View Full Version : C5 Forced Induction/Nitrous
  1. Some Wallpaper for the F/I lover in you.
  2. APS C5 fuel system
  3. Hooked up my wideband lc1, reading is 15.0??
  4. Add to fuel system?
  5. [Video] My buildup and first trip to track w/ TT Z06
  6. Great experience: superchargerrebuilds.com
  7. tube coating
  8. does High boost creat heat the same in turbo and supercharger?
  9. is there a cam thats good for turbo and supercharger?
  10. Stupid Q....Any run a TINY shot of NOS in an FI setup?
  11. Best nitrous kit for a C-5 running at least a 100-150 shot....
  12. how do i sup up my vette?
  13. STS GRIZ hits the streets
  14. JBSBLOWNC5 Bites the dust... {Video}
  15. Single Gauge Pod for 03
  16. LS1 TT Wagon
  17. Did CCW revise their drag package?
  18. Lowered C5
  19. *** ECS Paxton Supercharger - $7695 installed and tuned *** (Florida and SouthEast)
  20. Vortech install questions - sorry for length...
  21. Transmission 4th gear question
  22. Low Boost reading on Positive displacement?
  23. Kenne Bell?
  24. What's the "sweet" spot for a NOVI-2000?
  25. Vendors and Tuners in FI community - why they are just great
  26. What is the downside of going with an SC
  27. RPM and TPS connection for Wideband
  28. mikes99corvette
  29. First STS C5 in Germany...
  30. How much does/will alky injection help on hot days at the track?
  31. 402, 408 advice?
  32. Kenne Bell owners... step in
  33. Smaller Pulley/New Tune=Dyno Sheet
  34. Halltech Ram Air Tunnel Ports
  35. TT kit question
  36. my atco rental...
  37. Could really use some help from the pros, hooking up my dynotune window switch?
  38. Driveline upgrade advise for street and drags
  39. Royal Purple oil............
  40. Need A Little Help Down South
  41. CALLING UPSTATE NY.. (Rochester Area)
  42. Drive car home w/stock fuel system?
  43. I want one of these.........
  44. Fuel Pressure Resolved
  45. Maggie belt problem again!
  46. Twin Turbo's were are the 02 sensors?
  47. ECS fuel kit install instructions
  48. melted plugs
  49. Well the numbers are finally in!!
  50. Crappy Times...doesn't correlate with power?????
  51. Lopey Idle at Cruise
  52. Pulley question on a maggie
  53. Boost controller for supercharger
  54. does anyone know how much aps twin turbo for c5...
  55. 8 Rib Belt Setup Question.
  56. Crank Pulley and Front Seal Change Questions
  57. Need help with turbo setup
  58. Vortech BV57 Bypass Valve ?
  59. Need help deciding....
  60. C5 Turbo Exhaust advice...
  61. Interesting Fuel system item... would it be of any use?
  62. Rodney and RPM Trans Awesome
  63. Bigger throttle body on maggie?
  64. How Many Miles to Expect On a FI Motor?
  65. Textralia clutch question
  66. what engine should I get for my A&A kit?
  67. with a FI after the car is turned off does
  68. Will i need a tune when i hook up my wet nitrous kit??
  69. Durability of hollow stem valves
  70. SD Tuning started
  71. What do i need on a magnuson to make over 500rwhp on a 346?
  72. Help!...car Runs Horrible
  73. well its in, rpm trans brake
  74. FI Hoods
  75. SC question
  76. Second time at the track in my Procharged Z06!
  77. Let's Talk about blower cams.....long!
  78. p1 swap to F1
  79. Rear mount alky tanks? Let's see 'em
  80. Squeaky sound after supercharger install
  81. TTi tune up nets 564/512, dyno vid
  82. TR6 Plug Gap
  83. 5/25 Norwalk Track Rental: Hotel Info
  84. Fuel Delivery
  85. O2 Sensor codes
  86. Paging Road Rebel
  87. 03 Z06 supercharged questions from C4 owner
  88. Head Selection
  89. Boost gauge pods
  90. You think you have enough ?
  91. Custom twin turbo system we're working on
  92. looking at 03 z06 w/ vortec
  93. brand of gas you run in your FI?
