View Full Version : C5 Forced Induction/Nitrous
  1. STS Costs?
  2. Supercharged
  3. HELP, proper size belt for 3.1 pulley on mag
  4. Help me spend my money!
  5. Too many wimpy blowers!
  6. 408 & T88 Turbo It's Alive Pic's Inside. Dial Up Beware
  7. The Guys At OC Corvette - Wow!
  8. STS Oil Pump - Too Loud.
  9. looking for local help
  10. longtubes and rear mounted sts?
  11. Magnuson Superchargers On Sale!
  12. Does anyone know about digital gauges?
  13. Diff replacement
  14. Anyone with an STS video?
  15. F.S. 2004 auto-x trailer
  16. my pts is up and running!
  17. ECS Fuel System
  18. Need Help.......
  19. WTF is up w/ the KB blower?
  20. HAPPY EASTER to all the entire C5 Forced Induction Forum Members
  21. Procharger Oil Change
  22. who makes the best twin turbo setup?
  23. please help with turbo/supercharger question
  24. Dissapointed
  25. Corvettes of Westchester display at the NEW YORK AUTO SHOW!
  26. chris @ ECS busted!
  27. crankcase pressure under boost ?
  28. NOS 100-125 or 150hp Wet or Dry
  29. NX Wiring help needed, pics inside
  30. 18x12 wheel Picture
  31. MSD Window Switch - Normally Open/Closed ?
  32. Cost of Upgrading the P1 to D1
  33. took the plunge !!!
  34. Pics Of Some Pts Bling Inside!
  35. How much RWHP is each lb of boost worth?
  36. Thank you VETTE DOCTORS & STS -533 rwhp / 488 rwtq
  37. 714 RWHP @13 psi with "Street Force" twin stage 2 and STC forged 346"
  38. Is The 8 Rib The Final Solution To Belt Breakage?
  39. My Newest S/C Car!! [Dreamin] Ultra Cool Video Inside
  40. ATI ProCharger Price Increase Coming Soon!
  41. STS being installed @ Vette Doctors
  42. Timing for 13 psi with 91 octane?
  43. Idea for ECS alky pressure switch?
  44. Sts Turbo
  45. Corvettes of Westchester @ New York Auto Show!
  46. What length belt are you running? 4.5 pulley
  47. Magnuson vs H/C
  48. STS Question. Loading a tune
  49. TTiX Question.....
  50. Cartek Supercharged Car Makes 653 RWHP
  51. 1/8 & 1/4 mile performance updates for STS-TT Vette
  52. is 6 psi safe on stock ls1
  53. What tire are you guys using that are hitting 9's?
  54. Questions for those who relocated their battery to the rear
  55. Pulley size question, option between 4.5 and 5"
  56. Questions for you Nitrous guys
  57. APS Turbo systems
  58. Ptk Dynoed 1321rwhp 1013rwtq
  59. BBK or Carbon fiber for STS?
  60. Extremely High HP C5 Project - Tranny woes.
  61. 750HP plus, D-1 fuel recommendations.
  62. First Custom 427 Z06 STS Twin Turbo Build Done
  63. Fast Vette
  64. help,,,what tensioner
  65. new to this section ? on tt car
  66. Check this out!
  67. New dyno numbers on 02 Z06. 607rwhp 503rwtq.
  68. water injection with maf
  69. Education Needed on Methanol Injection
  70. Who Sells the nicest a-pillar gauge pod?
  71. Need maggie front casting
  72. who is running the Vortech T trim
  73. Question about Cold Boost
  74. What do you think of my Budget setup ?
  75. Auto-x trailer for sale
  76. The Grond Chronicles : ECS Paxton Supercharger Install Part I
  77. G5X3 and boost, Answers within....
  78. C6 guy, Supercharged car, should I upgrade my cam?
  79. What compression to run in a forged 346??
  80. With "all else" being equla what's the difference between a 4.10 and a 4.25 pulley?
  81. Convert 99+ to 97-98 Return Fuel Setup
  82. racetronix + kenne bell BAP questions...
