- 10,86 @ 132mph!!
- High HP folk, what rpm do you lose traction?
- Block question
- F1R head unit FS in the FS section.
- i want 800rwhp do i need to stroke
- Where is the Tach wire?
- 100 shot dry! Help
- if my car was tuned with a d1sc 13# is it safe to try a f1r or f1c at 13#and no retun
- TTiX and TTi Stage I-III Owners come on in.
- Has anyone ever stepped back and looked at what we have?
- Alky, 110* Heat, Tank Pressure = Flooding/HardStarting. I need your help..
- LWA built 408 stroker with A&A F1r Dyno Numbers
- 110*'s outside!! It's killing my D1SC. How to keep it cool?
- Maximum boost one has seen from a Magnacharger ?
- Wondering about a Solid Roller FI Motor ??
- Another TTi Stage X Is Prowling The Streets of Metro Detroit
- when people say the f1r or f1c is much louder then a p/d1sc,what do they mean
- Check out this intake system
- Nitrous Experts Step Inside RPM Spraying Questions & Torque Converters
- EAST COAST -N- A&A
- alky kit and nitrous ?
- NX Btl Heater. Diff. Between D-4 & D-6??
- Who has the Nitorus Gauge in their Ashtray?
- Bandit just ordered a Wet Kit (What do you think?)
- MTI 427 vs. my MTI Blower Car
- Anyone heard of these guys?
- How do you guys mount this item?
- Still waiting on Procharger kit ... should I consider other options?
- Problems with throttle on F/I 347??
- Broken rod bolt
- What's up with my MAF? Is this the BOV?
- Is retarding the timing necessary 4 a 75 shot?
- Couple of progress pics of my LPE 650 TT
- I/C Mag & /chrome ps reserviour cover
- Twin Turbo's or KB Boost?
- TTiX has Arrived in Canada...
- Improved Overdriven 5th & 6th Gear Ratios on the Street
- Suggestions?
- how to change the belt on a&a
- NX 10Lb. or 15 Lb. Bottle? 15Lb. Fit in Center Are?
- Bad News About My LPE Car
- forged bottom ,,help .
- Another queston about KB twin screw
- Curious Maggie ?
- "Spy pics" of the upcoming C5 STS Twin Turbo!
- how does the Maggie (or KB Twin Screw) produce instant boost...
- Possible fuel source for alky injection
- FS: ECS D-1SC ProCharger Kit
- Omg Ahhhhhhhhhhhhhh!!!!!!!!!1111!!!!!
- I can't fly - 511.99
- Which RPS Clutch and Flywheel for 800+ RWHP?
- DYNO TIME from Kenne Bell Twin Screw
- Kenne Bell S/C ... are they better than Maggies?
- how much boost do you pick up from 3.85 to 3.65
- Any Downside to a Vortech ??
- Need help figuring out boost drop please!
- Alky injection ordered for my stock ATI kit.
- Tranny recommendations for an A-4 blower car??
- LOOKING FOR A USED A&A D1SC OR TT KIT
- OK....car is at the shop....now the wait....
- Where the hell do I get my bottle filled (SoCal)?
- 1.8 rockers for tt...
- Got the Dyno to my car today, 347ci F1C
- Nitrous Filters ?
- Clutch Install-How much $$
- Have you noticed an added heat load with your Maggie?
- Billet Aluminum NOS Bottle brackets (Cool)
- Stage 1 with a Switch ;)
- 02 c5 nx nitrous kit
- How much HP gain w/ 90mm LSX intake & TB on a Turbo setup?
- Some advice
- In car vid at the track. 11.91 @ 128
- WHennnn oh wheeen will a fuel system BE AVAILABLE UGH!!!!!!!!!!
- I/C maggie heat exchanger leaking
- Proprietary Tunes
- power on stock bottom
- Nitrous Pictures wanted?
- Unidentified Blueish/purpleish oil leak
- the waiting game
- ECS Resolves My TTix Problem
- Who here does their own work?
- Had a long talk with Kenne Bell today.
- Ati Procharger Oil Change Tips
- nitrous and compression
- D1 vs P1
- Round 2 ECS Alky kit in and Tuned
- Brown smoke
- Tuners, I NEED YOUR HELP (Win a FREE T-SHIRT!)
- ProCharger advertises...
- Looking for Sponser Car for K's Kustoms
- Magnuson pullies- What sizes do you want / need?
- Together or Seperate?
- Working on new nitrous setup..
- Need a forged motor.....
- Help... BOV question, not sure if the car is supposed to make this noise
- F1 vs D1 for street use
- do you think a 3.50 reichard pulley will slip on a&a
- Who Makes Square Piece that connects to the intake for Wet Kits?
- 408 w/TT or F1?
- Was going 5177 DRY, Now considering NX Wet
- Recommendations on gear and converter from the FI guys
- NOS PICS dry Kit (05177) installed into a Vortex Air Rammer
- Pics of 97/98 Vette with a TNT Kit?
- HP turbo kit
- Vararam Special!!
- RPS clutch with aluminum flywheel
- Can I run a dry kit on 26 lb injectors?
- when you add more boost does fuel go lean or rich
- Belt 'Residue' Removal
- Will a 66cc Chamber raise or lower my C/R on a Z06?
- As far as timing and AF for FI?
- Is adding a Catch can A good idea?
- Hey Gents, What do you guys think is the best nitrous system
- Sneaky PETE
- Price of the new LS7 enclosed
- LS1/6 or LS2 for twins
- Oil Air Separators and PCV
- Looking for forged engine!!