  94. Relationship between temperature and fuel pressure.
  95. Dumb question of the day
  96. Fuel System Help!
  97. Callaways
  98. Any HP Advantage to Upgrade MAF with FI
  99. Uh oh, I took the battery out, now the radio says LOC
  100. sd tune
  101. Anyone running the inovative LC-1 Wideband Air/Fuel Ratio Gauge
  102. Blitz Boost Controller Users -- Step In
  103. Always looking for a better way to cool forced induction
  104. Used S/C's
  105. D-1SC Procharger Question
  106. Spec 3 clutch!
  107. NEW PRODUCT- MAF "scattershield"
  108. ATI belt size????help please
  109. Bugatti Veyron like you've never seen before...
  110. Hooking up my air fuel raito guage?
  111. Do you need the little side air dams? (outside little spoilers)?
  112. 84 LS1 vette... need assistance on superchargers
  113. zo6 manifolds vs ls1 for STS
  114. Check Out My First Video of My Z
  115. Fuel pump question
  116. Are Ford 30lbs injectors plug and play for us?
  117. Building up my tranny
  118. 550 hp Vette
  119. who makes a roll bar
  120. Great News on Andrew!! ! (9yr. Old in a Coma)
  121. What makes sense while changing water pump?
  122. hidden dry set up
  123. Great Video
  124. any APS results yet?
  125. Drove the new setup on the street
  126. Paging Slowhawk...
  127. Tuner in Northwest Florida/South Alabama
  128. Nitrous Guage Adapter ??
  129. meth/alky kit.
  130. TUne 2 bar or 1 bar
  131. Any FI guys need injectors? 60# Mototrons FS
  132. Blower cams
  133. Vortech Vs Novi2000
  134. Thank you Orange County Corvette! Got my car back!
  135. New "RPM" Wearables!!!!
  136. Drag wheels on a budget
  137. Took the Z06 to the track for the very first time!
  138. Mezeire Water Pumps worth it?
  139. Tracking my Kenne Bell on the 16th
  140. Bully dog turbos
  141. D1 Stage 2 on a Z06 - Catchcan location(s)?
  142. How much RW horse power will i get with a 100 shot?
  143. C3 Iron L76 Turbocharged cam question
  144. Oh Yea Twins!
  145. STS turbo kit questions
  146. What type of converter for F/I ???
  147. [Pic/Vid] Latest dyno results
  148. Need solution to A&A SC air intake tube crumpling
  149. Forging my LS6 bottom end. Need advice.
  150. Rev Limiter on Stock LS1/LS6 Bottom End
  151. Fuel system redux
  152. Nitrous on stock motor
  153. Direct port on a LS6 manifold
  154. Your LS6 Heads wanted!!
  155. s/c installed...now a/c shuts off, won't stay on
  156. Highest rwhp/rwtq on Stock LS1 or LS6 Bottom End
  157. What Is Diameter Of Factory Crank Pulley ?
  158. Fuel pressure ?
  159. Preliminary Pics of my 402
  160. Bought My Car, Picked My FI
  161. Need a SC bracket!!
  162. F2 procharger on C5
  163. hey heath jackson...