  83. Decisions Decisions..... what you think? N/A or FI
  84. thinking of nitrous
  85. BOOM! (kinda...)
  86. Halltech Ram Air (license plate screen) search.
  87. IAT Location and Kenne Bell S/C what do I do? SD tune guys step in!
  88. ECS Alky kit how-to...
  89. Meth/water nozzles in coupler - yay or nay?
  90. BLOWNZO6 - TTiX is done...
  91. STS 1/4 mile runs ... unofficial #'s for Stock LS1 engine
  92. Kicked off track before making all out run....
  93. If you could have anything you want....
  94. Driving without a tune ?
  95. Efficiency: sc vs turbo
  96. Z06 STS with .5 bar spring PERFECT!
  97. The transformation is complete!!!!Motor(?), TTI X, AFR's, A4, and a bit more
  98. ls7 clutch
  99. 1/8mile drag times
  100. Which intake? FAST, LS2, LS7, etc...
  101. I need nitrous opinions
  102. dyno tune vs. STS tune on a LS6
  103. what clutch?
  104. fuel pressure after cam .
  105. Boost Gauge hookup to brake booster
  106. how well do the c5s hold up under boost?
  107. Nitrous Plugs
  108. No Boost... Suggestions??
  109. Nitrous help
  110. Updated Dyno Numbers
  111. car was running warm
  112. ati A&A is coming off, sts going on. will i need the plastic front that was removed?
  113. Advice
  114. Kenne Bell website says C5 superchargers shipping
  115. Fuel noid stuck closed
  116. False Temp Reading
  117. ZEX TPS connection? Which wire?
  118. How much NOS can a stock motor/trans take?
  119. Nitrous Guru's / Need Advice PLZ
  120. 100hp Wet Nitrous Results
  121. RPM....great work and customer service...
  122. Help from the C6 side: STS install manual?
  123. Where is the restriction orifice located on a supercharger system?
  124. A&A Belt Removal
  125. A4 brake pedal removal? Come in A4 to MN6 guys!
  126. STS and 2.73 or 3.15 gear choice????
  127. Racetronics fuel pump model 03'
  128. The Best Charger......
  129. ECS Fuel System
  130. RPM TRANSMISSION 4L80E C4 Corvette
  131. bottle warmer ground
  132. F/I crew, any knowledge of broken comp 918 springs on F/I LS6
  133. Bought a D1SC Yesterday =D
  134. Fastest 6 speed irs car
  135. ***** CARTEK Procharged C5 goes 9.70 *****
  136. Best place to buy Methanol???
  137. Need help with spring selection
  138. looking for a big alky tank for the rear, any ideas?
  139. where to put the fogger nozzle
  140. Sound clip of procharger?
  141. stock crank??
  142. I need some help and advice for a Maggie Tune
  143. Did I Break it?
  144. Alky pump problems...any ideas????
  145. Cam kit for SC
  146. First Day at the track - (link to short video)
  147. like this turn-key?
  148. Optimal Boost for STS cars ... some beta tests
  149. 1200 hp Capable 6 speed
  150. Comp 918 vs Patriot dual gold springs for stock blown LS6 Motor?
  151. Intercooled Maggie for Autox?HPDE????
  152. ProCharger noise
  153. Looking for most reliablity, any downside to swapping out stock LS6 valve springs!
  154. Cleaned up the Maggie alittle, what ya think
  155. Whats the weak link under boost?
  156. .5 bar spring in STS setup?
  157. STS Turbo = No Radio
  158. 99C5 + A&A P1SC + FLP tune = 618 hp
  159. what is my best option, sc or turbo and why>??
  160. The First Kenne Bell S/C LS2 402 *Picture*
  161. ECS 8" Crank Pulley on LS2 402 Maggie
  162. [pics]kb Bap Install
  163. Throttle Body is Finished
  164. I took off the supercharger, what happens if I go wot without a retune?
  165. Simple little nos question
  166. Does Maggie install hurt highway cruise mileage?
  167. Needed: C5 Fuel Pump Bucket Assembly (w/o pump) or GM part ?
  168. Holy Shyte! Who want's to give this a track run?
  169. what kind of rwhp ?
