- NOS not hitting! Please help
- 10-rib conversion for the LTx based C4
- Finally got my Wideband O2 installed
- 1083 rwhp from turbo'd 406
- Rick Baldturbofreak
- New fuel lines
- CO2 Intercooler Sprayer, are you ready for the results!
- Tuning a Supercharged LT1
- Source for -3AN Hose?
- Cog Pulleys?
- Horsepower Formula vs. Dyno Results
- SRP-Pistons vs AFR?
- D1 R for sale
- Purge Kit to Dual Purge
- How many #'s for this injector??
- HP support for ATi Lt1 IC?
- question for those purging out the side fender gills
- Part Throttle surge at 0 PSI?
- Flexible Intake tubing...Where???
- Car back on the road, and running like poopie.
- The Smallest Nos Shot For A 85 L98
- pictures of intercooled procharger?
- an fitting sizing
- AFR heads with shaft mount rockers
- Tune for Boost....
- top/bottom or SS intercooler?
- High RPM miss still present after DFI
- Used ProCharger for sale @ 1/2 price
- Nitrous Go BOOM !
- Nitrous Go BOOM !
- How do you tune for timing retard?
- Tuning parts in Hershey area?
- FuelAirSparkTechnology-FAST- SEFI8LO Engine Management System
- Less Than Happy With ATI System
- Adding NOS to my Supercharged setup
- [help] Quench, comp ratio, detonation, SC
- Group Purchase on 5 gallon Torco Cans...
- Fast (speed pro) system into an L-98?
- Still Trouble shooting A/F ratio & Pressure!
- Beltless Boost Project Stage II
- Those doing turbos: (update please)
- 8 rib belt conversion???
- zex nos kit owners.. what jets are you running?
- Intercooler for L98 ?
- lt1 compucar nitrous kit f.s.
- Supercharger Boost Questions
- 14.7:1 AFR on a boosted motor?
- A little help on getting extra air to the inner cooler!
- ATI Intercooler for LT1 Corvette on eBay
- keyed hub
- Free Dyno and I smoked my clutch
- Question on L98 Supercharging
- hiding a NOS system
- IAT question: BOOST AND JUICE
- Newbie questions on supercharging
- forced air
- Build your own MSD RPM pills info...
- Finally sorted out problems with the vette....thanks
- Rpm info for window switch...where?
- Remote mounted turbo
- only picking up .5 sec with a 125 shot.
- Is it safe to drive car while not tuned???
- Fuel Pressure regulator suggestions?
- Purge Kit Locations---Pics wanted
- Procharger and a DFI
- Super ram and nitrous
- Attempting turbo install, got some Q's
- needed istall instructions for a nos wet kit
- ATI supercharger for sale
- New SC'd C4 owner....
- A/C for intercooling?
- Help Please w/ Gen 7+ Setup
- Another approach to belt slippage!
- NOS help needed
- Like New ATI P1SC For Sale!!
- Failed emissions... help!
- nos problem..loosing power.
- Jacobs Electronics Nitrous Mastermind yes or no
- Using under hood channels for cold air
- Eureka!! I found the problem!!!!!
- Nitrous jets
- Nitrous with methanol as teh fuel enrichment
- Plug Wire Change! Another engineer has to die!
- Using a wastegate for a blower! ... Yes, a wastegate
- Cleaning Your Nitrous System
- Took my problem to the Dyno today!
- Detonation under boost fixed....
- dyno results but dissappointed
- turbo sizing
- Who should pay?
- Help! Problems getting blown Vette to perform.
- BS Callaway ebay find...buyer beware!!
- ? about running Juice and TPI
- Pics of a "real" blower
- [pics] Blower? What Blower?
- Still Trouble shooting ATI Blower!
- NOS and ECM learn. Question
- Can boost-refrenceed retard be used in nitrous application?
- Fuel Mileage question
- stock fuel pressure lt1?
- Full pillar gauge pods
- Pressure drop across intercooler
- zex dry vs. nx hitman wet
- ASP will make me a cog drive, but warns me not to!
- Procharger P600B gears and Intercooler
- What's the most turnkey belt upgrade available?
- Are there any good west coast tuners for s/c vettes?
- supercharger guys how much timing?
- Anybody ever use these to cure collector leaks?
- Boost air temp and air sending unit
- NOS on slightly modified L98, some questions.....
- RPM Question!
- Runing 9-10psi
- NOS kit part#05151...F/S..TPI wet..84-96
- Spark plugs change?????????
- ECM, PCM, EDIT ??? Tuning!
- I pod Install ? on 93!
- I got some C16 race fuel today
- Converting D-1 ProCharged 383 L98 to LT1 Intake
- Agostinto 396, D1 charger, etc, What ECU is needed
- installed procharger
- Watch this nitrous explosion vid
- MSD Distributor Install w/ FAST
- msd start/retard box
- 100 shot safe on stock LT1?
- Turbo cam recommendation needed
- Nitrous Express Relay
- I Now Have An 8 Rib Blower Drive!!!!
