View Full Version : C5 Forced Induction/Nitrous
  1. D1 with 11:1 comp LS1???
  2. injectors
  3. supercharger installer
  4. where to go to have a 1500+ FI LSX longblock built?
  5. Head unit help :)
  6. Advice on what is the best Fuel Pump Route to take
  7. Rubber elbowes for blower piping question
  8. Rings.....Which Ones For Stock Pistons
  9. ** TPE's T2 WIDE BODY PANELS **
  10. Have you guys seen this?
  11. Tpe t2 widebody pics
  12. Parts Needed For Build What vendor has these?
  13. Procharger
  14. Header selection
  15. TPE Kenne Bell 2.6 & 408 Ready to go!!
  16. AA blowoff valve ??
  17. HPM A&A YSi Installation
  18. Sam's A&A Supercharger Inlet swap results!
  19. SudburyC5, goes SD, Flip Drive and gets 922 RWHP on 91 octane and meth!!!!!!
  20. Installers in San Diego
  21. Alignment Issues with a ProCharger Bracket
  22. Wife came home early....BUSTED!
  23. Thinking about a SC setup
  24. GOING FI- need advice
  25. what amp boost a pump do i need for my setup??
  26. No Induction...faster then a C6 and BMW
  27. Ive bought a vortech supercharger do i need a boost a pump??
  28. FLIP DRIVE - Finding the limit on 6 rib blower drive - Part II - 21 pounds
  29. interest in ls2/ls3
  30. I still need an engine block
  31. NO2 Primer
  32. Great ProCharger Prices at EPP!
  33. •• Look at this Block !!! ••
  34. What numbers should I expect
  35. LS7 clutch install help please
  36. Champion track rental oct.23 @ tmp
  37. Attention Vendors: Need a LS2/LS3 FI engine NOW at a rock bottom price!
  38. Hard starts after A&A fuel system??
  39. Meth inj
  40. A&A new procharger bracket with F1C ?
  41. Who's Coming out for SEMA? Party at my place..
  42. FI / Nitrous cars - what is your HP?
  43. Anyone have a Tial 50mm BOV they want to get rid of?
  44. cam questions about going supercharged
  45. Apples-apples forged 346 TPE or TXspeed
  46. 801RWHP Boosted 370 with ECS Novi 2000
  47. Reccomendations: Nitrous setup for C5Z
  48. Magnacharger Install
  49. Why is my belt shredding ribs?????
  50. Z06 Titanium Muffler Autopsy (Pics of the Inside of a Z06 Muffler)
  51. Maggie Installed members, CAI question
  52. How long
  53. is it possible to powdercoat a supercharger?
  54. AA install questions
  55. dededededede
  56. New 383 setup
  57. Etmc a&a kit install sale*******$ 6495*********
  58. Where to buy/rent a crank pinning kit
  59. Install questions on Procharger or Vortech
  60. STS C5's step in!
  61. Forged 346 longblocks** step in please
  62. All Pro heads
  63. rear end / trans 6 speed
  64. high flow cats, longevity?
  65. Is C5 And C6 the same clutch slave
  66. Oct 1 is date for more oxygentated % in gasonline
  67. Can i tap my oil pan for my vortech with my long tube headers
  68. FI and PCV Revisions -- APS specific, but all thoughts welcome
  69. Need a little help
  70. Innovators West OD 8 Rib
  71. A&A radiator lowering kit
  72. Bypass valve/Blow off valve..Whats the diffenrce??
  73. Tial 50mm question
  74. Should i upgrade my stock vortech bypass valve??
  75. What are some possibilities when the side electrode on my spark plug on #4 cyl...
  76. ATI underdrive balancer
  77. Oil restrictors on PTK system?
  78. recommendations for sts cam,heads and exhaust!
  79. Vortech YSI question
  80. TPE "T2 Widebody" rear panels Installed and painted {PICS}
  81. Trade up from D1SC to F1 Question
  82. *Pulley issue*
  83. steel or aluminum tubing?
