- Nitrous Install PICS WANTED for Z06 C5!!
- Wideband Interface control for the ECM
- Boosting a 441 C5R
- Back in the Saddle again , in my 9-second Cartek grocery getter ! !
- Anyone using a victor jr. intake manifold with an elbow?
- Oil pan is too oily
- Dry Nitrous after the MAF...
- Hidden Nitrous
- LGM Long tube & STS TT Not a good match!
- AZPS New Fuel Rail Fitting adapter for return style fuel system
- Pred/Nitrous
- gm high perf magazine
- Tranny rebuilds
- Who in the East/South installs Kenne-Bells?
- little P1SC
- Catch Can Hose Routing
- Supercharger question which to purchase
- What size belt for D1SC Procharger to see up to 14 lbs of boost on LS6 motor.
- TTI and LQ9 heads on an 02Z?
- FlashScan + LC1 = AutoVE... sweeeet
- What gauges for A&A Vortec?
- P1SC Guys How Much Boost on a 6 Rib
- going to smaller pully safe?
- ECS fuel pump install question
- Devils Own is a JOKE!!
- Maggie Owners, pls step in, need feedback!
- New Coil Relocation Kit - take a look
- Fuel up grade to run 150 nitrous????
- Broke your IRS? come in please
- New numbers 402 stroker motor
- Automatics and a Centri style blower-what kind of converter?
- Nitrous parts needed...
- Procharger Belt
- Another STS TT kit installed.
- Anybody want a nice stock LS6 motor to convert into forged f/i motor
- CODE help needed
- Procharger. Questions.
- Poll Does LB need the squeeze to be King?
- Best Oil for Turbos
- Puke Can a bit watery
- What HP/TQ Should a D1sc C5 dyno at?
- Need An Itroduction To Nitrous
- Procharger Question
- SEMA show 06
- Textralia Twin Disk Clutch -- First Impressions
- cats or not
- Thermal Efficiencies of Rear Mounted Turbos ??
- #001 2001 Z06's Dyno Results.....
- This will twist your brain!! (Please help??) :-)
- I Rule!!!
- Went road racing & clutch slipped in 4th gear, is it going?
- Supercharger belt life/cost
- Forged motor and Stock Heads
- Turbo Kits For C5 z06??
- Dish pistons on boost (help me understand)
- How do you pin point a pulley bearing squeak?
- STS boost threshold...
- What size pulley do I need
- Just Ordered an RPM Transmission!!
- Broken oil ring question.
- 4500ft elevation=less power/ less driveline breakage
- Any 3 gauge A pillar pics?
- who has won the corvette world cup?
- Smell burnt oil but only under WOT...
- On hold with A&A...country music
- Hot Lap Mounting
- Easy way to tell if an '03 has the NEWER style fuel system?
- boost gauge install
- Nos Intallation In Las Vegas?
- Airbridge for STS kit?
- Hardcore Crazies : EVAP removal Inside
- 15lb NOS tank, trade for 10lb
- Callaway Sway Bars
- Is it common for the Slave cylinder on our clutches to fail?
- 4.10 pulley on a D1SC
- SMOKE!!! Catch Can or bigger problem?
- Upgrade to a 8 rib from a 6 rib? Advice pls
- Turbo And Gears?!!?
- What are you guys doing as far as suspension mods for drag racing?
- Hit 143mph in the 1/4 on DR's and 778rwhp spinning the tires off the dyno!
- bought a zex kit off an '01 cobra...
- Store wide sale ends on Thursday!
- No oil pressure - who knows what is up?
- New ECS STS TT setup shakedown
- My first 10 sec passes
- New directport for Kumar's Vette.
- Rear knock sensor
- CORVETTES of WESTCHESTER - COLUMN LOCK MOD PARTY - SUN OCT 22 (today)
- Maggie w/402
- Awwwwwwwwww yeah!
- 410 gear??
- Which autometer gauges should I buy???
- N2O line
- procharger stage 2 dyno #
- Upper Vents In Center of Dash -- Why has someone not made a plate yet?
- Selling my LPE Stage 2 TT
- Where to mount gauges
- Who needs methanol and VP Fuel C16?
- Pleated paper air filters-source?
- Electronic Boost Gauge Power Source???
- Check Out Corvette Central’s New C5 Catalog
- ? For best price on Vortec kit Thanks.
- Kenne Bell
- Is the Vortech bracket assembly available from A&A?
- Ceramic Coating vs Exhaust wrap
- C6 ZO6 Tranny: Is it Same Ratio as MN6
- were is nick steffens?
- turbo failure solved!
- Should I change my camshaft?
- the twins have arrived!!!!
- Dry nozzle location
- What cam are the maggie guys running?
- outdated weekend mechanic
- Video STS TT
- C6 Pete/ Autoworx 1002 Rwhp 2nd Pull!!!
- Reichard pulley
- How difficult to remove Maggie
- Changing TB with s/c
- Anyone have a nitrous plate laying around FS?
- New Project 408 and GT 42 76 Turbo Rear Mount
- Methonal purchase ???
- F/I and C5's in retrospect!!!
- What kind of "HP" needed to run 9's
- Thanks OCC for helping me get to 195 MPH!!!
