- stroker kit question
- boost
- New P1 and D1 head unit prices?
- DM Performance Engine Main Girdle - Anyone Using This on Motor Builds? Comments?
- ** A&A Vortech on a Z06 @7.5 PSI - 572 RWHP **
- Pulley size on S Trim
- Stinger Hood
- Magnuson Supercharger With Hood Package!
- How do I disable coils to spin engine without starting.
- relocated coil packs questions...
- Best Aftermarket Airbridge for STS Kit ?
- P1sc vs D1sc
- New LS2 C5R Type Mini Heads
- test
- ECS Paxton install part 2...
- ECS Fuel System Pics???? Need help.
- Decsions, Decsions....that's making me CRAZY
- Ya'll said the STS rocker panel pipes are hard?
- Looking for 575-600 RWHP
- STS video or sound clips?
- Any one using the RAM 910 clutch?
- Drilling into the oil pan for return lin question
- Good deal on a supercharger?
- Boost guage mounting
- Racetronix kit question about float
- Visit to GM Arlington 1/23-1/25
- Sealevel Boost + Hi Alt. Octane = powerloss
- belt tensioner 4 Maggie Supercharger
- Nitrous and A/F question
- Don't laugh, but...
- Do I "Need" a FAST 90 Intake & LS2 TB for LS2 402 Build with ECS F1R Set-Up?
- Battery Relocation question???
- interested in Vortech, looking for info
- STS oil return options
- 402 TT Progress Pics
- * little off topic.... but Barrett Jackson Pics (Dial up beware)
- New Forged Boost Motors - Break in with Synthetic or Conventional Oil?
- A & A Vortech - Video? ? ?
- Boost-A -Pump install question
- Which flywheel are you running?
- Corporate greed steps on another "little person"
- CAM... which one should I get
- Fresh Canyon run, with a twist...
- [turbo] If you use speed density.....
- tom ulrich cars is going to crazy fast and trick
- Attaching fuel pressure sensor to fuel rail?
- Some results with our new 8" BALANCERS
- Are all P1SC (reverse Flow) Head units the same?
- Maggie Hood questions...please help
- How much of an efficiency hit?
- Nos 05168nos install
- Need Code Help
- Need some good heads for that boost?
- Help! with vortech rattling noise
- what to build w/70k a month?
- Added manual boost controller to STS today
- All those with power adders....
- selling my TTi Stage 1 for $5000
- please help with a few question, nitrous guys
- Blower going on...What about the fuel system?
- Need help installing 02 sensor on 02 Z06???
- Has anyone had an MTI installation ?
- I finally figured out my combo-what do you think?
- Rwhp# Expected 348 205cc and G5x4 with a 250shot
- STS TT - My First Impressions
- 346CI + tt + 6spd= ???
- STS questions
- Boost Gauge help
- Will a 10lbs N20 bottle mount/fit in the rear storage compartment?
- HOLY #@$% Check out my painted stuff!!!!!
- What to do with heads
- Sound difference Turbo VS Supercharger VS NA
- Questions about swapping LQ9 heads and dropping compression for boost?
- Twin Turbo Torque Curves [Post your graph please]
- Where to get a good oil cooler ...
- Dyno Day for a 408 ...
- Coolant?
- Will the tunnel plate (ABS of...) do anything at the strip?
- STS question regarding wastegates (STS rep. would be nice in here)
- Pics of NX install!
- Magnacharger Belts
- Where to tap in for fuel pressure gauge w/ Maggie?
- nitrous
- Thumbs up to ECS!
- Can I drill my stock Throtlebody for Nos wet installation?
- Will LT headers add power on NOS?
- How much hp do I need to take a KB Cobra vert?
- 1/4 times with A&A Procharger
- TORCO ACCELERATOR octane booster questions ?
- MSD digital Window switch help?!
- TNT jetting chart
- Impedance Converter for 95 Lb injectors
- PTK turbo pics..custom
- pictures of custom / PTK install
- C6 z06 cam + Nos video
- New turbo hood pictures..PTK turbo setup
- Boost-A-Pump placement
- NOS getting instaled today!!!!!!!
- LS7 ZO6 video ... what a 3-cam and NOS will do for it
- New Best Times, Special Thanks to A&A Corvette
- Acceptable numbers for the Kenne Bell Twin Screw...?
- >95% Injector Duty Cycle; 42# Injectors Not Enough?
- Good news today!!!!!!
- Help Picking Turbo Size
- NOS direct port install.....
- How well do metal substrate cats hold up to F/I?
- MDMC Slow Boat to China!!!
- Corvettes of Westchester Installs FIRST STS TWIN TURBO PROTOTYPE
- Drove my car 800 miles this weekend.
- Help needed on cam for N2O car.
- TTIX goes to the dyno
- Driveline is out, what else before reassembly and STS kit?
- Quick question for F/I guys
- boredom lets see your cars (my picts incl)
- i finally did it and it felt so good
- Loss of pressure and air in the rails
- I figured this is the best place to ask-anyone have a Procharger 4.25 pulley for sale
- what is the most rwhp/tq a stock tranny can take with fi
- ECS Paxton install started
- need heads advice......
