- How Many Of You FI Guys Run A A/C
- Kenne Bell Bap Question....
- Help Removing oil pan - Do I have to remove the motor?
- ECS Overdrive Pulley?
- delete the f-45 ride
- Raptor Shift Lights - Free ship! Buy before price hike!!!!!
- Torco Help!
- Somebody convince me that I should or shouldn't do this!
- Easiest to install/remove SC?
- BTW: Anyone looking for an IC'd maggie w/hood?
- Another oil cooler option
- ECS, I blinged your 8-rib.........
- First time using my new MT ET Streets
- Looking for more “usable” power from my Procharger
- props to sts .
- Paxton Novi Dyno Video
- Maggie and what else? To cam or........
- It's alive once more...
- Need Help Do you know or can you vouch for 1badtrain
- Kenne Bell/or What
- Dumb People
- The new 18" MT ET street Radials....
- How do I remove my gas filler door?
- Happy Fathers Day!!!!!!!!!!
- Whats the best n20 kit?
- Nitrous: max shot for use on stock motor?
- Share you Torco Experience, and get in print...
- I need a great engine builder in midwest
- Price for used Procharger?????
- ECS Paxton results today
- APS Cam Specs???
- P0343
- Are ya'll running your boost gauge/BP/andAlky kit off your brake booster hose?
- Fuel Pressure Safety Switch question?
- Which would be best unit(supercharger) for my 01 Z
- Show Me Your Gauge Setup....
- For sale: LS2 intake and ported ls2 TB w/ harness
- Remote Oil Cooler setup "Finished" [PICS]
- Lets See Your PCV Setup (Pics)
- Nitrous and A&A ALKY Kit?
- Is catch can required for P1SC?
- Pin the crank Help!
- Another Smoke coming from breather question. (Vid)
- Clutch recommendations?
- Easy maggie mod for better belt wrap
- Great Experience @ Norris Motorsport In Fl!!!
- Help! Anybody using Turbo 400 transmisson
- STS TT C5 vette vs F16 Jet in the 1/4 ... predictions
- Autopower Roll Bar
- Procharged D1SC with 10LBS of boost??
- PCV Pics
- Easy install fuel system
- Next chapter for blown LS1?
- 8 rib pulley options?
- "The Banana" gets a hood...soso day at dyno
- clutch help
- Just A Canuck thought...
- New numbers! with dyno sheet (fixed)
- What's The Difference Between Us & Canaidin S/c
- Talked to Chris today @ECS
- which s/c to go with????
- need advice/ vortech or psc1- intercooled
- Catch can pics on a magnacharger
- I need the DIY'er in here
- What BOV are you using?
- DRE New Supercharger
- Sean at OCC steps up, and Mcloed makes good!!
- 75 shot nitrous=35 rwhp gain?
- New water pump=Blower whine?
- Car won't shift at WOT
- Cam sizing for a Maggie.
- pics of coolant line output for turbos
- NEW VIDEO....Smoke Show and More!!!
- results of Procharger install
- What is the most quiet head unit?
- Local Tuner Needed in Tampa Bay Florida
- Big Thumbs Up To Bob@EPP And Procharger!!!!!!!
- Combining Nitrous & 4:10 Gears
- nitrous guys help !!!!!
- Supercharged Ls6 Piston Failure
- Will a restrictor plate put more stress on my engine?
- Car is off to Shawn @ OCC and Dr. Phil
- My 408 single Turbo Project...
- Broke my Bracket that hold Power steering and Alternator
- Opinions on improving Maggie IC setup
- Just in case one of you FI guys have one laying around...
- Looking for some pictures with Nitrous set up
- Most Popular Nitrous system for 100Hp
- Red maggie + NO hood = everyone wants a piece of you
- Sweet $4K LS intake
- Ok lets get this Dual Pump talk settled
- Dual Walbro pump, no issues!
- kPa conversion to psi....
- Anyone tried M3 meth? from VP Racing fuels?
- Front tire suggestions
- Vortech cog belt problems. Need advice
- c6 zo6 cam installed in an LS1
- Joing the FI club
- Magnacharger dyno sheet on 02 Z06
- EnglandGreen Shop - Supercharger Mania
- water cooled turbo / plumbing question
- APS twin turbo question
- How much time for installing a procharger
- NOS question? Can i get away without WOT switch?
- ECS 6 point Roll Bar Question/Pic.request
- Need help with P1SC!!
- Fuel system for C5's
- Timing Effects On Power Output
- RPM Transmission *Free shipping special*
- Will supercharged cars still pass emmissions in new jersey ?
- ATI ProCharger Superchargers On Sale!
- Saturday Cruise
- Mike-C5 And Peter Pan Dyno Video
- wet or dry on a cammed Z06?
- Bought MT ET Streets…Did I make a mistake?
- Kenne Bell hot air warning...
- C5 z06 + 100 shot = tranny issues?
- ECS NOVI and more coming together
- SC help from the experts
- National Trail Raceway - Columbus Ohio
- After Magnuson, what's your next mod?
- HELP!!! NOS drive-by-wire TPS/RPM window switch install ???'s
- Looking for more cooling options....
