View Full Version : C5 Forced Induction/Nitrous
  1. True duals with Z06 titanium mufflers.
  2. *procharger belt squeal solved
  3. Anyone Using a 2Step
  4. Injector size for ~750whp and 60psi fuel pressure?
  5. i think i got it?
  6. Reducing exhaust dB (without getting a new exhuast)
  7. opinions please
  8. FS: Gates belt laser alignment tool
  9. CTS-V with LS2/402 and ProCharger F-1A - 864 rwhp at 12.4 psi of boost!
  10. Twin channel exhaust housing valve.
  11. Video Preview of Pfadt Carbon Driveshaft
  12. CAMS No Clue?
  13. 19 lbs of Boost on SpeedyD's APS TT!!
  14. Question for Those Who Removed Factory Air Shroud
  15. TTiX No Boost
  16. maggie with headers
  17. Any help would be great. Boost question
  18. Can you run coolant through an oil cooler?
  19. progess numbers on TT vette
  20. Toys For The Toy
  21. A/F ratio?
  22. A/F ratio?
  23. Belt question
  24. GM High-Tech article on my 4L80E Conversion
  25. TTi Twin Turbo System Stage X NEW IN BOX
  26. Car is running VERY rich all of a sudden
  27. Stock C5 auto tranny, how much horsepower will they handle.
  28. Kenne Bell questions
  29. FINALLY - Boost By Gear for CENTRI Supercharged Cars by Dallas Performance
  30. Is a twin disc better for high hp than a single?
  31. ax boost on a TTIX kit????
  32. *** Unlimited HPTuners Pro Box *** See Inside!
  33. Desired IAT Value??
  34. P1 and D1 clocking, ECS, Procharger Stg II brackets
  35. Vote here!!!
  36. please help with plate kit
  37. For Sale! STS kit, complete! Pictures.
  38. polished my procharger!
  39. STS and Smoke when shifting and braking???
  40. Procharger/breather?
  41. one tune....
  42. do i sts with my 408?
  43. TTiX + stock LS6 pulls 717hp/677tq
  44. Our 8 Second Twin Turbo LS1 RX7
  45. Help, Car loads up and dies
  46. ECS SC600 + Toyo R888
  47. Anything wrong with this Belt Configuration?
  48. 3.4 and 3.6 SC pulley 6 rib for sale
  49. coolant heat issues with a TTiX kit, need some options
  50. Quick question regarding pipe routing and power steering cooler
  51. Beautiful C5 Blackwood Interior *PIC*
  52. Introducing!! **Plug-N-Play Oil Pressure Relocation Kit**
  53. Belt slip
  54. 922rwhp in the wrong hands..
  55. Two thumbs up to Jeff @ TPE
  56. Fitment Issues with Procharger install
  57. Who's running an LS2 intake manifold with FI ???
  58. serious help needed with heat problem asap
  59. anyone running FI on a stock c5 z06 LS6?
  60. I have a new Maggie Tank for sale
  61. FS: Found some old inventory - Beer Panels
  62. car rocks side to side after s/c install??
  63. NitrousDirect.com????
  64. How much does weather affect N20 cars?
  65. Boost Reference source
  66. Ls-6 or fast intake
  67. Predictions on power.
  68. Grit in intake manifold, Supercharger filter the cause?
  69. First Experience "as a customer" with TPE.
  70. TCI T-Com Transmission Controller (HaHaHa)
  71. TPE's New **Widebody** Quarter Panels {PICS}
  72. whipple / KB question
  73. Any in depth instructions for Paxton Novi install?
  74. Fuel PSI Question For Those Using BAP
  75. APS guys
  76. another procharger question
  77. How much do headers help a supercharger?
  78. Custom 2" ARH Headers and 3" Exhaust
  79. Anyone has a Procharger Stage 1 kit???
  80. Reduced Engine Power
  81. which pulley for my procharger setup?
  82. 2.08" Valve on a 3.905" Bore....
  83. 4.00" 6 rib pulley
  84. Looking for a maggie schrader valve
  85. It Lives!!!!!! MuHaHaHahahahaha
  86. boost or nitrous?
