View Full Version : C4 Forced Induction/Nitrous
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. work stock block or go new
  2. work stock block or go new
  3. Oil Leak..Too much internal pressure????
  4. Limiting supercharger boost levels
  5. What brand and weight oil, with charger????
  6. SC'd Decals
  7. Help me pick...
  8. MAF location?
  9. Pics: ready for dyno on Friday
  10. Can you use a Camaro Turbo kit?
  11. Spark plug gap and heat range????
  12. Cam centerline choice with nitrous
  13. is this just an electronic fmu? (technology experts)
  14. Procharger has its first "Procharger Bracket Challenge"
  15. ignition retard, & FMU to band-aid programming issues? 92'-93' specific
  16. My New Nitrous System
  17. Ed Wright chip?????
  18. witch ingnitoin box is better crane hi- 6trc or msd btm
  19. Super Ram runner to plenum bolt solution
  20. 1985 supercharger bracket?
  21. LSx conversion for LTx based C4s
  22. NOS System for LT1
  23. IGNITION COIL QUESTION 6800rpm lt1 procharged 383
  24. 600b bracket for lt-1
  25. Turbo or Super charger kit made for C4 ?
  26. 95 Pro-Charger p-600 B
  27. Where are my manners; I should have it shared it here first !
  28. Ditch the Procharger Intercooler????
  29. Stock LT1 w/ 8psi and injector size
  30. Vortech V3 self contained superchargers announced
  31. looking to buy a water/meth injection kit...questions
  32. D-1-SC pulley size?
  33. Spray on Speed-Pro Hyper Pistons?
  34. Super charger
  35. Vortech MSD Question
  36. Intercooler or Meth Injection?
  37. 93' tuning for boost with stock computer, out of luck? Please help...
  38. Callaway Twin Turbo BIN
  39. Orderd a New Turbo for the New Project
  40. Timing setting for SC
  41. Blowoff with nitrous use.
  42. Attn: lcvette - Turbo Kit
  43. 383 and a Procharger D1SC
  44. 8 rib A/C pulley made
  45. Supercharging experts? heads/cams needed?
  46. maf and blow off valve
  47. AIS Fender/Firewall Mount Water Methanol Injection Special - See Post For Detail
  48. F/S: D-1sc procharger
  49. Annoying fuel pump noise
  50. new turbo technologie for high CR
  51. P600B for 85-91
  52. Turbo System For Sale
  53. C4 with a Supra Engine
  54. 84 crossfire
  55. Getting ready for tune (dyno), comments/suggestions on setup?
  56. Vaccum lines and P600B
  57. project AWD daily Drivewr went awry somewhere..lol
  58. lt1 nitrous retard
  59. n2o system pics with carb
  60. Is anyone running a supercharger w/ stock L98 ECM?
  61. Jacobs Nitrous Mastermind
  62. TNT nitrous
  63. dyno but low numbers
  64. D-1-SC install on a 95
  65. D1-SC on a stock motor?
  66. AIS Rear Trunk Mount Water Methanol Injection Group Buy - Ends Feb. 29th
  67. Plugs and SC set up
  68. Procharger P600B advice
  69. nelson playing with a callaway...
  70. AFR heads and spark plugs
  71. Nitrous and hyperutectic pistons
  72. rebuilding one of my motors
  73. Who has the "supernatural" powerdyne kit?
  74. 1988 Procharged L98
  75. 383 n2o cranck case venting need some advice
  76. Selling Out
  77. "Kill The Bottom End???"
  78. Attn: Brand-X
  79. supercharged iroc-z
  80. Fuel Pump Location
  81. Fuel Pump behind the plate - Install questions
  82. Powerdyne alternator relocation question
  83. procharger d1r rebuild help
  84. F/S ZEX 10 lbs. purple nitrous bottle cheap
  85. Anyone have a link or know the flow data on siemens deka 3103's?
  86. No D1SC bracket for l-98's
  87. is this a good turbo
  88. Tuning the supercharged vette- fuel pressure doesn't rise under boost
  89. D1sc clocking
  90. dual fuel pump pics or how to?
  91. Blow-through MAF: New idea
  92. Nitrous on 11:1 Compression
  93. Best place to BUY FAST XFI computer for tuning???
  94. Looking for Paxton for 86
  95. New NX NOS electric bottle pressure gauge
  96. Going to buy a Vortech, What else do I need?
  97. Reichard and OEM Pulleys for the Magnacharger
  98. 93 LT1 383 Turbo Motor runnign Too lean above 6 Psi. Help!!! Cannot fix this...
  99. Is this guy legit?
  100. Need help building a motor for FI
  101. My 85
  102. Clueless on boost/vacuum readings
  103. Can someone explain this
  104. Procharger #'s
  105. do i need a new Bypass valve?
  106. do you get a vacuum with boost?
  107. do you get a vacuum with boost?
  108. STS update?
  109. FMU or AFPR?
  110. Which Block and Heads?
  111. Is a charger right for me?
  112. 12 rib pulley kit for L98 and Procharger
  113. 12 rib pulley kit for L98 and Procharger
  114. Jet Technologies supercharger
  115. procharger catalog
  116. Build-up of L98 ???'s
  117. Garage Pics
  118. stock fuel system enough?