- Alkycontrol problem??? not pressurizing
- Stinger Hood Form And Function A New Use
- Posting this for the FI crowd
- Cartek Aps Forged 347 Twin Turbo Install Update
- Thumbs Up For Jeff Creetch At CAM
- Need help from the masters!! Is anyone NOT happy with their STS kit ???
- WB O2 senosors and exhaust backpressure
- DeWitts Radiator with built in Engine Oil Cooler and TTiX kit - Are they compatible?
- MIKE C5 Video 10.21
- heads and NO2
- Meth vs. Alky?
- 700+ rwhp guys, who has traction in 3rd gear?
- Chirping, squealing when cold?
- Dreaded #7 lean out
- Need help with spring selection for lift and boost
- Chirping / Squealing When Cold, Any Ideas?
- Aps 1/4 Mile Times
- Killer 735 rwhp Z06 Badges - pics
- Thanks To Andy/A&A Corvette
- Help with grinding my Maggie
- It is finally ALIVE ! ! !
- Aps Twins
- ECS TT SHake down pass for Pinks at Mir
- My new crankcase breather pics
- how to check....
- I want to go FI but I think I bought alot of wrong mods
- 78wrhp for $100
- calling ecs
- D1SC ECS bracket question
- Aps Gt3582r C5
- Supercharger on bone stock engine
- Would different headers help?
- Did a Leakdown Test and...
- Kinda FI related....
- lets talk turbos
- anyone running a wet dual nozzle N/X kit
- Anyone here have an ECS or A&A kit lying around?
- Will my red minimaggie make 600 rwhp?
- [B]Will my red minimaggie make 600 rwhp? [/B]
- Got car back from ecs this morning
- Is there a problem with HP tuners
- Twin Turbo Problems
- Blower cams, more intake duration or higher lift? What is the right combo.
- Canadian Turkeys
- Supercharger Guys..your Kits At Nothing!!!!!!!!!!!!!!!!
- Has anyone used PowerForce Series by Professional Products?
- S/C Installation in Notheast Ohio
- Running hot!
- 100mm MAS
- atco rentals
- Greddy EBC users
- Who has the best price on the Snow Meth Kit?
- Any tuners close to the Hickory, NC area?
- tuning supercharger
- Took out air dam
- BAP mounting location?
- KB for a 97?
- Chemical intercooling questions
- Track results for stock LS1 with STS
- Whats a used STrim Vortech Superharger w/Intercooler Worth???
- Aftercooler?
- It's ALMOST there...The finish line draws near!!
- When is enought HP enought
- Anyone Running Ati Cog Drive Set Up
- 1997 1998 charging problems
- Oil - Viscosity - Usage - Brand
- How many crank pins you are you using?
- Procharger best price
- I need a 160 degree T-stat???
- Norwalk Video - better late than never
- Guys w/2 diff tire height sizes any problems w/abs?
- looking to go nitrous on 01 z
- Dyno pass
- Big Announcement!!!! GCP Shop Opening!
- 90mm Magnuson Upgrade w/90 ported Throttlebody
- Englandgreen Grand Opening PICS
- What rear Polyurethane Bushings are y'all using?
- Smoke from Vented Catchcan
- S/C Price
- Snow-Boost meth kit-6 pcs.
- Vortech repairs?
- C5 Supercharging need help! Purchase or Not?
- Rookie Takes K/belle To The Track, Flame Suit Is On
- Xtreme Procharger Sale!
- ECS Paxton Installed...plus little idle vid.
- AEM wideband Wiring
- Anyone tried Halltech's twin turbo kit?
- when should I squeeze (nitrous)
- A4 Transmission Running Hot after Vortech Install: Update
- Leakdown results shady
- Questions
- In Search of ... a Syringe for ATI Procharger oil change
- Air Conditioning loss with FI?
- What are the record holders for IRS C5?
- NORWALK NO SHOW VIDEO [ sorry not permitted to go ! ]
- Supercharging Questions: Chris from ECS you out there?
- ***Cartek 408 w/200 shot , 9.7 pass video ***
- Anyone w/novi 2000 around N.VA?
- Big changes this spring APS self installed and said I DO!
- Turbo gurus please please step in
- Dynotune Window Switch
- Help with supercharger
- How many miles can a s/c engine handle on a basic system?
- 01 Z06 Procharged Idle Video
- Best coolant
- Procharger guys, any suggestions where to mount a Catch Can?
- Oil and Coolant Temps...normal?
- Proper Break In Procedure
- TTix plus Forged 347
- Procharger vs Paxton
- twin turbo's FS..like new
- A&A ProCharger kit help!
- England Green Wanted by Authorities
- Question I'm sure many of you guys would know ....
- APS TT OWNERS best step inside!!!!
- GIBSON SALE!!! For your other Car/Truck ****
- tempature input for tt guys
- Whatever happened to these guys.
- Supercharger, Mag or Belle?
- Oil Consumption
- What tops Cannuck's NOS cars ?
- MSD fp voltage booster
- Fuel Gauge...
- Chromed Air bridge
- Where to get 3 gsuge pillaar pod 4 03 Z06
- More boost and a new Alky/Meth system
