- Lets see your Nitrous setups!
- dialed the tune in enough to finally get her through to redline
- Zex N2O Kit
- Zex Nitrous kit
- Banks Twin Turbo
- got the tune in.. car is friggin fast!!
- A pillar guages
- DFI/FAST/Big Stuffs
- locked PCM
- Fuel Pump Configuration
- #60 injectors for NA 383 ???????
- Gapless rings & Forced Induction ??
- Old paxton unit owners,question for you!
- 3" Collectors 2 1/2" cat back
- Fuel Pump for NO2
- they have a turbo kit for C4..
- First drive after blower install!!!
- This Turbo System Design Sounds Nice!
- c4 4l80e trans installed
- which garretts
- snapped soem pics of the blower kit installed... :D
- Gen 7 HELP
- Glens Car is ALIVE!
- Naturally aspirated no more!!!!!!
- wiring MSD 6a.. brainfart..
- Injector size?
- Would A 50 (dry) Shot Kill a Stock engine
- Supercharger Owners, lend me your ears...
- waterpump fitting for procharger?.. pics?
- well i did it
- turbo question
- nitrous kit?
- hi-compression with turbo
- 92-96 LT1/4 Vortech SC Kit
- Direct Port Nitrous and S'Ram
- pROCHARGER QUESTION
- ATI Procharger Pros and Cons
- I'm all tingally ......
- major set back tonight
- 427 tt sbc on dyno
- Nitrous Direct-Direct Port & SuperRam
- water on intercooler mod?
- Procharger front mount IC guys please chime in ...
- what size exhaust pipes?
- Accel Gen 7 Fast Track Harness for sale.....
- Intake question
- Not that I want to but..
- Help 1985 supercharger wanted
- Went for a ride in a procharged 355cu LT4 last night.
- crank case evac system
- ait to air vs: gaseous intercooling
- DYNO TIME/TUNING. getting there but small problem to fix....
- WTB...Procharger kit/parts
- Procharger pressure release "use"
- paxton sn89 boost?
- D1 owners chime in
- My new ride is a supercharged addition
- Maggie Blowers for SBC's and LT1's
- fuel pump issues
- timing retard for boosted cars
- the adapter is out.. :D but....
- Greg or others.. ATI balancer install help..
- I want to supercharge
- L98 Vs LT1
- SC vs. Rear Mounted Turbo?
- Do I need more fuel pump?
- Build recommendations?
- Please post your C-4 Turbo pics
- MAF and Boost???
- Garrett M27 ID
- ATI plumbing
- torque converter
- Tuner for 87 Corvette with Powerdyne Supercharger
- Just bought a blower
- 8 rib drive for procharger????
- Got My Fjo Controller!!!!
- Tony's New Homemade Headers
- LT-1 rpm question
- LT-1 cam question
- P1-SC install instructions... help
- Logging Software
- ** Huge News ** Hot New Product!!
- Turbines vs Turbos
- Best retrq on AFR cyl heads - 12 psi
- Best Twin Kits ... for the C4 ?
- Fuel Press Sending Unit Location - L98
- Probably not, but maybe a turbo kit for a C4?
- Xtreme Motorsports---DYNO DAY---Results are in
- What plugs Ya running(Nitrous)...
- HP/TQ Estimate... Anyone similar to this setup?
- Solid roller lifters vs Knock sensor?
- what can a 85 4+3 take?
- supercharger question 87 Vette
- turbo kit on ebay!!!
- Machined Lt1 Intake Manifold
- WTB: Tuned Port Nitrous Plate
- Nitrous Question
- Vortech question
- Turbo Cam?
- AFPR Boost Sensing?
- NO2 Limit
- WTB Procharger
- mods
- LT1 block
- So what can I expect to get out of a procharger?
- What and Where to put the intercooler
- NOS kit #05151nos wet system
- Dyno Tune nitrous #610 dry vs. wet ?
- Lets See Some Pics Of Your C4's With Blowers
- Timing retard box, sparks??
- How to install an ATI 8+6rib crank pulley with a procharger sc
- Window switch with zexs kit
- Video Clip of SC 240Z
- Dyno Tuning
- A Vortech kit is in the classifieds...
- N2O blowdown tube
- High Pressure Tubing for Water Injection?
- Who has used this S/C bracket kit from these guys Tempo Design Inc - (QuickGlass?)
- SHURflo pump?
- Nitrous- how much for intsall? and all together
- how much boost can a maf take?
- how do you build a bullet proof LT4 to take a 2 stg 200shot (125+75)
- where can I find?
- Rear mount single turbo for c4 ??
- Vids of Water/Alc injection in action?
