View Full Version : C5 Forced Induction/Nitrous
  1. Racetronix fuel pump running out up top
  2. How are you guys breaking in new motors and still dyno tune?
  3. 21st CMC Stage II Twin Turbo. 608RWHP and 580ft-lbs Torque...
  4. FS: NX Wet Kit with extras
  5. Next power plant?? Bore +/- stroke
  6. All ATI superchargers are on sale!
  7. Experience with "Vette Shop"
  8. Had a great time at Carlisle with ECS
  9. would i blow up my car if...
  10. in the 11's
  11. FI &warrantty ?s
  12. Made it to the track
  13. MDMC 346 790RWHP and 675RWT
  14. 100shot +3000stall+otherwise stock A4=??
  15. Onboard computer is in (pics inside).
  16. New Quiet T-trim
  17. Design your FI parts by mail...
  18. A4 with ATI
  19. 757RWHP and 667RWT @ 5800rpms!!
  20. Mag + nitrous anyone?
  21. How restrictive is the Ti exhaust for (relatively) high HP cars?
  22. Reduced pricing on 5 Gallon Can of Torco!!
  23. Brief Review of Alky/Meth Injection kit...
  24. ECS did a great job – photos inside!
  25. Moderate bolt on horsepower?
  26. Modern Day Muscle Cars and EATRICE 346CID 900HP
  27. Props To Andy at A&A!!
  28. SC Setup
  29. So What Kind Of Heads Does Everyone Like For FI ?
  30. A4 gearing with ATI?
  31. new with ANDY p1sc
  32. I'm looking for a picture of.....
  33. You have less fuel pressure than you think...
  34. Ok whose S/C 427 is this????
  35. Learned a hard lesson at the Chevy dealer..
  36. Fuel pressure problem
  37. can i use nittos for everyday driving...
  38. Where do you guys get oil for your prochargers?
  39. Did I Setup my PCV Catch Can correctly?
  40. Questions about NOs with a4
  41. A&A Setup Questions
  42. Is there a kit made where I can switch from my NX wet kit to an NXL direct port kit?
  43. What cam is better for Mag the LPE or 21 Cent blower?
  44. Think I blew my tranny in my mag car
  45. Nitrous Express NXL questions
  46. FASTECH - Cold Fusion Nitrous GP
  47. [f/s] 2 brand new, never filled 10# NX bottles
  48. Big Cube Nitrous Users
  49. 98 fuel system
  50. direct port nitrous users
  51. IC Maggie questions
  52. Moving on...Getting a new motor...
  53. Engine carnage from F/I...
  54. ati car, catch can set up ,should i cap the passenger line?
  55. blowing up cats in FI engine, cont.
  56. Andy,s procharger or heads&cam&nitrous
  57. A4's w/ the Mag
  58. Tuners going to Carlisle
  59. 1st round thinking, Rings are bad..most likely do to tuning. :(
  60. Engine Temps
  61. ati pulley chirping noise?
  62. H & C + 150 shot...exhaust popping under accel..
  63. My lovely dyno picture..maybe this will help next time around
  64. ATI Daily Drivers out there
  65. How Deep to flycut Stock Piston and Nitrous
  66. Dyno #'s for A&A P1SC
  67. What the heck is this stuff coming out my tail pipe?
  68. Anyone want to FI an LS2 (Ebay listing)?
  69. Should I bother upgrading my gears if I get FI?
  70. 3 Huge Pages of News – Don’t Miss This!
  71. Has anyone with a Mag noticed engine tick?
  72. Thanks ECS!
  73. WTB: P1SC or V-2 SQ or other Head Unit
  74. Any of you Vortech guys running larger radiators?
  75. Man this WAITING is "KILLING ME"
  76. ? on misfire and FI
  77. TNT N2O what pressure to you run?
  78. AFR 205 Heads and IC Mag Project
  79. 2000 A4 w/a zex 150 shot
  80. Exhaust cut-out idea...
  81. Is the magnacharger and 4.10s compatible?
  82. 180 or 160 degree t-stat???
