View Full Version : C4 Forced Induction/Nitrous
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20
  1. 88 Vette with nitrous questions?
  2. What lbs. Injectors should I use?
  3. how much power?
  4. water injection vs IC
  5. a used supercharger
  6. SC on A4 92 LT1 - Basic questions (with more likely to come)
  7. Zex Nitrous Kits
  8. who sells hood prop relocation kit for supercharged vettes.
  9. P1SC install on 94 Auto... questions for you experienced pro's...
  10. Dependability with SC
  11. Glow in the dark N2O gauge yet?
  12. Carroll supercharging
  13. Nitrous on a LT4?
  14. To install nitrous, or not to install nitrous?
  15. Weird humming droning noise ???
  16. How much is this setup worth???
  17. Idea for fixing SC belt slip
  18. 100 shot results finally !
  19. NX kit on stock fuel pump?
  20. Converting L98 Vette 727 ECM To Boost Aware Sy/Ty 749 ECM?
  21. 406 with 8.5 to 1 compression fordged pistons? 7-8PSI safe?
  22. Direction for dry shot
  23. D1 Procharged L98 Design Excersise...
  24. what is the stickest blower belt?
  25. Which Procharger Head Clears FX3 Shock Actuator In 91 L98 Vette?
  26. Is The ATI Procharger Kit For 91 L98 Vette 50 State Legal?
  27. Carroll Supercharging Website
  28. Turbo V's SC
  29. I want to supercharge a C4! Lead me in the right direction!
  30. 1/4 ??????? please
  31. New Combo Dreaming - Air to Water Intercooler
  32. what time should i be getting
  33. HEADS OR NOS WHICH ONE?
  34. Art Paul/ Bart/ One other out there--- 621 rwhp@#5800rpm w/DFI problems ??
  35. 137 K 85 L-98 stock TPI and a 150 shot goes 11.91
  36. How much horse could i expect when installing a superchrager? and does it just bolt on?
  37. What jet sizes should I use?
  38. How much $$ for NOS
  39. HAL QA1 COIL OVERS
  40. Relocating The AIR Pump On Blown L98...
  41. Dyno Printouts Of Centrifugally Blown L98's...
  42. IS THERE A STOCK CHARGER OF AN 88 L-98
  43. Ball Drive Paxton Info Needed...
  44. kick back on start up.
  45. The Good, The Bad (and the Ugly)
  46. NOS kit...
  47. Selenoid sticking OPEN
  48. Calling D-1SC owners.........
  49. Install instructions on NOS inline pump?
  50. Help...Oil pressure jumping erractically after supercharger
  51. Almost there!
  52. What would I be getting myself into?
  53. Oil Cooler for Paxton Supercharger, L98
  54. NEW Bottom end
  55. Help! 8PSI pulley is causing my car to stutter, cough at WOT.
  56. Camber brace
  57. Putting ATI on 84,000 mile engine.
  58. new fuel pump for nitrous?
  59. LPE219 and blower?
  60. (just curious) What is the most wet shot a stock LT1 can take?
  61. Help with info on this engine buildup?
  62. Suggestion on checking for slipping Supercharger belt.
  63. Well guys... Im back in business... Got my NEW Car
  64. WTD:10# Nitrous Bottle
  65. 93 (SD, no MAF) LT1 NX nozzle vs. IAT sensor locations?
  66. Breather to replace oil cap in VC on LT-1???
  67. Injector size
  68. Who esle makes S/C besides ATI?
  69. NOS jetting and timing questions. Please HELP!!
  70. bottle heaters
  71. Toughy Question
  72. ATI Pro Charger intercooler mated to C4 LT1 Vortec Kit
  73. Nitrous System Suggestions?
  74. Sandblasting S/C pulley for grip
  75. Can you use NKG TR55 with 100 shot Nitrous?
  76. Which spark plugs?
  77. How much was your auto trans?
  78. BOV on supercharger
  79. Electric water pump gains
  80. Vented opti and blower
  81. if your all out
  82. Dual BOVs?
  83. Is a 100 shot or more ok with 10:1 compression?
  84. Calling out STILLDADS67................
  85. crank case pressure
  86. Decided to TT my 86 need info.
  87. how much can i handle
  88. First time using spray
  89. 16G and 20G Hahn Turbos
  90. nitrous kit wiring help
  91. is there a difference in nirtous
  92. N20 cam choice for a 383, part 2. Need more help, lol...
  93. another video of a vette making a pass
  94. Meziere electric waterpump on ATI Procharged 94 vette...is there any fitment issues?
  95. what weight oil?
