- Procharger kit... anyone have pics and details?
- Is it really neccessary....
- Turbo kit? or Just turbo headers?
- Need help with boost and fuel gauge install
- Need help to start with my mods on my L98! =)
- Turbo C4 guys... advice needed for future...
- F-fody turbo pics
- F.A.S.T. ecu and turbos
- Single turbo Lt1 headers
- i love this vid
- Good cam for supercharged L98?
- Here is a good supplier for SC hoses
- Selling an forced induction LT1 shortblock
- The biggest Drag Racing Event in 2004 Feb 19-22
- What is Necessary Octane for 12:1cr?
- Injector Sizing
- N2O arming switches?
- good turbo for l98
- Knock Sensor in Water Jacket???
- Huge turbo: this fella around these forums?
- Good Nitrous Setup???
- cogged belt info or 8 rib pulley info
- GM 1985 TT Corvette
- Anyone heard of these guys?
- Blower Problems?
- Blower vs MAF?
- Best Suppliers?
- Turbo exhaust flange and pipe questions.
- My LT1 Vortech Supercharger kit is for sale
- need help with displacement and turbo size...
- 93 Pro Charger Install Help.
- this has been on my mind for awhiile...
- Addressing the Vacuum Pump Issue
- 100 vs 150 shot
- what's it worth
- Vortech Supercharger Kit 94 95 96 LT1 - For Sale
- Hats off for John....
- N2O jets?
- Supercharger Install
- activation switches?
- Ricer + Gas = Boom!
- I am SUPERCHARGED AGAIN :)
- KY vette owners. Write your state reps NOW. KY is trying to outlaw nitrous!
- Turbo efficiency question
- Feeling out sale of supercharged LT1 engine package
- I like this Body kit
- Supercharger for $160
- Mr. Gasket Crank Case Evacuation
- where can I?
- S/C on 12:1 motor with 110 race gas?
- S/C....is buying a used one OK ?
- FMU's and speed density ?'s.
- YS Trim on ebay
- GMPP LT4 kit
- "Zex" dry system, will my car handle a 75 shot ok?
- Belt tensioner, new belt, on D-1 3.7 pulley size
- Wastegate sizing?
- blown small block combos??
- Propane torch to heat NOS bottle - How dangerous is this?
- Hit the NOS today for the 1st time
- How much noise have you experienced with SC cog drive?
- Rough Idle after procharger install...Please help.
- Any preferred N2O system for a L98?
- ATI 2.55 & 2.25 pullies
- What to do now???????????
- Magnusons new blower
- dual N2O bottle brackets, which ones?
- best way to find the right blower cam?
- camshaft??? confused...
- Help with N2O braided line
- ECM programming for 90 - L98
- New to NOS and I have a few question.
- Newbie questions on Supercharged LT1
- My header quandry....I need serious suggestions.
- Nitrous - DRY or WET for L98?
- Procharged Big Block
- [paging vette noob]
- Is anyone using accell header plugs w/ Nitrous?
- N20 install....
- Turbos and compressions ratios
- NGK plugs?
- What brand of fuel injector to buy???
- Intake and forced induction
- Noszle ??
- ProCharger or stroker?
- Where to find DIY turbo parts
- Has anyone ever had a solenoid failure?
- First Time NOS user
- C4 turbo kits
- Long tube vs short tube headers
- Interesting Turbo Question.
- Rear mounted turbo
- No slip for supercharged L98s?
- Smaller pulley for P600B
- Callaway Twin Turbo Upgraded wonderbar
- What plugs to run w/ nitrous?
- Zex kit on a L98?
- Turbo on C4 using my procharger piping?
- My new toy:
- Camshaft for blown L98??
- Question about the purge lines.
- Procharged stock LT-4?
- Banks New Twin Turbo system for the C4......possibly
- Modified Callaways Twin Turbos? Anyone done it?
- need opinions on my d.c.r.
- Nitrous bottle orientation
- About to order an ATI Procharger P600B HO - Questions...
- NOS questions can someone help??
- Any S/C guys interested in a Vortech T-trim...
- WTB 1996 original equipment owners manual and black zippered case
- Is it possible to fit a z06 engine in a c4
- N2O advice?
- safe compression for 125 shot of juice?
- Any guess? hp?
- do they make a roots style blower for C4 vettes?
- Stock or stroked w/ SC?
- Venom Nitrous
- Nitrous done neat
- Hot Rod mag/turbo L-98 C4
- N2O.....
- Can you check my math???
- NOS system recommendation for LT-1
- Turbo Fun
- 1992 Twin Turbo Corvette LT1 kit for under 5 500 USD? (Project but realistic)
- Here is the 2nd pic of the 86
- 86 almost done
- Electric vacuum pump???
- Is Mono Blade too big for my engine?
- Instructions?
- N20 tank locations?
- HotRod: Guide to turbochargers
- Do it yourself SC?
