- Where's the best place to get a P-600B bracket?
- Will it fit?
- Anyone see the new directional blowers/pullies
- Preperations to install supercharger
- anyone have a supercharged LT4?
- Compression ratio on a built 383 LT1 w/ NOS
- Juicing the stock L98?
- stock L98
- BMN window switch
- Turbo Kit
- Newbie - What Plugs to Run?
- Water/ Alki Jet sizes
- Please reccomend a nitrous kit for me
- 20" rims on a C4? Pics!!!
- Anyone running an intercooler on a Blowerworks kit?
- double turbo corvette c4
- o-ringing the block?
- Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
- Upper Radiator Hose Recomendations with SC pipes in the way
- Can I add a SC or turbo
- Where have all the Callaways gone?
- opinions on this shortblock
- Is this a good Nitrous set up ?
- Which Gauges Should I USE?
- Pondering new set up..comments?
- vortec
- Off to the world of naturally aspirated...
- what kind of half shafts to run?
- My new cool-air blower intake
- Blowerworks crank pulley install help
- big shots of nitrous with high commpression
- Anyone use the blowerworks superfueler as a stand alone alky injection setup?
- Double check me please [supercharger install]
- Timing retard
- Fuel Pump Questions- Bosch 044 and walbro in tank
- Best SINGLEPLANE intake manifold ?
- exhaust pipe size
- Forced induction LT4s
- FI or nitrous crossfire?
- 60 + injectors does nay one have some?
- nitrous hook-up question
- brakes upgrade
- fuel pump wiring
- Recommend Some Injectors
- Vette Guys ,please Post Pic's Of Superchagers
- Can't find a LT1 Tuner!
- Best forced induction kit
- Even more4 money!!!!!!!!!!!!turbo
- Acceleration
- Considering a few engine mods. Opinions?
- Spark Plug Wire Recommendation [L98]
- looking for Holley Stealth Ram/950 commander computer Guru
- Can you tell me if my setup makes correct RWHP??
- A little help with a BIG problem. PLEASE!
- Nitrous Setup Pics
- Nitrous Dyno Numbers and Track Times?
- TBYRNE Motorsports Year End Nitrous Sale!
- Smokeshow's New Cog Drive
- Nitrous
- 85 with lt1 intake conversion
- cutting on engine mounts? (custom stuff)
- Racelogic traction controll with a supercharged engine?
- AFR elim heads recall!!!!
- Effect of Boost on Peak TQ/HP
- Oil pump
- Boost, big power and failed CAT
- you guys see this?
- supercharger with stock ECM
- what road would you guys go...
- will 90 prochargesetup fit in an 85?
- electrick vacuum pump, relieve crankcase pressure?
- electric vacum pump to relieve crankcase pressure?
- Atlanta Emissions
- paxton supercharger
- Speaking of Typhon engines in Corvettes
- I guess you CAN convert a B&M to EFI
- Any delteq ueser out there have N2O?
- FI Disp limits in SM2 may be lifted
- Where do you run your N2O purge line?
- Man, removing the balancer is the most annoying thing I've had the pleasure of doing.
- I might try this Nitrous "stuff".
- Head Flow, Valve Size and Boost.
- NOS plate behind bbk on lt1
- post pics of super/turbo charged engines
- Anyone running the denso iridium plugs?
- Long tube headers for a 85?
- Nitro Junkies Come On In!!!!
- Close the Gap?
- methanol injection or intercooler ?
- Dry Sump Pump for Crankcase & Rear Turbos?
- Boost gauge install question.
- Why N2O instead of air?
- Any Input Appreciated
- selling my turbo hot parts..
- Selling my extra 3" Vortec LT-1 pulley
- Superram & Nitrous
- Help Me Decide:Carroll or Procharger
- WTB--10 lb used Nitrous Bottles
- L98 RPM considerations
- Why NO2 instead of O2
- 383 with ProCharger superchager
- 1st pass on the juice
- Anyone found compressor maps for the Powerdyne units?
- nos 90 L98
- Getting more Boost; Larger SCs
- Gotta check it out
- Anyone ever notch their hood rails?
- New Heads for FI.... lets talk
- Any tips or tricks?
- Nitrous questions
- Centerforce Clutch!
- L98 Blower Clearing FX3 Shock Actuators?
- Vortech volute questions with carroll bracket
- 88GT & 95 Vette
- Need NOS jet size help
- intercooler location
- Procharger Pulleys
- 10 second convertible s/c show car
- Better Nitrous Kit for TPI intake: Nozzle or Plate?
- Is compression too high for a S/C?
- Don't Laugh, ProCharger C2 For L98?
- First dyno results - feedback welcome.
- Carroll supercharger brackt- AC line questions
- Bank Fire with big injector questions
- Fuel Pressure under boost
- It Has Arrived.... new turbo... :)
- STOCK L98 HEADS - possible power level ?
