View Full Version : C5 Forced Induction/Nitrous
  1. Early or Late production Torque Tube
  2. dynocom
  3. My Car sounds like
  4. IAT sensorocation
  5. Magnuson fuel injector sizing
  6. help me with STS turbo install
  7. 3:73, 3:90 0r 4:10 with turbos
  8. How many here have stock P1SC ???
  9. need your .02
  10. Tubo Blanket Where to find ?????
  11. THANKS ECS...... great product.
  12. Any FI bretheren going to the Woodward (Bennigans) event tonight?
  13. Limitations?
  14. Replacing the Heart of the Beast
  15. Fuel Pump Question 700rwhp+
  16. Charge system fault - PTK alternator
  17. Intercooler fans for the twin setup, come on in.
  18. Triple Gauges Install
  19. Bradenton Florida
  20. Vette Doctor Custom Rear Mounted Turbo Is Hitting The Track
  21. ECS Scattershield ???
  22. 90mm Maggie Question
  23. How much compression (ratio) is too much?
  24. Best place to buy SPA dual gauges (or other dual gauges)?
  25. Spark Plug Question...
  26. Which is better? Turbo vs. Supercharger
  27. Boost and fuel pressure guages?
  28. head and cam question
  29. Kenne Bell Boost a Pump to Racetronix wiring
  30. F/I Roadracers enter here.
  31. School me on the Alky and Meth
  32. MDMC L92 custom intake
  33. 42lbs injectors and blackwing for sale!
  34. Is this normal?!?!?
  35. MSD boost a pump - can ECM drive two relays
  36. Mesh Liscense Plate Cover for cooling
  37. what did i do to my car?
  38. Maggie Cars Need Your HELP!!!!
  39. video of my procharged vette
  40. Just to clarify my overheating issue with my TTi kit
  41. Anyone with rotrex?
  42. Bottle mounting with Subwoofers, Pics
  43. Accumulator mounting
  44. Beadblasting Pulleys
  45. 5 step process for nitrous (many pics)
  46. How do you???
  47. EFILive Speed Density
  48. Drive drain concerns with added torque
  49. Peak and Hold Injectors on a the GM ECU?
  50. Special motor oil required?
  51. Do I need a new radiator?
  52. Spinning @ 125
  53. High temps with my Maggie
  54. Snapping Shafts
  55. Nitrous pass in car video
  56. final drive ratio
  57. Magnuson 1/4th mile run times
  58. what have you guys done when your mainshaft breaks?
  59. Website Full Of Info
  60. Anyone Seen This?
  61. Any 370ci Turbo guys out there?
  62. Ran the N20 at the track
  63. First day out to the track with new combo-close but not close enough!
  64. FP & Boost Gauge Takeoff on a Maggie - Where?
  65. Wow
  66. Converting fuel system ???
  67. ProCharger Alignment Question
  68. Beer Panel expieriments
  69. nick's latest mod
  70. First impressions of the Textrailia twin disc
  71. anybody know about gm heads L 92 and were you can get intake
  72. What gauges and Pod do I need?
  73. heads/cam vs forced induction
  74. $795 F/I installs in New England
  75. Latest Rear Mount Turbo Insanity....
  76. Injectors...???
  77. Pics of my fuel pump setup
  78. What does 1000lbs of Torque look like on a Kenne Bell 402???? PICS INSIDE....
  79. Bracket for Procharger.. anyone make one?
  80. PTK alternator connector
  81. Kenne Bell install special
  82. Should I Supercharge my 1999 Heads/Cam A4 vert??
  83. What about using 105 octane E85?
  84. Jerry's Cartek A4 427 dyno numbers.
  85. new sts# with upgrades
  86. how much can a cam help my sts turbo(huge lag)
  87. Powder Coat Job
  88. ECS Paxton setup:751rwhp 687rwtq...Bitter Sweet Day
  89. progress pics of my vette (1st STC production twin turbo kit)
  90. Need a quick tip on stock fuel system
  91. Zex Good Or Evil
  92. Predictions on ATI D1SC HO kit
  93. Custom Painted N2O Bottles..
  94. Textrallia OZ700 .....Question!
  95. want to be in the 550-600 rwhp range
  96. ** Forced Induction And Clutches: The Solution **
  97. Bradenton Florida
  98. Bradenton Flosida
  99. Valve Covers
  100. ECS & STS = 9's
  101. Kenne Bell dyno video
  102. Ati procharged vette looking for more power
  103. Big Mouth Air Dam & FI
  104. A quick pic - APS C5 twin turbo system
  105. Ttx 402 Test Drive !!!!
  106. New FRC for my A&A Vortech
  107. Check out this 2001 speedway white Z06...
  108. Anyone had Nitrous install/Tune in SoCal?
  109. Is anyone else sick of the "find a good clutch" crusade
  110. Valve spring replacement
  111. decent air finally!
  112. Re: Clutch for Sale
  113. Procharger Fan Question
  114. Supercharger questions
  115. Whats a good fuel pump for forced indction ??
  116. Getting ready to get 317 (LQ9) heads. Recommendations?
  117. How many are running Patriot LQ9 heads for FI???
  118. How many have lifted port 6.0L heads?
  119. Car harder to start since relocating the MAF after intercooler?
  120. Bore size vs detonation
  121. HorsePower TV
  122. for those of you who though I was kidding...or thought I have lost my mind.
  123. K27 Compressor map
  124. It's TT time or should I say TTi
  125. Kenne Bell "Big Bore" 2.8L Supercharger
  126. procharged 03 zo6, belt issue
  127. Droped My Ride Off @ Esc On Sunday UPDATE
  128. Any one with Big Stuff 3 and C5 corvette automatic Transmission???
  129. Is this a good engine for SC/TT?
  130. Rwhp/boost?
  131. Thanks RPM Transmission
  132. can anyone send me the instructions to ECS's fuel system?
