- What spark plug gap for TR6's?
- STS Track Results----> Inside
- Turbo Blanket wrap
- STS question
- Bro got screwed buying a car, what can he do?
- Post pics
- Paxton Novi headunit question...
- FI question
- Hamad115........ MDMC Update???
- ATI P1SC blower cam choice???
- ECS alky kit questions
- How did you tap into your fuel rail?
- what cam for a maggie?
- Who can Help?
- ECS/ Paxton customers
- MagnaCharger Rear Belt Problems ????
- anyone use NOS with an automatic?
- Looking for SC tune (bin/hpt) files
- Which C5 Z06 for FI?
- 90mm maggy inlet
- Does the A/F ratio required for a SC car always cause your exhaust tips to turn black
- Got some fuel pressure back
- Fuel cell ??
- 408 + D1sc ???
- 150 shot
- 2004 fuel tank removel??
- STS FRC for sale
- Pro Torque torque coverters are the any good?
- Race fuel what octane 104,108 etc. to use?
- what should I add to a STS setup for road racing?
- Ultimate daily driven street car
- Fuel system testing methodology.
- any reason why the KB wont heat soak like the mags do?
- Help, How do you read this thing?
- how much do the PTK and TTI kits cost?
- STS Turbos Blown?
- where to get a 3 pod a pillar
- What tires for TTi Stage 1
- Excellent Service From Pts (ptk)
- What BOV do you use for 14-15lbs boost ?
- Late Model Valve Stem Seals Question
- Almost finished with the Baddest Blown C5 of "Epic Proportions"
- Low Mount Turbos and water
- Those with a surge tank setup
- H20 & Methenol Whats your thoughts
- STS installers step in...
- 100 Dry Shot No Window Switch
- ECS Fuel system meets King Pin...
- Supercharger Friday @ TBYRNE!
- test
- 600Rwhp guys.. What fuel system?
- march 3rd big day for somone here on fi section
- LS1 Valve Spring Float with STS TT ... corrective measures
- Mod Project from Hell
- Took the ECS Paxton to the track
- Running a 6 rib pulley bracket on a 408 motor.
- what kind of spark plugs should i get
- Any LPE TT Owners with Hotchkiss Sways?
- Dynotune nitrous pressure gauge install??
- Stand Alone fuel system for around $200?? But do I dare do it????
- Final Dyno day....
- Should I upgrade to the GT32 from the T3/4
- STS TT KIt - Goodbye Resonance, Hello Whistle
- 99C5-Twin Turbo spark plug gap/misfire detection
- chrome finally done!
- Proper PCV Setup
- new to the forum, problem with acp hood!!!
- Gwinnett Co. GA members???
- Bearing for Magna Charger
- 2 Serious questions about STS C 5 Kit
- I'm selling my 2000 C5 408 vert M6
- STS kit vs. DTE Brace
- Confessional: I blew my motor ..
- How much does the cradle+engine weigh?
- B&B Shorties Xpipe on a STS C5?
- engine setup for 18psi
- LPE Magnuson Hood
- Guys with built engines
- Fuel Pressure Drop
- What is an alky kit, really?
- Raceway park Saturday
- Kenne Bell Setup? How Long Of A Wait?
- TT cam question...
- What do you put in your alky kit and where do you get it?
- How big is ALKY really in preventing stock f/i LS6 motor failures.
- what do tuner shops charge to install PTK, TTI, STS kits
- what is the max boost the STS return pipes can hold?
- Any LPE TT Owners do HotLapping Events?
- Ati MMS bracket pullies go squeek squeek squeek
- A few FI questions for soon to be new vette owner
- Got some giggly from UPS today
- Doing an STS kit, what is mandatory?
- STS IC, BBK air bridge, lowering rad bracket question
- How do i check the maggie oil level?? where is it!?
- Twin Turbo Kits?
- Help Vortech With The Ultimate Customer Gallery!
- Asmokegars gets a new avatar
- Guys using NX switch panel
- MDMC Modern Day Muscle Cars
- Lambo Cruise {VIDEO}
- What are your opinions on having 21st Century install an ECS kit
- Belt Squeal P1SC
- d1sc power on a c5?
- ? Line lock for FI
- What will an LS1 with a D1SC @ 10psi put down?
- took a ride in my car tonight
- joel (jbsblownc5), were you teasing the Lambo's?
- how should i hook up my throtle switch
- 408ci/D1 Numbers
- SDPC Forged 402 for FI
- PTK stuff
- Has anyone disassembled a Maggie?
- PCV valve, with k&N breather...
- ECS Paxton at the Nationals
- Super Charge your Corvette - Only $59.95
- Well car caught fire tonight... oil problem... help.. seggestions
- C5 Twin Turbo w/ No cats
- has anyone had a procharger and switched to the novi?
- Homebrew tubing bender...
- Put the drag radials on, pictures and impressions.
- Anybody running victor intake/intake elbow
- Used Maggie
- Something new for tuners
- transgo shift kit
- On my way to a better fuel system for my 04'
- F/I folks with after market clutch, any problems with stock master cylinders?
