View Full Version : C5 Forced Induction/Nitrous
  1. Advice
  2. Kenne Bell website says C5 superchargers shipping
  3. Fuel noid stuck closed
  4. False Temp Reading
  5. ZEX TPS connection? Which wire?
  6. How much NOS can a stock motor/trans take?
  7. Nitrous Guru's / Need Advice PLZ
  8. 100hp Wet Nitrous Results
  9. RPM....great work and customer service...
  10. Help from the C6 side: STS install manual?
  11. Where is the restriction orifice located on a supercharger system?
  12. A&A Belt Removal
  13. A4 brake pedal removal? Come in A4 to MN6 guys!
  14. STS and 2.73 or 3.15 gear choice????
  15. Racetronics fuel pump model 03'
  16. The Best Charger......
  17. ECS Fuel System
  18. RPM TRANSMISSION 4L80E C4 Corvette
  19. bottle warmer ground
  20. F/I crew, any knowledge of broken comp 918 springs on F/I LS6
  21. Bought a D1SC Yesterday =D
  22. Fastest 6 speed irs car
  23. ***** CARTEK Procharged C5 goes 9.70 *****
  24. Best place to buy Methanol???
  25. Need help with spring selection
  26. looking for a big alky tank for the rear, any ideas?
  27. where to put the fogger nozzle
  28. Sound clip of procharger?
  29. stock crank??
  30. I need some help and advice for a Maggie Tune
  31. Did I Break it?
  32. Alky pump problems...any ideas????
  33. Cam kit for SC
  34. First Day at the track - (link to short video)
  35. like this turn-key?
  36. Optimal Boost for STS cars ... some beta tests
  37. 1200 hp Capable 6 speed
  38. Comp 918 vs Patriot dual gold springs for stock blown LS6 Motor?
  39. Intercooled Maggie for Autox?HPDE????
  40. ProCharger noise
  41. Looking for most reliablity, any downside to swapping out stock LS6 valve springs!
  42. Cleaned up the Maggie alittle, what ya think
  43. Whats the weak link under boost?
  44. .5 bar spring in STS setup?
  45. STS Turbo = No Radio
  46. 99C5 + A&A P1SC + FLP tune = 618 hp
  47. what is my best option, sc or turbo and why>??
  48. The First Kenne Bell S/C LS2 402 *Picture*
  49. ECS 8" Crank Pulley on LS2 402 Maggie
  50. [pics]kb Bap Install
  51. Throttle Body is Finished
  52. I took off the supercharger, what happens if I go wot without a retune?
  53. Simple little nos question
  54. Does Maggie install hurt highway cruise mileage?
  55. Needed: C5 Fuel Pump Bucket Assembly (w/o pump) or GM part ?
  56. Holy Shyte! Who want's to give this a track run?
  57. what kind of rwhp ?
  58. Boost A Pump - Forum Vendors Selling These?
  59. ZEX Remote Bottle Opener For Sale New Cheap....
  60. Dirty Howie's 5 Gallon Torco Sale!!!
  61. 11.2 on Nitto NT-01... {VIDEO}
  62. Anyone running direct port NOS?
  63. Did some driving this sunday...
  64. what is the most boost you would run on 91 octane?
  65. Nitrous guys may be proud, check it out. Video, pictures, and numbers.
  66. water and Meth-Your Thoughts
  67. Does Maggie install hurt mileage
  68. Pictures of a Magnuson
  69. FS: NOS brand billet Aluminum bottle mount
  70. FS: Custom Billet Aluminum Nitrous bottle and solenoid mounts
  71. Going FI, rebuild my 427 or get a new 402?
  72. What size of drag slicks to run
  73. Street tires for Turbo car?
  74. Oil separator
  75. accurate FP gage, does the AM Cobalt get the nod?
  76. Fuel pressure saftey switch on LS6
  77. Results A&A Vortech
  78. TT pro's please.....
  79. Convert Tnt Power Ring To Direct Port
  80. STS twin turbo kit for C5 pricing?
  81. Will these heads work on a stock ls6 bottom end?
  82. boost guage with vac mod tranny..?