- IC Magnacharged Z06
- TT or Supercharger race videos...?
- Took it to the track and....
- Autometer Gauge: needs good power
- dip stick popped out.
- Belt length? (A&A bracket users)
- Any Pics of Spiral Grey Magnacharger Hoods ?
- guys with a&a kit, my bov is to loud, and ?
- Question for Magnuson owners
- WTB: Vortech T-Trim blower hat
- A&A + ECS + ICS = 540 RWHP, 469 TQ...Dyno Sheet Inside...Cyro2 is Working!!!
- the beast lives again!
- Innovate wideband users...
- LPE Cam for the IC Magnacharger
- Lowering the radiator do you
- Mag beautification
- Interesting AUtomotive website
- Progressive NOS Controllers
- how can you tell if your gas/octane is to low,will wot hurt forged motor
- 570rwhp/560rwtq dynotune from Newtech (Hayward, CA)
- will a supercharger fit under a stock C5 hood ?
- Suggested NOS for stock c5
- Who is running with less than 9:1CR?
- NOS DRY KIT 5177 & Vortex Bottom Breather. Where Mount lines?
- nitrous dyno help
- Alky Injection, A&A kit & Tranny.....opinions??
- Want Nitrous DRY SHOT on my A4,,,Help.
- Boost controllers?
- Who’s actually running SD tune on SC/turbo setup?
- Pros and Cons of Superchargers vs. Twin Turbos?
- A&A Procharger setup questions
- ATT TTI guys come in here....
- Looking for a supercharger
- A&A turbo kit pics?
- ESuperCharger! THIS IS THE FUTURE!!
- 4 Sale Team Zr1 Water Alky Injection Kit
- 200hp Shot On Stock Motor?
- How about a TT Magnusson setup..check it out!
- pics of my SMASHED TUBE
- 97/8 regulator question
- How much should I ask for my motor?
- New Avatar
- WOOHOO.... Got my ECS alky inj. kit in...
- Are there any TTi X, PTK or F1R Videos?
- ECS 382 D1 + meth/nos fogger 970rwhp 850rwtq
- Will this be a good blower cam?
- I'm not sure about how much boost can she hold Captain!
- Need Help With Cam
- Interesting TT/Mag kit
- friday is the day !!!!
- Break in on these High Perf. motors?
- NXL wiring ?
- Mag Pulley...got a quick?
- what is the smallest pulley u can use w/a&a bracket?
- Paging Doug @ ECS - RE: Air Bridge and Filter
- What you do when you use alot of nitrous
- Nitrous Guys... Post your E/T's
- May go NOS
- Need New Radiator
- mustang for supercahrger
- nitros bag kit
- Is Switching to Truck heads to lower C/R a good idea?
- Looking for a TT kit
- Auto Insurance
- Conversion to rail mounted regulator
- *Vendors Need your help- Timing Tuner
- 17" ET Streets on Back/ 18" radials up front
- Lowering Radiator
- Who's engine bay is this?
- Best Model Year of Z06/C5 for a MagnaCharger??
- HP Twin Turbo Video.
- IDEA: Alcohol Inj.+Spray on intercooler???
- Alky questions
- Free overnight shipping for Nitrous Express kits!
- Well the engine work is done....wheww
- just spoked to sts about the c5 kit
- Nitrous Express NXL owners inside please (the direct port type)
- C6 Z06 Price Announced
- Procharger D1SC Build....She is ALIVE...pics inside...
- Vette tuners in hawaii
- A&A BBQ **Video**
- does the vortech bov adjust
- Where is this 7-sec LS1?
- clutch ?'s
- I won $1000.00 at ANDY'S annual A&A Party/Dyno Day!...
- Kooks 1 3/4" or 1 7/8"??????
- Dumb Question....... D/A
- Finally got my Alky install set up..
- Smog????
- MAF and IAT sensor placement
- For the guys with C5 and C6 check this out
- Glad its over with
- [FI Power Tip] Stop hose swell from exposing pipe into airstream
- Just confirmed by Universal today! Im in.
- Im sure its been done before but...
- is it bad to go top speed in a fi car
- 3" Random Tech mid-pipe/cats/x-pipe on LPE TT, exhaust talk too
- Intakes:LS6 vs LS2
- Vortech SC owners
- GP for LM-1, LC-1, and Innovate products
- G-Tech Users Chime In
- Rumble and puff (video)
- Magnacharger questions
- Took My 383 Stroker Back To The Track W/nos 10.89...
- Engine temps with the A&A SC setup???
- Nice Stand Alone Fuel tank/pump from Nitro Dave
- 9.5:1 safe for what level of boost?
- Advice, opinions on supercharging
- should i have the bov point up or down on a&a
- Another Octane ?
- Stage II Motor
- Magnacharger 1/4 times?
- Exhaust system with TT?
- ATI procharged z06 wont stay cool!
- Some of the cheaper mods for HP gains.
- Here is the video of my car on the dyno
- Where to get an Elect. water pump?
- 370 Fe Shortblock - F/S - New
- Corvette vs TA?????
- Maggie Pully upgrade?
- Good price on LM-1 wideband
- ECS Alky kit on the Way
- The numbers started coming in today
- How loud (noisy) are the diaphragm pumps used in Alky systems?
- Rockingham, NC - Street Car shootout 06/18/05
- Blower cam question
- Just bought one of Andys Mills
- Video Of My Twins At The Track
- Twins are HOME finally!!!!!
- Att turbo vette owners!!!
- NX Nitrous Wet Setup Jet Question
- Well, months of waiting and she fired up today.
