View Full Version : C4 Forced Induction/Nitrous
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20
  1. 383 with 8:9:1 compression... on 12# boost...what injection to go with? TPIS or...?
  2. schrader valve
  3. <GEEK> VORTECH OIL feed .. How does it actually work?
  4. Vortec intake for TPI?
  5. How much beating can a stock L98 drivetrain take?
  6. Anybody ever try a Singal Turbo on a C4?
  7. dry kit for 85 l-98
  8. Nitrous injection plate for TPI
  9. Aluminum or SS air intake ducts?????
  10. Looking for Procharger pulleys
  11. No Power, 88 stock, 100,000 miles
  12. Vortech FMU
  13. NEED SOME HELP 6,8 OR 10 PSI
  14. Is the NOS 05151NOS nitrous kit for the TPI a good kit?
  15. Anyone have a TPI corvette Vortech Install Instructions?
  16. Should I use check-valves on my vacuum lines??
  17. Nitrous switch question
  18. Looking for pics of TPI corvette Vortech systems.
  19. Glow in the dark gauge yet?
  20. Nead pics of a TPI with foggers...
  21. A couple of Last Turbo Questions before the build
  22. NX wiring questions on a 1996
  23. NOS for 85L98???
  24. LT-1 Fuel Rail Line Tap Fitting Size 4AN ? And Another Question
  25. NOS wet? NX, TNT? who's got the best? I like the lower NOS sys/acc prices.
  26. intake tubing?
  27. Whats a purge kit do? Whats purging?
  28. best nitrous system&safeguards for a speed density 93 Corvette LT-1...wet? ->
  29. TNT wet nitrous system? Wheres the best place to get this? Summit doesnt ->
  30. L98 supercharger questions
  31. nitrous nozzel location?
  32. Best EFI system for Turbo application (Info Needed)
  33. 383 with nitrous
  34. Do the N20 sprayer bars impede airflow, reducing HP during non-N2O WOT op>
  35. bone stock, how much hp to be expected with procharger?
  36. Turbo Ideas (long)
  37. Anyone using MAF 'pull-through' supercharged setup?
  38. getting info about superchargers
  39. Anyone using the TNT quick connect?
  40. Nitrous and Propane Injection
  41. Who has long term success with a blower?
  42. 150 shot on Cross-Fire
  43. frustrated part 2
  44. Nitrous for me???
  45. nitrous
  46. Can someon please post pictures of your purge kit and solenoids?
  47. Turbos for a C4?
  48. Which has the better performance gain on a stock car? N20, Turbo or Supercharger
  49. could i see pics of your nitrous setups in c4s please.......
  50. Turbo Question...
  51. Need nitrous jetting info for using 2 nozels.
  52. ATI Procharger D1-SC for 1990 L98
  53. Boring my intake and tb's
  54. Does anyone here use a Jacobs Nitrous Mastermind?
  55. Using a NOS nitrous feed line for fuel?
  56. Supercharged motorlife
  57. What Sparkplugs should I get?
  58. N.O.S. question?
  59. {This could make someone's C4 mighty quick!}
  60. How much gain in the 1/4 mile with 100 shot
  61. LT-4 with a blower?
  62. Electric water pump on LT-1 w/ ATI Procharger???
  63. Too much play in camshaft!!!!!!
  64. TB - ByPass + Meziere + Supercharger
  65. Help with digital 6
  66. Problems installing my nitrous kit!
  67. My supercharger needs rebuild. Who can do it?
  68. Whats it cost to fill your bottle?
  69. Turbo on a CrossFire Engine
  70. nitrous on a crossfire sys.
  71. Twin Turbo On a CARB
  72. for the forced induction illiterate (that would be me) how does a turbo work?
  73. Heres what I have; what else do I need? (N20)
  74. Check out these TWIN TURBO headers for sale!!!
  75. Can camber brace be used with supercharger
  76. frustrated
  77. 383 with 10psi of boost?