  133. What is the max. rwhp without loosing traction on stock rear tires (with a Centrif).)
  134. What is behind the front license plate?
  135. **INTRODUCING** CCW's NEWEST Wheel for the C5 (Dial-up Death)
  136. New Head Gaskets....
  137. 2002 gibson les paul custom shop ri 1958!!
  138. First Boost Run
  139. FFHP Closed and now I've had about all I can take!
  140. Tuners/Installers (near seattle)
  141. HP Potential of Nitrous Direct Pro Dry Kit?
  142. Belt Size
  143. Valentine One
  144. ATI Radiator Mod
  145. Go back to Steel Flywheel ?
  146. Engine difference in years 97-98 vs 99-04
  147. Looking for complete fuel system
  148. Help Fuel Pressure Fittings for fuel Gauge.
  149. Finally got to try out the direct port 200....
  150. A&A BBQ **Video**
  151. Calling all i/c maggy users!!! ????
  152. What is needed alongside a TT kit for a stock LS6?
  153. so who makes a guage pillar worthy of putting on a $50,000 car?
  154. Racetronics kit compatable with my Z16??
  155. I/C Maggie: economical forged/displacement increase?
  156. FFHP no more??
  157. power under the dash
  158. Test loading image on photobucket
  159. STS ok with my mods?
  160. 5V source for logging fuel pressure?
  161. Boost 101 ?
  162. Supercharger & Column lock recall
  163. UPS/STS C5 Custom Rear Mount Turbo Kit a Sure Thing!
  164. n2o system and progressive controller?
  165. C6 ZO6 Camshaft, Is it good for FI?
  166. Now this is a Vette Intake!!
  167. First time dealing with A & A Corvette
  168. Back from the dyno again... Vid and graph
  169. C5 & Z06 Magnacharger Summer Special - $6122 Installed Packages
  170. What is the most boost
  171. I Know
  172. Fastest stick record F/I IRS
  173. moving!
  174. Spark Plug Gap?
  175. Maggie vs Centrifugal
  176. Maximum boost for a stock LS1 / STS TT car
  177. Help
  178. Anyone with pics of HP turbo setup???
  179. SD or maf tuning?
  180. Pics of a project Zo6 FMIC
  181. FS: TTi Stage 3 Twin Turbo Kit
  182. Fuel pressure drops to 50psi @ WOT, but A/F is fine..
  183. Need Crank Pinning Kit by 8/05/06
  184. Major Problem With My Procharged Vette Need Help!!!
  185. Considering TT, few questions
  186. Belt For 10 Rib F1-c
  187. STS base turbos, let's see what psi we can really get...
  188. Boost/Vacuum Guage reading almost always in Vacuum?
  189. How can I reach 500 rwhp?
  190. Spal fans?
  191. TPS, TACH leads
  192. Any 03-04 C5's using APS fuel system?
  193. My newest mod...
  194. Procharger D1SC tune issues above 600 hp
  195. procharger pulley question
  196. Contact info Nick Williams
  197. Gauges: What Wire for Dimmer?
  198. Helppppppppppppp !!!
  199. Timing Turner
  200. Durabilty of 6A paddle shift with 700 Plus Hp?
  201. Does it pay?
  202. guys with magnusun superchargers on stock blocks..
  203. Question for those of you running an intercooled Magnuson
  204. ECS Fuel System Install
  205. 4 Sale Ti Z06 Ti Exhaust Greensboro NC
  206. 8 rib belt set ups help please were to buy
  207. Cherry on top?
  208. FI for Road Racing Question?
  209. Dyno
  210. BFG G-Force DR 315-18
  211. I have an opinion question on a new Supercharger install
  212. Can we say 800rwhp/800rwtq???? Out of a Kenne Bell S/C that is....
  213. gaugages
  214. 224/228 581/581 113 sound clip?
  215. Nate Carter of Chicago, please call me.....
  216. people with HP turbo kit...are you running hot?
  217. Pinning the ECS 8" overdrive crank pulley?
  218. Reasonable Price for Supercharger Install/Tune ???
  219. Big fuel setups poll
  220. Reichard Racing Pullies-are they worth it?
  221. Meth kit part information
  222. The Videos you've ALL been waiting for.. 750rwtq Kenne Bell SCREAMER
  223. Who is up for a Nick Williams 100mm Billet T/B??
  224. P01071/P01074... Am I truly running lean or is it a tuning issue?
  225. C6 UPS Twin Turbo / STS Update
  226. 402 Maggie Vs. 402 Twin Turbo Video
  227. what will maggie give me in RWHP????
  228. LS7 Crate engine prices .... predictions ?
  229. Just torques me
  230. Own a Z06 W/Magnacharger?
  231. p1@7psi doing 180+mph (( 300kmh ))
  232. LT4 hotcam with NO2
  233. Low Boost Dyno Numbers - Procharged LS7/C5R
  234. dyno insight
  235. Upgraded cam for 2001 Z06
  236. Best place for boost gauge?
  237. Chasing a Ford GT & Viper at Fontana Raceway!!! {Video}
  238. supercharging 101
  239. question about twin disk mcleod
  240. What is the pulley size on the crank?
  241. Daily driver and cams ?
  242. Real turbo experts (need some assembly advice)
  243. new cat back , sport motorbike rhythm ???
  244. Need Meth help, what mixture is ideal in the South
  245. I think (one of) my motor's dead... need mechanically inclined inside.
  246. LAPDs tuner Doug Stalter.
  247. LS6 intakes, best place 2 buy?
  248. Blower Cams
  249. A little bit of twin turbo action.....
  250. Who can loan me a ported LS2 TB????