- Impressions with dual in tank pumps- fuel system questions
- Started the Vortech YSI/Carroll bracket changeover from t trim/vortech bracket
- Talk me out of SC'ing
- N2O opinions
- Some Interesting Pics
- The most Bastardized Vette ever!
- F1A on LTx Engine
- F1A on LTx Engine
- Removing factory undercoating.
- Got a ysi trim today with the carroll bracketry
- Can I see pics of your fmic's?
- Where to buy Nitrous Supply
- C4 won't stay on steep driveway!
- trick looking pulleys
- What winter projects do you guys have this year?
- LT1 sparkplugs for nitrous
- 95 red blown vette rides again.. finally..
- Paging the Nitrous Guru's
- detonation question/LT4 knock module
- Turbo Vette at the Track
- Vortech tensioner problem- stripped bolt
- IAT?? How much boost can she take???
- Modified vortech inlet pics
- 15+ psi with a 6 rib Factory Serpentine
- Found a YS trim on ebay...(questions for TJ or Greg)
- Thinking about staggering turbo sizes
- What is the highest flowing exhaust for an L98?
- sparks plugs
- Just ordered an RPM Transmission!!!
- Accel SR and paxton SC,wich injectors size???
- Nitrous plugs
- Anyone on here use the carrol vortech lt1 bracket?
- A couple supercharger questions
- Vats ignition cylinder replacement
- Best scavenge pump for turbo
- nitrous
- Vacuum pump??
- Post Pics of Alcohol Injection???
- Fastest Street Legal Car?
- shortblock setups
- Any feedback on MSD opti ?
- More weird stuff from ebay....
- What's wrong with this?
- Sintered Brass Air Discharge on BV?
- Anyone have a ysi yet?
- Which brand N2O does everyone use?
- Anyone running the NS brand N2O system?
- Posting a FAST Datalog???
- Cog Crank Pullies for Vortech LTX setups
- Vortech Y/YS Leaking. Where can I find a seal?
- Twin superchargers?
- Interesting vortech s trim observations
- nitrous install ?
- Still having issues with the s/c.....NEED HELP
- Nitrous Question???
- Lifter Valley Girdle on SBC??
- Is anyone else running the gm hot cam and boost?
- Procharger owners in here!
- advantages to bigger N20 bottles?
- www.corvettett.com
- Help on fuel LT1 system upgrades
- Spare Vortech oil feed fitting?
- Remote oil reservoir for supercharger???
- New 2 D Forum Need Help
- fouling plugs
- MSD OptiSpark with Accel/DFI computer
- Attn: lcvette
- Have you guys seen this page?
- A4 Transmission Running Hot after Vortech Install
- 300M billet axles for vette???
- "How bad is it on a engine to drive it running rich?"
- Who Makes a Bracket System for a Vortech YS L98 Supercharger
- Need Tech Help - BTF, TJ, etc
- V3 R trim vs. V1 T trim
- Fuel cell pics
- Any rear mounted Turbo C4's ?
- Looking for info to twin turbo kit for 94 LT1
- Can i go above a 75 shot?
- Help!! Turbo Guys Please Step In
- what's the purpose of a bov
- Dry or wet??
- Thinking about putting an Eaton in my LT1
- Anyone have an extra s, t or jt trim vortech sitting around?
- Gaseous Intercooling vs Air to Air
- Wasted spark-all good. Shook her down tonight
- DIY E-Boost controller
- Somewhere to find superchargers
- Intro and pcv question.
- Powerdyne crap or good,L98 advice
- sn89
- New Ecu 1227749 w, low Z injectors.. BIG PROBLEMS!
- Vortech L-98 bracket...Anyone have one?
- Underhood Heat - ProCharger P600B
- Who emailed me about a VSQ blower?
- Turbo 383...
- 58mm Holley with built in NOS nozzle?
- Head gasket for supercharger
- S-trim?
- Houston, we have a problem!!!
- p600b quick questions...please chim in
- Brief shakedown last night
- Has anyone built a C4 fuel cell yet?
- 383 Stoker
- FMU?....Bigger injectors?
- Installation now complete....finally!
- Anyone use a Zex dry kit?
- Turbo Vette Update
- T trim over a Ball Drive on a TPI
- Pics as promised, more to come
- TBI and Nitrous???
- FMU question
- C3 TV81 Rear Mount with Questions...
- what plugs and gap on my supercharged Vette
- Boost Changes Coming
- ENOUGH.....Procharger coming out!!!
- Install Help: MSD 8969 Digital RPM Window Switch
- Out of curiosity
- Anyone building cog drives for C4 blowers yet?
- Very strange problem.....
- Vortech YSI trim
- ATI harmonic balancer question.
- Gaseous intercooling