  96. Your recepie for supercharged 450+ HP?
  97. Direct Port Intake complete and back on the car...
  98. Max.boost before needing intercooler
  99. Aeromotive A1000 fuel pump
  100. Blower with 10.5 to 1 compression, how much boost ?
  101. air intake temps
  102. Aftermarket Intercooler with Sc..? Yes or No?
  103. Why not use the NOS NOSzle
  104. What kind of nitrous set up for a procharger vette? (lt1)
  105. Timing Cover and Oil Pan
  106. vacuum modulator trans control
  107. Check out this twin turbo deal
  108. speedpro/fast turning
  109. New plug gap with MSD???
  110. thinking of putting nos in my stock l98 lowerend ??
  111. First pics of Direct Port progress...
  112. Blower Pics Test
  113. 24psi Procharged and 1275hp
  114. Superfueler and superram
  115. WB O2 meter effectiveness with Supercharger
  116. Remember the ProStreet Stlye Red C4 with one huge Turbo?
  117. Custom cog balancer is half way done.
  118. Guys w/ MSD's and Prochargers, where do you mount???
  119. How did you mount your Nitrous Bottle Brackets in your C-4?
  120. Got no turbos but want a BOV sound???
  121. ATI D1 Supercharger Installed in L98...Experience/Problems/Help!!!!
  122. Dual Fogger? Sounds fat.
  123. 1000hp TT LT1 Impala SS
  124. Looking for a link to Aqua TT 1200hp Florida car...
  125. Anyone change the pulley or belt on a LT1 Vortech install ('94-'95)? Advice?
  126. here is sample 8psi 450rwhp kabom
  127. For anyone who has plumbed their own direct port nitrous....
  128. "Fogger" type kits / Install tips ?
  129. Broke the Timing Chain
  130. NX Wet system with extras $450 shipped
  131. new numbers tonight
  132. HEY! Cheap wideband has hit the market!
  133. Reichard Racing "Ultra grip" pulleys
  134. Look what I just ordered!
  135. ATI intercooler for C4 --- Effective?
  136. Solid Roller Cam Button Flexing Timing Chain Cover
  137. electric water pump/vortech
  138. Best drive units for Corvette LT1 blowers?
  139. N20 cam choice for a 383?
  140. Nitrous plugs?
  141. Hood Louvers
  142. msd timing retard how, where, do they make?
  143. Injector size?
  144. C4 throttle cable?
  145. Got a combo for someone with DD2000!
  146. nitrous lines hit the hood?
  147. some new nitrous pics just took them
  148. nitrous first time out
  149. ATI Procharger D-1
  150. Dyno tuning question?
  151. PEOPLE WITH BELT SLIP, THIS MIGHT BE FOR YOU!!!!
  152. 2 Bar MAP sensor conversion on Vette?
  153. fuel pressure drop
  154. looking for some turbo help....
  155. Which Blower Type Is Better......?
  156. HEY BLACK BART !!!!!!!!!!!!!!!!!!!!!!
  157. How far are those Twin Turbo Headers?
  158. Can't know it all can i :(... Lost some boost i think i know why your 2 pennies!
  159. F1R on L-98?
  160. Nitrous 1/4 mile Times
  161. LT1 cogged drive is coming a about 2 weeks
  162. Supercharging a stock LT-1
  163. ET on Nitrous
  164. RE: Paxton Super Charger on E-bay
  165. Anyone using the new NOS wet kit?
  166. Tall valve covers on a C4?
  167. Where to get a 91 Auto Stock ECM chip
  168. I think I need breaks now!!!!!!!!!!
  169. S/C on stock motor + 1.6 RR's and Headers = ????
  170. JohnGuc
  171. Mganacharger on an LT1
  172. 92 LT1 SC
  173. Replacement 2 bar sensor for #16009886?
  174. Re: Procharger kit on Ebay
  175. DFI Program
  176. Proper jets for small shot on TPI plate system
  177. vvv90... Hows your Supercharger???
