View Full Version : C5 Forced Induction/Nitrous
  1. turbo
  2. Short Vid of Run With 850 Hennessey Viper
  3. Step On In With Pics Of Your Mounted ECS Meth Controller
  4. Help Needed With Console Switch Assembly
  5. What compression Ratio to run 15# of boost
  6. my new a/4 and ptk
  7. Bigger PS idler for small 3.2" blower pulley (Thanks Andy)
  8. A & A Procharger Set Up.
  9. A&A P1SC / 2.5 MILE ROAD COURSE
  10. Best Setup for Traction
  11. Whats the smallest turbo you would put on a v8.
  12. need help>>....chime in
  13. Textralia’s New Flywheel… With a thank-you!
  14. Aux Fuel system for Wet N2O
  15. what injectors for 530rwhp on n20???
  16. how much time to install an 8 rib pulley set for A&A
  17. F/S NEW A&A D1SC COMPLETE KIT minus Injectors
  18. How to get a F1R head unit?
  19. bitchen!
  20. New Dyno Numbers on my Maggie, and heat issues.
  21. Plug Wires, Which Ones????????
  22. Anatomy of a Walbro Fuel pump?
  23. Who has a f1 series blower and drag races
  24. 2003 zo6 fuel system upgrade..whats best?
  25. N2O Wet System pics
  26. Pulley removal off magnuson
  27. Turbo Timer
  28. New Z06 Clutch
  29. Anyone need I/C mag belt tensioner?
  30. Anyone have directions
  31. What size pulley do I need?
  32. ATI guys, what is your rev limiter set at and how much boost?
  33. Anyone have Mag programmer to loan?
  34. NX ELECTRIC Nitrous Gauge (Will this fit in the ashtray?)
  35. FS- Reichard Racing BLOWER PULLEY..........
  36. 4.10s with a Maggie?
  37. What is needed to hold 15 psi
  38. Supercharger+Nitrous
  39. STS Rear Mount Turbo's For C5????
  40. Another problem . . .
  41. Put my procharged Z06 on the dyno today....analyse my numbers!!!!(Chart inside).
  42. lift
  43. And then there were two!
  44. Which heads for Magnuson
  45. superchargers boost, rpm, rev limiter, when to shift
  46. are turbo cars rwhp limited by what the motor can take or the turbos
  47. How much rwhp/torque w/ this Mag setup?
  48. A&A procharger kit question...
  49. See my lost boost ...... ?
  50. Where to mount transmission cooler
  51. Procharger kit for C5 for sale $1500
  52. Maggie Cutstom tune: What'd you do?
  53. Is Torco the best way to go?
  54. Whats your oil Pressure . . .
  55. My first Shot from the bottle!
  56. C5 World Record Is Mine - 1st Z06 In The 8s
  57. Transmissions...
  58. Lifter Boxes
  59. Before and after engine pitures.
  60. Questions about FI..???
  61. A&A Turbo- It's getting there
  62. How do superchargers hold up on a road course?
  63. Throttle Body Poll
  64. Its so nice to be cool
  65. How to tune after Maggie install?
  66. Need Some help w/ nitrous and the "tune" i had done
  67. Lpe Tt Q.
  68. New Nitrous Express MAF Kit Coming Soon!
  69. How much HP can stock bottom end LS1 handle?
  70. Overkill to change to dual valve spring on stock Z06 motor with ATI SC?
  71. Spal Fan problems
  72. Going rate for D1 or P1 head unit?
  73. Lunati 408 stroker kit on stock block
  74. Best sleeper setup
  75. Kennebell Boost-a-pump or MSD?????
  76. Pictures of Rudy's Kenne Bell setup..............
  77. New boost support in EFI-Live Flashscan
  78. Really good twin turbo set up for C5
  79. Ausi...Clutch Guys What Do You Think?
  80. Magnacharger and the Blackwing
  81. Hot temp starting problem
  82. anyone got an extra brake fluid reservoir laying around???
  83. ptk makes big power and......
