View Full Version : C5 Forced Induction/Nitrous
  1. Question for Supercharged A4's
  2. Question for Supercharged A4's
  3. What Exhaust?! - Magnacharged 03 Vert
  4. How far can you go??
  5. Vendors, I need a fuel fitting. HELP
  6. RPM A4 Level 6 plus more for sale
  7. vic jr and regular elbow, not low profile. will it fit under my aci cowl hood?
  8. Fender Flares installed ..Pics inside :)
  9. What type of fuel to use in C5 Z06 wether or not Supercharged
  10. Modern Muscle - ProCharger Results
  11. Matts FRC 427/TNT kit track runs
  12. ALky Anyone????
  13. question for 700+ rwhp s/c 346's out there
  14. (TEXAS FOLKS AND ANYONE) has anyone had experience with this guy
  15. Speed Inc. / A&A results
  16. blowby issue with the new revxtreme catch
  17. Will these injectors be too large for my setup?
  18. Highest RWHP on stock bottom end!!!
  19. Wont be running nitrous. swap plugs?
  20. 20psi Fuel Pressure at 5200rpm
  21. Anybody heard this kind of noise
  22. How do U know if U R over injecting meth?
  23. Maggie and Meth injection
  24. Ordering 2" ARH for my 347/F1C setup!
  25. Affects of Ethanol
  26. oh man
  27. Help with snow meth kit
  28. New to F.I.....
  29. oily residue inside intercooler
  30. Anyone bought the UPP kit yet?
  31. more nitrous ? or b happy :)
  32. what blow off valve needed for 18psi?
  33. Custom reservoir to relocate in the battery location
  34. Vortech vs Paxton vs Procharger
  35. New clutch and dyno tune a bad idea?
  36. Slowhawk Performance hooked me up
  37. Thanks to A&A and Mike Norris.
  38. WTB, Borrow or Rent Crank Pinning Fixture
  39. Where do you spray your Meth ????
  40. My new intake manifold
  41. ‎28,7 PSI on a 4 bolt heads
  42. Lets see your mounts!!!!!
  43. FS: 8 rib alt and power steering pulley
  44. Dfw gtg
  45. No fuel pressure _how can i tell if its my msd bap
  46. Run with cats or take em off?
  47. areomotive spring wanted
  48. Best Clutch for 500rwhp maggie vette
  49. Info Needed: Self Contained Oil System for Turbo
  50. MY vette on the Dyno made 1490 rwhp and 1540 rwtq
  51. I Need A New Forged Engine
  52. Fuel system question
  53. Thanks guys!! Good advice!
  54. Is a progressive switch necessary?
  55. Video: my car on the dyno with a 75 shot
  56. How is this cam with a D1sc or ysi
  57. A few 317 heads questions??
  58. Single rear mount piping size suggestions
  59. non intercooled maggie
  60. Another A&A supercharger kit thread...
  61. What should I do?need advice on my maggie
  62. A&a ysi & fast 90/90 wtf!!!
  63. Mo's Texas mile results & experience !!!!
  64. Another 427/YSI Build
  65. Cammed A&A C5Z Video!
  66. $165 fuel sump hat and you run whatever external fuel pump. Your thoughts?
  67. Adding nitrous
  68. Easy belt changes and Gorilla tight belts!!!!!
  69. Texas Mile crash at 230pmh !
  70. Twin-Turbo Corvette flips
  71. new to nitrous..
  72. Supercharger or Turbocharger System
  73. 3.5 inch dongle??