- 'DOH' MAT sensor not plugged in.
- Anyone use a blow off on a paxton?
- Who Wants Procharger Oil Seals?
- Tuning on Glens (GM_96LT4) engine is going well
- McMasters nozzles for my meth injection
- FMU question?
- Where to mount the MAF on a Custom supercharger install.
- books on blowers
- Supercharger Bracket
- what timing set and chain?
- Et time?
- compression ratios and nitrous
- remote MAT location on SD setup
- A compression ratio question
- Anyone have a extra vortech bracket and discharge tube?
- Twin Turbo project in the shop this week
- From the ZR1 section
- alcohol injection this time for real
- Wideband to get an AF ratio reading?
- ** Hot Nitrous News!! ***
- What size injector would you run?
- What other choice I have?
- It's ALIVE.... !!!!
- Vortech tensioner assembly(ford part)
- Can Anyone help? Sensor problem
- what happen to TonyDee this day
- Basic Simple Question
- Mini Ram, Super Ram or Stelth Ram
- Help with zexs wet kit!!!!!!
- here is another turbo destruction
- Happy New Years Booster
- Vortech T trim boost levels/pulley combos
- ASP vs Vortech Pullies
- Who makes a TPI supercharger?
- New ignition system
- Super Ram Question for experts!
- speedway corvettes turbo headers??
- Dual Gauge Pod - Boost Readout and ??
- where to mount DFI box...hmmm...?
- Supercharge with SuperRam or TPI tubes
- New Intake Coming for Yellow
- Twin turbo Banks system
- merry christmas to all you boost guys
- West Coast F/I cruise in So Cal....
- Header coatings?
- Crank Reference Angle setup issue on the FAST XFI.
- weird fuel trims ~long~
- supercharged, bored, and stroked LTx motors, step inside please
- Options To Using An FMU?
- '90 coupe, fast ET's back in '92
- lt1 396 corvette Supercharged
- Engine tuning w/ Turbo
- Lets talk injectors...
- Looking for a new Turbo??
- Vortech balancer/crank pulley removal help.
- stock heads for turbo?
- I´ve missed some stuff! N2O problems
- Fuel Pressure Problem
- Boosting 1984 Corvette?
- 75lbs delphi injectors on ebay
- 8 rib on ebay
- Need some advice.
- NEED C4 Air/Air Intercooler
- Gauge Brand Recommendations
- Happy Holidays!!!
- Anyone need a polished Vortech SQ Trim Supercharger
- Barry Grant with chip?
- help find tt turbo kit for 90 "L98"
- High RWTQ clutch opinions (did search)
- where to hide the bottle
- update pics 12-11-2005 turbo....
- MOre Pictures LT4 396
- advice on Turbo for my motor
- Holset Turbos-Questions??
- Rick here is your old turbo compressor map
- Cloyes Timing Chain sets
- Who Wants free Car?
- Mo Power LT4 396 Stroker-Update
- Ecm
- Questions for nitrous direct and or others about progressive controllers.
- Ecm
- procharger and loss of boost
- Vortech ... running very rich it stinks
- ** Hot New Product Release
- supercharger noob
- need contact info for purchasing a LTCC kit!
- 1984 Single Turbo by JoBy
- Repair damaged engine Supercharger C4 LT1 1992
- Preliminary Vortech 4" inlet tube info...
- Fantasy NOS build (help!)
- Rear mount turbo?
- supercharger
- MO Power LT4 396 Forged Stroker
- Twin Turbo LT pic???
- New Nitrous Vendor!!!!!!!!!!!!!!!
- lt4 hot cam conversion and n20....
- Best Tranny with a turbo?
- Embarking on a single turbo project
- spool em
- Boring Sunday
- Tuning for supercharger with modified L98.
- Friday Night's Runs - After Thoughts
- Nitrous Poll
- IC Project Moving Along
- GS vs Z06: Future project car?
- whats inside the heater box? any room for trimming?
- Stainless turbo manifold update pics :D
- My talk with Procharger....lump it.
- Aftermarket DFI in a 1990?
- video motivation.. its a viper, but its bad ass!
- To Spray or Not to Spray
- turbo update progress,,
- Block filler?
- turbofueler or aftermarket FMU?
- Did a few wot run tonight
- more boost questions
- Questions for Calloway (B2K) Modifiers
- FAST EFI With wide band
- Ate a Belt: Fairly Expensive; Lessons Learned
- hidden nitrous on 95 ?
- Nitrous install part 1
- What hp/tq does your boosted car put out and what does it run in the 1/8 and 1/4?
- TURBO tech: center cartriges
- Interesting new intercoolers for the space challenged (us)
- Procharger questions