- A&A vortech c-5z
- HP and busted drivetrains
- ***ENOUGH!!*** please read
- What is the best turbo for all out power??
- Fuel Pressure still dropping HELP PLEASE.
- What TT setup is this?
- Corvette Wheelie....(Title changed)
- Maggie belt chirp when shifting w/ A4
- Narrow cog belts and blowers- how do they work?
- Who's got the best price on the TTiX kit??
- crankcase presure venting ?
- Need single turbo pic
- Vortech Dyno Numbers
- How much do your F/I monster weigh?
- APS twin intercooled twin turbo system - MSRP
- McMaster Carr Check Valve... 0.3 psi crack pressure???
- Spagetti 4 Two :)
- tried a couple of 1/4 mile passes at bg with no luck.
- Need a Setrab oil cooler this week
- What does it take to hit the 200mph mark
- Questions about anti pump-up lifters
- Dual Fan Advice ...
- KB BAP Users I have a Question
- Magnacharger coil covers?
- Pics of where your bottles are. NOS
- Maybe a Dumb Question
- My clutch, did I make a bad choice?
- May have blown clutch today...
- Opinions Wanted
- Next driveline setup...
- H/C,N/A going to F/I?
- 3 pod guage pillar
- 2002 Z06 or 2004 Z16 for my FI Road Racer?
- belt blown
- Nitrous solenoid question
- Killed the Procharger whistle!
- Big Dry Hit's great. "Ultimate PRO Dry" Times/Dyno
- Dimensions - Sources for Vortech restrictor plates - need info
- Nitrous Cheating?
- Which piston? Pick one
- 8 Rib belt question
- OH NO, funny noise under the hood, need some advice/moral support...
- Maggie vs Kenne Bell
- Multiple forced induction questions
- 03 Autometer Pod Pillar Install Help
- How much is too much for my auto?
- A different kind of alky injection (or nitrous)
- Torco and MY Arizona test...
- Column Lock DISASTER AVOIDED!!! A close Call...
- Do I need a new fuel pump?
- 2006 C5/c6 World Cup To.prediction !!!!!
- plugs
- New "secret" blower cam....
- Approaching the goal line
- Question for my fellow F/I brothers...
- American HP SIGN FUNDS
- Nitrous Express Price Increase!
- TNT nitrous kits Vs. Cold fusion kits???
- stock block nitrous setups
- APS C5 intercooled twin turbo dyno graphs at 7.6 PSI
- Another quick oil cooler thought...
- Blower Cam
- 427 w/ TNT 150 wet shot
- I have a MSD 2 bar MAP sensor but..
- American Hp Neon Sign
- MAF Table question P01514
- 347 or 402 ?
- NLP Billet PCV Catch Can, $74.95
- Twin Turbo LS1 in a BMW.....?.... Pic inside...
- Sell me your stock procharger bracket
- Sts 1/4 Times Who The Fastest...
- Catalytics and FI-they don't mix well!
- Will it work?
- shaking down the tt 402 at the track
- It's the "Hi Mark" thread (mdhmi)
- Nitrous
- stock pump, no boosters, and still returnless
- turbo cam SPECS - OPINIONS.
- RPM Transmissions is closing the doors
- Anyone here using Lucas Synthetic oil??
- First post...First z06...First supercharger ??
- How is bOOst changed in the Paxton ECS kit?
- wet 100 shot + modded Z06 = tuning necessary?
- A&A setup cutting the 6th rib off the belt
- is there much of a market for a used forged 346
- Trade 15lb NOS bottle for a 10lb
- How strong is a stock IRS?
- Geoff Skorupa Per Tech Center
- Mdhmi Fingers Broken????
- a and a vortech kit? plz step inside. ques.
- How are these Sts systems holding up
- 1st gen P-1 belt slip issues/bracket opions?
- anyone go to Byron IL for fastest street car shoot out and wheel stander contest???
- How much to have exhaust heat wrapped? STS
- need help: tnt wide open throttle sw. instruction
- Deburring a new block???
- So many oil cooler options, which ones work?
- What kind of shot of nitrous?
- Dyno numbers on new setup
- Narrowed down the choices...asking final advice
- Digital or analog gauges?
- Procharger 1/4 times
- How many miles are too many for a Magnuson?
- Hit every goal I had this year: 9’s baby!!!!!!!!!!!!
- Procharger.
- Anyone running bigger injectors on a Maggie
- 2002 Z06 supercharged or not?
- Ripped 2 Teeth out of my Ring & Pinion at Buttonwillow... {VIDEO}
- Getting closer...
- A & A Helps Again
- Your 700---800rwhp Vette Is Slow
- what kind of spark plugs for f/inductions?
- How long have you been F.I. before you had problems?
- BAP insatll
- d1sc overheating roaad race/meth inj?
- Fuel System Question
- what does sandbagging meen
- PLEASE give me your input and thoughts on my vette
- kENNE BELL VS MAGGIE
- lets talk slushboxes and TT
- Catch can install behind Procharger
- Post your quick ET for S/C and stock bottom end
- D1SC Pulley ??
- engine is out of the car, will it help TTIX install
- Whats Better
