View Full Version : C4 Forced Induction/Nitrous
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20
  1. Single turbo Lt1 headers
  2. i love this vid
  3. Good cam for supercharged L98?
  4. Here is a good supplier for SC hoses
  5. Selling an forced induction LT1 shortblock
  6. The biggest Drag Racing Event in 2004 Feb 19-22
  7. What is Necessary Octane for 12:1cr?
  8. Injector Sizing
  9. N2O arming switches?
  10. good turbo for l98
  11. Knock Sensor in Water Jacket???
  12. Huge turbo: this fella around these forums?
  13. Good Nitrous Setup???
  14. cogged belt info or 8 rib pulley info
  15. GM 1985 TT Corvette
  16. Anyone heard of these guys?
  17. Blower Problems?
  18. Blower vs MAF?
  19. Best Suppliers?
  20. Turbo exhaust flange and pipe questions.
  21. My LT1 Vortech Supercharger kit is for sale
  22. need help with displacement and turbo size...
  23. 93 Pro Charger Install Help.
  24. this has been on my mind for awhiile...
  25. Addressing the Vacuum Pump Issue
  26. 100 vs 150 shot
  27. what's it worth
  28. Vortech Supercharger Kit 94 95 96 LT1 - For Sale
  29. Hats off for John....
  30. N2O jets?
  31. Supercharger Install
  32. activation switches?
  33. Ricer + Gas = Boom!
  34. I am SUPERCHARGED AGAIN :)
  35. KY vette owners. Write your state reps NOW. KY is trying to outlaw nitrous!
  36. Turbo efficiency question
  37. Feeling out sale of supercharged LT1 engine package
  38. I like this Body kit
  39. Supercharger for $160
  40. Mr. Gasket Crank Case Evacuation
  41. where can I?
  42. S/C on 12:1 motor with 110 race gas?
  43. S/C....is buying a used one OK ?
  44. FMU's and speed density ?'s.
  45. YS Trim on ebay
  46. GMPP LT4 kit
  47. "Zex" dry system, will my car handle a 75 shot ok?
  48. Belt tensioner, new belt, on D-1 3.7 pulley size
  49. Wastegate sizing?
  50. blown small block combos??
  51. Propane torch to heat NOS bottle - How dangerous is this?
  52. Hit the NOS today for the 1st time
  53. How much noise have you experienced with SC cog drive?
  54. Rough Idle after procharger install...Please help.
  55. Any preferred N2O system for a L98?
  56. ATI 2.55 & 2.25 pullies
  57. What to do now???????????
  58. Magnusons new blower
  59. dual N2O bottle brackets, which ones?
  60. best way to find the right blower cam?
  61. camshaft??? confused...
  62. Help with N2O braided line
  63. ECM programming for 90 - L98
  64. New to NOS and I have a few question.
  65. Newbie questions on Supercharged LT1
  66. My header quandry....I need serious suggestions.
  67. Nitrous - DRY or WET for L98?
  68. Procharged Big Block
  69. [paging vette noob]
  70. Is anyone using accell header plugs w/ Nitrous?
  71. N20 install....
  72. Turbos and compressions ratios
  73. NGK plugs?
  74. What brand of fuel injector to buy???
  75. Intake and forced induction
  76. Noszle ??
  77. ProCharger or stroker?
  78. Where to find DIY turbo parts
  79. Has anyone ever had a solenoid failure?
  80. First Time NOS user
  81. C4 turbo kits
  82. Long tube vs short tube headers
  83. Interesting Turbo Question.
  84. Rear mounted turbo
  85. No slip for supercharged L98s?
  86. Smaller pulley for P600B
  87. Callaway Twin Turbo Upgraded wonderbar
  88. What plugs to run w/ nitrous?
  89. Zex kit on a L98?
  90. Turbo on C4 using my procharger piping?
  91. My new toy:
  92. Camshaft for blown L98??
  93. Question about the purge lines.
  94. Procharged stock LT-4?
  95. Banks New Twin Turbo system for the C4......possibly
  96. Modified Callaways Twin Turbos? Anyone done it?
  97. need opinions on my d.c.r.
  98. Nitrous bottle orientation
  99. About to order an ATI Procharger P600B HO - Questions...
  100. NOS questions can someone help??
  101. Any S/C guys interested in a Vortech T-trim...
  102. WTB 1996 original equipment owners manual and black zippered case
  103. Is it possible to fit a z06 engine in a c4
  104. N2O advice?
  105. safe compression for 125 shot of juice?
  106. Any guess? hp?
  107. do they make a roots style blower for C4 vettes?
  108. Stock or stroked w/ SC?
  109. Venom Nitrous
  110. Nitrous done neat
  111. Hot Rod mag/turbo L-98 C4
  112. N2O.....
  113. Can you check my math???
  114. NOS system recommendation for LT-1
  115. Turbo Fun
  116. 1992 Twin Turbo Corvette LT1 kit for under 5 500 USD? (Project but realistic)
  117. Here is the 2nd pic of the 86
  118. 86 almost done
  119. Electric vacuum pump???
  120. Is Mono Blade too big for my engine?
  121. Instructions?
  122. N20 tank locations?
  123. HotRod: Guide to turbochargers
  124. Do it yourself SC?
  125. L98 w/ Nitrous............SAFE?
  126. Trying to get a general idea of Turbo/super charged L98/LT1's
  127. Fuel pressure isolator install through firewall question
  128. Nitrous Gauge: Eletrical or Mechanical?
  129. Spark Plug Recommendations
  130. new ngk tr-6 plugs miss fires after 4 runs with 100 shot what' up
  131. LT-1 Hot Spark ignition systems ???
  132. ATI procharger and Camber Brace
  133. [NITROUS] Should I pull timing on my LT4.....
