View Full Version : C5 Forced Induction/Nitrous
  1. 1400HP Twin Turbo C5 on Ebay ($65K)
  2. 1400HP Twin Turbo C5 on Ebay ($65K)
  3. Researching ATI/A&A; Starting to get serious
  4. smoke or steam out exhaust
  5. SLP "ZL402" LS1 and LS2 short block assemblies on sale!
  6. WOT / TPS Switch Questions!
  7. Free accessories with Nitrous Express kit purchase!
  8. Are 10s possible with.......
  9. Made a few shakedown passes friday night
  10. All w/ A4 w/ 3.42 rear and blower-come inside
  11. Does the stock ATI kit have one or two fans?
  12. 8 Rib Factory Idler Pulley
  13. Alky/water injection question
  14. Yellow Zo6 On Spray
  15. Cam Question
  16. is it bad to hit the rev limiter often on procharged car
  17. First impressions of my F1C
  18. Ok someone with a PTK or TTiX needs to do this mod.
  19. Found 1/4 gallon of methanol..
  20. if you add alky and dont retune, what is the best way?
  21. do you guys run alky in the winter cold?
  22. I need some feedback about this tires
  23. 2004 Procharger Fuel Problem
  24. Cajuns T-Shirt
  25. Air Pocket in cooling system?
  26. Break in procedure?
  27. Kenny Bell Supercharger (video)
  28. Paxton SUPERCHARGERS
  29. TTix vs LPE
  30. forged 370+mag+nos..
  31. Gap on TR6 Plugs
  32. Which is better for a daily driver? H/C or Blower?
  33. Expectations - A4/98/Stock + Vortech (Z06)
  34. Another PTK plus ......
  35. will a lower octane gas destroy a fi forged motor
  36. Red Coupe Bandit's Nitrous Video Inside..
  37. Opps. I f/u crank bolt install. Think its ok?
  38. Magnacharger Tune
  39. You Drive Hard, You Crash Hard (VIDEO)
  40. What's with the '04 Fuel System
  41. Rollers or Not
  42. Maggie Planning Help
  43. top 3 Pistons and rods
  44. vid of my vette......ati procharger /ls6/heads and cam
  45. Magnacharger Systems On Special @ Texas Speed
  46. Magna Charger
  47. Is this a good deal?????
  48. will a procharger head unit from a camaro work on a c5
  49. Weight of Superchargers
  50. Need Forum members help to finish my car. PLEASE read if you live around me
  51. My D1/A&A Custom Setup in action on the dyno
  52. A&A Turbo header pics- redesign
  53. Nitto DR's...R1's or RII's Need Advice
  54. where to buy the Bosch 310 pump ?
  55. Belt size?
  56. I TOOK 3rd PLACE @ The Connecticut Corvette Concours Show....xpost w/pics
  57. MAF location?
  58. C5 + Nitrous Questions!
  59. weight of superchargers...
  60. Suggestions Placement Nozzle(s) NX Wet Kit(Pics inside)
  61. Got My NX Dual Nozzle Kit today from UPS
  62. My C5 vs. Single Turbo Supra (short vid)
  63. vid's of my vette......ati procharger /ls6/heads and cam
  64. gates Greenstripe belt, where do you get them?
  65. Does gearing significantly affect TT spool time?
  66. Please help me with this setup
  67. Canyon cruise with a 2005 GSXR1000!! **VIDEO**
  68. What wire for TPS switch
  69. alky injection 100% or not
  70. How do you check a wastegate for boost leaks ?
  71. Best way to get more power w/ a Maggie...
  72. A&A Turbo (teaser pics)
  73. Vortech and ATI superchargers on sale!
  74. widebody fenders?
  75. 3.15 or 3.42?
  76. TTiX on stock motor?
  77. What to do after Waranty Expires
  78. Procharger advice please
  79. Maybe not the fastest C5 but not bad!!
  80. Cats
  81. Nitrious Question
  82. Tranny upgrades...
  83. Spraying Nitrous, MUST YOU turn off Traction Control?
  84. Estimated Labor costs for Nitrous Install (Specific List inside)
  85. Estimated Labor costs for Nitrous Install (Specific List inside)
  86. belt route on a&a setup
  87. Need Andy's Contact info
  88. A Few Kenne Bell Questions
  89. 6 low 9 second passes for my TT and a new best 9.004 @ 150
  90. Andy's cars featured in September "VETTE" mag...
  91. 408 ?