- L98 w/ Nitrous............SAFE?
- Trying to get a general idea of Turbo/super charged L98/LT1's
- Fuel pressure isolator install through firewall question
- Nitrous Gauge: Eletrical or Mechanical?
- Spark Plug Recommendations
- new ngk tr-6 plugs miss fires after 4 runs with 100 shot what' up
- LT-1 Hot Spark ignition systems ???
- ATI procharger and Camber Brace
- [NITROUS] Should I pull timing on my LT4.....
- 84 NOS question???
- Anybody ever put a LS1 motor in a C4 corvette?
- engine bay shot with juice
- Intercoolers needed for a TT setup?
- ATI Owners with Tension Assist
- NOS question for 84.
- Forced Air on the Intercooler?
- Hot Rod mag this month....great article on Turbos.
- ANYONE RUNNING A TNT NITROUS ON A LT1
- Procharger air filter on 1991
- Opinions on Paxton SN89....?
- Procharger installation guide
- 87 vette with pcv problem after SC
- Common problems and issues
- Stupid question concerning power brakes with boost
- Will Balancer On LT1 Spin With A Blower?
- TIMING RETARD USING 100 SHOT
- Noob want to know about turbo'ing an L-98
- PCV System for Boosted C4
- NOS Novice
- They say it can't be done but I'm going to do it! Electric Forced-Induction!
- Juice + Boost...whats it like?
- Zex wet nitrous system
- Vortech Blower on a '94 383
- Nitrous-stock
- Just purchased a 350ci block what to do and doing it right!
- Supercharger, need answers
- dedicated fuel system for NOS
- Turbo projects
- No cold start injector on SuperRam?
- Times before Nitrous?
- Pillar guages, help!
- Moving MAT Sensor on SC C4
- Parts for a D1-procharged LT1?
- Does anyone know when the zf-6 will break? (power wise)
- Oil film in side the intake manifold
- ZF 6-speed rebuild kits
- Experience with superchargersonline.com?
- Win over frod SVT lightening at 5psi...need help
- Intercooling options
- stock lt-1 with spray goes 11.52@116
- Mods for an 84
- Cog drive
- Any one running the Mcloed street twin?
- Looking for transition hose on FI setup.
- long tube headers for an LT1
- FORGED PISTONS ????
- Novice needs SC advice.
- Value of ATI twin intercooler set up ?
- [Calling TJWONG] Your other ride??
- mounting bracket
- difference's between ATI's P600B and D-1?
- Accel Gen VII+ tune
- 383 SC/EGT's AFR
- Any info on a 100 shot for a LT4? Please Help
- eBay find!! Considering...
- what kind of damage am i looking at if...
- air-water after cooler......one more time
- What plug gap should I use
- One phase done a few more to to go on my T Trim updrade!
- 100 TNT Spray without retarding timing?
- Boost and Octane
- ATI D1SC head unit...what parts needed?
- Belt tensioner?
- Searched for intercooler threads, couldn't find any? D1 kit make sense?
- my weekend project..uugghh! New ram ducts for my intercoolers on a 91
- Track with my NEW Car...... Baseline Runs.....
- What Gap with MSD and ATI
- Nitrous Help Needed!!!
- Vortec vs Procharger
- 91 Superram supercharger pics
- For Procharger LT1/4 8ribs/cog conversion mounting barcketry
- Timing Retard without using MSD
- lt 1 balancers
- BOV for SC on your car!
- NOS info/help please
- 91 Superram is now Supercharged
- Need supercharger/turbo info
- Anyone using a single wet fogger nozzle on their lt1?
- 1990 L98 ProCharger running Too Lean - Need Help
- using the cruise control switch for nitrous?
- Thinking of Future D-1 or F series ATI Procharger?
- Cheapest Nitrous setup to get a L98 car near the 12's?
- Did you high psi guys require special pistons?
- Manufactured Turbos
- Turbo Project
- Could use a recommendation on Fuel System parts.
- Ran over my intercooler last night....
- Where'd the post go???
- Rough running ATI supercharged 86 Vette
- Dyno'd on a 100 shot this week-end, results within
- Engine build-up for FI
- AFR LT4 220 Heads and LT1 Intake Manifold
- Considering supercharging, real dummy need help
- Stock early C4 fuel pump & 500 horsepower?
- d1 install advice please help
- Help ! ! ! need nitrous info for l98 roadster
- fuel problem on a 383
- Dose anyone have ATI with out intercooler pics
- Boost loss with new motor, is this accurate?
- J&S Ultra Safeguard knock retard with P600B Procharger on a 86`th C4
- I am new to nitrous. Thinking of installing on my 85.
- How much will I gain with a procharger
- D1 producing 10 psi when cold, only 5 psi when hot
- ATI PROCHARGER COMING
- Is it worth it?
- Need some opinions on forged pistons
- Pics of Electric waterpump installation needed