- Can I go s/c for $5000?
- GroundZero Motorsports Twin Turbo Kit
- You don't need no stinkin' Tach!
- Microsoft vs GM
- Decisions....Decisions...
- Problems with stock master cylinder for aftermarket clutch on F/I cars
- Pros and Cons Of PTK and TTiX Kit
- FS C5 New STS twin turbo kit
- nos bottle & heating
- Nos MSD Window Switch?
- stage 2 procharger or turbo
- Highest boost by a blower on 9.5 CR
- P0327 Code
- New upgrade for ECS Paxton Kit!!
- Mondo BOV
- TJWong STS Turbo install!
- BFG Drag Radial Redesign?
- Fuel Pump Wiring
- Maggie carbon fiber coil covers coming soon
- MSD 6200 pill needed
- Please Help with low hp #s with Vortech
- STS Horsepower, what the deal?
- Next Step
- How can you determine Intercooled vs. NonIntercooled by pictures?
- What do ya think about LPE's new C6 maggie hood?
- If you have a Maggie can you step in here real quick?
- Injectors larger than 60#?
- STS tweaking
- Stock fuel pump limit?
- STS Question
- Hey guys think I'm going s/c. I need help with a HOOD.
- fastest 1/4 with tt running 17 radial?
- Need advice on shops, round 2.
- any need???? maggie question
- Anyone running HIGH compression LOW boost?
- ET Preformance Heads
- Which pulley on T-Trim?
- Maggie + Stroker =
- Vette Doctors installation of the STS Rear Mounted Twin Turbo [PICS]
- Can someone with an STS kit explain
- HPTuners Upgrade Questions!
- Blown Vette vs LS7 Z ... Fun factor !
- Cog Pulley System
- Watching the gauges
- Magnacharger Supercharger
- Tuning
- Synergy Motorsports Dyno Day Results
- The most quiet LT Headers???
- do the sts kits, hit as hard down low as other kits?
- Looking into Forged Short Block
- A public thanks to PAXTON !!
- SC whine anyone with an opinion step in :)
- installed the NOS t.b. plate kit
- Must see TV ... no, not NBC !
- tt questions on specs/components
- Mobil 1 vs Amsoil vs Royal Purple with FI
- Nitrous Puring on a C5
- Boost for 4 5/8" pulley?
- ***Intro new PRO Wet kit***
- ** Hot Nitrous News!! ***
- Selling Reichard pulley for Magnacharger
- FI crankcase evacuation/catch can set up
- Fuel injector swap (instructions) look here! Thanks to Bill Reid
- STS TT installed by ECS
- ECS overdrive Crank Pulley Just got here!
- Dynoing my A&A P1 This Weekend - Guestimates as to my HP/TQ
- Questions about Original ATI P1 kit
- ATI Supercharger Sale!
- Procharger Belt Walking Problem
- Need A Donor Car For Free Kenne Bell Install!!
- Good info on Methanol
- How do LPE magnacharger covers attached to the engine?
- C6 vs. FI C5
- Different location for mounting A/F guage.
- HP turbo kit
- LS6 INTAKE vs LS1 INTAKE ON A S/C LS1??
- Anybody got a soundclip of Andy's Vortec S -trim?
- Where do I buy Methanol in SW Florida?
- What gauges would you keep on the bottle
- just dreaming but..
- Intalled a new pump today.
- Hey Jay!!!!!
- Magnuson belt tensioner upgrade
- New best time at the track!
- Very good experience with a forum member
- 3:90 geras in TT 427
- Threw a code...
- Let's see some videos!
- what are some sts rwhp #s?
- A real bummer
- PTK install question
- New Racetronix wiring harness for sale
- Best intake for Non IC Maggie
- NO2 and compression
- LS6 Stock Bottom
- HELP!! Does anyone know where I may be able to find the belt tensioner that ECS uses
- I'll say it again
- Injector offset for 60lb mototron injectors?
- A@E Street Racing
- Magnuson or centrifugal???
- PTK hot parts
- BEST DEAL going for FI..............
- Nitrous suggestions/thoughts?
- ? about BBK aluminum airbridge + STS turbo
- Is My Cam O.k?
- Just getting a felling of what every one is doing with there car.
- Pillar Gauges suggestions
- ls6 compression with boost= discuss
- meth kit
- Nitrious Legality?
- Boost 'pressure' vs. 'airflow'
- SC on Backorder MDMC offered Turbo Kit
- wife gave me the ok!
- A&A Vs. ATI Stage II
- Clutch recommendations for streetability
- RPM tranny rocks!!!!!
- New turbo kit for C6,really nice work!
- Retrofit C6 kit?
- Replaced clutch master cyl, now boost gauge acting up......
- Maf
- Go Lonhorns
- Blower CFM and boost questions
- what would you think?
- 100 Shot & Flycut Pistons = ?????
- Safe Nitrious Shot??
- Dyno tune in Westchester NY?
- T3 vs T4 (Turbine)
- New Supercharger setup
- lurching problem, i dont know what it is, i need some help/ advice
- FS: Vortech Racing BOV