  92. LS7 and how it pertains to C5 F/I
  93. NX Nitrous Switches (Will there be Enough for all my stuff?)
  94. Forged Rods/Pistons?
  95. Looking for drag radials to fit a 19x13 wheel
  96. Installed SC and blew the engine
  97. Has anyone gotten close to 1000 rwhp with the f1r and a stroker motor?
  98. Fastest 1/4mile P1 car in Us?
  99. Just how much NOS can Bottom End Handle?
  100. if my belt shredded after 650 miles what are the options?
  101. Difference in Price From D1 to F1?
  102. Does Haltech still make Twin Turbo kits for C5?
  103. Experience with Rotorpros.com?
  104. Completed Ptk Project Pics
  105. Who installs NITROUS Kits in South Florida?
  106. d1 procharger on a stock motor
  107. Temperature of turbo housings.. need some info
  108. Highest HP Maggie build?
  109. 034 nos nitrous pill
  110. Superchargers
  111. LS2 402 Solid Roller on Boost is it Possible?????
  112. Stage X install commences
  113. Magnuson to ECS procharger
  114. Anyone Have Big Cubes Plus A Mag S/C?
  115. Public Thanks to Andy, Charlie, and A & A Corvettes
  116. I'm in good hands with Grundy!
  117. Spark Plugs/Nitrous ?????
  118. Forged goodies install
  119. Choosing proper t3/t4?
  120. BAD LUCK (Vent)
  121. Age old Turbo vs SC
  122. Reputable engine re-builder in Las Vegas???
  123. drag radials for the street w/ fi car should be mandatory!
  124. are all turbo cars quite...exhaust sound
  125. 4500ft altitude, try more boost,93-91 octane
  126. NOS 08031 Direct Port Nitrous
  127. Results: LPE oil cooler added to TT
  128. egt probes
  129. how often does the pcm pull timing when the car is hot?
  130. pully size with maggie+alky ?
  131. please explain what a heat soaked motor is
  132. Hesitation with a Maggie
  133. Cam advice for "383" with ATI DS1...
  134. does alky help oil temps and coolant temps?
  135. Innovate LC-1 instock for $185
  136. Electric Water Pump on High Hp Cars
  137. 600+hp evo vs 644whp z06 & a 667whp cobra
  138. 383 w/ supercharger feedback wanted
  139. High Compression and boost...?
  140. Installing boost controller on TTiX
  141. Another A&A Baby Will be Born...
  142. if my car has all 6rib, can i use an 8rib blower pulley only
  143. 210/215 cam 575 lift, what does this tell about my FI car?
  144. how do i pull the codes?
  145. Question regarding Magnachargers and C5's/Cobras
  146. Can anyone tell me the specs of G5X-3 cam
  147. nology wires
  148. Which Clutch Should I Get????
  149. Direct Port on my Z06 - pics
  150. can f1r work with a 6 rib?
  151. Factory Supercharged C6 Z06 (Blue Devil)
  152. Beware ethanol blend fuels
  153. my car says check engine, but seems fine
  154. Pics of my new intercooler
  155. 160 MPH Video, Fresh Dyno Graph, Fuel Surge tank Update...
  156. Blower and compression ratio
  157. Nitrous bottle off???
  158. Car heats up quick. . .
  159. Explain Alky for me in dummy terms, do I need it?
  160. other then more power what do you get when you do from a d1sc to f1r/c
  161. Nitrous 100 Shot & Yank SS4000 TC (Need suggestions...)
  162. guys in las vegas, how much boost do you lose?
  163. guys with superchargers or fi, kicking the back end out on a turn
  164. Made few passes in the TT
  165. 10,86 @ 132mph!!