  119. help me corvette 85 nitrous
  120. Just a Test
  121. Best BOV for the $$$
  122. ATI ProCharger price hike coming in February!!!
  123. SPA gauge install question
  124. Higher boost options for powerdyne guys
  125. A/C pulley
  126. Paging SuperL98!!
  127. Road race twin turbo C4
  128. Turbo Exhaust Size Info
  129. Any Lt1 Turbos Out There??? Videos Post Here!!!!
  130. NOS System for LT1
  131. Procharger p600b
  132. DIY-EFI.org gone???
  133. My new purge kit!
  134. New pulley bracket for better crank belt wrap
  135. just a thought
  136. 383 stroker boost question
  137. anybody have a d1 bracket for drivers side?
  138. nitrous oxide
  139. Procharger questions for stock bottom end.
  140. Throttle Body Suggestions?
  141. loose hub
  142. Paxton SN2000 from 89 Camaro
  143. Help me with a new FI engine setup
  144. Intake Setup For FI
  145. Check out the intercooler on the new ZR1
  146. lt-1 procharger vs l-98 procharger
  147. Recommendations for Forged Short Block Builder
  148. Do I need a new ignition system?
  149. Manual switch for N2O
  150. Would this kit work?
  151. Edelbrock's new blower crate engine
  152. STS TURBO out yet for LT1 engines...Vettes and F-Bodies w/CARB #???
  153. What should FP be?
  154. Kinda Goofy Question
  155. super chager plugs
  156. Bottle heater AND blanket??
  157. after market efi ecm tuner
  158. Turbo system build question.....
  159. Why build, when you can buy??
  160. TPS Nitrous Switch vs. Window Switch
  161. WOT Nitrous Switch
  162. Vortech Supercharger Discounts PLUS A $250.00 Rebate!!!
  163. L98 to LT1 for Powerdyne install, Want to make it work!
  164. Using both nitrous and supercharger at the same time
  165. Vortech kit tuning
  166. Good supercharger & turbo article in MM&FF
  167. C4 Rear Mount Turbo in Vette Magazine
  168. Single turbo on a C4 with a ZZ383 questions
  169. turbo friction
  170. PCV valve
  171. intake/ ram air help
  172. Maryland Nitrous Laws?
  173. How much horse power is enough?
  174. I-charger (Twin Screw)
  175. hyperutectic pistons+nitrous?
  176. Supercharger Help Needed
  177. New Turbo Setup
  178. Relocating the Procharger
  179. very impressed with the blower works web site
  180. what size headers are you guys using
  181. Finally took the plunge
  182. 10:1 Compression
  183. basic question on boost and choices
  184. Venting Crankcase Question
  185. Belt slippage! GRRRR! How to prevent it?
  186. Pulley removal...How to
  187. ever heard of them
  188. Chevy Small block Twin Turbo Kit
  189. Looking for input on a S/C on a fully built 383 LT4
  190. CFI + NOS = Good/Bad??
  191. Supercharger on stock compression
  192. NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
  193. (2)Garret GT 4294 (70mm ) Turbos 4-sale
  194. adding a supercharger down the road...?
  195. 2008 ProCharger calendar, we have a C5 in there!
  196. ATI ProCharger Sale at Exotic Performance Plus!
  197. Procharging a 92
  198. An alcohol spray on the out side of an inter cooler?
  199. Questions About Water Methanol Alcohol Injection - Post Them Here
  200. Please post pix of your procharger system
  201. WTF I have a 377? What Gasket to use?
  202. mods before suppercharger LT1
  203. Could this be what is wrong with my TURBO kit?
  204. What spark plugs
  205. First time poster in here... Got questions
  206. I think i found a bottem end i want
  207. Location for Supplemental Pump
  208. Posted in C4 Parts FS: Complete dry NOS kit, including special throttle body, NIB
  209. Belt Slipage! help!
  210. Supercharged Power-How Usable?
  211. Vortech power starts where?
  212. In-car video of a lil' 1 mile run on my lil' 300 shot
  213. Dyno tuning for supercharger
  214. Accel Dual Sync
  215. Twin Turbo dyno results
  216. Dynoed My Paxton'd '87.
  217. Intake Gasket trouble
  218. Crazy Procharger mounting question.. can this work?
  219. Would you cut your hood for twins?
  220. Critique a theoretical build, please.
  221. Anyone know of any good threads pertaining to e85 switchovers from regular gas?
  222. Neat way to heat bottle quickly.....
  223. Boost question - need input or help
  224. Any supercharged LT4s out there??
  225. Well I got to drive my car for a day!
  226. Twin Turbos on stock LT-1
  227. best gaskets for boost
  228. Leaking Zex Nitrous management unit ??
  229. supercharger cam selection help
  230. How much money does it cost to get 500 rwhp??
  231. Would this air to water unit be a restriction?
  232. How many of you are making over 700 rwhp?
  233. one way to give you twin turbo some traction
  234. Can this work?
  235. A few questions on Belt Tension of serpentine belts
  236. I'm finally stepping it up.... I bought an innovate wideband
  237. B&M 144 Help
  238. Cold Fusion LT1 Nitrous Kit?
  239. 18 (or 11) degree heads under boost
  240. My own '99 Hugger Orange Z28 is finally getting put back together!
  241. BigStuff 3 for a blown 383
  242. question about injectors and fuel pressure with Procharger
  243. [LT1 w/ Procharger] Need help with Header/Exhaust selection
  244. Best Nitrous kit brand??
  245. procharger
  246. 2618 or 4032 Forged Pistons
  247. Need C4 IRS advice
  248. victor jr. efi conversion
  249. Looking to do FI andmoneyis not an option
  250. Question about Wet Nitrous Kit
