View Full Version : C5 Forced Induction/Nitrous
  1. LSX: how many of you buying?
  2. replace both output shafts?
  3. Cam and Meth results on P1 C5
  4. Pictures of 0Z Twin Disk
  5. corvette race in feb, date, place, info??
  6. Highest IAT's on a I/C Maggie?
  7. 'roadrebel' turbo cam?
  8. ProCharger Stage II installed/tuned/dyno'd $6995
  9. STS Exhaust
  10. Dyno Tune vs Street Tune
  11. STS and ECS
  12. 402/408 With n20 what ya running
  13. STS owners with gt32 upgrade please enlighten me
  14. I heard that cartek is building a low 9second p1 blower vert
  15. Tex Twin or McLeod Twin
  16. how safe am i pro charger on my high mileage vette
  17. Help with diagnosis?
  18. First Time Caller, Long Time Listener - N20 Question
  19. (Upgraded STS Turbo Kit for Sale)
  20. What Sled28 does over the holidays!
  21. SuperChargers CFM
  22. Expert Opinion 80mm TB
  23. Fuel System Idea/Quuestion
  24. Kenne Bell Install Are We Having Fun Yet.......
  25. 1st of the year Torco Sale!! Videopromo...
  26. PINKS! at MIR June 9th
  27. PINKS...me vrs earl
  28. Thumbs up to Doug at ECS!
  29. *NEW* ExileTurbo.com Boost Controller
  30. Anyone looking for a F1R?
  31. New supercharger, now warming up active handling?
  32. how to drag ?
  33. APS TT Prep - help me remove my LG headers
  34. 600 RWHP, help me get there
  35. How much power can the 6 rib pulley setup hold?
  36. I guess it's my turn for one of these threads
  37. Which sway bars?
  38. What's the latest on clutches?
  39. Procharged turbo ? Need technical input.
  40. Got Switches?
  41. Going Kenne Bell!!!
  42. Who has the best selection of 8 rib belts?
  43. 850hp Twin Turbo Z06 Idle Video
  44. Straightline Performance Blower Pricing
  45. Is a 90mm Fast intake and TB really needed on a SC engine?
  46. Interesting injector constants
  47. Anyone ever used the Callies Superlight Magnum XL crank
  48. 918's enough with 'turbo' cam?
  49. People using the Bosch 420 intank pump-please step inside.
  50. With F/I what are you giving up going from M6 to A4?
  51. I have a couple NOS questions.
  52. Torco GP
  53. 9/16 head studs
  54. which one to drive...UNBELIEVABLE!
  55. T-Trim OR D1SC Help me
  56. Selling A&A Vortech T-Trim kit
  57. TTI X : Let the fun begin
  58. Maggie question?
  59. Intercooler shrouding
  60. Forged Bottom End, please help
  61. TT exhaust
  62. Hardcore: Max RPM of Paxton Novi 2000
  63. Piston Rings...Zero Gap?
  64. APS which kit?
  65. PeterPan
  66. Coating exhaust manifolds for TT?
  67. Research Project of Dyno sheets and performance
  68. Finished up my new heads..
  69. Need source for SC 4" thin flexible black tubing
  70. ** Official FI Owners Club **
  71. alternator bracket
  72. Great Telemarketing
  73. Repsol
  74. Need help picking what turbo?
  75. faster reacting IAT
  76. a couple questions
  77. NOT Happy Again - low compression on several cylinders
  78. To All MY FI Brothers
  79. (poll) Maggie and A4
  80. I/C Maggie and HPDE
  81. This might get me in trouble
  82. NOS questions Wet kit
  83. Whtas New for GM Now!
  84. complete solid mount
  85. Flat-top vs Dished piston for Blower vs Turbo?
  86. Why is my car so damn quiet!
  87. Saddam
  88. TTi Kit Special......
  89. Thanks to eb02z06
  90. Cam Help having problem chosing 8lbs ATI
  91. Someone Educate Me on the Vette M6/M12 please
  92. Single Pillar Pod
  93. Gauge mounting, other than pillar?
  94. Zex Nitrous system hook-up help
  95. Who's spraying their boosted car??
  96. Anyone using this plate system?
  97. Tremec TR6060
  98. Triple Pillar Pod from RPMOutlet........
  99. Who has the highest HP TRUE daily driver?
  100. TTi-X Ordered...
  101. Its In!! Its In !!!!! My New Turbos!!!!!!!!!
  102. Question on PTS kit
  103. BAP install... cut coax and bypass potentiometer?
  104. We're Now Taking Orders For the MP122 Kits!
  105. Good wideband O2 info
  106. Thinking About New Cam, ECS 8" Crank Pulley... Thoughts??
  107. Yank TH400 conversion question
  108. Peter Pan
  109. V2-sq t-trim super charger
  110. Traders Ratings
  111. How much ya bench????
  112. !!!! VetteDoctors/ AmericanRacing Headers!!!! 1 more day left
  113. Write up on the "history" of manifold style superchargers. Interesting read.
  114. Re: Electric vacuum pump....ok...help me out here people->
  115. Just Came Back From The Vette Doctors......Woohoo!!!
  116. Low Bottle Pressure........
  117. Clutch and Trow out bearing C5 FI
  118. How much would CR play.....
  119. Weak Link...Should I worry
  120. DTE Stage V Differential
  121. sealer on Fuel Injector o-rings
  122. Escrow.com
  123. Why is there a filter where the oil cap is
  124. Who has the highest dyno'ing SC'd 346ci??
  125. vortech install needed near montreal
  126. How can I make my suspension work?
  127. Track Time (Peter Pan)
  128. 365 CID, MP122H project almost done...