- Any A&A TT updates?
- Hood recommendation for magnacharger?
- Sucked a chassis washer into my Z06!
- How much boost on stock internals are you running?
- Wheel hop, let's solve this
- Getting ready to start the STS install...
- Hot parts coating?
- TT FRC - exhaust clips
- Those with experience with 28x10 Hoosiers?
- Not F.I., but I thought you hard core guys might enjoy it.
- Bad Cam For Procharger P1SC?
- A&A or ECS Procharger bracket conversion guys!! Help!
- Anyone installed the Kenne bell yet?
- How much RWHP+TQ can a stock C5 Z51 clutch take with stock tires? better tires?
- Procharger?
- Turbo charged power.com
- Turbo vs. Super - NOT peak hp or preference though!
- My opinion of ECS...
- Lets add some power - HELP please!
- Well....Looks like TFS and Edelbrock now make heads for us? Anyone
- Heads
- DynoTech Engineering Nitrous Plate
- STS Quad tips & Baffle picture
- Mufflers on STS TT sound clip
- STS C6 website update 2/23...new info+videos
- Any interest in a used F1R
- Procharegd C6-Z06 goes "boom"
- for those that wanted that coolflex rad hose
- STS Twin Turbo Setup Question
- Koolsox - does anyone use these?
- HELP installing manual boost controller.
- How much can I spray on a stock fuel system?
- FI engine build
- Thanks Chris @ ECS
- supercharger?
- Rocket scientists, check in!
- help up out,,,A and A vortech install
- Need some advise from the FI gurus for my project!!
- [magna charger]Does anyone have....
- Where is my ETP Heads
- New C6 - A6 Tranny ... is it built right?
- Breakin' in new motor sux...
- Best way prep FI car for sale?
- never been blown!!!
- Boost gauge Question
- kenne bell pics??
- Any one running the MDMC Fuel system??
- Where to mount manual boost controller on STS car
- Dyno tune Site
- Where do you have a fire extengisher mounted?
- Lots of Nitrious Questions!!!!
- quad tips STS tail pipes
- which is the best way to go
- Removing ATI Stage 2 - what parts will i need to go back to stock
- Attention all rocket scientists! need explanation
- Big Brakes for FI Vettes
- Catchcan setup on LS-1 engine
- BLOWNZO6 - TTiX Install Part 2 - Turbos
- LQ9 head question.
- What plugs ya'll using ?
- silicone couplers
- dowel the crank?
- Whats your fuel pressure with boost a pump?
- Pics of supercharged badge installed.
- Centrifugal Feel Slower Than Stock At 2-3K Rpm?
- Boost with LS7 Heads?
- Ok Guys . My Motor Is Out Of The Car And I Need Some Advice .
- Bottle mounting Pix
- Mag equipped & oil seeping passed oil pan plug
- BEST fuel pump and exhaust housings
- Ron Davis radiator question
- Turbo Oil Pump Noise?
- Guys who know lifts, check in
- 2004 A4 2.73 Is supercharger a waste.
- what is Traction control code 1288
- About halfway through my g5x3 swap.... AND...
- Racetronix wiring harness
- ECS Meth kit a good idea for a stock bottom end?
- Anyone have pics of their C5 nitrous installs
- Torque converter trouble please help!!!
- Anyone thought of running straight cut gears in their MN6
- Is keeping stock mn6 with 900hp smart?
- Superchargers and Turbos Available At TBYRNE Motorsports!
- ** Huge News ** Hot New Product!!
- Lingenfelter/Magnuson S/C & hood package on sale
- Ecs
- Electronic Boost Controllers ....
- Maggie & 3.90 gears, are the 3.90 gears too much?
- Maggie - Wet vs. dry Nitros
- wew whooooo
- nitrous bottles behind seat, and daisy chain?
- Dyno Differences
- How much is TOO much HP in a convertible??
- A4, FI, and Big Converter
- Boostlogic TT, 1st #'s
- what makes a RPM tranny so strong
- STS Boost Poll .... describe your setup
- in the market 4 fi...post your times
- any regrets after installing FI
- Well one of my cousins in New Orleans has been busy again...
- Aquastealth.com
- Anyone got 60lb injectors on a 346cu.in. working?
- Explain Maggie Heat Soak!
- Supercharger with 11.2:1 Compression???
- how long will it last?
- Braided stainless vs. stainless hard line vs. aluminum hard line
- My Valentines Day present - C5R block arrived!
- Ported TB... yes or no?
- forged short blocks?
- Dyno results of new ECS overdrive pully on maggie
- C6 Z06 clutch installed - master cylinder needed?
- 408 + Stage X = ???
- STS Dyno Results ... on LS1 engine
- MAGGIE, MAF's, and MAP's.
- have you guys seen this... Another Halltech knockoff
- A & A Vortech ? ? ?
- "04" ZO6 Vs "06" Coupe
- 408 ????
- 200 Mph
- Weight of turbo or supercharger intall.
- Any A4 guys running Andy's Vortech Kit?
- LQ9 heads with Boost
- Questions about the 8 rib belt kit for Procharger
- Dual Pumps
