- What jets should I use for 100/150 shot (NX wet system) 20920
- turbo in the back, WTF? slightly off topic
- Want to try nitrous on LT1 goods and bads???
- Can you get the D1 in a Self contained????? QUICK!!!!
- how much spray can a stock zz4 take??? driven every day
- Do I even need an FMU???????
- Dyno tuning ain't cheap!!!
- d-1 Procharge and blower?
- Quick help?
- one more time, L 98 full ati intercooled supercharger kit for sale
- Anyone install a Paxton in a 91 Vette?
- can I spray ahead of the air meter?
- which replacement coil???
- New system for the 91 L98 Vette..
- Is a rearend gear change necessary for me???
- Upgrading FP to Walbro GSS340???
- MSD 6AL question
- 421rwhp at 5800RPM but running lean and need trouble shooting :(
- Procharger pre-install pointers?
- 400 sbc 4sale
- I just ordered my gauges and accessories
- EGT Gauge Question.
- Info on Cogged Pulley Setup for Procharged LT-1's
- Pix OF 91 L98 Procharger Install With Dual IC's?
- EGT=what cylinder?
- spark plugs with Blower-setup
- Check this out...Ebay...Electric supercharger?
- Purge Valve Setup
- Should I bother using a FPSS with my nitrous?
- proper ignition for a 125hp shot on an LT1
- Need pointers for Procharger set up
- Got Any Idea For N20 Setup
- a-pillar gauge ???? 4nitrous guys?
- Rear axle change
- Anybody else think there nitrous heater takes forever to heat their bottle?
- Dyno Results for ATI Procharger???
- From(rags) 4" pulley 7psi @ 6,000RPM TO (riches)3.7" pulley 11psi @5800RPM!
- Who owns this Callaway? #053 from 1991
- What thermostat are you running with supercharger?
- Throttle Stuck WIDE OPEN!
- nitrous works kits for the lt1
- NOS Pro Shot Fogger Nitrous System
- cam for nitrous
- FS: A-Pillar-perfect for guage pod
- Need pics of the hidden direct port N2O on the LT1-LT4 intake
- BOV (blow off valve)
- I WANT THE TRUTH (about supercharging an L98)!
- Does Procharger Eliminate the AIR pump???????
- l98 ati intercooled supercharger kit for sale
- Adequate or over kill on blower car fuel system?
- Limits of ATI intercooler,and factory ecm?
- Vortech adjustment question
- TPI Throttle Body SC Inlet Tube
- Need help troubleshooting a high rpm condition on the spray.
- this is cool check it out...
- looking to the future
- Figured out what was causing my problems on nitrous
- headers **hot**
- Couple turbo questions...
- Carbon Fiber nitrous bottle...$1300????
- Some more L98 nitrous install pics for the archives....Dial-ups beware
- Which N20 kit do you prefer?
- WHERE TO PUT THE MAT SENSOR ???
- some pics of my nitrous setup
- Best spark plug for 100 shot nitrous....Autolite or NGK?
- Wanted: P600B ATI 6 or 8 PSI Pulley (pulley only if you have one)
- What bottle pressure at room temperature do you see on a 10lb after refill?
- Twin Turbo kit for L98 C4s?
- MAP P/N for 2Bar
- [pics] krivera's ProCharged 383 Vette
- feels like xmas!
- 1991 L98 (383ci, Supercharged D-1) Just got it BACK!
- HELP! NX problems. I cant feel a 50hp shot and car feels slower w/o N20 ?
- Procharger, Vortech....I'm gonna buy next week!
- LPE Stage 2+ TT For Sale
- NOS 5177 kit??
- Supercharger/Intercooler Theory........
- "B Trim" 6-8 psi blower
- ngk tr5?
- the new guy
- Another Supercharger Question
- FPSS question for nitrous setups
- permit for nitrous?
- L98 on Nitrous
- Got N2O? I do... :)
- Negative Supercharging fact or Myth?
- Opinions about new intercooler sprayer system by DESIGN ENGINEERING,INC
- Risk involed with running a small shot of nitrous for additinal intercooling?
- C4 LT1/4 Supercharger cogged belt drive system
- Billet 4130 Steel LT1/4 balancer hub
- Help- do I need a bigger Throttle Body now????
- Price for a vortech
- Fair price for shop installation???
- wires?
- Help With Jet Sizes
- can i get some pics?
- Pictures of D1R & Custom Intercooler
- Oil Pressure through a Vortech V1 Blower?
- where do you put the NX nozzle on a 92-93 intake shroud? the side? the bottom?
- GM service
- Eaton Supercharger Install
- Compression...on L98 383
- Convertible bottle mounting behind the seats...where to drill?
- NOS Sneaky Pete system.
- Question: Where to put Soleniods with miniram?
- looking for a northern n.j. nitrous installer
- install and codes
- Attn: Procharger folks w/ squashed air filters
- 58mm Throttle Body for Supercharged 383?
- Intake mods with nitrous
- Which oil (5w-30 or 10w-30) should i run with 100 shot of nitrous?
- ?? For nitrous users.........
- Strange TPS problems
- Need a little help here...
- Pro Star wheels Lug Nuts
- Nitrous switch box
- WTB - 4@ 3AN hoses 12" ( I know it's not parts for sale section)
- About how many 1/4 runs will you get in with a 100 shot N20 w/ 10lb bottle ?
- top speed runs with nitrous on an LT-1? anyone ever try it?
- SR + Direct Port Nos
- imports
- 11's on L98 stock bottom end, possible???
- running intank pump and inline pump for nitrous?
- MAF or speed density?
- Dumb question..is the bottle heater on while spraying, or just prior to spray?
