View Full Version : C5 Forced Induction/Nitrous
  1. ZO6 Vs Viper GTS Dyno wars
  2. Hats off to East Coast Supercharging!!!
  3. NX wet jet size chart inside
  4. Magnuson with 3" blower pulley: Length of belt?
  5. Anything Required by the Track if Running ALKY?
  6. Bigben Vortech with Kook's Headers Dyno Results
  7. How much alky/h20 do you guys go through in a run?
  8. Voice activation, verification, and report?
  9. procharger belt
  10. Alternator Bracket
  11. 125 NX jet sizing?
  12. best deal on carbon air bridge ???
  13. Roll bar requirement for verts on the track- How do u like the way they look?
  14. Question for Magnacharger Owners/Tuners
  15. Twin turbo recomendation
  16. Help
  17. How can you tell if your walbor pump fails?
  18. Fuel pressure drop...How much over how long?
  19. 600+hp FI cars....1/4mile times?
  20. Anyone have a video of their car?
  21. Nitrous newbie questions
  22. PCM controlling Turbo set up in 1998 vette
  23. mileage and supercharging
  24. Finally got my P1SC dyno tuned
  25. Hood Clearence Problems (ProCharger)
  26. Nitrous on my vette
  27. Max Injector Duty Cycle?
  28. Custom 2002 Tigershark Z06 with F1R Procharger For Sale
  29. custom radiator support
  30. Kenne Bell Twin Screw Project - any update???
  31. a-pillar guage pods... who makes em ?
  32. Racetronix Fuel Pump
  33. anyone running the supermaxx headers with procharger
  34. Injectors
  35. Look what I got
  36. ECS Alky kit? inside
  37. Fuel system for 700+rwhp?
  38. Final got the alky kit to work… (Thanks Andy)
  39. Innovative Motorsports
  40. Pics of my CUT OUT HOOD, Vette, and Crashed Vette
  41. 03 hood
  42. wtb supercharger
  43. Who Here With FI Roadcourses their Car?
  44. NEW NX Corvette Maff Kit Footage.
  45. Belt tensioner question
  46. Gauge Pod and gauges, Where to buy?
  47. Front plate air intake....who's done it?
  48. f/s NOS brand nitrous kit
  49. Brackets for High Horse Power Motors
  50. Valet switch, 2bar support, SD autotune
  51. Replacement Engine/Fuel Rail cover
  52. Anyone have the ATI Single fan laying around?
  53. Squeaking Vortech belts!!!
  54. BFGoodrich Drag Radials
  55. Information from ATI on the 4.5 Twins intercoolers
  56. Looking For Advise On Tires??
  57. Anyone have pictures of ECS full brackets and belt wrap
  58. Nitrous Feed Line Routing
  59. Alright, VETZILLA, what did you run at Milan?
  60. Want to buy P1SC or D1SC
  61. Radiator Tilt kit for blower cars (ATI)
  62. Looking for a S to T Trim Dyno
  63. anyone know if theres a sts kit for the c5?
  64. Gear heads inside for some real FI or is that F1
  65. Shinobi's Hood Pic's
  66. Turbo pistons
  67. Jacobs Nitrous controller.....
  68. Modern day Muscle Cars...
  69. Best way to spray with my NX wet system
  70. Quarter mile gains with Nitrous???
  71. alky or meth
  72. Gauging interest in parting out all my mods...[blower car]
  73. Need for retune with Alky kit?
  74. Anybody with a 15 lb bottle in their coupe?
  75. MAF screen removal
  76. Twins / Singels
  77. Exact dimension?
  78. My ECS methanol installation (custom...somewhat)
  79. APE, Who has stuff on order???????
  80. Ok - who is going to retro-fit this kit to a C5?
  81. ls2 double roller chain
  82. Twin Intercoolers and Tigershark front end
  83. List of all turbo kits for C5's???
  84. Nitrous with this cam?
  85. Project Forged
  86. 1500 HP+ Supercharged C5s...{Pic}
  87. TTi Stage 1 Tuning with a 2bar MAP
  88. ** Single Turbo Gto 10.68@129 Mph !! **
  89. best tuner in ohio for pro charger in ohio ??