  78. Anybody forcing air through a superram?
  79. TURBO FOR 84 CROSSFIRE
  80. Need Help Ordering Parts for 5174 NOS Dry Conversion to Wet TPI Plate Please
  81. Paxxton SN-92 ???
  82. What about a Kenne Bell or Whipple for LT1?
  83. I Cannot get idle above 600rpm
  84. Carroll supercharger question
  85. Use of BOSCH platinum +2's with a supercharger.
  86. One Last Turbo Question[I think]
  87. THe baddest c4 :reddevil
  88. BOUGHT MY LAST BLOWER FROM ATI
  89. How much power???
  90. Plugs with my 150 shot?
  91. Air/fuel ratio help
  92. Dana 44 + Supercharger = ?
  93. I ordered my kit
  94. Started procharger install today
  95. Magna Charger
  96. HYDRATECH GROUP PURCHASE !
  97. Superchargers
  98. Looking for Turbo reseller, maybe Canadian.
  99. compression ratio with a supercharger?
  100. supercharger noise?
  101. >>f/s complete vortech supercharger<<
  102. PCV boost question
  103. What is the smallest engine you could run Turbo on.
  104. New Supporting Manufacturer!
  105. Nitrous question???
  106. 84 THROTTLEBODY
  107. Factory ECM, Blower & AFPR Question
  108. N2O PURGE - HAVE IT? LIKE IT?
  109. Cheap Power..
  110. Callaway turbo question
  111. getting a day at the spa!!!!
  112. nonadjustable NOS TPI plate?
  113. s/c
  114. P600b or D1???
  115. Supercharger on stcok corvette???!!
  116. CHASSIS DYNO RATES NOW ONLINE>>
  117. C4 Turbo systems fabricators (east coast)
  118. ATI Procharger and SuperRam
  119. Fuel feed from cold start fitting for nitrous?
  120. Oiling a Twin Turbo Setup
  121. Kicked off the track!!!! 12.0 @ 116.92
  122. ATI Intercooler Question......
  123. SuperCharger Blow-Off Valve Question....
  124. ATI pro charger for L98 for sale
  125. Stock fuel pump limitations on the bottle?
  126. Compucar TPI plate $135!!!!
  127. Injectors...430 RWHP??
  128. TPI nitrous plate
  129. Just purchased ATI pro charger for my LT4
  130. How much did your nos cost
  131. if you have a C4 with a single turbo...
  132. Stock motor w/procharger
  133. ATI twin IC air ducting pics
  134. Stock injectors or .....
  135. What size injectors ?
  136. Nitrous in the runners?
  137. D1sc for sale
  138. Supercharger Noise
  139. LT1, Hotcam and N20?
  140. Supercharger install questions
  141. WTD: NOS T/B plate for LT-1
  142. Anybody Running an LT-1 EFI Wet Plate System ?
  143. Few Questions About Supercharged LT1s, pretty random and broad, thanks.
  144. PURGE SET UP - ANY PICTURES?
  145. Chip woes
  146. fogger
  147. Will this cam work if I add a ProCharger (6 psi)?
  148. Bought BOTTLE HEATER, but no Instuctions, Could ya Post 'em???
  149. Mounting postitions of Turbos on a C4
  150. How much better is the Dual Intercooler over the Single?????
  151. FS: Superfueler by Carroll Supercharging
  152. where to mount WOT switch
  153. Max N20 on an Engine?
  154. What's max C/R for a future S/C????
  155. WTB: TPI supercharger
  156. differances between f-body&vette chargers
  157. zr1 supercharger
  158. Question for the N20 guys...........
  159. carroll supercharger ?
  160. ZZ4 + TPI + Supercharger .... has anyone done it?
  161. Newbie nitrous question
  162. LT4 and the bottle... let's hear it...
  163. Ya want to include a C3 on the Forced Induction section? Intercooler Finished!
  164. DOC'S LAKE SHACK "CORVETTE GIVEAWAY" Benifiting AMBUC'S & HELPING HANDS
  165. Tires For Runnign at 1\4 mile...?
  166. NITROUS WOES
  167. Procharger Kit for 1990-1990 for Sale
  168. Can the LT-1 front mount intercooler be used on TPI procharged vette???
  169. used LT1 with TNT??
