- Procharger questions
- MiniThesis: Sequential/Twincharging Theories and Possible Practice Take 2
- (2ND try) Any "real" benifit from spayed main caps on an LT1?
- dry or wet nitrous?
- What is with the forum server...? SHEESH
- need fog lights
- Intake manifold gasket on LTx motor
- what is this i hear about nitrous leaking into intake?
- Nitrous Necessities.....?
- Nitrous Install started
- FI Heads/Cam Recomendation
- Aftermarket radiators
- Anyone replace the vortech inlet pipe completely?
- Question re: John Meany's Big Stuff3
- belt slip maybe
- turbovette update pics fuel system :D
- Vortech LT1 balancer
- Twin Turbo Progress Part IV
- 2 ecu's to 1989?
- turbo update pics 11-9-05 :)
- compression ratio? good for boost?
- what is on the side of the intake manifold?
- gym bag?
- Supercharging a C4
- Post Your Centrifugal Blown Dyno Sheets
- FJO mini controller
- just got into the 10's 383/vortech
- March Power & Amp Pulleys & Superchargers
- What caused it to this?
- waterneck, oil return pics T74GTS build
- twin turbo's 4 sale
- New cam is a nice addition on my single system.
- Where Did all the horsies go?????
- Clearancing the vortech inlet tube for the t trim blower
- How much does it run to have a vortech (satin finish) polished up
- Which purge kit to buy?
- Cost of SC kits?
- lt1 internals for supercharger
- Stock LT4s runnin spray??
- Supercharging an L98
- Twin turbo with L98 type block
- 6 rib to 8 rib
- Need packard connectors for wiring harness....
- lowering the boost for a Vorthech
- Got No2
- Vortech Supercharged 1994 C4 tuning help
- NOS + Procharger Opinions
- NOS advice
- turbo update pics 10-25-05 :)
- upping boost
- ATI D-1 Procharger and Camber Brace
- Need a chip for a supercharger setup
- Can you convert curved discharge to straight?
- Engine Management System
- Performance Injectors
- ZEX dry nitrous kit
- Serpentine Belt Position!!
- 42 SVO's for sale perfect for boost.
- a few ?'s for you guy's
- How come my power curve doesn't keep climbing?
- Alky injection AFR's and o2 readings
- best guages to get with supercharger
- Any benefit from water injection?
- Anyone with a Paxton SN2000?
- What is a slightly used Paxton/Carroll set up worth??
- 6L80 and 6L90 auto trans- is this our solution to or f/i torque issues?
- What is going on?
- Oiling a Turbo
- will a supercharger help
- alky kit?
- PCV Systems-FI
- syclone intercooler
- How do I get more boost?
- Heavy equipment turbo identification?
- water injection vs air/air intercooler?
- procharger parts needed.....
- C4 on a little NAAWWZZZ
- oil cooler question?
- need duct pipe...p600b to throttlebody (no intercooler)
- O-ringing heads....
- pickin turbo/s.. thought this might help
- 30 lbs SVO injectors big enough?
- Finally broke the 500 hp barrier on datamaster...
- fuel pressure regulator question
- S-Trim oil requirements
- racetronixs
- Lt-1 Turbo Kit
- lt1 block capabilities
- Forced Induction - Carburetor Style
- 30 lb injector w/o reflash?
- ne one running a 200 shot or higher?
- Just ordered 8 rib from ASP, have a few questions
- Please post pics of Nitrous set ups
- intercooler pics, please post
- best place to buy a fuel pump
- l98 electric waterpump
- Not a vette, but a late model 9 second daily driver
- vortech install pics?
- ATI ? please help
- Hi-Flow fuel rails
- Attention to those considering turbo..
- Oh no look, IT's Godzilla!!!!
- Head Gasket
- lt4 module
- Just ordered my big injector
- Blower and or turbo kit purchase source?
- hello everyone
- "Centrifugal supercharger" Question...
- Zex Nitrous
- Parts for sale in C4 Parts Section
- fuel pump question
- Supercharging an LT4?
- bad news for vortech
- vortech question
- very quite here lately
- scan tools?
- supercharger install question
- spark plug gap smashed under high boost and rpm?
- Spark Plug Gap Tuning
- Interesting boost observation- s trim
- Info on NOS NOSzle's needed
- Turbo front end? pic inside
- Procharger Question
- 90 Procharger Setup
- Question regarding ATI Superchargers
- Thoughts on NGK
- MSD BTM needed with FAST?