  74. Codes after AA install
  75. Issues please look!
  76. Those of you who have Moved the Radiator Brackets
  77. How much rwhp can this fuel system support?
  78. another ETMC stg6 out the door but this one with the new RIPPER cam(vid inside)
  79. Which BAP
  80. Rear end gears with Centrifigal?
  81. D-Day is Upon Us
  82. Just joined the club!
  83. Special Thanks to ECS, They go the Extra Mile!!!!!
  84. BAD ASS STREET Car!! THANKS Tommy, Doug, Chris, & Matt! ECS
  85. *** F/S Brand New AIS Stage 2 Trunk Mount Meth Inj Kit ***
  86. Where are you mounting your catch can, other than on/near engine?
  87. PFADT carbon fiber drive shaft instal question
  88. A special Spring message from the crew at The Vette Doctors
  89. Alkycontrol question?
  90. Avoided belt slip: A&A Upgraded Bracket or Flip Drive?
  91. A&A Vortech Oil Feed Line? Length?
  92. anyone got a bosch blow off valve laying around?
  93. Any body use Nitrous Outlet???
  94. New etmc ripper fi cam results
  95. My new A&A SC Impressions
  96. boost controlers
  97. ProCharger without Headrers?
  98. Engine Under boost
  99. Need Help With Meth Decision on an ECS SC600 Novi 2k!!!!!!!!
  100. stupid question. Where can i buy a cap for the bottle
  101. Looking for a tuner/installer in Iowa
  102. Installing A & A supercharger auto trans lines are in the way?
  103. Which way to mount bottle nozzle. driver or passenger
  104. Best 6 bolt heads
  105. Which MAP should I be running?
  106. New dyno #'s & Texas Mile Bound !!!!!!!
  107. Procharged C5 Drivetrain Upgrades
  108. ECS powerglide or th400 swap - anyone using in a street car?
  109. Buying a SC'd Z06 - What To Look For?
  110. wtb wibeband
  111. 427 & Turbo sizes
  112. Ragin Racin Boost by Speed
  113. Added new stuff, waiting for dyno!!!
  114. new numbers after changing intake
  115. BLOWNBLUEZ06 (Bret)
  116. Started installing my A & A supercharger tonite
  117. Pic request: Unique Fi setups
  118. *Official Release* RSI Triple Fuel Pump Hanger for C6 and C5 FFS Corvettes
  119. 02 Z06 with A&A YSi
  120. Webb kills E85?
  121. Fuel pressure w/ A&A kit?
  122. fuel pumps...i need one
  123. Supercharged 383 build thread
  124. Trans removal
  125. Quick Boost-Referenced FPR Question
  126. I dont have a nitrous syphon tube...
  127. Oil Pressure Question
  128. Supercharger Help Questions
  129. Stock LS6 oil pump good enough?
  130. Numbers are in!!!!
  131. AA SC sound
  132. vortech V-2 SQ impeller shaft nut torque?
  133. Looking to sell ZEX nitrous kit-- upgrading
  134. oil slinger/reclocking question on a procharger
  135. Will this tire setup be ok?
  136. Looking for a larger Procharger 6-rib pulley
  137. A&A Vortech Superchargers!-$6599.99 INSTALLED!
  138. Will this intercooler inlet size be a problem?
  139. LG Motorsports Long Tube Headers-$1999 Installed & Tuned!
  140. Need Fuel Pump Problems Solved
  141. Boost guage tubing through firewall
  142. question about a & a corvettes radiator lowering kit.
  143. Just bought the A&A kit for my C5Z!!
  144. Turbo C5
  145. Wondering about putting NOS on 01 Zo6.
  146. Vette TT Questions
  147. Nitrous Vs. Procharger
  148. dynotune lean shut down switch
  149. Switching to TR6060
  150. Moving on to a new setup....
  151. How stupid am I??? Input please!!
  152. Dry nitrous kit question
  153. Looking to test drive car with high stall..
  154. Nitrous safety during accident
  155. ecs tensioner wrench
  156. toyo on a c5 98" coupe
  157. backpressure problem
  158. Need some help on my intake setup from my FI brothers.
  159. dead battery parasitic drain 10.2 volts
  160. CCP 10 Rib Upgrade
  161. Boost hitting early and late
  162. recemandation's on a fule pump
  163. Wolfe Roll Bar Install
  164. Callaway Honker and NOS
  165. Anyone have a wright up on installing a auto diff brace
  166. What Small things do i do to get ready for FI
  167. Valve springs
  168. Aeroforce Interceptor gauges
  169. Silcon Couplers
  170. Scary Thought, Is the Modded up C5 Going To Be a Dinasour
  171. Do you guys have traction in 4th and 5th? (video inside)
  172. Low voltage message on display
  173. need insight on flip drive install
  174. Help what do I need for meth set up?
  175. WTB: supercharger for '02 C5Z
  176. when do you really start to lift heads with boost?