  90. Do i have to many miles to go FI?
  91. BETA Testing
  92. A & A ATI Single Inercooler question ..Help!
  93. Bad Cats, only 1 year old
  94. Which boost controller should I get?
  95. Alky injection and 10lbs of boost...q's
  96. Need to Sell C5 F1R Blower Set up great deal!
  97. Not FI related, but only you guys would understand
  98. DTE rear end brace
  99. Freeze Plug Exploded off my heads!!!!
  100. LPE Mag install 472 RWHP!
  101. Billet "LS1 Turbocharged" Emblems F/S BRAND NEW!!
  102. ECS Kit straight meth way to go?
  103. TTiX install finished.
  104. Just finished my ATI P1 winter project.
  105. Calling Out Blackmagic C5
  106. Supercharged Vette Passes NJ Inspection
  107. New Pics of TTi Stage 1 with a Twist
  108. Does anyone have a vortech for sale?
  109. List Of Tuners W/load Cell Dyno
  110. Aussie clutch at the track?
  111. Calling out new member 99 C-5 F1C VETTE ....
  112. Ls6/fast90mil/ls2 Intake??????
  113. Single Turbos .... do they compare favorably with Prochargers/Maggies?
  114. Ratio of SC to TT
  115. 72 cc AFR 205's
  116. California smog check and FI
  117. AFR 205 vs. A&A Stage II heads
  118. Driving impression-1 month with ECS D1
  119. check eng light on
  120. Vid of my 11.2 run
  121. Suggestions for 50lb injectors
  122. What To Use For Alky Injection?
  123. A4 Procharger guys: How do u launch at the track?
  124. Supercharger Oil
  125. HP tuners 2/3 bar SD setup
  126. Who makes best air-to-water intercooler cores?
  127. I'm sick of clutches
  128. tti
  129. Shopping for the FI kit
  130. Is my setup a good candidate for NOS?
  131. What bore and stroke do prefer?
  132. Any downside to f/i on a darton resleeved Block?
  133. FI or NA for Road racing?
  134. Upgrade direction - Need Advice
  135. Limits of "streetable power"
  136. MSD Rpm window switch prob..Need help fast
  137. Thanks Finish Line ( aka Chuck ) and Precision Industries
  138. and for my next amazing feat.....
  139. Nice item for us nitrous guys..
  140. Do you gain using a LSX 90mm orver LS6 intake ?
  141. What heads are you using???
  142. crank choice / $$$ & pros & cons
  143. Wider Front Tires - Alignment Question
  144. 8rib belt sizes?
  145. 500+rwhp FI cars, what gears are you running?
  146. Boost a pump install question
  147. Anyone have ideas on how to fix rubbing of SC
  148. New Mod List....
  149. Fuel line for fuel pressure sensor
  150. Mag cut-out hood pics. dial-up beware
  151. Good Tuner in Orlando/Daytona Beach?
  152. Looking at switching from NA to Turbo need help?
  153. TT + small shot of nitrous
  154. Go ahead... contribute :-)
  155. Tips on pinning the crank
  156. 2.9 pulley Magnuson on ECS alky
  157. 540 Rwhp And Up. What Clutch Are You Using
  158. Engine build for boost
  159. previous TTi Stage 1 owners come in
  160. 408 Iron Block, D1SC, Stg III Heads
  161. Has Anybody Installed A Timing Tuner To There Car....
  162. after installing window switch....
  163. if you change the pulley and not the tune,when used in higher altitude only,what will
  164. polished maggie
  165. Best 1/4 Mile Times on STREET Tires
  166. ECS/RoadRebel TTix Joint Venture
  167. worthwhile to intercool a magnuson?
