- Anyone using the NX Maximizer?
- What to do?
- Ocasional stumble upon startup?
- Racetronix pump seems really loud...
- Anyone have a extra window pill...
- N20 what kit is best. how much HP and where to buy
- Alky injection, pre-MAF or post-MAF?
- Maggy pulley vs. boost #'s???
- Valve Cover "Snorkel" -- no more stinky stinky
- Bottom end LS-1......how much?
- Nitto Tires
- Which S/C ???
- Best Wheel Combo for FI
- turbo sizing and spool up
- HKS BOV question with ATI kit
- Sonic Banana Sighted in Southeastern Michigan
- Need a new belt which one?
- Looking for 800+RWHP? We got it!
- ZEX Nitrous for LS1 and tuning ques.
- Finally got the Luk Pro Gold clutch adjusted...
- Where do you guys get your ALKY
- Maintenance of P1SC
- Air/fuel ratio guage. Where to hook in at???
- What lifters are you guys running??Check in
- Considerations ESC alky & 75lb injectors
- Who is making Twin Turbo Kits?
- Just drove it for the 1st time in a week, something is wrong...
- WTB Used Polished Maggie
- Tire selection for track use in my Procharged vehicle
- Another Aussie Clutch going in
- Vortech chirping!
- Does anyone know how the STS rear mount turbo system
- Goes without saying - ANDY IS THE MAN!
- LS1 head Mag #'s 515hp 487Tq
- How big is the sending unit for the fuel pressure gauge?
- Oil change for P1SC
- Torque converter for F/I
- new direct port pics
- What happens when you max out your maf?
- Tuner help please....
- Drove a Stock C5 Yesterday - yuck!
- Hood Clearence Problems
- So why would you go FI/Nitrous over NA?
- What to do?
- getting cats on a TT
- What way should I go w/my N20 setup?
- Weights of ATI, Mag, and TTi kits?
- How Much RWHP / RWTQ Can R2's Handle
- What are the fastest times for magnacharger with stock LS6/LS1 motor with bolt ons?
- Almost ready for MTI again paint job is closer.
- P1 or D1 for stock bottom end Z06?
- Is Xpipe worth it?
- ptk easter sale
- HEADERS-Yes or No
- new nitrous for my vette
- Here's a new one
- THANKS! 21st Century Muscle Cars
- tps is selling their mock up car i guess
- z06 Fender Badges
- Is,,,,,
- Need help with DTC1514
- The LOUD Fuel Pumps...?...
- double post delete
- Should I change my Spark Plugs?
- WTB Nitrous parts
- Custom ATI's Vs. Twin Turbo
- Can you use P1SC with ASP underdrive?
- Turbo Timers
- 6000 mile FI spark plug analysis please
- Best Oil for my TT Stage II Lingenfelter?
- Cheap Magnacharger ...dupe?
- Cost of clutch replacement, labor only?
- How fast does this look?? {A short Videoclip}
- Best hood for blower
- Squires rear mount Turbo system
- Oh, so close to 800 RWHP
- My TTiX kit SHIPPED TODAY
- Question on 2002 z06 full throttle switch HELP!
- Unusual bottle location question.
- afr 225's????????
- Ptk Project
- Got Alky…
- caravaggio hoods any bodykits for FI
- porchager head cam package
- Dyno sheet A&A SIC ATI
- Anyone have the new Lingenfelter hood for Mag?
- Since adding the Alky I've decided to turn up the boost
- Turbosmart E-boost?
- BSFC of FI engines
- What springs/shocks setup are you guys running for drag racing? the stockers?
- Here is the first impresion of my toy...!!
- New to supercharging...quick question????
- nitrous gauge question
- Maggie Stick vs. Auto
- WTB: PRT Exhaust
- Installed Nitrous Kit Pricing??
- Stock mufflers bad for all FI or turbos only?
- 700+ RWHP on 3 separate cars in a week
- Belt Slip? Help.....
- My 523rwhp Procharger Dyno Run [Vid]
- good tuner near chicago?
- Just had my Motor City Molds hood painted
- Bottle mounted pics on Z06
- Stock ATI bracket to A&A Bracket
- nitrous dry shot thru MAF sensor, anybody doing it?
- Big issue after A&A re-tune
- Just broke 700 RWHP 700 RWT on a 6 rib
- Lunati's Pro Mod Rods?
- Stock ATI bracket owners please check in.
- single gauge pod
- Vortech and ATI Superchargers on sale!
- SMC Alky injection
- alky injection
- My Dyno Graph, A&A kit vs ATI kit...
- ProCharger 6 Rib vs 8 Rib
- Alky Injection And Emmissions Testing?
- Boost controllers - electronic/manual
- Finally ECS
- Should I get Nitrous?...
- methanol injection ?
- What type of gages needed w/SC?
- Boost controller question
- Fuel System Advice?
- Procharger guys w/ stock heads/cam/bottom, what are your #'s?
- Any information on the Kenne Bell Twin screw?
- How much power
- How many guys here are running stock catalysts on their TT setups?
- Alochol injection for turbo?
