View Full Version : C5 Forced Induction/Nitrous
  1. HELP! Need Boost-A-Pump install instructions
  2. never seen this one before.
  3. **FOR SALE** single turbo kit and frontmount intercooler
  4. What supercharger or turbo produces the most hp on a 346?
  5. What Supercharger Or Turbo Makes The Most Hp On A 346?
  6. Gas mileage question.............
  7. Monster Z06
  8. Slipping Clutch - from what?
  9. prior military aerospace vehicle crew chief? step in
  10. Swaintech coated turbo headers ..lets see them
  11. textralia
  12. Post up videos of the Novi 2000 set up!!!
  13. Meth injection, run b4 or after the MAF, what about the IAT?
  14. Andy @ A&A MADE MY DAY !
  15. I have a problem, Input from ALL PLEASE
  16. Is it worth removing the stock cats for straight pipes?
  17. Keep cool in Florida?
  18. BIG HP cars what clutch do you run?
  19. How much can be on engine when putting it back in from the top?
  20. ATI Superdamper and A&A Kit compatibility Ruined my day...
  21. Thanks Excelsior Motorsports in San Diego. New upgraded tranny and TQ works fine..!
  22. knock off ptk
  23. Help, please keep an eye out
  24. best blower for the price? what is it?
  25. Dr. Phil Auto complete
  26. Rear tire selection for high HP
  27. First, a few questions...
  28. CCW Drag Pack - what is it?
  29. Help me solve my clutch hydraulics issue
  30. OMG...i cannot believe i just bought this!
  31. Looking for an ATI pinning kit
  32. The Big Yella Chronicles- Bulletprooofing the driveline
  33. questions on window sw. high limit
  34. Looking to win some money
  35. Different BOV for ECS D1SC ????
  36. Grond..... Is ALIVE !!!!!
  37. procharger stage II dynoed
  38. New to nitrous..everthings hooked up.. whats a good run through process
  39. Dumbest question of the year
  40. Joined the 10sec club @ 135mph
  41. Crank pinning kit instructions
  42. 3/31 Corvette Challenge results
  43. Our heart go out to Eric Medlen
  44. i hate these!
  45. Wanted ECS Novi Procharger
  46. Dirty A&A filter...
  47. need more fuel presure
  48. Dumb Mistake on My Part, What Did I Hurt?
  49. Turbo and Supercharger ?
  50. Turbo ?'s
  51. Street Warriors (San Antonio)
  52. ATI Super Damper Question
  53. Racetronix + BAP + Meth
  54. I promise that I'll post in this forum next time.
  55. Lpe C-5
  56. How would i configure ECS alky kit to work on a big cubed Stroker LS2?
  57. Racetronics Pump and hot wiring kit complete
  58. Best cam for stock LS1 block with good lope at idle
  59. 10 sec Rearmount Turbo C5 Pics, Videos, Results
  60. Turbo 408 finally close to done!
  61. Should I attempt to build a forged engine myself
  62. Stand alone fuel system problem.PLEASE HELP !!!
  63. Alittle FI drag racing eye candy
  64. 2003 non-FFS Z06 fuel schematic/drawing?
  65. Horsepower Issue!
  66. z06 transmission problems... advice/input needed.
  67. Kumho MX or Goodyear GS-D3’s
  68. How easy to remove crank pulley once it is pinned?
  69. Help. Procharger problem solving.
  70. MTI Racing...Thanks!
  71. Norwalk Hotel Information - Amerihost
  72. APS or TTI X?
  73. Coming to MTI's Defence
  74. Two Inline Fuel Pumps
  75. what level of boost requires SD tuning for Twin turbos set ups?