- Boost Problems.
- New ProCharger=No Change ???
- How and where to hide nos lines and nozzle on l98
- supercharging for road racing
- Ask Pro Charger
- TPI schrader valve
- max ati intercooler CFM
- Let me see where you all mounted your purge switches
- Procharger fuel pump
- FROM DRY TO WET KIT ?'s
- Who makes an adjustable 50-75-100-125 nitrous kit for my car??
- Guys with nitrous in hot weather climates....
- L98 timing with Nitrous?
- twin turbos
- Tell me how N2O actualy works
- c4 twin turbo kits?
- Holley NOS TB Nice!
- Which MSD "Window" Switch do I need to get?
- procharger air filter does not fit
- Whats a safe AFR ratio with vortech/stock lt1
- Tell the truth, Vortech owners
- Nitrous and DFI???
- ADD NITROUS SISTEM TO MY SUPERCHARGED??
- Is it worth it? L98 Supercharged?
- help procharger keeps throwing the belt
- ATI kit and more for sale
- S/C with vented opti question
- water/air intercoolers
- Zex Installation Notes
- What do you do with the A/C if you get 8 rib.
- vortech install tip
- dumb newbie question
- Procharger Results from DEZ Racing in Seekonk MA!
- boost guage, easiest place to run line
- Dyno Results Procharged
- To high comp?
- Saw a Viper with Nitrous and Propane injection.
- quick procharger question
- group purchase on WBO2
- Anyone using a water injection unit?
- how much RPM increase with nitrous ?
- Beltless Boost Project.........For Sale?
- if you need a nos refill in cny i can do it.
- Calling tjwong for some Maf questions..
- vortech owners, what weight oil r u using
- Video...not a vette but must see!
- guys lookn for guage pods look at this.
- will a 10lb nos bottle fit in rear cargo?85
- Which brand Nitrous Plate has a nozzle on both sides?
- Accusump oil accumulator
- MAF, stock or not?
- Has anybody seen these on ebay?
- Turbo-oil lines?
- where to get n2o????????
- Stupid Question?
- Walbro installation kit Part number?
- Question for Vortech LT1 owners
- PCM and DFI????
- Oil scavenge Pump? WHere can I find or how can I make one?
- custom intercooler pics plz? ( L98 supercharger)
- whered thesmog pump go? with procharger?
- Heads-up and bracket racing at E-Town, June 26th!!
- HELP! installed new fuel pump - regulator, wont hold pressure
- Need 10's, how much NOS?
- ??? about NO2...more blow by???
- Stripped 20 tooths today
- cam for supercharger?
- Low Oil Pressure
- 1khp people....
- Turbo gaskets
- Need a new PROM
- Slight stumble when I first hit the button .... ?????
- Dry or Wet, 100hp on stock LT4....
- low alt voltage since procharger installed
- Any 10 second C4's around here?
- Injector Size Advice
- Lets get the power to the ground!!!!!
- 100 shot dyno numbers
- Electrically assisted turbo
- 600B and D-1?
- Dave Stone's 9-second C4 - blown intercooled
- For those of you that are using kenne bell's boost a pumps
- How long did it take to get your twin disc?
- Anyone have good tune with s/c & 30lb injectors
- What spark plugs?
- Dead spot in throttle after ATI and MSD install
- Dyno tune this Friday/Sat
- FI LT1/4 guys What ignition to buy for the most spark?
- zex nitrous kit
- Air-Air Intercooler vs. Alcohol Injection
- super chargers which one?
- ATI surge valve position. Before or after IC?
- The spray is finaly tuned....Best new time, woot!
- how big can i go with my tires
- 88 L98 with 100 shot of Nitrous...What HP and TIME????
- what ati model to go with for 91 l98
- supercharging the L98, maybe......and supercharger questions.....
- Cracked Intercooler
- ATI procharger P600B with HKS SSQV instead of ATI surge valve possible?
- I need help with .bin file for my twin turbo LT1 corvette project
- Modifications to maximize HP for 1985 L98 (no nitro)
- Can't find affordable turbo!
- will gen. 6 support 4x3 overdrive ?
- Which exaust set up would best suit a L98 supercharged vette
- Guestimate on how much RWHP?
- How much should the fuel pressure rise with a FMU?
- Under the fuel rail cover direct port Nitrous
- Lt1 to Lt4 Conversion Kit
- Turbo Setup
- Question on tubing/hose for boost/vacuum gauge?
- Delayed again.. wife broke Valve spring on her 95..
- Which runners on a LT5 should be used for a direct port setup?
- gauge setup for nitrous installation?
- ProCharger Owner step in side
- 95 LT1 need more power
- aftermarket hood cutting Q's
- HOLY COW.. New Turbo came in today....
- educate me please, what is needed for a 150 shot vs. a 300 shot?
- Safest nitros setup
- Look's like a good deal
- Custom blower installation
- Vortech Install with a After-market Radiator Problem?