  83. Need Help finding what belt to get for D1SC !!!
  84. H/C, bored/stroked and 427 owners, need some input.
  85. Nitrous and Paint
  86. magna extractor hood
  87. Battery charging or jump I/C Maggie?
  88. Adding Headers to my Magnacharger ?
  89. Plate install
  90. LPE 383 A4 A&A SQ Vortech
  91. Where should I wire the hot wire for Gauge install?
  92. Need Setup Help; P-1SC-1 or D-1SC
  93. which wire for lighting on the stock cluster, for boost/fp gages?
  94. Questions on Customizing my STS
  95. Dry Shot A/F
  96. Dual Gauge Pod, Full A Pillar
  97. Vortech Superchargers On Sale!
  98. 104+ octane boost - yea or nay for nitrous
  99. remember this turbo kit?
  100. my STS.what rpm/boost should my alky start to spray?
  101. Got caught spinning the tires
  102. 402 w twin Gt4202R's
  103. Newbie Question
  104. Two stage N2O progress
  105. Midwest Area .... STS TT regional car show
  106. Electronic Boost Controllers, What are you using
  107. Anyone have a HPtuners bin file for A&A supercharged Z06?
  108. SD vs. MAF Tune
  109. MCM Hood who has the best price?
  110. FI Cost?
  111. How much boost for a stock LS6
  112. Front Tire to Match BFG Drag 275/40/17
  113. N2O jetting and s/c how much diff from na jetting?
  114. nxs kit,, whats numbers to expect on a 1/8 mile
  115. Bought a Defi A/F gauge, Will it work accurately on a blower car
  116. what clutch should I get for STS 15# of boost?
  117. Procharger to paxton
  118. 6.0L Heads Which Gaskets? Help Please....
  119. 402 SLP with Maggie
  120. Customer pictures for RPM Transmissions website
  121. just got my car tuned
  122. Blown 408 Vette for sale
  123. Who has the most miles on their STS setup?
  124. G5X3 N/A now....blower later. Problems??
  125. HELP car will not crank!!!!!!
  126. At what HP level does the stock Ti become restrictive?
  127. where to connect the white (signal) wire on the MSD window switch.
  128. Help Please!
  129. SLP ZL 402 short block with blower.
  130. New balancer or not?
  131. exterior pump
  132. Help, tire sensor question
  133. technique to change oil in P1SC?
  134. SO, who wants to know my final numbers?
  135. How important is it to pin the crank.
  136. Poll: Should APS be banned from the forum. Please research and vote.
  137. Has APS dumped Dave Inall? If no, why are they here? APS posting here, or is it Inall
  138. 42 Pound Injectors enough?
  139. C-5 Logo Bottle Blanket Done
  140. Anyone have a vid of a supercharger BOV in action
  141. anyone using procharger stage 2 kit
  142. Nitto R2 vs BFG drag radial review
  143. Video of My STS TT C5
  144. Which roll cage do ya'll use and did you install it yourself?
  145. Halltech twin turbo c5 hood
  146. TORQUE TUBE?????????? Please GET IN
  147. Question about sts system
  148. supercharger bov
  149. Best for potential power? TT or S/C?
  150. F1R Graphs
  151. Where Are My Maggie Fuel Rail Covers
  152. Dyno Vid.. S/C vette with Meth
  153. Prostate Cancer
  154. FRC fit with ETP 215 heads
  155. ATI vs. Paxton
  156. A Sure Sign Spring is Here
  157. Need Help with Fuel Pressure Sender
  158. YES Another Fuel System Question
  159. Snow Performance meth kit/MAF output?
  160. Magna or not
  161. ECS Restrictor Plate
  162. Blackwing Dry shot and wet plate Bench tested
  163. FOR SALE: Z-06 rear wheels..
  164. Bandit finally Sprays at 1/2 Mile Help Evaluate (Pretty Cool!)
  165. Anyone running a Timing Tuner?
  166. 50/50 used as winshield washer fluid ok?