  83. C5 Hurst Shifter
  84. It's almost done! Supercharged 427 by ECS!
  85. My pig rich Dyno video! ECS KIT
  86. Where to connect boost/fuel guages on maggie?
  87. Don't expect a twin screw from whipple
  88. New fuel pump for new motor and Nitrous?
  89. Any pics of ACI Mag Fuel Rail Covers?
  90. Forced Induction SpEcIaLs @ Texas Speed
  91. If You Have On-Board Wideband O2, Please Check In
  92. Norris Motorsports / Next Level Performance Installed Supercharger Specials
  93. FMIC Efficientcy at the 1/4 Track??
  94. Dyno numbers are in from ECS...
  95. eaton M112 adiabatic efficiency?
  96. NEW ATI setup?
  97. nitrous install pictures
  98. HELP.....Need to know ASAP if I should pull the trigger....the mod monsters are takin
  99. Rev Limiter On A4w Non I/c Mag?
  100. Question about adding a dry shot to a 2004 Coupe
  101. n2o ,too rich?
  102. Tuning after S/C
  103. Ok, Who installed their own Magnason?
  104. what are u guys doing for a FP gauge??
  105. Could a nitrous motor be built for 10k
  106. A4 w/supercharger question?
  107. c5 goes 12.2@114 now w/ 4.10s, should i go 3.90 w/ ATI?
  108. What Blower In A Street Race?
  109. Fuel rail covers for Magnason?
  110. Can't decide if I should install my Procharger myself, or have it done.
  111. Tire Selection Help
  112. Andy's D1 in Heat
  113. How far should n2o nuzzle be from MAF ? (dry shot)
  114. Anyone with a Meziere water pump reply
  115. Reichard Pulley -- First Impressions
  116. So what if I want to do H/C and then S/C
  117. Gears for FI, what are you running?
  118. Ran the motor at 16:1 this weekend.
  119. Triple gauge Pillar POD?? Where.....
  120. Dry 50 +Wet 100 or just wet 150?
  121. Blower cam
  122. 6 hour drive - FP gradually drops to 55psi?
  123. gap for NGK TR6 plugs
  124. FI guys, you burning up cats too?
  125. Is My Belt Slipping?
  126. Anyone have a 4.10 6R pulley?
  127. IC Magnuson Retrofit...anyone have it done?
  128. What size fitting do I need?
  129. 500rwhp vs. 600rwhp
  130. New turbo kit?????
  131. LS1 Magnacharger vs. Z06 Magnacharger
  132. Got an A&A P1SC w/4.5" Pulley...got a question for you
  133. what do i need to hook up my...
  134. What spark plugs to use?
  135. Has anyone tried a Miller Cycle cam with their Magnusson?
  136. New Turbo's For C5...
  137. Hit 500RWHP Unlocked A4
  138. Who Has A Blown 04?
  139. Excellent article on why to use Gaseous Intercooling (IE, water/alky injection)
  140. I/C MAG and THERMOSTAT
  141. IC Mag back from ECS!
  142. now I'm forged with P1SC
  143. Anyone used RaceTronix Fuel injectors?
  144. Vortech and Paxton supercharger GPs!
  145. Question About this Nitrous Setup on my Z
  146. Alky/Meth Inj;Wide Band O2? I really need these!
  147. IDK, where to post this?
  148. Intercooled TT system for C6 - any interest from the US guys
  149. What kind of power does a LPE 550 motor make without the turbos.
  150. I need to buy a racetronix fuel pump, who has the best price?
  151. Lingenfelter installation?
  152. Back to back dyno comparison Magnacharger vs A&A
  153. Category 3 Forced Induction!
  154. What extras needed for Installing Stage III TTI Kit
  155. Super Chargers and Emmissions
  156. to s/c or not? that is the question
  157. How loud are the Magnuson's??
  158. a4 rpm shift on nitrous?
  159. Getting my car back from ECS - It's been a long time...
  160. Anybody fouled out a plug before when using nitrous
  161. Cold Fusion Nitrous Group Purchase!! - FASTECH
  162. what IAT's are you magnuson people seeing?