  170. Boost A Pump - Forum Vendors Selling These?
  171. ZEX Remote Bottle Opener For Sale New Cheap....
  172. Dirty Howie's 5 Gallon Torco Sale!!!
  173. 11.2 on Nitto NT-01... {VIDEO}
  174. Anyone running direct port NOS?
  175. Did some driving this sunday...
  176. what is the most boost you would run on 91 octane?
  177. Nitrous guys may be proud, check it out. Video, pictures, and numbers.
  178. water and Meth-Your Thoughts
  179. Does Maggie install hurt mileage
  180. Pictures of a Magnuson
  181. FS: NOS brand billet Aluminum bottle mount
  182. FS: Custom Billet Aluminum Nitrous bottle and solenoid mounts
  183. Going FI, rebuild my 427 or get a new 402?
  184. What size of drag slicks to run
  185. Street tires for Turbo car?
  186. Oil separator
  187. accurate FP gage, does the AM Cobalt get the nod?
  188. Fuel pressure saftey switch on LS6
  189. Results A&A Vortech
  190. TT pro's please.....
  191. Convert Tnt Power Ring To Direct Port
  192. STS twin turbo kit for C5 pricing?
  193. Will these heads work on a stock ls6 bottom end?
  194. boost guage with vac mod tranny..?
  195. Need Help finding what belt to get for D1SC !!!
  196. H/C, bored/stroked and 427 owners, need some input.
  197. Nitrous and Paint
  198. magna extractor hood
  199. Battery charging or jump I/C Maggie?
  200. Adding Headers to my Magnacharger ?
  201. Plate install
  202. LPE 383 A4 A&A SQ Vortech
  203. Where should I wire the hot wire for Gauge install?
  204. Need Setup Help; P-1SC-1 or D-1SC
  205. which wire for lighting on the stock cluster, for boost/fp gages?
  206. Questions on Customizing my STS
  207. Dry Shot A/F
  208. Dual Gauge Pod, Full A Pillar
  209. Vortech Superchargers On Sale!
  210. 104+ octane boost - yea or nay for nitrous
  211. remember this turbo kit?
  212. my STS.what rpm/boost should my alky start to spray?
  213. Got caught spinning the tires
  214. 402 w twin Gt4202R's
  215. Newbie Question
  216. Two stage N2O progress
  217. Midwest Area .... STS TT regional car show
  218. Electronic Boost Controllers, What are you using
  219. Anyone have a HPtuners bin file for A&A supercharged Z06?
  220. SD vs. MAF Tune
  221. MCM Hood who has the best price?
  222. FI Cost?
  223. How much boost for a stock LS6
  224. Front Tire to Match BFG Drag 275/40/17
  225. N2O jetting and s/c how much diff from na jetting?
  226. nxs kit,, whats numbers to expect on a 1/8 mile
  227. Bought a Defi A/F gauge, Will it work accurately on a blower car
  228. what clutch should I get for STS 15# of boost?
  229. Procharger to paxton
  230. 6.0L Heads Which Gaskets? Help Please....
  231. 402 SLP with Maggie
  232. Customer pictures for RPM Transmissions website
  233. just got my car tuned
  234. Blown 408 Vette for sale
  235. Who has the most miles on their STS setup?
  236. G5X3 N/A now....blower later. Problems??
  237. HELP car will not crank!!!!!!
  238. At what HP level does the stock Ti become restrictive?
  239. where to connect the white (signal) wire on the MSD window switch.
  240. Help Please!
  241. SLP ZL 402 short block with blower.
  242. New balancer or not?
  243. exterior pump
  244. Help, tire sensor question
  245. technique to change oil in P1SC?
  246. SO, who wants to know my final numbers?
  247. How important is it to pin the crank.
  248. Poll: Should APS be banned from the forum. Please research and vote.
  249. Has APS dumped Dave Inall? If no, why are they here? APS posting here, or is it Inall
  250. 42 Pound Injectors enough?
