View Full Version : C5 Forced Induction/Nitrous
  1. Nick Williams 90mm TB - The Latest Version...
  2. F...k; I got 572RWHP/538T on D1SC!
  3. any recommend for NW Fla S/C install?
  4. No cut Procharger install
  5. Kelly Chevrolet's answer to my SC!! What a FN...Joke!
  6. Headers required with S/C ????
  7. East Coast Supercharging
  8. 01 vs 02 Z06 with MagnaCharger
  9. access to ecm?
  10. Head/Cam or Supercharger setup?
  11. Transmission Cooler Instal
  12. Scca Solo
  13. Humidity + 80+degrees = Run like crap?
  14. The age old question . . . new gear or stay with the 3.42
  15. The Vette Dr's Come Through In a Pinch!!!
  16. All these fuel pressure drop off problems at high rpms are making me nervous
  17. Picking up the car tomorrow
  18. Finally the LPE 427cid TT stage 3++ is on the way!!
  19. Got my Vortech in today!
  20. Fuel Rail Covers
  21. maggie no whine
  22. 383 Twin Turbo Z06 Pics
  23. Any S/C C5's still running Stock Clutch?
  24. ATI car tuned for sea level moving to 4500ft?
  25. IC Magnusons are in and on sale!
  26. Racetronics FP Press.?? PCV setup; which way????
  27. Unique one off ATI blower FS
  28. Has anyone tried this for a fuel system upgrade?
  29. 4.125 stroke with boost/nitrous???
  30. Need BIGer injectors?
  31. Come along for a ride (video)
  32. Wtb: Procharger Pulley
  33. automatic trans question please help
  34. Anyone look at their oil pan lately?
  35. Everyone with NXL kit inside . . .
  36. The MAG is on!
  37. Incredible supercharger installation rates!
  38. need pictures, advise
  39. My Car Will FINALLY Be Back Friday
  40. Any one use 7/16" head studs?
  41. Opions On Nxl Dp Good Or Bad
  42. Shifting with N20?
  43. Anti-boost
  44. anyone got a 6 rib 4,10 reichard pulley for an ati they want to sell?
  45. Wheel2wheel 1560fwhp turbo LS1
  46. Car is in ECS hands now - Guess the results!
  47. Tight belts need latest alternator bracket
  48. WTB Exedy twin Clutch...FAST
  49. Supercharger IC/AC Weights
  50. Help
  51. On Spay, New A4 wont shift 3rd
  52. On Spray, new A4 wont shift to 3rd!?
  53. Which way does the pulley on the blower rotate?
  54. F1-R head unit on ebay $2K 'Buy it now' price
  55. Installed used nx wet kit. WTF?
  56. Ati has a rattle sound, is this normal?
  57. MSD Didgital Window Switch
  58. High rpm noise?
  59. Heat extractors?
  60. Where can I find a custom power steering pulley??
  61. Road Racing with the Magnacharger
  62. Important question from LPE 427cid TT owners!!
  63. C5 Magnuson blower fits on a C6?
  64. More Belt Slip Discussion
  65. Important question from LPE 427cid TT owners!!
  66. you want a vortech?????
  67. Anyone using the gatorback belts?
  68. MSD Window switch
  69. Anyone Have Results to Post on FI Car with Nick Williams 90mm TB and 90mm FAST Intake
  70. Patriot Boost LS6/6.0L Heads Specs & Info
  71. Twin Turbos Now Home
  72. N2O Not Hitting Anymore...
  73. goodbye twin turbos, hello A&A D1sc!!!