  167. Robert56
  168. ls2 402 stroker camshaft question.
  169. Alky Refill?
  170. Will adding the ECS alky kit stop my black exhaust?
  171. Where can i find instrucitons fro ATI pipe routing ?
  172. UPDATED NUMBERS!! But still not final...
  173. My 76 custom turbo
  174. BIG HP guys inside. Question about fuel pressure..
  175. Magge I/C vs non I/C HP shootout fun.
  176. This video brings back nitghmares for me
  177. ATI head unit has a leek!
  178. Ok since the fastest C5's are in this section
  179. blowoff valve
  180. Questions on a Magnuson S/C
  181. Wanna Sell Your Beast?
  182. 4" red couplers 4 ply
  183. Alky pump mounting location
  184. Kenne Bell and cam
  185. 8 rib pulley set up
  186. Bottle mounting
  187. Extremely stupid question.....
  188. any tuners using EI Live?
  189. Pictures ECS Paxton SC Installed?
  190. Need a good fuel pump!
  191. fuel question: stock pump and BAP
  192. My New 408 and T88 Pic's inside
  193. Beefing up car to hold power...
  194. air/oil seperator
  195. Small vid - APS twin turbo Corvette
  196. VIDEO g5x3, direct port, fast, ls2tb, ECS here I come!
  197. is my cam ok for a sts turbo setup?
  198. Super charger on eBay
  199. Tach wire for the MSD window switch
  200. the ULTIMATE challenge.. Pending TT Viper smack down!!!
  201. Other post no workie, advice needed so I can give ya'll the track numbers
  202. Hey Guys where can I find A 4in V band Clamp
  203. Kenne Bell S/C, will it work on a '97 MY?
  204. Ok, so I'm going to give ya'll track numbers this weekend, advice needed
  205. What Fuel system for a little Maggie?
  206. Valve
  207. Nitrous progressive controller
  208. STS Install questions
  209. Im in love!!!!
  210. 1/4 of a mile run ?? ......700 rwhp
  211. What plugs do I NEED to use with a NOS shot?
  212. How many guys have a Kenne Bell S/C ordered?
  213. Looking for Chrome Shop in SE Michigan
  214. Magnacharger for Sale!
  215. TTI X second dyno pull
  216. BOV info wanted
  217. Any good tuners near Tulsa ok.
  218. 100 Shot
  219. which is worse w/tt..A4 or MN6?
  220. For Sale Just freshened 6L Heads Ported and Polished
  221. What makke 8 rib belt are you using??
  222. Kenne Bell Is on the market! couple questions.
  223. King Pin's TTiX dyno
  224. Need pics of hoods that will fit the Magi
  225. what horsepower
  226. When I get boosted, should I change out my hi-flo cats to straight pipes?
  227. maggy pulley size vs boost level?
  228. APS twin turbo install instructions
  229. here is my moderen day muscle car run 10.47
  230. LPE pump/KB BAP vs. Racetronix w/ direct wiring
  231. Question about identifying Pulley on a Procharger ??
  232. A-pillar pod mounting ideas wanted.
  233. Bin File
  234. Seafoam and maggy???
  235. TTI X first full dyno pull
  236. Rockers ?
  237. What is the perfect A/F for boosted cars?
  238. Need Some help w/ weird Knock
  239. Pulling vacuum from crankcase to seal rings
  240. NOVI guys on stock LS6.....
  241. ETP240 heads
  242. DYno S/C vette with Meth
  243. Got some dyno numbers for ya'll finally...
  244. Where Can I Get These And What Are They Called?
  245. FI Related and Supporting Vendor News ---video inside---
  246. Took a ride in the first C6 STS Turbo Car Today
  247. Is the diff brace needed?
  248. What do you think about 7.25lbs of boost?
  249. My Cats Failed
  250. Fuel Pump ??????