  87. Finally joined the FI club-KB inside
  88. RSI fuel hats; great product...but..
  89. installed patriot valve springs today and have questions?
  90. TTiX & LS1 Track Results
  91. Need help with oil issue from engine builders
  92. additional maintenance?
  93. What FI for forged 403ci?
  94. Turbo Rebuild
  95. Ms3 with p1sc????
  96. Provharger stage 1 kit questions?
  97. Changing DRL's with APS kit.
  98. Boost guage and Alky controller mounting options?
  99. Fuel range readings?
  100. what TT kit is this??
  101. Please help!!!!!!
  102. Maggie sticking through Hood....
  103. Worth it to build a 383 stroker?
  104. TTiX + stock LS6 goes 9's
  105. XMS Spring Into It Forced Induction Sale
  106. Who makes the HIGHEST rise hood avaiable...
  107. Check out my Fuel Cell...pics inside
  108. N/A or F/I for 600rwhp street/road race?
  109. How much did your S/C & LS2/LS3 setup cost?
  110. Thanks ECS!!
  111. A4 To M6 Conversion
  112. 500hp goal!!
  113. great stress reliever A & A
  114. Kenne Bell 2.6 versus 2.8
  115. aftermarket rocker arms
  116. Crazy Loud noise coming from Drivetrain
  117. Great customer service A&A
  118. want to spray my c5
  119. Edelbrock pro flo xt intake fitment on c5
  120. Top Mounts
  121. Ram air sheet metal mod to intercooler?
  122. Opinions on running stock rockers on FI
  123. doug rippie motorsports
  124. belt squeal
  125. •TECH TIP• How To Make The Stock Master Cylinder Adjustable
  126. For Sale: 70264 B&M Trans Cooler (Brand New "Never" Installed W/Pics)
  127. Warhawk 440ci N20 Motor Build Pics
  128. Results EPP 383 with a D1SC at 10psi.
  129. Question
  130. I think its Vortech rebuild time...
  131. Horsepower sales of florida magnacharger sale
  132. Kenne Bell Build Thread by TPE {With lots-O-pics}
  133. Now Avail!!! HUGE TPE Coolant Pumps for the Kenne Bell
  134. A and A Vortech by Vettedoctors
  135. Top Speed Numbers
  136. Anyone Have Pics of Nitro Daves Fuel Cell Installed ?
  137. Post up stock cube numbers!
  138. Custom Hidden Dry Kit for sale...(DFW,TX)
  139. Now Shipping!! **NEW** Mototron 80LB Injectors
  140. *** My Cartek beast gets some press on Lsxtv.com ***
  141. Results: A&A T-Trim Stock Bottom End
  142. Biggest Turbos for STS Setup
  143. Paxton novi 2000 z06. Expected hp/tq gains from dif. bolts-ons?
  144. Fuel system return advice
  145. Harland Sharp tells Charlie to " go pound sand"
  146. ls9 engine block
  147. Private messages not private but visible...
  148. Dynojet vs Mustang Dyno
  149. What do you have to install to reinforce a stock engine?
  150. looking to buy a forced induction system
  151. Blower input shaft seal, P1SC-1. Help please!
  152. How many cubes out of a LS-6 block?
  153. Turbo Question
  154. sheetmetal intakes
  155. *** Shop Specials at LG Motorsports ***
  156. Max boost with stock compression on built motor?
  157. P1 vs D1 for my goals
  158. *** Incredible Deal on ProCharger Installations at LG Motorsports! ***
  159. Different blower types for daily driver--good gas and massive hp
  160. Building a Fuel Cell...need advice
  161. Kenne Bell Z06 dyno
  162. Part of Factoryracecar arrives north of the border!
  163. >> NEW MONSTER CLUTCHES Available NOW !!