  164. Any F/i Guys Braking Mass Air Meters
  165. Need some Mototron injector info
  166. Best 42lb injectors
  167. Loose cam bolts - shoud I swap to blower cam?
  168. What's the biggest TB can I run on a maggie?
  169. Another custom gauge mounting option
  170. Dont know what to do... help... Bottle mounting pictures in a coupe would help alot.
  171. Supercharger install done!! Thanks FLP and A&A!!
  172. What does it take to beat a new Gixxer 1000?
  173. 9 Yr. Old Needs Help
  174. can 26lb injectors handle a 150 dry shot
  175. ECS kit 4 sale
  176. Dyno Pictures
  177. Announcement: EG teams up with East Coast Supercharging !!!
  178. looking for a window switch for my nitrous set up? please help fast
  179. Novi install questions
  180. ATI Vs. A&A Brackets
  181. Having a Senior Moment
  182. Where to hook up the blow down tube in my 98 c5 coupe?
  183. NOS small bottle kits
  184. Take one part 06 TBSS and one part 2.8 Kenne Bell and....
  185. Carolina Auto Masters
  186. Supercharger Belt Issues and Misc Ramblings...
  187. Chris @ East Coast Supercharging
  188. Magnuson Supercharger W/ FREE RK Sport Hood!
  189. My first time at Spring Mountain Roadcourse!!(Video)
  190. RPM 4L60 and a Trans Break
  191. [vid] Finally!!! Halltech TT results
  192. Nozzle Position on Trap Intake?
  193. Wet or Dry kit for my 98 6 speed c5?
  194. procharger and other goodies
  195. Hardened axle source?
  196. Hey Auto FI guys-where are you mounting your tranny cooler?
  197. motor oil for vortech setup
  198. ?? high power f/i, for cheap (ish)??
  199. TTi Turbo Kit
  200. Nitrous Explosions
  201. Maggie questions - issues - whatever you call it!
  202. Are C5 rear calipers the same as 98up Fbod rear calip?
  203. HELP! I bought 3 guages, now they tell me there's no triple pods!
  204. Vortech ysi/power cooler questions- anyone run this combo? Is it too small?
  205. Dyno Time
  206. LS1/6 to LS2 Conversion CAM SENSOR wiring needed
  207. Need dimensional help with ECS Novi 2000 kit
  208. IF im swapping out my catback to i need to retune?
  209. PSC1 and Air Filter?
  210. Boost and Belt
  211. Optimal Vacuum at Idle and Cruise???
  212. Oil in Procharger Hose
  213. Forged longblock
  214. Deleted
  215. Our fully installed C5 ATI ProCharger D-1SC price
  216. Boost gage/controller questions
  217. Ok guys please help me out with a descision
  218. Cam only 04 Z with 150 shot?
  219. e-bay twin turbo update
  220. Exhaust for TT? Best?
  221. how can you tell if your blowoff valve is working right
  222. Big HP FI guys, what tires do you run on the street?
  223. L92 Standard Bore heads.............
  224. Fuel rail fitting size?
  225. Exhaust Turbo housings FS
  226. Is this...Reliable or not ???
  227. Can i run a wet nitrous kit with my vararam.
  228. v2 s-trim head unit
  229. Video Z06
  230. e-bay twin turbo
  231. A few pics
  232. Mike Norris Motorsports Complete DynoTune $350 NA - $400 FI
  233. Torco anyone....................
  234. RoadRebel..this is 4 you.
  235. ATCO Noob questions?
  236. Max psi on the P1SC is?
  237. Interesting Hypothetical: Traditional Front Mount Twin AND Rear Mount
  238. Best CAI for Dry Shot?
  239. Damage to LPE TT noted when taking delivery
  240. APS TWIN TURBO install PICS
  241. First runs with my 427 STS kit
  242. Broken Idler bracket (twice in one day) with F1-A
  243. So Close to 9.6 with ECS Paxton
  244. New 2007 ATI ProCharger application guide!
  245. Corvette Challenge
  246. Congrats Stealth C5, on cover GM H. Perf Magazine & great article!
  247. Meth Injection
  248. Really need HIGH HP PARTS <List in description!>
  249. This Sucks!!! My car only likes 100 Wet shot.
  250. ☺ ☺ New Release - L92 Medium Geometry Cylinder Heads ☺ ☺