- 1st Bottle fill with BOTTLE HEATER
- looking to get nitrous for a stock c4
- Boost Junkies- which spark plugs don't burn up?
- Advice for supercharging my 87 vette.
- to procharger w/ Mass airflowusers, please reply
- window switch
- Still trying!
- All systems are go!!!
- LT-1 w/N2O&hotcam kit.what RPM should I set my MSD window switch to go off at>
- n2o and overdrive?
- Seat belts FS
- Has anyone used a Paxton Novi200 on a L98?
- Anyone had this problem
- I was thinking of mounting my MSD window switches here----------------->
- VetteNoob and others.........check it out, cool Nitrous Plate!
- Which car will win?
- Paxton Novi 2000 Bracket for a C-4
- Looking for input on ATI Procharger Supercharger....
- New Break in... with blower...need advice!
- Questions on boost, ECM's, and sensors
- Best place to buy a supercharger kit for an 85' ??
- Any better air filter location on 88 SC P600B?
- MSD Window Switch connection sequence
- Timing & fuel adjusting!
- Progressive Nitrous controller, will it work with TNT or NX etc?
- MN_Vette, you use Nitrous with your turbo(s)??
- Problems w/Corvette Intercoolers
- FS - NOS 10lb Wet Kit
- Turbos, water cooled vs non water cooled.
- All Supercharged Vettes.... Post your ET, HP and MODS!!!!
- Learn from my (expensive) mistakes.....
- Supercharger with a Hot Cam?
- 8 rib pulley set up on a 90 roadster, any promblems????
- Bottle getting too hot....
- 383 or 396 for blower?
- 100 shot times with basically stock 85 vette
- Safe amount of boost with D1?
- Pics of my Nitrous set-up. Everybody likes pics riiight? :-)
- NX N20 w/ speed-density (92-93) cars:Where in the intake do you put the nzle?
- Rollbar and N20 bottle mount in a convertible? Can it be done?
- D-1 or P-1 supercharger?????
- NX Solenoid mounting question
- Issues on Supercharging an LT4
- Need an auto-off switch for my nitrous system arming where do I get one?
- Who has the best price on a B&B Tri Flow Exhaust
- SC and MAF Sensor
- Supercharger & Camber Brace
- If you have a Vortec Supercharger installed on your C4 please come inside
- mixing different octane fuels mixing in the engine(N2O), can I get an average?
- Procharger intercooler - Efficiency question
- DFI - Timing at Idle
- Now i call this fast! --->
- Supercharger
- Anyone use Holley 950 Commander?
- Bottle Install. Does this looks ok? Is it going to be safe there?
- Does NX make a wet kit for the 92-93 LT-1 (prfr TB plate N20 system) ? part#?
- Would this work to cool an intercooler?
- Anyone have Supercharge a speed-density 92-93 LT1? is the kit any different?
- they best n20 kit
- Anyone use a vacuum pump on the street?
- Input Please - Best price on a ATI ProCharger for a L98 ??
- where do you guys tap into the fuel line at on a wet NX system?
- Adding a SC to your '85 ? Beware - More Inside
- Nitrous.....L98??
- High miles and N2O
- Who makes a good bottle heater?
- Might build a moter for a blower and need help.
- whats a good price for these turbos?
- Cam for Blower and 383?? Need help choosing!
- Finished Pro-charger this weekend.........How much noise is normal??????
- Am I asking to much form kit?
- Another question about spark plugs and N2O, please advise
- Boost Control and Blow Off valve question!!!!!!!!!
- Purging pics...If your bored, go snap a shot for me!!
- Need a pic or instructions for a dual Fogger TPI plate
- Tell me a story..........
- base timing on an L98 and 100 shot
- GUAGES GUAGES GUAGES!!!
- Beltless Boost Stage I......a success???
- Anyone using a Air-Water Intercooler or Aftercooler?
- Nitrous billet bottle mounts.
- Any RWHP estimates for my new combination?
- two 1 core intercoolers or 1 big 2 core intercooler?
- Finally started my ATI install!!!!!
- radiator clearance
- Procharger question
- Boost gauges
- A nice little article about nitrous for the newbies.
- pics needed please!, of dual intercooled procharger install
- procharger pulley size vs boost level question
- N20 switches finally repositioned!
- 3 wks left Before I order Parts For Twin Turbo, need some last suggestions!
- anyone working on a eaton type blower for the C4?
- MAN I want my SC!!
- NX NOZsle setup
- Nitrous Oxide (N2O)
- procharger question
- Bottle heater problem?
- NX Fogger jet to Nitrous plate.............Questions?? Please help.
- Aftermarket Ignition (MSD or Mallory)?
- N2O to boost ratio?
- need jet sizes for t-n-t wet kit on tpi
- HP gains expected with FMU
- [CALLING MONTY] Standalone Fuel Management
- Quarter Mile Times With NOS
- Mounting position of Intercooler on TT setup?
- Need thoughts on putting a Paxton on my '92.
- What does Supercharging do to your MPG???
- Have some Turbo Q!
- Where to mount FMU in C4 L98 ???
- Which NOS system should I buy?
- Procharger+LT1 = what plugs and wires?
- Pillar Gauge illumination question
- Calling all experienced nitour guys??
- 1984 forced air induction
- Need recomendation on purchase of my Stealth Ram, cheeeep!
- Where is the best place to install my NX Fogger Jet?
- Injektors and fuel manegment?? w/procharger
- plug gap
- Reasonable amoumt time for a stroker long block from a professional builder
- Who has blown up THEIR engine using Nitrous?
- For sale New in Box NX Express kits for L98/LT1/4
- piggyback ecu (may intrest forced induction owners)
- What is the downside to a hidden N20 system like this?
- Did you turbo guys see this????