  178. L98 Nitrous Setup Pics PLZ!
  179. Pulley sizes for Paxton SN93?
  180. plug gap
  181. [PAGING BLACK BART] Pillar Pod Question
  182. NX Owners please post your PICS of your Nitrous set up.
  183. How much boost w/o needing a intercooler?
  184. Ive Got BOOST but NO Intake system
  185. Callaway TT on the dyno....
  186. T trim does appear to have belt slip now
  187. Saw a Mustang driver using a blowtorch to heat a nitrous bottle at the track?
  188. LT1 Juice+Boost...Do you guys who do it recommend it?
  189. Blown 85 Running Really Hot - Any suggestions?
  190. DesktopDyno Exhaust data
  191. Help Please T-trim only making 5lbs Boost
  192. Track times NA and with 100 wet shot NX nitrous today.
  193. Procharger installation instructions
  194. O2 sensor mounting?
  195. Nitrous Relay - Problem and Question
  196. Noticed on dyno run w/ nitrous that car runs LEAN when nitrous first kicks on.
  197. Header make no differance with supercharger?
  198. 116k, should I juice the LT1?
  199. supercharging 89 vette
  200. Blower Heat, Oil Heat, and Techroline what does it all mean?
  201. Another Window switch question.
  202. Dyno run with NX 100 shot. Results: useful info
  203. Starting my Paxton Novi200 Install
  204. Accel fuel pump rating?
  205. Anyone running zex nitrous???
  206. I see 36 degrees max advance at WOT. Do I need retard to run an NX wet 100shot?
  207. Intercooler Idea
  208. Need some help with Supercharger and Nitous setup
  209. Destroyed IAT sensor HELP!
  210. Dana 44 on already stout motor + nitrous addition ?=? disaster?
  211. 1227165 with supercharger and 2-bar MAP
  212. Do I need timing retard on 93 6spd with 100 wet shot NX?&Ed Wright hotcam chip
  213. MSD Digital 6-plus...major problems on 93 LT-1
  214. Nitrous EXPERTS...step inside.
  215. [PAGING] Jerry Myers....RE: C4 Twin Turbo kit
  216. New NOS system
  217. Fuel rail nozzle tit. Does it use a standard insert
  218. Fogger Nozzle broke..... Can I just..... [Quick Fix]
  219. 2-bar map sensor Part number?
  220. Vortech or Procharger
  221. NEED SOME HELP WITH BOOST GAUGE
  222. Finally used the bottle today...initial thoughts (L98)
  223. I got a turbo...
  224. Vortech (carroll) or Procharger?
  225. NOS bottle in the sun
  226. Need help!!!
  227. $250. off any supercharger!
  228. 92-93 speed density LT-1...Do or dont spray nitrous onto the air inlet temp sens?
  229. NEW TIMES ARE IN WITH 150 SHOT, ANY SUGGESTIONS
  230. Anyone Ever Twin Turbo a Big Block on their C4?
  231. Interested in doing a Twin Turbo setup on my 92 Vette
  232. Man this NX Nitrous install is one BIG HEADACE!!!!
  233. RPM window switch
  234. CA - Carroll/Vortech Supercharger FS - $1500.00
  235. ~~[TURBO] L98 vs LT1, which ones better?~~
  236. Finally got 8-rib pulleys back!!!
  237. HELP! Should I put Liquid Teflon on a brass fitting for my fuel pressure Saftey Switch?
  238. [HAPPY] can you say ATI PROCHARGER???
  239. Anyone with a 396ci/T-trim?
  240. FUEL PUMP.... should I get a 255Walboro instead ?!?!?! HELP
  241. Rebuild Solenoid's?
  242. Help me Pre-tune my car...... For a Supercharger
  243. Running Boost, what do you do with the vacuum lines?
  244. Idle problem with D-1 intercooled sysetm
  245. Nitrous pressure question
  246. Professional Grade Help Needed!!!
  247. Holley commander 950??
  248. NItrous on an 84, anyone done this before?
  249. Exhaust on procharged corvette??
  250. Anyone using Zex Nitrous on an LT1?