  177. Any Musician's in the F.I. Crowd?
  178. Nitrous 101?
  179. It's Alive!!!!!
  180. Champion Motors stock ls6 717rwhp!!!
  181. how hard you spinning your ysi ?
  182. A&A Question
  183. 83 or 120# injectors
  184. Tune increase boost?
  185. Who was this?
  186. Question about custom intercooler piping.
  187. A&A 10rib Eye Candy
  188. Motor is done link inside rhs block
  189. updating 97 pcm with 99 and newer
  190. I am now A full fledged SC Family member
  191. restrictor plate?
  192. Warhawk Block or an ERL Block
  193. ProCharger fitment on an LS2
  194. Heavy Duty Idler Pulley's!
  195. Good experienced porter for some bowl and throat porting on 317 heads?
  196. Aeromotive A1000 In-Tank - Graph Inside
  197. need belt advice..
  198. Anyone have experience with RSD Radiators? TT cooling options?
  199. ran outta fuel with a&a's pump
  200. How is this cam?
  201. Hey Chicago Guys.....who running Meth???
  202. A&A Supercharger
  203. Anyone tried the Deatschwerks DW300 fuel pump?
  204. 317 or 243. Need your advice. (MAGGIE)
  205. A short Supercharged Video! Mojave Mile Shakedown...
  206. Fuel line check valve? Pressure drops after ign OFF.
  207. Is a cam swap worth it for an M112 LS6?
  208. those running meth...
  209. Its Almost Ready To Come Alive!
  210. Opinions on clutches
  211. What balancer??
  212. lets talk fuel systems - hob switches and check valves
  213. A little food for thought
  214. :::::A&A Supercharger and American Racing Headers INSTALLED................$6995.....
  215. Are these specs good for a turbo cam?
  216. East TX Muscle Car
  217. James' 2001 C5 Vert w/ A&A Supercharger Installed
  218. Nitrous/Meth
  219. Anyone need a big FI fuel system?
  220. LPE launch Controller
  221. Look what my girl got me as my Bday cake :)
  222. Here is some Motor pictures
  223. SEE YAA at ECS
  224. Meth and maf question
  225. Learning to Work on cars
  226. Some Upgrades
  227. lpe fuel pump
  228. Doing 317's for A&A kit. What mill to get 9.9-10:1 SCR?
  229. NXS Boost Controller
  230. Backing out of the garage video...
  231. New set up!!!!!
  232. WTB: STS Exhaust tail pipes
  233. engine condition
  234. Putting on some GOODIES, ECS Novi, 3.42, SS3200 and new Leather!!!
  235. Post Cat O2 sim or Extension for 03Z
  236. HELP I want to spend around 7K for installed single Turbo setup
  237. fuel pressure regulator location
  238. IForged TE7 Big Brake Kit Custom Wheels
  239. Need Guidance on Blower Pulley, Boost Level
  240. Ngk tr6 gap?
  241. For those who are wondering...
  242. Help reclocking my procharger!
  243. Who uses the MAGNACHARGER TVS 2300?
  244. Anyone use Comp Cam on the Maggie LS6 car?
  245. A&A on Stock bottom-end. Problems?
  246. UHHHHH Darn Tire Installers
  247. now to driveline part of the build
  248. MityVac bleeding through remote bleeder
  249. Anyone used 928motorsports for SC rebuild?
  250. What is the explanation of how these cars gain 200 or so rwhp with F.I.?