  74. Any vendor have a 3.3" pulley for magnuson 4sale?
  75. NEED OPINIONS ON TNT vs. NOS
  76. Smoked by a modded SVT, need a lttle help!
  77. What are your Bat Volts and idle with the SC?
  78. Intake options for procharger...
  79. Custom ECS SIC D1SC ProCharger Is Done
  80. Magnacharged Auto Dyno Results
  81. What fuel system are you guys running for 700rwhp plus?
  82. '98 IAT sensor location w/ Andy's kit
  83. Modern Day Muscle Cars and EatRice
  84. adding 21st century cam to Magna via ECS
  85. Pulley Sizes for Procharger P1s
  86. ECS......Magnacharger installations
  87. Head Cam & vortech cars
  88. Magnacharger belt jumping update
  89. 1/4 mile times with A&A P1SC
  90. Dyno #'s are in from A+A kit.
  91. I Need Some Blower Cam Advice / Recommendation
  92. What's a good cam to go with the ATI D1SC setup?
  93. Procharger
  94. I/C MAG does 509rwhp 474rwtq!!!!
  95. At a 100 shot right now, will I have issues w/125?
  96. Has anyone relocated their battery?
  97. Smaller supercharger for custom system
  98. Silly question regarding TRAC. control on S/C C5s
  99. Tensioner position?
  100. Magnacharger belt jumping off
  101. 2004 Vortech superchargers are ready to go!
  102. TR6 Maintenance
  103. Fabrication questions..Alternator, PS Pump, Brake lines...
  104. Twin Turbo Exhaust
  105. VetteDoctors - Magnacharger Install?
  106. HOT deals on all ATI superchargers!
  107. Z06 went to FLP TODAY!!!!!!
  108. Supercharged 600-700rwhp Tire Experience?
  109. Cost estimate for dyno tuning nitrous?
  110. What is Andys Website Address
  111. A+A Procharger installed!!!
  112. Vortech SC V2-SQ pulley?
  113. New Excedy Clutch Instaled! Thanks Tommy & Andy
  114. Novice Question about Magna Blower
  115. Looking for N20 overview
  116. How many shots? help
  117. Boost gauge question
  118. Are Headers neccessary?
  119. Horsepower Limitations on Stock Block?
  120. Anyone use an aluminum radiator with the Vortech kit?
  121. Pics of my new Motor City Magnacharger Hood
  122. Is it summer yet? My winter project is finally done!
  123. BLUHEVN finaly done
  124. Just diagnosed my nitrous problems...
  125. What size shot to run?
  126. Woo Hoo - I am smiling again!
  127. Cam for magnacharger?
  128. ##A&A bracket boost results - from MMS bracket##
  129. Belt change with A&A bracket?!?!
  130. ATI Procharged Corvette vs Corvette on 150 shot
  131. NXL Jetting Problem, HELP!
  132. diffrence between wet,dry, and direct port systems
  133. What is your gas mileage?
  134. NOS for 03 stock vert
  135. Is this possible/likely?
  136. A&A Setup has 3psi what's wrong?
  137. LGm recommends 1-3/4" for high HP F.I.
  138. My buddy is telling me there are MANY 700rwhp plus SC'd C5's?
  139. Many questions for you FI guy's.
  140. Fuel pump SOCK replacement?
  141. Please post pics of Mag hoods on your verts
  142. MTI's Latest Project Car ....
  143. Is a Retune required after a BOV change?
  144. track times Sc vs H/C
  145. D1SC on a Stock Bottom End
  146. DTC's set for Bank 1 & 2 running lean
  147. 02 ZO6 IC Magnacharger Dyno results
  148. Dyno Results for A&A's P1 With ZO6 cam
  149. Single Kit Update
  150. Snow Performance vs. Alky Control Meth Injection
  151. Twins Versus Superchargers
  152. Alternator nut spinned off!
  153. Caravaggio hood installed
  154. Need info on FI fuel delivery...
  155. NXL kit not until August?
  156. What is a Vortech Race Bypass worth?
  157. FS: ATI P1SC Dual Intercooler kit
  158. S/C owners...benefits of stock BOV vs Vortech BOV?
  159. Wet shot junkies read this please....
  160. Power wire for electronic boost gauge?
  161. Stock rods???
  162. Ic Magnacharger Running Hot
  163. Change timing chain for S/C install?
  164. Short Videos of my A&A Procharger and Kooks Longtubes
  165. Dyno results from MTI.......
  166. Brand new still in box A&A procharger
  167. First time @ track!
  168. A&A Single Intercooler Location
  169. A little tech questions about maybe whats wrong on my car
  170. Throttle body oil issue 04 coupe/Magna
  171. Buying a used C5 and need suggestions
  172. Crank pinning kit
  173. F/S: ATI D1SC head unit
  174. 1st Run on Norris Dyno, Sad day for me..
