- Roots type Blower?
- Should I try a 150 hp Shot?
- Turbo motors and boost controllers - any experience?
- Help! Can't fit nitrous gauge to Compucar bottle!
- will i need fmu or bigger injectors
- Extended Warranty
- ATI Intercooler do you need to cut the radiator shroud?
- pinging
- Would I be safe with this jetting?
- N2O routing?
- What kind of numbers should I expect ?????
- This is sick!
- Which cam with a Supercharger???
- To those of you that bought ATI intercoolers....
- Has anyone come up with a good cold air set up for this application?
- N2O and supercharging stock LT-1 ????
- If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump?
- Anyone ever heard of Zex Nitrous Oxide System? CCA-82018 ?
- New to N2O - how many 1/4 mi. runs can you get on a #10 bottle?
- All NX nitrous kit owners............Need Help! (Kit is installed, one wiring question tho)
- Tuning 96 LT1 w/ATI Procharger
- Which system ??????
- supercharger problems
- adding to L-98??
- BEST supercharger kit???????
- Synthetic oil and nitrous
- need help nos control
- ATI Procharger P-1SC
- Digital Boost Gauge?
- HALO sparkplugs
- Supercharger
- Considering 100hp dry shot of nitrous on a 93 6spd LT-1 w/ hot cam kit ->
- Custom Prom
- 30lbs/hrs injectors. How much HP will they handle?
- Please help, Fuel pressure problem supercharged L98
- Will this n20 gauge kit my compucar "nitrous in a bag" kit??
- What's the pressure in a #10 bottle on an 80 degree day?
- Somebody here had said they could get good deals on Nitrous kits?
- How often do you spray it?
- Looking to get the bag kit 100 dry shot (will this hurt my motor)
- Best Spot for NX nozzle/solenoids on 94 Vette??
- Compucar "Nitrous in a Bag"
- NX 150 lean on take off............
- Is 10:1 too high for a 200 shot with a complete forged bottom end?
- Cool Bottle Install.......
- Lose of power with N2O
- Questions on NOS products
- What's The Best Nitrous Kit To Buy?
- Finished my SC install on fresh 383 - Overheating now New Everything - Help
- can anyone tell me the wholesale price of a NOS kit? pleeeeeease?
- Does Nitrous Express (NX) warranty hose. I blew one last night!
- Supercharger ...Go with Procharger or otherwise?
- Who's spraying a 150 wet shot??? How is you LT1 holding up???
- How boost-friendly is the L98?
- Fogger system/super rams/ fuel system/Hobbs switch/wiring/ I have a few Q's.
- Building a Stroker. Want pros and cons of turbos/superchargers
- Cons to F.A.S.T.
- LT4 and Nitrous Whos got it?
- NOS accessories wanted
- Which rings for a Supercharger?
- Ok, so are my 85 forged pistons....
- supercharger help
- NITROUS SPRAY SET UP
- NOS NOSzle kit
- MSD Digital6 problem solved *You will not believe the solution*
- Please help, Timing set for Supercharged L98
- Selling my kit....
- Thinking about using nitrous, need advice please!
- Where can I get this part...?
- Need help on verifying wiring on an MSD digital 6 box.
- New to board Question on C-4 S-Trim Kit VS LT1 F-body S-Trim kit
- compucar nitrous ?
- Is a spray bar plate made that has a fitting for the NX shark nozzle?
- what r ur numbers?
- 85 pistons or ???
- What size pulley to make 8psi boost on Vortech?
- Looking for turbocat
- Installed an MSD digital 6. ASR code is now glowing????
- Nitrous, turnkey kit??
- RUNNING A 100 SHOT
- Paxton lubricating fluid
- MAX boost for me????
- intercooler pic needed
- WHICH ARE THE BEST PLUGS FOR NOS
- half second?
- What would suit this car?
- FS:72# msd injectors
- What I need to do to post some pics of my blown 383 750HP engine??
- Cam change with SC???
- What's the diameter of stock L98 crank pulley?
- N20: 150+, stock block, done right , why not?
- Vacuum diagram for a -87 wanted
- Who's Responsible?
- TESTED NEW SYSTEM TODAY
- NOS bottle placement & fuelpump inquire
- [ot] need your help all. got a speeding ticket. could lose car
- Dynoed the Juiced ZR-1 again...
- Anybody running a 100 shot with no adjustment in timing, fuel, plugs etc.
- Supercharger
- Fuel pump upgrade.
- ATI Intercooler with Vortech for LT1 is available
- Timing control
- how stupid am i to actually be considering putting my daily driver on the bottle?
- Nitrous, hypereutectics and a SR-gonna be OK?
- Lingenfelters turbo systems, worth the $$ to lay down or not?
- How much boost can a stock short block handle?
- Who is using the 100 shot?
- Good price on 50s Injector
- Seriously thinking of getting Carroll kit
- has any one tried this?
- Anyone refill their own bottles?????
- Belt Slippage?
- What # injectors?
- Anyone Using these on their Vette?
- EAST Coast Timing ASSN.
- Turbo, Supercharger, or NOS?
- NOS activation switch assembly
- To juice or not to juice
- Any CA supercharged vet have emission probs?
- CompuCar "Bag Kit" System.....
- Need NX wet kit/system part numbers......What's included in system??