  76. CARTEK Line-Locks Now Available @ ICS Performance ***
  77. Do LS7 heads require special long tubes
  78. are there any good shops in Las Vegas with a Dyno
  79. MAF fault code
  80. Show your fire suppression systems
  81. Gonna be looking for used A&A or ECS s/c kit soon
  82. Zero to 60 time from 60' Time
  83. Torque Value for Fuel Pump to tank Bolts?
  84. stage 5 transmission FS
  85. Multiple boost setting question...
  86. Hey guys, where are you getting your Torco from?
  87. Prepping car for FI
  88. Meth.
  89. Might consider trading complete ECS D1SC on stock LS6 for N/A Superstroker LS motor!
  90. Opinions: What would be quicker?
  91. Pulley swap/dyno tune?
  92. Goin to Vegas with the dyno...
  93. Kenne Belll owners....please come in...
  94. WTB: used A&A or ECS supercharger
  95. It started with a simple header leak...
  96. APS install problem
  97. Help! Chris@ ECS i'm dying
  98. ECS meth controller, wideband, liinelock Ashtray Panel
  99. My Car is almost done
  100. 3500 dollar Twin turbo kit. (new)
  101. Belt Issue, please chime in!
  102. TNT Force 2 Nitrous system experience anyone?
  103. is there a 10 rib pulley set?
  104. 346 or 402 will have more belt problems
  105. ECS Fuel System
  106. Twins added and now very high Oil Pressure
  107. If you have blown up your stock internal motor, how did it happen?
  108. Paxton Restrictor Plate
  109. Fuel solinoid is releasing small amounts of fuel with the nitrous off???
  110. Help help, fuel solinoid is releasing small amount of fuel into fogger with nos off.
  111. FP gauge install
  112. FI Newb Confused
  113. TT/SC competition
  114. Need pics of direct port nitrous setups.
  115. Magnuson Superchargers @ TBYRNE Motorsports!
  116. Dropped the car off with EG!!!
  117. Houston tune special at HPE
  118. 427 auto zo6 meets vinnys 402 novi ...
  119. !!Cylinder Head P0rn!!
  120. ported ls6 heads for sts car
  121. Hot weather
  122. Twin Turbo setup questions
  123. Safeguarding my car for a procharger kit
  124. LQ9 heads worth the trouble for a Maggie
  125. MAF flange size for air filter?
  126. First time at the strip with drag radials
  127. White Lightning Coating
  128. So I have the dreaded P0343 CMP Sensor Circuit High Voltage
  129. Redynoed...
  130. How to test my nitrous system with a window switch setup, will my solinoids turn on?
  131. IS there enough fuel flow for my nitrous to work in a safe manner?
  132. Its alive!
  133. Vortech or kenne Bell
  134. Ecs Fuel System Problems ???
  135. Hooking up fuel line to fuel solinoid.??
  136. BobJ Kenne Bell Kit Installed!
  137. New Mods
  138. Turbos
  139. Best location for O2 bung on Kooks headers..
  140. MT vs. Hoosier
  141. ET Streets
  142. Need info on vendors for forged parts
  143. Maggie Owners Spraying Nitrous, Little Help Here
  144. MT ET streets much better then BFG drag radials?
  145. Nitros??Wet/Dry
  146. nitrous guys please help
  147. Who wants a dyno day/gathering in PA???
  148. Who wants a dyno day/gathering in PA???
  149. Do you keep meth in your car incase you run out?
  150. Anyone have a number for PTK?
  151. ati set up
  152. boost gauge help install
  153. Mag LS2 TB Upgrade
  154. Evans vs. GM
  155. Great Taste vs. Less Filling, Which Would Win?
  156. Where is a good tuner in the jacksonville area
  157. 1066 horsepower, 30 lbs boost with E85
  158. I blooo my dif
  159. What do you all think about a restrictor plate?
  160. Fuel Pressure Gauge for Alky
  161. Is this right? (boost Question)
  162. ported ls1 heads from 346, ok for 402?