  134. 84 NOS question???
  135. Anybody ever put a LS1 motor in a C4 corvette?
  136. engine bay shot with juice
  137. Intercoolers needed for a TT setup?
  138. ATI Owners with Tension Assist
  139. NOS question for 84.
  140. Forced Air on the Intercooler?
  141. Hot Rod mag this month....great article on Turbos.
  142. ANYONE RUNNING A TNT NITROUS ON A LT1
  143. Procharger air filter on 1991
  144. Opinions on Paxton SN89....?
  145. Procharger installation guide
  146. 87 vette with pcv problem after SC
  147. Common problems and issues
  148. Stupid question concerning power brakes with boost
  149. Will Balancer On LT1 Spin With A Blower?
  150. TIMING RETARD USING 100 SHOT
  151. Noob want to know about turbo'ing an L-98
  152. PCV System for Boosted C4
  153. NOS Novice
  154. They say it can't be done but I'm going to do it! Electric Forced-Induction!
  155. Juice + Boost...whats it like?
  156. Zex wet nitrous system
  157. Vortech Blower on a '94 383
  158. Nitrous-stock
  159. Just purchased a 350ci block what to do and doing it right!
  160. Supercharger, need answers
  161. dedicated fuel system for NOS
  162. Turbo projects
  163. No cold start injector on SuperRam?
  164. Times before Nitrous?
  165. Pillar guages, help!
  166. Moving MAT Sensor on SC C4
  167. Parts for a D1-procharged LT1?
  168. Does anyone know when the zf-6 will break? (power wise)
  169. Oil film in side the intake manifold
  170. ZF 6-speed rebuild kits
  171. Experience with superchargersonline.com?
  172. Win over frod SVT lightening at 5psi...need help
  173. Callaway Twin Turbo
  174. Intercooling options
  175. stock lt-1 with spray goes 11.52@116
  176. Mods for an 84
  177. Cog drive
  178. Any one running the Mcloed street twin?
  179. Looking for transition hose on FI setup.
  180. long tube headers for an LT1
  181. FORGED PISTONS ????
  182. Novice needs SC advice.
  183. Value of ATI twin intercooler set up ?
  184. [Calling TJWONG] Your other ride??
  185. mounting bracket
  186. difference's between ATI's P600B and D-1?
  187. Accel Gen VII+ tune
  188. 383 SC/EGT's AFR
  189. Any info on a 100 shot for a LT4? Please Help
  190. eBay find!! Considering...
  191. what kind of damage am i looking at if...
  192. air-water after cooler......one more time
  193. What plug gap should I use
  194. One phase done a few more to to go on my T Trim updrade!
  195. 100 TNT Spray without retarding timing?
  196. Boost and Octane
  197. ATI D1SC head unit...what parts needed?
  198. Belt tensioner?
  199. Searched for intercooler threads, couldn't find any? D1 kit make sense?
  200. my weekend project..uugghh! New ram ducts for my intercoolers on a 91
  201. Track with my NEW Car...... Baseline Runs.....
  202. What Gap with MSD and ATI
  203. Nitrous Help Needed!!!
  204. Vortec vs Procharger
  205. 91 Superram supercharger pics
  206. For Procharger LT1/4 8ribs/cog conversion mounting barcketry
  207. Timing Retard without using MSD
  208. lt 1 balancers
  209. BOV for SC on your car!
  210. NOS info/help please
  211. 91 Superram is now Supercharged
  212. Need supercharger/turbo info
  213. Anyone using a single wet fogger nozzle on their lt1?
  214. 1990 L98 ProCharger running Too Lean - Need Help
  215. using the cruise control switch for nitrous?
  216. Thinking of Future D-1 or F series ATI Procharger?
  217. Cheapest Nitrous setup to get a L98 car near the 12's?
  218. Did you high psi guys require special pistons?
  219. Manufactured Turbos
  220. Turbo Project
  221. Could use a recommendation on Fuel System parts.
  222. Ran over my intercooler last night....
  223. Where'd the post go???
  224. Rough running ATI supercharged 86 Vette
  225. Dyno'd on a 100 shot this week-end, results within
  226. Engine build-up for FI
  227. AFR LT4 220 Heads and LT1 Intake Manifold
  228. Considering supercharging, real dummy need help
  229. Stock early C4 fuel pump & 500 horsepower?
  230. d1 install advice please help
  231. Help ! ! ! need nitrous info for l98 roadster
  232. fuel problem on a 383
  233. Dose anyone have ATI with out intercooler pics
  234. Boost loss with new motor, is this accurate?
  235. J&S Ultra Safeguard knock retard with P600B Procharger on a 86`th C4
  236. I am new to nitrous. Thinking of installing on my 85.
  237. How much will I gain with a procharger
  238. D1 producing 10 psi when cold, only 5 psi when hot
  239. ATI PROCHARGER COMING
  240. Is it worth it?
  241. Need some opinions on forged pistons
  242. Pics of Electric waterpump installation needed
  243. Anyone try the NX "N-tercooler"
  244. Who makes custom chip for L98
  245. cog drive setup?
  246. Wil a LT1 intercooler fit
  247. how big a shot can this set up handle
  248. S/C on a stock LT-1
  249. Nitrous in 5th/6th with 4.10's?
  250. Need Pics and instructions for Procharger