  175. A few supercharged questions
  176. ATI D1SC -- Single vs Dual IC's.
  177. 405RWHP and only 13.7 at the Track WTF?
  178. Excedy Clutch Package Anybody Install One Yet?
  179. A Special Thanks to East Coast Supercharging! 700RWHP!!
  180. Wheels Size
  181. Caravaggio S/C Hood owners
  182. double post sorry
  183. AC Compressor Bad (have to remove supercharger)?
  184. HEADERS OR TRANS...for PS1?????????????
  185. Where to get an ATI Supercharged Z06 Smogged in Cali?
  186. Air conditioning air pickup location??
  187. Finally installing the Procharger
  188. Need a belt.
  189. Anybody seen a single turbo kit capabe of supporting 1000+ horsepower?
  190. Boost referenced regulator tuning
  191. Rev Limiter on a FI car???
  192. A company that stands behind their work.
  193. What additions reccomended with Nitrous "Kit"?
  194. 1st Vortech Dyno
  195. why doesn't paxton make a sc kit for the c5?
  196. anyone have the zex purge lights?
  197. Nitrous questions, please advise!!!!!
  198. SC overboost problems for all stock LS1 engines
  199. what should i expect
  200. Nice Fuel Rails On The Way
  201. High revving motor?
  202. All right! I'm back!!!!
  203. Installed my TPIS headers, Xpipe and Racetronix fuel pump this weekend
  204. FYI - for those with Electrical PVC intake Tube......
  205. Anyone interested in a Wide Band O2 system???
  206. Can anyone give me a list of Magnacharger hoods?
  207. Keying the crank.
  208. What Size Pulley
  209. Found Boost vs. Static CR chart
  210. Props to LAPD Tuning Guy and Patrick @ Vararam!!
  211. Help - New Supercharger slower 0-60 times
  212. HAVE YOU SEEN THIS FUEL RAILS
  213. gettin water on the window when on the juice
  214. First pic of my new S/C setup and one Tech question
  215. Direct port injection - what kits are there?
  216. Nitrous Bottle Mounting Angle? Prob?
  217. Hi everybody, NICKSLICK BUSA rider here with video of vette races...
  218. Andy does the right thing
  219. How long did you wait for your A&A SIC Setup
  220. GOOD cam for N/A and Nitrous
  221. Quick pic of what to lookout for when getting Mag installed
  222. Looking for a tuner in NH or Mass.
  223. Nitrogen Spray Jets on Single Intercooler
  224. How many people need 8-rib setups?
  225. Looking for Post by Andy on Easy Belt Replacement on ATI Vette
  226. Alcohol Injection on i/c magnacharger results
  227. JBSBLOWC5 Pulls on a Yamaha R1 and Does 185MPH on GPS
  228. Looking at a Magnusson s/c LS1 with manual tranny. Does the year matter?
  229. A&A Procharger and extras installed First impressions… LONG, but lots of information, Pictures
  230. Call it a day or add more boost?
  231. Too Much Boost on Dyno
  232. Supercharging VS. Nitrous
  233. 85MM MAS for a 2000 Procharged Car
  234. Need to know 2 things about goin F/I
  235. Need cam options for ZO6 with a Vortech!
  236. BOOST QUESTION
  237. will my auto tranny handle 500-525 rwhp?? 2001 coupe?
  238. 3.90 or 4.10 gears???
  239. OHHHH MYYY GAWD!!!!!!! kinda long
  240. Can someone tale a picture of their mag. for me
  241. A&A Corvette Procharger Kit with the LGM Headers
  242. Dewitt's Rad Arrived Today
  243. Looking for a piece for NX bottle.
  244. magnacharger
  245. 427 TT questions..........will someone please help
  246. fuel pump guru for TT
  247. What's Normal - Coolant temp with AC vs NO AC ?
  248. Still seeing belt dust after 1000 mi after install...
  249. Still losing some fuel pressure :(
  250. A&A ATI kit and LG Headers question on Z06