  168. Best way to spray the engine?
  169. Tips for the new guy Sprayn the Juice???
  170. Cobalt Boost gauge.
  171. Where to get a replacement drive belt?
  172. Next Level Performance SC650 Package - Forged 346 & D1SC - $14,995
  173. Tired of waiting on TT, trying my own idea, think it will work??
  174. Alky Kit
  175. Best pulley setup - finally!
  176. How long have you had your FI C5
  177. Alky install done, How can you tell if it's spraying
  178. any procharger guys going to the vette viper shootout in atlanta
  179. Catch cans and Maggie??
  180. TTi Stage I w/ ecs alky kit
  181. baseline setting for alky system
  182. Alky system just about done
  183. NGK Tr6's
  184. Cam is in.... TTi stage 1 with a twist
  185. Any downside to f/i on a darton resleeved 427?
  186. AIR Tube Location change in 2001?
  187. Video of HPE's Turbo LT1 going 8.21 at 170 mph
  188. Which is a better supercharger??
  189. Does your Aussie Clutch......
  190. Nitrous RULES
  191. Tti X Kit Daily Driver ??/whos Crank??
  192. One step closer to FI!
  193. Looks like somebody else going up top with TTs
  194. Boost blowing out Spark? Lets discuss.
  195. Adapting Truck Whipple kit to C5
  196. Thanks RoadRebel
  197. Question about ptk tt kit?
  198. Top Speed Turbo vs supercharger vs nitrous vs large displacement
  199. Big Puff of white smoke then.... need some help
  200. Comments on the NX Nitrous Kit
  201. My TT was #1 Qualifier in Top Street & set new e.t. best
  202. Alky Injection Kit
  203. My Ls2 402 Stroker Tt Ptk Project Pictures
  204. Are my 02 sensors history? 2 codes...
  205. New Price Custome F1R Setup!!
  206. New Sticky Thread ?
  207. Have questions about different S/C's *Read This*
  208. PTK TT Tuned @ A&A Corvette Performance
  209. 90mm TB and FAST intake, Is it worth it on a 346 W/D1SC
  210. Getting a code need alittle advice
  211. Mallory window switch
  212. Stock Z06 MAF table
  213. L/F A New or Used Single Inter-cooler for D-1 Procharger
  214. Finally Getting Twins!!!
  215. F1R setup for sale.
  216. I would like to see a picture or two of a layed back or down Rad.
  217. ATI price increase coming soon!
  218. Redline single turbo kit ?
  219. Injector size ?
  220. Yano's Stage X up and running
  221. Stroker500 Rwhp Vs Tt 600 Rwhp 1/4 ???
  222. Install Belt on ECS D-1 ?
  223. ECS alky injection
  224. 78mm vs 90mm throttle body & intake systems
  225. spray in 5th gear ?
  226. Bad day......TTi Stage 1 (with a twist)
  227. [How to?] remove pulley from power steering
  228. Got my car back from Andy yesterday!
  229. HP Twin Kit
  230. Twin Turbo Callaway
  231. Procharger oil change [very easy way]
  232. WTB: 32- or 34-tooth cog (gilmer) pulley for Vortech
  233. blower or paxton supercharger
  234. Got my new S/C from A&A and new pix!
  235. ZO6 Bottle mounting places
  236. Can't decide on other gauge choice.....suggestions?
  237. [f/s] 60# mototron injectors
  238. MSD Digital Window Switch
  239. Serious Question For Guys With A Blitz Boost Controller
  240. New #'s with forged bottom & mag
  241. Questions on Fuel Pressure Regulators
  242. Just got my blower installed!!!!!!!!!
  243. wiring my NXL (nitrous) kit
  244. Tti Stage3 Kit On Ebay!!!
  245. anyone have a nitrous bottle heater 10 pound
  246. New F1R setup with Water to Air
  247. Gauges for supercharger
  248. Anyone tried running w/o intercooler on Vortech SC setup?
  249. ECS Raises the C5 S/C bar topless!! 9.62
  250. FI cars,how much does a humid day effect hp, compared to a dry day