  84. Anyone see this latest B.S..
  85. no2 question
  86. will this maggie work
  87. Help: To much Fuel Pressure?
  88. 410s a4 3500stall 7# ati what do you think?
  89. Aggresive Cam Size Needed On 97 Stock Motor, Future SC
  90. Designated Fuel System for Nitrous - What type of fuel to use?
  91. Rocker Arms
  92. Question for you tuners
  93. SHOW ME YOUR A&A PROCHARGER PICS
  94. Poll: ATI owners past and present.
  95. Poll: ATI owners past and present
  96. Poll: ATI owners past and present
  97. Vette Doctors...
  98. Anyone in the market for HP Tuner?
  99. hp tuners
  100. What Numbers Should I See
  101. Magna-Volt ... anyone tested it
  102. A&A install tips
  103. blitz new boost controller
  104. Engine oil temp
  105. Stage X - gas consumption
  106. Got a call from Procharger today
  107. Got a call from Procharger today
  108. ZEX wet kit and Ramchargers timing tuner question!!
  109. Cam advise please.
  110. Off Topic but FI related, I think it's pretty cool....
  111. Turbo headers are on
  112. STS TTi update: great news!
  113. Mondo position
  114. NX N-tercooler System
  115. Cartek SC 418 Shake Down Passes
  116. if you were to build a FI car for 4500ft elevation, what one?
  117. Prochargers and Emissions Testing
  118. Do i need a WOT switch if i have a Window switch ?
  119. A4 Ati cars what shift points?
  120. Anyone need a boost and fuel pressure gauge?
  121. Does anyone have a laser alignment tool?
  122. Who has switched to a 2bar MAP sensor
  123. Phase 1 of engine is complete. (Pics) Very clean.
  124. Great service from RoadRebel
  125. Hey Doug/Chris at ECS _ NOVI 2000 blower questions
  126. Who is running has knowledge of the RPS single disk clutch?
  127. NOVI 2000 blower anyone know how they sound?
  128. Just some new PICS, mostly the CO2 System ...semi large pics
  129. What happens if you run no jets in a NOS nozzle ?
  130. Mag pulley size suggestions
  131. kenne bell blower
  132. NON IC MAG w/BLOWER CAM ARE HEADERS WORTH THE MONEY?
  133. ECS D1SC Cars-Can you kindly post pics...
  134. I want to trade my loud vortech bov for your quite Bov.
  135. **DTE HD Vortech S/C Belt Drive Kit** (photos)
  136. Rodney's number? (Crashed94)??
  137. How hard is 75 wet shot on Heads and Cam car?
  138. adding 104, 110 to 91 octane in fi car?
  139. 408 ?
  140. BOV loss of boost?
  141. ***Big anouncement from ECS on head units***
  142. Questions About ProCharger
  143. guys who went from supercharged to turbo, is traction that much harder?
  144. HP gain ?
  145. Will procharger sell a head unit only
  146. Nos 5177 Kit
  147. Need FI Experts opinions : monster cam and supercharger?
  148. What wire do you tap into for a MSD window switch for tach signal ???
  149. Need Help with the MAF on the Tune
  150. SC guys, anyone else have ALOT of exhaust discharge at idle?
  151. tuning with the R question
  152. C5 Magnuson supercharger with SuperMaxx long tube header package!
  153. any one install the meth/alky kit? is it hard?
  154. Meth Inj Help?
  155. any one know about STS alky kit?
  156. Installing a Maggie..what to look out for?
  157. TT K&N Air Cleaners? ? ?
  158. What is the latest w/ Kenne Bell
  159. 90mm t-body
  160. I wonder if getting a KB blower on a Vette
  161. Rotrex Superchargers...
  162. bouncing of the rev limiiter
  163. Whats the best 1/4 mile times with just a Procharger?
  164. Belt Suggestions
  165. show me your fi fuel system
  166. Who is supercharged in Maryland ?
  167. CR and Nitrous
  168. NOX...Seriously considering, but need some help
  169. NITRIOUS...What is your honest opnion
  170. looking for advise on gears??