  129. What are the BIG power FI guys driving daily? Or does your commuter trap 135+?
  130. t-5 Jet Technology Supercharger
  131. Wolfe Racecraft Rollbars?
  132. Thoughts on VCN 100 and 2000?
  133. Does anyone have any Zex nitrous jets?
  134. What do you think of putting emblems on the side of your car?
  135. Intakes, LS1, LS2, LS6, Fast
  136. Maggie Rumors
  137. ET peformance Krank Vents
  138. anyone looking for a direct port kit?
  139. Check Valve Location?
  140. I got a ride in Andy's car, A&A
  141. Boost-a-pump
  142. First Impressions of Fpadt Coilovers...
  143. loudest blow off valve for supercharger ?
  144. Pulley Chirp Noise Coming from Supercharger Area
  145. Exhaust sound level after adding a big motor??
  146. Prepping for APS TT Kit
  147. the demon has been exorcised
  148. MERRY CHRISTMAS to everyone!!!!!!
  149. vaccum pump, modded pcv?
  150. Merry Chritmas F/i & C/f Memeber's !!!
  151. Need a little help
  152. Mototron 60lb IFR
  153. ZO6 Heads/Cam
  154. Maggie LPE coil covers question
  155. Mid-Hudson Valley Supporting Tuner
  156. Gears and FI
  157. Reduced Power Mode with supercharger
  158. Magnacharger Heat Exchanger & Fan
  159. 1000rwhp combinations - SC / Turbo / Intake / Exhaust
  160. Kenne Bell / Hood
  161. Dipstick blowing out
  162. Put up or shut up!!! Who?
  163. What would be the optimal F/I setup for 40 to 160mph sprint??
  164. Boosta Pump..............
  165. Elite Engineering Catch Can - A Macro View [Pictures]
  166. Looking to blow some of my year end bonus...
  167. Fuel system question...........
  168. RPM Tranny Conversion Eye Candy!!!!!!
  169. What do you think guys??
  170. Pickin Her Up...
  171. What to do, ECS, A&A, KB, Maggie.....
  172. Trans check valve question..............
  173. I Finally Got My Car Back! And It’s Supercharged!
  174. Best place to pick up NT01s
  175. Question for guys with auto conversion
  176. Gates Alignment tool
  177. What exhaust system to support 1000 rwhp?
  178. Flying Corvette
  179. Speed
  180. SW's Rides
  181. Winter upgrade
  182. TBYRNE Motorsports Year End Nitrous Sale!
  183. what injectors for TT
  184. Can We Run Boost By Gear...
  185. **ECS Paxton kit Special $7,995 installed and tuned **
  186. throttle body switch/traction control
  187. Textralia twin disk clutch update
  188. Pound for Pound RWHP #'s via SC vs Turbo..
  189. Peter Pan's Future Bling
  190. Vette Doctors C6 ATI Rx Supercharged 2006 Special. $7595!!
  191. C5 Wide Body
  192. APS Complete or APS Lite ?
  193. Is the tunnel plate a worth while mod?
  194. 2000 C5 Supercharger Installation
  195. How much will the nitrous help?
  196. 2 days only $500 off !
  197. For naysayers of KB
  198. Good LSX block video..........
  199. C6 Convertible
  200. Garage
  201. Logo
  202. Happy Hollidays
  203. gotjuiced?
  204. How is the Kenne Bell performing on the Vette?
  205. Best for the street: Kenne Bell, TT or Centrifugal
  206. fuel system options
  207. TTI turbo kit people, need help LPE turbo cars as well
  208. Need wideband adaptor for Autometer A/F Guages?
  209. A few nitrous questions from the new guy
  210. Turbo Guys- Electronic Boost Controller or Manual?
  211. to the guys with 550rwhp or over .........
  212. difference in SAE and Std
  213. Madness Monster Motor build started
  214. It's set in stone!!!
  215. Any big cube TT guys...
  216. Happy Birthday to Mikes99Corvette
  217. What Is On Your 2007 Wish List For New products??
  218. Can you port a magnacharger?
  219. Maggie 90mm up-grade, question!
  220. Weiand vs. LS6 Intake Manifold?
  221. Tnt Ring Kit
  222. GTA GUYS...Was the party for Fast Eddy this past weekend??
  223. To Much Gear For Blower
  224. Yahoo
  225. Boosting a stock LS2?
  226. how much boost can I run?
  227. How good are FI Intakes?
  228. Nitrous Injector Plates?
  229. Peter Pans Bling
  230. Cam for twin turbo?
  231. 03 D1SC Z06, against a Lambo Gallardo
  232. TTIX Exhaust
  233. Christmas Present...........
  234. 7 Second Viper 6spd Video
  235. If you had the choice??(nitrous or blower?)poll
  236. Fuel pressure--How much???
  237. Forged Shortblock Is Coming Together
  238. Magnuson Superchargers - Year End Special!
  239. So who here wants to see some Canadian Smack talkers put up or SHUTUP!!!FEB 24TH!!!
  240. Just back from PRI - some new stuff that I saw...
  241. I have a real noob question
  242. LG Headers
  243. Anyone used A4 radiator cooler as oil cooler on FI car?
  244. What kit can trap 150mph plus in the 1/4th!!
  245. maggie belt question
  246. XMas FI Wish List (F1c, TTIx, APS) help please..
  247. Anyone use a MTi X1 cam in a D1SC car?
  248. New Coil Relocation Kit + Bling
  249. trying to decide which kit is best for my 00
  250. STS Turbo Boost Controller