- N2O w/ SuperRam info needed
- Supercharged Twin Turbo Subi STI
- Engine Gurus, I'm Stumped
- friday was track day thanks greg
- Superramed engine with SC
- L98 Supercharger-Ignition?
- Plug Gap?
- found the problem!
- 1990 what nitrous setup
- timing for 383 with nos
- Turbo LT1 383 or 350?
- 8 rib project finished
- how long will my LT4 engine last on a 75 shot used once every couple of days on a DD
- Spam : '94 Supercarged, F.A.S.T, 4L65 Upgraded, Delteq car about to up for sale
- whats a reliable and good 75 shot for a stock LT4
- How do you know when your head unit needs servicing?
- New blower mods
- attn: Crazyturbo
- 92 sc ati help ; )
- Total seal piston rings
- TonyDee64 Hits The Dyno at FLP
- ignition systems for NOS?
- LT1 / LT4 PCV Valve
- Accel DFI GEN VII
- whats better? ignition wise
- hey Mo
- dyno at carlisle
- Turned up the boost wow.
- intercooler air/air or air/water?
- Autometer Broken?
- biggest intercooler on C4
- What polish do you use on your supercharger and tubing?
- what rims are these?
- supercharger setup
- ATI procharger kit (L98)
- Looking for a Paxton SN Supercharger installation manual for L98s - anyone?
- supercharged with a stock shortblock read this
- LT1 Pistons?
- Bruce, the mega is ready.
- which Spark plugs and what gap?
- Datamaster questions....
- Water injection?
- 224/236 on a 116 LSA?
- Interesting day on the dyno and alcohol injection
- Seeking 98/99 Red 65000 miles or less
- Removing FMU and adding injectors questions
- How much Nitrous I get run thou my 383 set up?
- Should I get it (supercharger question)?
- Attn: TJWong
- Idea for budget DFI, opinions please...
- Stand-alone selection and the LT1: Your opinionis wanted.
- LTx supercharger kit for LESS
- 11´s possible??
- boost pressure
- goes dead at idle too cold of plugs?
- How much boost can a -31cc piston take??
- How big a shot will a 255LPH support???
- Can I put supercharger or twin turbo on my 383 engine set up? – need advice!
- Will stock MAP read above 14.7psi?
- what tranny for turbo?
- [Pics] My Nitrous Install
- Who makes the best SC kit for LT1's?
- rant--Any adults from Orlando w/fast cars?
- Friday is the day
- How are you controling timing with a turbo?
- CO2 spray to intercooler???
- Man, If I turned my headers around
- How to get cold air to blower????
- New Pictures (Turbo Setup) :D
- No-nos
- Experiences w/ Greddy aux fuel ctrlr, Fasttrackperformance.com, or SpeedPro PCM, w/in
- Acceptable Intake Temp
- Nitrous Mastermind
- Do I Have to Stroke my LT1 to Add a S/C?
- How do the C4's handle the nitrous ???
- Brand new Vortech SQ-upgrade time :-D
- Nitrous Purge Solenoid
- Blower or turbo for early C4
- Attn. mnVette
- Spark Pugs for Procharger
- to greg at blowerworks
- Are the PT-52 just like 60-1's with T3 turbines?
- what would a PT-52 turbo be equal too?
- Quick tuning tips
- Turbo for sale
- L98 tt
- Blowerworks or somebody in the S/C biz...
- Thanks to Blowerworks I'm taking the plunge :)
- Intercooler thickness vs. radiator airflow
- Callaway Twin Turbo Grand Sport
- callaway TT
- Attn. Bruce/Rick, I have a megasquirt question
- The Disease Continues... also parts 4 sale
- Need help with transmission selection
- nitrous help
- MOTOR is IN!
- temperature problems
- mmvette, Icevette
- it nasty Twin turbo destruction
- F1R and F2
- NOS to hot
- what sprak plugs?
- new gt42 for sale on ebay if anyone's interested
- Finally Mega Squirt is here
- Power Loss...S/C LT1....
- Free accessories with Nitrous Express kit purchase!
- Bought my drysump pump
- blower discharge temps with alky injection
- Nitrous Update II
- FAST Tuning question
- where is the serial port so that I can connect my akm cable?
- serpentine belt driving me CRAZY!!!!
- Can someone explain alky injection? (89A4)
- FULL Nitrous Report :) :D
- Is tts datamaster the only way to monitor knock?
- Putting the sauce on for the first time tomorrow!
- Got Fuel Pressure Issues
- noob ?s
- LT1 Nitrous Solenoid Mounting
- Blown Head Gasket My ARSE!!!
- 1984 Help