  170. Anyone running direct port nitrous?
  171. Where to find ATI Procharger CHEAPEST...
  172. ZEX NITROUS SYSTEM
  173. ZEX Nitrous Systems
  174. GRRR :cuss: :cuss:
  175. NX maximizer
  176. Procharger........
  177. Anyone supercharged and nitrous on stock bottom end?
  178. Lets see your nitrous bottle mounted...
  179. Vortech Oil lines location/install
  180. Max RPM for D1/P600B ProCharger Unit???
  181. Maxing out on your SC? Are you?
  182. Opinions and comments please (which brand supercharger)
  183. How to get more boost than 12psi from Procharger 600B???
  184. Big Big Procharger Issue... Need opinions
  185. Bye Bye 383:(
  186. Can I adapt a Paxton LT1 kit to my L98????
  187. Turbo guys...
  188. What is the max L-98 HP obtained from SC-350?
  189. nitrous help, need some info from the pro's
  190. Best WET kit for LT1????
  191. what is the best way to inject a 300 shot?
  192. Picture of the ONE & Only - "Go for the Gold Corvette!"
  193. Use 9nth injector to dump more fuel under boost??
  194. Fuel line upgrade -L98
  195. Low mounted turbos = separate oil pump?
  196. Running Carbs on a Root SC
  197. How do you store your nitrous/fuel jets?
  198. What type hose/tubing to use for intake???
  199. Caroll Supercharger for sale
  200. Turbo Cam?
  201. Procharger vs. Vortech
  202. Help L98 Nitrous gurus.
  203. SC Pricing, have they gone up?
  204. '84 nitrous
  205. New to the Nitrous world, some ?s inside.
  206. Fuel pump Q's and SC Q's
  207. Please, pictures Callaway turbos
  208. Best rods?
  209. Anyone found way to block SC whine?
  210. A few Supercharger Questions...
  211. NOSzles
  212. L98 Supercharger Kit
  213. Where to mount NX solenoids??
  214. I Need Help!
  215. Stock Fuel Pump Enough?? (Caboboy?)
  216. Pics of Electric waterpump installation needed
  217. Anyone have experience of this Acceleronics Impedance Converter
  218. LT1 TNT Plate Kit....
  219. Nitrous question...
  220. NOS low=pressure drop?
  221. MSD Digital 6 problems?
  222. ON DEMAND - Two Stage Nitrous
  223. NX TPS WOT switch?
  224. ReBuild for Boost for under 3K? possible or not?
  225. vortech users
  226. Cheapest place to get a 4L60E ?
  227. Disappointing track day...was this the reason??
  228. Where to get (Siemens) 50-55 lbs injectors?
  229. ATI Pulley interchangeable with Vortech Pulley?
  230. NOS dry system questions for lt1 owners
  231. IAC driving me nuts
  232. Low FUEL PRESSURE>>>>???
  233. Extra gauges go where???
  234. Paging KRIVERIA.....
  235. banging noise in the Heads?
  236. SuperCharger Question for L98
  237. Max stroke for a blown LT1
  238. Has anyone tried this to INTERCOOL?? Custom Intercooling?
  239. Delphi 50s Injector
  240. New Update on Banks Twin Turbos
  241. 125HP jets for NX?
  242. Billet Dual Bottle Mount
  243. Too late 2 add a Supercharger?
  244. What fuel pressure is best for nitrous applications?
  245. LPE Walbro pump questions
  246. Booster only producing 4lbs of boost???
  247. L98 turbo, some questons
  248. Need ideas to reduce heat from headers to supercharger
  249. Custom chip and bigger injectors?
  250. how big can i go?
