- C-5 Logo Bottle Blanket Done
- Anyone have a vid of a supercharger BOV in action
- anyone using procharger stage 2 kit
- Nitto R2 vs BFG drag radial review
- Video of My STS TT C5
- Which roll cage do ya'll use and did you install it yourself?
- Halltech twin turbo c5 hood
- TORQUE TUBE?????????? Please GET IN
- Question about sts system
- supercharger bov
- Best for potential power? TT or S/C?
- F1R Graphs
- Where Are My Maggie Fuel Rail Covers
- Dyno Vid.. S/C vette with Meth
- Prostate Cancer
- FRC fit with ETP 215 heads
- ATI vs. Paxton
- A Sure Sign Spring is Here
- Need Help with Fuel Pressure Sender
- YES Another Fuel System Question
- Snow Performance meth kit/MAF output?
- Magna or not
- ECS Restrictor Plate
- Blackwing Dry shot and wet plate Bench tested
- FOR SALE: Z-06 rear wheels..
- Bandit finally Sprays at 1/2 Mile Help Evaluate (Pretty Cool!)
- Anyone running a Timing Tuner?
- 50/50 used as winshield washer fluid ok?
- Robert56
- ls2 402 stroker camshaft question.
- Alky Refill?
- Will adding the ECS alky kit stop my black exhaust?
- Where can i find instrucitons fro ATI pipe routing ?
- UPDATED NUMBERS!! But still not final...
- My 76 custom turbo
- BIG HP guys inside. Question about fuel pressure..
- Magge I/C vs non I/C HP shootout fun.
- This video brings back nitghmares for me
- ATI head unit has a leek!
- Ok since the fastest C5's are in this section
- blowoff valve
- Questions on a Magnuson S/C
- Wanna Sell Your Beast?
- 4" red couplers 4 ply
- Alky pump mounting location
- Kenne Bell and cam
- 8 rib pulley set up
- Bottle mounting
- Extremely stupid question.....
- any tuners using EI Live?
- Pictures ECS Paxton SC Installed?
- Need a good fuel pump!
- fuel question: stock pump and BAP
- My New 408 and T88 Pic's inside
- Beefing up car to hold power...
- air/oil seperator
- Small vid - APS twin turbo Corvette
- VIDEO g5x3, direct port, fast, ls2tb, ECS here I come!
- is my cam ok for a sts turbo setup?
- Super charger on eBay
- Tach wire for the MSD window switch
- the ULTIMATE challenge.. Pending TT Viper smack down!!!
- Other post no workie, advice needed so I can give ya'll the track numbers
- Hey Guys where can I find A 4in V band Clamp
- Kenne Bell S/C, will it work on a '97 MY?
- Ok, so I'm going to give ya'll track numbers this weekend, advice needed
- What Fuel system for a little Maggie?
- Valve
- Nitrous progressive controller
- STS Install questions
- Im in love!!!!
- 1/4 of a mile run ?? ......700 rwhp
- What plugs do I NEED to use with a NOS shot?
- How many guys have a Kenne Bell S/C ordered?
- Looking for Chrome Shop in SE Michigan
- Magnacharger for Sale!
- TTI X second dyno pull
- BOV info wanted
- Any good tuners near Tulsa ok.
- 100 Shot
- which is worse w/tt..A4 or MN6?
- For Sale Just freshened 6L Heads Ported and Polished
- What makke 8 rib belt are you using??
- Kenne Bell Is on the market! couple questions.
- King Pin's TTiX dyno
- Need pics of hoods that will fit the Magi
- what horsepower
- When I get boosted, should I change out my hi-flo cats to straight pipes?
- maggy pulley size vs boost level?
- APS twin turbo install instructions
- here is my moderen day muscle car run 10.47
- LPE pump/KB BAP vs. Racetronix w/ direct wiring
- Question about identifying Pulley on a Procharger ??
- A-pillar pod mounting ideas wanted.
- Bin File
- Seafoam and maggy???
- TTI X first full dyno pull
- Rockers ?
- What is the perfect A/F for boosted cars?
- Need Some help w/ weird Knock
- Pulling vacuum from crankcase to seal rings
- NOVI guys on stock LS6.....
- ETP240 heads
- DYno S/C vette with Meth
- Got some dyno numbers for ya'll finally...
- Where Can I Get These And What Are They Called?
- FI Related and Supporting Vendor News ---video inside---
- Took a ride in the first C6 STS Turbo Car Today
- Is the diff brace needed?
- What do you think about 7.25lbs of boost?
- My Cats Failed
- Fuel Pump ??????
- FREE Kooks Long Tube Headers with Magnuson Supercharger Purchase!
- t-bolt clamps?
- 01 z06 p1sc A&A blower kit what size pulley should I run
- Meth tunning on S/C
- Maggie and n20?????
- STS commercial
- hardened Output shafts.. Question..
- Starter Question????
- 408 and T88 Turbo almost done Now I need a Tuner
- Blower/Heads on A4; Install costs & other parts?
- What size belt for 4.10 pulley and A&A bracket?
- Belt size for A&A P1SC and smaller pulley
- Blowdown Tubes for Nitrous / Co2 and NHRA Safety rules...?...
- Tti X Problems ?????
- VaraRam expected returns?