  164. Project TTiX FRC
  165. Oil return on A&A kit
  166. My Kenne Bell Stroker results
  167. just introducing myself to the fi section (with pics)
  168. Roots/twin-screw blower options
  169. Methonal question just switched from M3 to M1
  170. A&A stage 2 Procharger bracket belt size?
  171. Is it safe to run a 75 wet shot on my vette??
  172. YANK Torque Converters Customer Service Unbelievably Excellent!
  173. Kenne Bell results thread
  174. Length of return line
  175. stock zo6 cat back on a procharged c5?
  176. Some advice on a output shafts
  177. ouch! engine went boom!
  178. fast fuel rails
  179. Procharger stock engine??
  180. Fastest Time with 6-speed and supercharger
  181. Help me, future FI setup
  182. **Vette Doctors-ARH complete Exhaust System $1,895 Installed and Dyno Tuned!!**
  183. **Vette Doctors A&A Vortech Supercharger with Ram Air Intercooler $6,599 Installed!**
  184. Simply turn volute, or not???
  185. Alkycontrol/ECS Meth Kit Users In
  186. Re-Clocking P1SC-1. DIY job or not?
  187. Pre turbo/SC water injection.
  188. Forged crank, who sells it?
  189. Vortech Maxflow racing bypass valve for sale - used -
  190. high compression and boost.. who is doing it?
  191. GTP ported 6.0 heads.
  192. Hinson kit w/ custom intercooler setup
  193. NOS Intercooler spray bar kit. What kind of gains?
  194. •• Annoucing Klotz Synthetics ••
  195. Tensioner pulley for Maggie
  196. How often should I change plugs on a nitrous car??
  197. Powershifters... what knob?
  198. 2001 ZO6 346 forged motor P1sc1-stage II
  199. ECS Paxton novi2000 sc problems again..
  200. ecs paxton novi 2000 dyno sheet video time slip
  201. nitrous activation switch question
  202. Twin Rearmount Turbo Sizing Question
  203. Power Gain From A&A Kit?
  204. TTi X kit with an SD tune
  205. Meth kit question
  206. Another great job done by Nick Yoskin!
  207. Ram air intake, headers, exhaust, What's next?
  208. blow off valve without supercharger
  209. intercooled maggie Q
  210. spal fans
  211. 6 or 8 rib with stock motor C5 Z?
  212. My plan for controlling engine temps
  213. Meth users where do put you IAT sensor
  214. Procharger install instructions
  215. Dressed the blower up a bit.
  216. FLIP DRIVE - More power at same boost level and tune
  217. Procharger Air Filter
  218. A&A Procharger stage 2 backet upgrade??
  219. ECS Paxton novi2000 sc / tune help!!
  220. Red Hot Cats
  221. WTB: F1R Head Unit
  222. Short little video Rob took of my 924 rwhp dyno
  223. restrictor plate question
  224. boost pump wire help
  225. what degree thermostat are you running??
  226. Here's a brain twister for Meth addicts-How come I'm leaking alky and not water?
  227. Exhaust Back Pressure Lift Head?? Water In Oil. Have Questions ( PICS )
  228. c5 maggie question
  229. My new baby Boy
  230. A&A P1SC-1 with stage 2 upgade. Question on running piping.
  231. Another satisfied customer, A&A kit w/ Charlie @RPM tune
  232. How hard is a 75 wet shot on my transmisson??
  233. New to Nitrous
  234. Do i need different injectors for my z?
  235. Anyone want a transmission that will hold your F/I, nitrous power???
  236. Intake Air Temps
  237. A Huge Thanks to ARUN @ Champion! from MadMatt!
  238. Almost did it today 924rwhp@6300 pump gas !!!!!
  239. blow off valve
  240. New Over Drive Balancer Question for ProCharger
  241. Hmmm word on the street is Arun has done it again!
  242. need some Pics, advice and info on Nitrous
  243. ecs twin turbo
  244. Supercharging ? ?
  245. procharger pulley
  246. Opinions on Z06 Project
  247. ACT Twin Disk Clutch Review first impressions
  248. How much should this cost ?
  249. Ok, I'll ask over here. Did Spec change their PP?
  250. Easy A&A Vortech belt change???