  166. High HP folk, what rpm do you lose traction?
  167. Block question
  168. F1R head unit FS in the FS section.
  169. i want 800rwhp do i need to stroke
  170. Where is the Tach wire?
  171. 100 shot dry! Help
  172. if my car was tuned with a d1sc 13# is it safe to try a f1r or f1c at 13#and no retun
  173. TTiX and TTi Stage I-III Owners come on in.
  174. Has anyone ever stepped back and looked at what we have?
  175. Alky, 110* Heat, Tank Pressure = Flooding/HardStarting. I need your help..
  176. LWA built 408 stroker with A&A F1r Dyno Numbers
  177. 110*'s outside!! It's killing my D1SC. How to keep it cool?
  178. Maximum boost one has seen from a Magnacharger ?
  179. Wondering about a Solid Roller FI Motor ??
  180. Another TTi Stage X Is Prowling The Streets of Metro Detroit
  181. when people say the f1r or f1c is much louder then a p/d1sc,what do they mean
  182. Check out this intake system
  183. Nitrous Experts Step Inside RPM Spraying Questions & Torque Converters
  184. EAST COAST -N- A&A
  185. alky kit and nitrous ?
  186. NX Btl Heater. Diff. Between D-4 & D-6??
  187. Who has the Nitorus Gauge in their Ashtray?
  188. Bandit just ordered a Wet Kit (What do you think?)
  189. MTI 427 vs. my MTI Blower Car
  190. Anyone heard of these guys?
  191. How do you guys mount this item?
  192. Still waiting on Procharger kit ... should I consider other options?
  193. Problems with throttle on F/I 347??
  194. Broken rod bolt
  195. What's up with my MAF? Is this the BOV?
  196. Is retarding the timing necessary 4 a 75 shot?
  197. Couple of progress pics of my LPE 650 TT
  198. I/C Mag & /chrome ps reserviour cover
  199. Twin Turbo's or KB Boost?
  200. TTiX has Arrived in Canada...
  201. Improved Overdriven 5th & 6th Gear Ratios on the Street
  202. Suggestions?
  203. how to change the belt on a&a
  204. NX 10Lb. or 15 Lb. Bottle? 15Lb. Fit in Center Are?
  205. Bad News About My LPE Car
  206. forged bottom ,,help .
  207. Another queston about KB twin screw
  208. Curious Maggie ?
  209. "Spy pics" of the upcoming C5 STS Twin Turbo!
  210. how does the Maggie (or KB Twin Screw) produce instant boost...
  211. Possible fuel source for alky injection
  212. FS: ECS D-1SC ProCharger Kit
  213. Omg Ahhhhhhhhhhhhhh!!!!!!!!!1111!!!!!
  214. I can't fly - 511.99
  215. Which RPS Clutch and Flywheel for 800+ RWHP?
  216. DYNO TIME from Kenne Bell Twin Screw
  217. Kenne Bell S/C ... are they better than Maggies?
  218. how much boost do you pick up from 3.85 to 3.65
  219. Any Downside to a Vortech ??
  220. Need help figuring out boost drop please!
  221. Alky injection ordered for my stock ATI kit.
  222. Tranny recommendations for an A-4 blower car??
  223. LOOKING FOR A USED A&A D1SC OR TT KIT
  224. OK....car is at the shop....now the wait....
  225. Where the hell do I get my bottle filled (SoCal)?
  226. 1.8 rockers for tt...
  227. Got the Dyno to my car today, 347ci F1C
  228. Nitrous Filters ?
  229. Clutch Install-How much $$
  230. Have you noticed an added heat load with your Maggie?
  231. Billet Aluminum NOS Bottle brackets (Cool)
  232. Stage 1 with a Switch ;)
  233. 02 c5 nx nitrous kit
  234. How much HP gain w/ 90mm LSX intake & TB on a Turbo setup?
  235. Some advice
  236. In car vid at the track. 11.91 @ 128
  237. WHennnn oh wheeen will a fuel system BE AVAILABLE UGH!!!!!!!!!!
  238. I/C maggie heat exchanger leaking
  239. Proprietary Tunes
  240. power on stock bottom
  241. Nitrous Pictures wanted?
  242. Unidentified Blueish/purpleish oil leak
  243. the waiting game
  244. ECS Resolves My TTix Problem
  245. Who here does their own work?
  246. Had a long talk with Kenne Bell today.
  247. Ati Procharger Oil Change Tips
  248. nitrous and compression
  249. D1 vs P1
  250. Round 2 ECS Alky kit in and Tuned