- Halltech Twin Turbo in Ohio dynos 778 RWHP
- Horsepower Record Meltdown at 701.32 !
- Anyone need a 4.30''RR or ati 4.10'' pulley? Anyone have a 4.50"?
- Whats is max boost you can safely run on a magnacharger on stock LS6 bolt on motor
- Is the ECS or A&A Procharger kit as reliable as mangnacharger for stock Z06?
- Best Z06 1/4 mile times with magnacharger stock motor with bolt ons?
- **rear Mount Turbo**
- 550 rwhp Luk Pro Gold Stage 2
- Please Post Pictures Of Mounted Boost Controllers
- TPS Wire
- Need expert advice!!!!!
- Installed a Tial BOV on my A&A kit, also pics of my car!
- Fixed My Sig...
- alky?????
- Best supercharger for a Daily Driver?
- Help w/a 4.25 pully
- Finally, Dyno results inside....
- Converter question
- Best Heads for Magnuson
- Would running SVO 30# injectors hurt me in any way?
- Vortech Race Bypass Valve Question
- Any Mechanics in the "Vegas" area?? If not I'll fly you out..
- 150 shot, new fuel pump ?
- LPE cool site update
- Who makes this Turbo kit?
- which fuel system upgrade for an '04 turbo?
- Explain the MSD Window Switch to me.....
- Nitrous Routing Question
- Anybody looking to upgrade their P1??
- if you add more boost does that increase the need for more octane in gas?
- can u use lower octane in higher altitude
- Alk and N2O question
- Stopped by PTK today
- How much boost you running on MagnaCharger Z06's??
- Alcohol Kit Question!
- HP TT kit...Latest update from EPP(installer)
- Oil Pressure Drop in SC Car
- Clutches... again.... with a twist * vendors wanted
- Tnt Install Help 02 Z06
- What's the best motor size(cubes) for FI?
- Who has the best price on 60# Motortrons
- need help picking turbo kit
- The LS7 engine ... what HP boost would a 100 shot or alky kit add
- Drag Radials vs Tubbed with 345s
- 1999 Silver Twin Turbo!
- Intercooled Magnacharger
- What tires?
- What type of oil with a nitrous application?
- Pull timing on Cam Z06 for 100shot? 540rw ok on stock fuel system?
- Which gears???
- Cam Selection For a D1SC on a 346 CI
- Hot Rod's Mangie buildup---major letdown
- To the boys at ECSC
- S/C guys- Question on fuel pressure with a boost a pump.....
- Removal of the maggie pulley?
- Pic of my boost gauge
- Procharger P1 with NOS OK?
- Nitrous Kits?
- who has the lowest price *Vendors Welcome
- mag sc question
- Boost vs RPM question
- What wire is the RPM wire on the PCM for 2004??
- What packages to get into the 9 seconds?
- Pushing The Stock Bottom-End ??
- Yeah, Its Stock
- whatever happened with zo6gmans ride?
- MAG/Reichard pullys are in: 2.8/2.9/3.0/3.1/3.2
- HP Performance Twin Turbo Kit delivery time??
- WTB: Your blower....Maggie, A&A, ECS....
- tnt kit
- S-Trim to T-Trim Upgrade Notes
- Free shipping for Magnuson superchargers
- Thanks MDMC ran 11.42 today
- Little help with my nitrous set up
- Vetzilla Went for a Sunday Drive
- Dyno Tune n2o kits
- Which S/C has the MOST "Blower Whine??"
- Has anyone successfully adjusted the Luk Stage 2 pressue plate...
- Zex RPM window switch
- Nitrous Usage
- gap settings for NGk TR6 plugs
- ATI Pulley Change
- What Blitz controller do I need S or R?
- A & A procharger install ; 507 HP
- What converter are you C5 guys using with Vortech blower and exhaust..
- Single intercooler conversion
- Twin Twin Screw
- Went to the dyno...Need advice?
- Correct fuel pressure for non intercooled maggie?
- Torque converter questions
- My Beltflew off my Procharger twice today!
- magnacharger pulley change
- Nos Concern On A 04 Z06.
- Audibility of Whine and Whistle
- Magnacharger & Vararam?
- LS7000 Turbo Mega Stroker
- please delete
- Anyone have a block laying around?
- Bought a NX Wet Kit today.
- Hidden nitrous.....
- F/I Tuner in MD area
- Metal Shaving on Magnetic Oil Plug.
- I am Back
- BAP Vacuum Line
- How much will I get?
- Pics of installed 5177 kit
- Forced Induction Tuners, a few Q's
- Who has ARP head studs on their TT set-up?
- top speed w/new ptk?
- I Think I have a Problem!
- SC corvettes in Denver and Colo Springs.?
- Official ECS/Julio Alky Installation Support thread
- opinion on this alchy kit
- ARP head studs
- best nos kit for stock 01 auto???
- TTP Equalizer v3 cam, how is it on spray?
- Drag Radial TOYO PROXES RA1?
- How many of you started out H/C then went FI?
- Is the KenneBell 2.2L twin screw gonna be big enough for a 427
- Gates Laser Tool
- Luk ProGold series...same as stock Z-06 clutch???
