrous jet ???
  200. 421 ci LT1 nitrous motor article
  201. Fedup with my SR,going MR?
  202. really need help from turbo c4 guys
  203. whats the best size lt1 engine for forced induction?
  204. relocate your IAT, if you havent done so, if you are forced induction
  205. Need Help! Car Sputters when spraying.
  206. how much fuel do you need to take out with meth?
  207. Not a vette, but another supercharged car is now in my stable....
  208. with exhaust heat, how much hotter is the air charge from a turbo at 8 vs. SC@8psi
  209. Wide band A/f Gauges?
  210. twin turbo headers
  211. Backwards Alternator?
  212. my turb build
  213. injector size and fuel pump???
  214. How much can the stock MAF handle?
  215. F/s new hks super sqv bov black limited!!
  216. 90 Turbo vs 07 Z06
  217. Spark Plug Recommendation
  218. rear mount turbo 90???????????
  219. Mods for Powerdyne L98?
  220. 86 corvette putting on Sn92 Paxton Superchager?
  221. Turbo Kit for Sale in "For Sale" Section
  222. What are you guys doing for crank case evac?
  223. Upgraded Accel Gen 7 from 3.2 to 6.0
  224. supercharger for a 1996?
  225. Free installation... Raptor Turbo...
  226. MAF on LT1 Blow Through or Draw Through
  227. Anyone run a large fuel pump(aeromotive a1000, ect) on a stock fuel system
  228. Turbo kit where my AC was? '86
  229. FMIC vs Snorkel-Charger
  230. for sale complete lt1 wet nitrous setup
  231. Let's talk valvesprings and boost....
  232. does anyone have a water - air intercooler on there c4
  233. Forged or cast pistons?
  234. Trade 10lb bottle for 2 lb bottle of Nos!
  235. does it matter what plenum is used if you blow it?
  236. 144 blower on a 383 in a c4
  237. LTx_P600B_CCW
  238. Maf?
  239. super for lt1 work on a l98
  240. vortech
  241. vortech
  242. Going turbo.....
  243. lt1 engine balance question
  244. E85, PT91.5 mm , 1000 + setup
  245. Custom intercooler
  246. Trade 10lb bottle for 2 smaller 1lb bottles
  247. Help Turbo camshafts ??
  248. Can OPTISPARKS take a lot of boost???
  249. electric supercharger?
  250. 84 vette Cross fire Nitrous