  163. Dyno number for Billy Foutrous
  164. Going with super charger soon, questions for my current set up
  165. Help, where to put nozzles(pic of airbox)
  166. Cartek line lock is here, sweeeeeeeet!
  167. drag times for 427
  168. I should have posted here. Those waxers just don't understand.
  169. RPM 4L80E to be installed in a C5 *PICS*
  170. ECS or Racetronix and boost a pump, Help PLEASE!!
  171. LS7 Clutch
  172. K&N Breather LS1/LS6 Group Purchase
  173. NITROUS Newbie, Input PLEASE!!!
  174. Safe boost with stock internals 01 Z
  175. New gauge shows low fuel pressure
  176. Help need Bosch Fuel pump for ECS Fuel system
  177. Who is running a 2 Bar SD tune
  178. Labor, tools, knowledge required for rear end swap
  179. Superdamper Crank Pulley ?
  180. Removing my schrader valve for nitrous fuel hookup?
  181. Procharger Boost???
  182. Custom "TurboCharged" decals?
  183. Results of my Vortech installation..............
  184. Kinda famous???? LOL
  185. Replace valvesprings if going FI??
  186. SPA Boost/Fuel Gauge ?
  187. Built Auto Tranny w/ Paddle Shifters for C5?
  188. Badges
  189. W2W Short Block
  190. Nice Job Andy A&A
  191. valves for FI
  192. Rear Nitto NT555r, what to run in front?
  193. FAST fuel rails
  194. Boost Controller Install?
  195. taking the plung, going auto
  196. ***Cartek C5/C6 gear Special $1195 Installed***
  197. What Drag Radials do you like?
  198. Mark Shaner Ported Throttle Body For Sale
  199. DTE axles
  200. Need Help with cold air intake
  201. New best times........
  202. Springs or Spray for 8mph Gain?
  203. Tom, do you recognize this car?
  204. procharger install at MTI!!
  205. Looking to buy C5 with nitrous
  206. Explain n/x
  207. Who's running a 150 wet shot with a stock fuel pump?
  208. LS7 swap in a C5 Z06
  209. A&A Vortec install pictures plus some other Bling
  210. Everyone Will Want Rpm's T-brake!!!!!!!!!!!!
  211. Upgrade Path? Suggestions
  212. [B]Injector Question LS7 Intake on C5R heads w/ LS1 wiring.[/B]
  213. A&A P1SC Belt Replacement
  214. Fuel shut off or wastegate?
  215. fogger or fan spray
  216. ** Remote Clutch Bleeders - Free Shipping **
  217. How hard is it to install a boost-a-pump?
  218. My A&A Vortech Install (lots of pics)
  219. can you make a turbo cars exhaust loud?
  220. TTi X Stage Turbo
  221. What would be a good, BIG, turbo cam?
  222. if looking for engine longevity what is max boost
  223. what compression should i run if in mountains?
  224. Went to the track today
  225. Julio's Email Please
  226. direct injection for corvette?
  227. Alky Controller Mount...
  228. The Big Race ... Preview Of This Up-Comming Season !
  229. How much HP/TQ can I get from a Maggie on a Z06?
  230. Does s/c'ing make the car louder without headers?
  231. HPM 2003 ZO6 TTiX Installation
  232. No Cat's-Turbo
  233. Mechanical boost gauges vs electronic
  234. Transmission or Differential
  235. A pillar pod install question
  236. HP vs TRQ, Who Would Win ?
  237. To F/I or not?
  238. Oil cooler before Vortech?
  239. will my tpis headers from my 346 work on a 402
  240. Cost install used procharger atlanta
  241. My newest heat exchanger..[Pic]
  242. Anybody running the Borla #12649 kit?
  243. Easiest/cleanest line lock?
  244. Fuel System (mikes99corvette)
  245. Cost of Installing used Procharger
  246. Some Turbo pics
  247. Quick Dyno Run Question
  248. How many are on 113lsa cams with F/I???
  249. Need instructions/Catch can on Maggie
  250. Peter Pan's Dyno Video