  171. What are the best drag radials?
  172. WTB....alky kit
  173. something to check once ever few months
  174. Hypothetical Question : Nitrous bottle hidden behind drivers front wheel?
  175. guys with vortech bov, do the hiss,chirp, under part throttle
  176. how much power can you lose if you have knock?
  177. More power on Z06 IC Maggie vs non IC with alky injection?
  178. Anyone Have a Picture(s) of a Magnacharger Sticking Out of a Stock Hood ?
  179. Drag radials E.T. difference ?
  180. [Alcohol Injection, mind explaining what it does?]
  181. Nice Looking
  182. OK, how many have knowledge of 500 to 550rwhp that went kaboom with Prochargers
  183. Dialed her up to 13 psi tonight! YOWSA!
  184. Stainless Vs Coated Headers?
  185. Remember my rear end issue?
  186. Okay, ready for Nitrous, but need some help please!
  187. Very Dissapointed
  188. Magnacharger coil covers
  189. HKS SSQ, Every ricer wants a piece of me now....
  190. Intresting, Higer Engine temps with shroud..next step?
  191. if you beat the crap out of a fi car and after find kr!
  192. Shroud, how do you cusomize one?
  193. Shroud, anyway to cusomize one?
  194. LS1 to LS2 Conversion Harnesses
  195. Truck Turbo Kit on C5?
  196. TTi Stage X guys...
  197. If anyone can read EFI files, let me know what you think..
  198. UPS brought me a nice new Chrome Tial BOV today
  199. What gets better mpg sc or hc
  200. the speed of the blower or amount of air, create heat?
  201. Ati 7# stock motor kooks headers what size?
  202. if you want to quite down the blow off valve, i have a way!
  203. Showdown in Jackson
  204. Procharger?
  205. What nice aggressive street cam is compatible for NA on Z06 and with Procharger?
  206. A&A Procharger Kit no problem for a daily driver?
  207. 390 in blower car?
  208. hot and humid or hot and dry, hurts fi more?
  209. How much more boost are ya'll running w/ alc. injection ?
  210. Need help on LTFT BANK1&2 @ 25% 2500RPM
  211. In a drag only turbo car can you run meth with no intercooler
  212. New MSI Magnacharger Cowl Induction Hood!!
  213. My Ptk C5 @ 14psi!!!
  214. A Public "Thank You" to Doug at ECS
  215. Andy is getting famous in Vette Magazine
  216. Blow Down Tube. What did you do?
  217. 90mm LS2 TB and manifold on C5
  218. Suggest removing the spring behing your clutch.
  219. Post pic of your NX and NOS systems!!!
  220. NX/Nitrous Outlet EFI System Installation Help Needed!
  221. Gents-If you wanted just a 100 shot, what would be the best
  222. How much extra boost can you run with meth injection?
  223. Where To Ground Bottle Heater, Etc?
  224. What Boost Level is Everyone Turning on the Meth
  225. Andy need your help FLATLNE
  226. 3.85-3.6 on ATI stock bottom yes or no?
  227. Sound of Magnacharger vs LPE TT
  228. White Pride World Wide!!!!
  229. Boost with A&A P1 Setup??
  230. Happy Birthday Bill Reid !!!!!!
  231. Only you guys would appreciate this...
  232. MAGNACHARGER at the Drags
  233. Nitrous Question Concerning Fuel
  234. Removing rear O2 sensors
  235. Picking the right Meth Kit.....
  236. Great service with an Import shop on my car.
  237. LQ9 heads for sale
  238. 500rwhp for under $10 grand ???
  239. used LPE TT
  240. FI guys what radiator to use
  241. OK I'm serious about Meth Injection.....
  242. I think this is hysterical
  243. Vortech C5 supercharger
  244. Anyone have any extra used N20 solenoids laying around?
  245. Short Run Through Some Twisties!!! + Bonus Pass...*Video*
  246. Intake manifold gaskets?
  247. 383w/F1R-Alky kit&Nitrous shark nozzle(New Pics)
  248. Which plugs
  249. MY TT's Run Awsome...Thanks ECS
  250. this is ridicolous!