- engine temp with ati procharger
- Paxton Supercharger question
- Help....installing ati supercharger
- NOS help
- Whats the best Supercharger for the L98?
- Will a NOS Remote bottle opener work on NX bottle ?
- Boost issue?
- Cogged Pulley's
- Experts - Help with Nos Install
- Nitrous Tuning Resources
- Sparkplug question
- Pics of your bottle mount setups
- Need pics and advice from LT-1 Procharged Vette owners!!!
- NOS Nitrous controller.
- Electric Superchargers
- Just installed Nitrous!!!
- T-fitting for a fuel pressure cut off switch....
- Timing advance for Nitrous
- Nitrous Question with TPI
- It's been one day???
- Nitrous bottle storage in a 93 convertable?
- want a nitrous kit!..but need all info I can get first...please help
- which window switch?
- Just ordered an NX nozzle kit $469!
- Nitrous Button Placement Question
- Twin Turbo lt1 project. Design ideas...
- Direct Port Nitrous setup (Miniram) + Pics anyone????
- Question about BOV valve on ATI
- Anyone useing a TPS wot switch for nitrous?
- Holley NOS Equipped TB?
- Ati...tuning....forged low c/r 355?
- Hints and tips on NOS wanted
- Superram + Nitrous question
- Thanks to all that responded,C4 supercharger problem.
- Need new 3" inlet/outlet mufflers
- C4 supercharger problem advise needed
- BOV / bypass valve question
- something I saw on Hot Rod tv concerning nitrous set up
- Opti Spark/Accel 300+ ignition
- Pro Charger Air/Air intercooler adapted to Vortech System ???
- Whats the best purge valve to buy and where?
- Feasability of temporarily disabling super or turbo kit occasionally on LT4
- where is the tach autput on the PCM on 96 LT4??
- where to buy Ram Air System for my license plate cut-out?
- ZEX NOS EFI Kits
- Vortech FMU same as a fuel pressure regulator???
- Nitrous prices
- Wet vs Dry (What is each) ???
- Lost A Head Gasket Will the LT- head "NOT FLEX UNDER BOOST"
- nitrous switch panel in cupholder.......who has the pic????
- Question on nos 5151 kit or similiar plate systems
- nitrous articles you might want to read
- a few nitrous questions
- Twin Garretts on the way....Questions
- Is there an easy bolt on Nitrous System for the LT1...
- 100 jets don't do much.
- I need help fast motor won't come out
- New C-4 Owner
- Vortech YS motor and GearVendors Turbo 350...
- I need pictures of Supercharged SuperRam L-98 with Nitrous kit
- Can the stock transmission take the extra power?
- Nitrous Bottle Filling...Where?
- Just waiting for new supercharger pulley, then ready to go
- Who has the best Nitrous kit out right now for 150 or 250 shot?
- Do I need a Purge valve?
- NOSzle question...
- Should I change fuel pump before nitrous install?
- ATI Pullies,FMU and blow off valve
- Need help choosing SuperCharger for my LT4
- Difference in Medical grade Nitrous Oxide.....
- New nitrous prollem...
- Using a window switch with nitrous on an automatic......
- Nitrous kit GP anyone ?
- What size inj's come in ATI kit?
- show me where you place your purge line
- xtreme supercharger kit
- NOS QUESTION
- Supercharger's & MAF Screens & Idle Problem
- New turbo packages!
- I have to say it.....
- My car + spring = STRESS and why!!
- More NOS questions...
- Nitrous HP? Tuning
- NOS Explosions
- Nozzle placement....
- PAGING: RATRACER
- dry shot in throttle bottle
- SuperCharger for an 87
- Basic LT-1 NOS questions.
- nos dry shot system maf sensors quest
- Long Island Nitrous Users, Where do you fill up?
- Two heaters on the bottle.
- Direct Port ZR1 Nitrous
- New NOS NOSzle system for V8's -- Anyone got one? Opinions?
- Can I run a supercharger with my mods?
- anyone with a c4 find a good place to hide your nitrous tank(s)??
- NOS DRY SHOT ques
- Best N2O kit to use on a stock bottom end 94LT1
- How much nitrous can you shoot at a motor!
- Question About Forced Induction.
- N2O bottle size question
- Location of MAT sensor with a TPIS Mini RAM?
- How to change out S/C pulley and belt?
- Best Place to buy a ATI Procharger
- NOS...how much and how difficult to install?
- Carroll vs Procharger?
- Bottle Heater question.
- ATI Procharger chip
- I don't want to drill a hole for nitrous vent tube, what else.
- FS- lots of brand new NX Express nitrous stuff. everything you can think of.
- Pics of Blower/Turbo Applications
- air density and boost
- Issues with running two bottles?
- What are the largest jets anyone has used on a wet system ??
- Who make solenoid covers?
- this bugs me...
- Xtreme now offering ATI Prochargers for 85-96 C4's
- Have NOS 5174 Setup on 95 383 Rebuilt Due to Prior Nitrous Burp
- Electric supercharger?
- NOS Fogger II ?
- ATI procharger owners - need your input
- Will a blower blow up the stock motor?
- [ROLL CALL] Who has Nitrous??
- what setup should i use
- direct port nitrous/propane
- PCM programming with Nitrous (wet shot)
- Help me post my ZR-1 nitrous pics.
- Now that this section is open....
- Picture of my Forced Air Induction system