  163. SC/TT Vettes vs Vipers in SoCal - Sept 17th!!!
  164. Ecs Ati D1sc Supercharger Kit For Sale!
  165. Fuel Rails
  166. Which blow off valve for P1-SC?
  167. Car back from ECS!
  168. C6 cats mount directly to the manifold, E legal TT possible?
  169. Mercedes to drop Kompressor supercharger technology
  170. BlownC5 Chases 600+ HP Porsche TT!! [VIDEO]
  171. zex nitrous wet kits- good or bad ???
  172. What Will The C6 Do to the Price of F/I Kits?
  173. Did I smoke my clutch?!?@#
  174. 10.810 @ 125.75 1/4!
  175. Why doesn't anybody make a Whipple S/C kit for the C-5?
  176. Anyone know where to get the right side output shaft??
  177. 100 shot ..where's the power..help
  178. No boost from Autometer boost gauge
  179. Any F1R on - 6.0L Iron Blocks or 383 Strokers
  180. Help on Racetronics Install
  181. Anyone using a ProCharger on 5.3L Stage 2 Heads?
  182. 11:1 CR... how much N20?
  183. What's the expected 0-60 time on a SC C5 w/exhaust & Intake
  184. Got my 10 sec. run, but at a price....
  185. Help-Where to Buy Throttle Body Hose?
  186. ??? on nitrous
  187. Final question on A&A s/c Install
  188. Where to spend 20K????
  189. little extra boost
  190. Magnacharger CARB E.O. D-488-6 (6/21/04)
  191. So what research on maggie+heads?
  192. How to purge pressure without a purge valve
  193. ATI Procharger CARB Approved on Z06
  194. What Vaccuum Levels Are You Getting
  195. Broken Vortech
  196. AFR 205 Heads with 76cc Chambers...
  197. maf/nitrous/cai
  198. Does Procharger boost always build linearly?
  199. 21MC cam and 3.3 pulley Dyno #'s on my magnuson here
  200. What size jets are needed for a 100, 125 & 150 horsepower shot of N2O ?( DRY)
  201. TT and S/C Tuners in CA
  202. Twins Home Saturday Night
  203. Installed Andy's Upgraded Supercharger Bracket!
  204. Single Turbo vs S/C
  205. The Right Jets Please
  206. A4 vs mn6 driving with SC
  207. Value of a supercharged forged motor?
  208. Pillar Paint
  209. Help Can't get my belt on
  210. Tire Input (Michelin Pilot Sport Cup)
  211. How to access onboard Diagnostics?
  212. Trouble code C1283 after Magnacharger install
  213. King Pin - TTi w/out Cats Quesiton
  214. Kenny Bell Boost-A-Pump install instructions
  215. Car Going to MTI Today for Blower Cam + Tune
  216. Halltech Carbon Fiber Hood
  217. Long Trip With S/C?
  218. Lowered with Andy's SIC ATI???
  219. Tuning a D1!
  220. Who has a LPE twin turbo in Dallas?
  221. Twin Turbo or Supercharger???
  222. TUNING and 50# FI???
  223. 93 octane boosted car vs 91 octane b car
  224. 6-point rollbar
  225. First Round of #'s are in
  226. A picture of a "real" supercharger...
  227. How to pin the crank?
  228. Is Belt Slipping?
  229. Z06 Fuel Rail
  230. The joy of a superchager
  231. New to the Forum & The Mag Goes on Next week!
  232. anybody know where to buy stock fans?
  233. Need Nitrous controller recommendation..
  234. Prices and P1SC vs D1SC
  235. ? on Kenne Bell Boost a Pump
  236. Something you may not know about the ATI S/C
  237. Fun with a Ferrari 360 Modena
  238. S/C Tuners in Minnesota
  239. It's Magnacharger time! ECS has my car now.
  240. Please HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!
  241. Detuning, new FLP L5 and Vigilante converter available
  242. Who In Southern California............
  243. Sic
  244. rough idle when using a/c
  245. Finally, a killer 346 ls1
  246. Ati twin int but want to lay down rad, labor?
  247. looking for a little information
  248. MCM Hood = High Quality
  249. snapped shaft on magnuson pulley
  250. NX Wet Kit?