- Birthday present to myself
- A4 transmission cooler type and location
- KB BAP install??
- A4 with custom Turbo trans go Boom!
- New motor break in
- Can you help me decide on a fuel pump
- ProCharger Pulleys Size Help!
- STS Oil pump question
- Cudos To Darton...
- new turbos!!
- Ashtray plate made, ECS alky control, line lock, and EBC
- My recent project, 90mm conversion, although not C5 specific
- Hooked up BAP, which gray wire?
- A4 Trans. ??? Need Help
- Serial and paralell pumps
- Help with A&A Procharger belt routing bracket with 3 tensioners?
- Next Weakest Link
- off to ECS...for more power
- Mod & Sell??? . . . Why?
- whose familiar with Keith Craft Motorsports f/i LSX heads?
- Nitrous install
- I've searched and searched. Where did I see that thread to find a 3 gauge pod?
- How many hours approximately to install TTiX?
- Is my cam going to be ok for FI?
- What cam Recommended with Procharger P1SC?
- Video and audio clips of Maggie/NOVI 2000
- Zex kit with a Digital window switch?
- Guess its time to tweak the fuel system?
- what does an ECS magnacharger 8 rib tensioner setup look like?
- skid frame/rad support mod for A&A D1; anyone have the info or pics for this?
- If you were going to drop about 10 grand in a c5 what would u do?
- smack talk!
- Question About ACP Fender Flairs!
- Need Help, I'm on the brink of going SC, but have some questions!!!
- Power curves between Maggie and centrifugal
- Boost Gauge???
- 97/98 Fuel Rail System
- 403 RWHP with Procharger?
- Props going out to Cartek and Neverlift tonight because...
- What is the extent of your Meth habit??
- Twin Turbo vs Supercharger
- ECS novi getting installed
- Silicone Rad hoses??
- Am I being unreasonable?
- PTK alternator: How steady is your voltage?
- Straight up POLL, Procharger vs STS
- Questions for Maggie owners
- Pictures of installed boost controllers
- Do you have to splice the brake booster to get your BOV to work on Supercharged cars?
- Formula for boost + hp & tq ??
- Supercharger Or Turbocharger With Nitrous?
- Non Z06 STS Turbo Install question
- Help Need Motor Advice - Are LS1 & LS6 Blocks from 2001 forward the same
- 200mm Throttle Body
- Procharger oil - who has it in N.Calif
- What's the proper way to setup the wastegate actuator?
- Mirabay, FL Moderator???
- ICS Performance C5 Supercharger Oil Catch Can System ***Now Available***
- Gauges for Supercharged C5
- Atco 04 24 06
- MagnaExtractor hood is now on sale!!!
- 10% OFF Innovate products
- STS Kit, black compressor housing
- Those who switched to Racetronix pumps
- Installing ECS 8-rib Overdrive pulley - major issue???
- Getting Closer...She's gettin' HOT!
- A&A blower question
- Question about slicks
- Think it'll fit the Z06?
- wow...STS
- Sprayed For The First Time
- A&A + cam = low numbers WTF?
- Nitrous wet system
- A+A air dam mod link????
- Looking For An RK Sport Hood For Your Maggie?
- First time at the Track!!!
- Installed STS TT kit pics taken from rear - dialup beware!
- FI Turbo guys I need some with HP Tuners
- Maggie ate a front drive belt.
- Big Cam sound with SC
- 100hp-150hp Wet Kit
- stock torque tube coupler limit?
- Tires
- TTiX...what do you guys think about this?
- Help! Problem pinning the crank!
- What Piston and Rod Combo for Z06 and Maggie?
- Worth swapping to 72CC AFR 225 Heads for my blown stock LS6 engine?
- Two dumb newb questions but I need answers.
- Rodney's Level 5 Tranny Question
- Ken King from Vette Essentials has Passed Away!!
- ECS alky nozzles vs. BBK air bridge
- Fuel pump/system info
- FI Alky Bling. Watch out EG I'ma Comin'!
- 9 Second Pump Gas Daily Driver
- Special thanks to Xtreme Motorsports
- More Kudos for Andy At A&A
- When is huge not enough??
- Count me in - Just ordered STS TT
- 700rwhp plus? Lets find a place for this..
- Looking for cam suggestions on my A&A P1SC
- what adds more cylinder pressure? Boost or N2O
- Lingenfelter Stage 2 TT's /// in C5
- STS Turbo System Boost Control
- Fastest Street Car With Cats
- What kind of psi should I expect with a D-1 and a 5" pulley?
- highest mph trap w/fi......any model or make
- Boost-a-pump question
- Which blower, T or YSi
- Which cam for my blower?
- LS6 Heads on my setup?
- C5 Direct Port Take 2.....
- Thanks to Ed and Graham at LPE for the hospitality.
- F1R Users
- G5x3, fast 90, ls2, and stand alone DIRECT PORT. NOW..
- 790 rwhp pump gas 13 psi
- Anyone have a mag ls1 edit file I can checkout?
- Best block & head for FI applications
- One bad Azz Nitrous Car
- Tapping Oil Pan
- STS oiling question
- Installing Maggie need some info?
- LG's G5xB cam who is using it?
- Finally put it on the dyno (not too bad for stock bottom)