  84. Help with intake & TB
  85. Do I need gauges?
  86. Superchargers
  87. air/fuel gauge o2 sensor wire
  88. Budget Boost Rebuild. A Few Q's
  89. Output shaft failure?
  90. WAY off topic, STRANDED in LV and need help
  91. <<Forged 346 making over 600whp>> how many miles before it's time to refresh???
  92. Forced induction on a Z06
  93. Looking for an LSX block
  94. Some pics of the car with the new LPE decals.
  95. Meth question?
  96. Need advice.
  97. Intercooler Question
  98. ECS Twin Turbo Kit Special!!! $8995.00
  99. solid roller with hydraulic lifters
  100. Which crank pulley for Turbo Vette
  101. Anyone have any pics of LPE billet axles.
  102. Torco and supercharged cars questions
  103. Driveline couplers for 500rwhp?
  104. Chrome or Painted Skull & Chicklet .........pix
  105. Apsis' Beautiful D-Shape SW w/burlwood & torch red leather...installed...pix
  106. need insight in proper vacum readdin with new boost guage
  107. Air filter question for those with LPE TT cars!
  108. Vortech bracket
  109. Why Meth?
  110. Apsis' C5 Door Panel in Italian Nappa Leather.....some close shots
  111. Boost on 11.8:1 CR?
  112. ONTARIOVETTE's CLOSING IN ON 1000RWHP!!!!!!!
  113. Boost a Pump Question
  114. Those who installed ZR1 trans & diff
  115. One Mile Shootout (Ochopee, FL)
  116. * H U G E * 60 & 80 lb Injector Sale
  117. Help: I am losing BOOST!
  118. A&A Vortech kit with FAST intake
  119. Champion motors track rental day
  120. Anyone Heard of Illinois Dyno Center in Port Byron, IL ?
  121. Flip Drive vs 8 rib questions
  122. Procharger F-series dimensions
  123. What does a 440 make for HP
  124. Launching
  125. Dyno numbers are in
  126. Need help with a decision
  127. Billet 12MM Torque Tube Coupler
  128. Engine Water Temp on I/C Maggie????
  129. Need consult on clutch noise.........
  130. n2o on a high mile motor//help
  131. Spec twin disc question
  132. Need machinist lifter bores LSX based block
  133. TS Front end from Extreme Dimensions Poor Quality
  134. What are some good boost and fuel pres. guages??
  135. BlownblueZ06, Z06wanted, EvlZ06's trip to Z06FEST in BG Kentucky!!!!!!
  136. need some help
  137. FS **Ported LS2 Intake**
  138. PLX gauges... anyone use them?
  139. Worth it?
  140. No fifth, sixth or reverse
  141. Best combo for 600whp daily driver
  142. Champions Motors TT Z06 ride
  143. Car running lean
  144. Which Balancer do you run?
  145. Apsis' C5 Door Panel in Italian Nappa Black & Torch Red Leather......pix
  146. Ragin Racin Introduces Under Stock Hood Supercharger!!
  147. fuel system 600rwhp procharged vette
  148. What oil pump for TT 402?
  149. My ECS Procharger install pics
  150. Has anyone thought about twin charging?
  151. New 427 warhawk for my C5Z!
  152. Anyone have a 3.7" Procharger Pulley
  153. Who has best prices on Forged Pistons, Cranks,and Rods????
  154. ***The new EnglandGreen Facility! EG GTM SUPERCAR! SPECIALS! GIVEAWAYS!***
  155. Mechanical or Electric boost/vac gauge??
  156. N2O knowledge needed.
  157. custom plates for FI/nitrous guys?
  158. ***NItrous kit installed and tuned sale!!!!!*****
  159. Blower RPM Calculator
  160. D-1SC. Need to calculate how much more boost I can run...
  161. Help me choose a size of Drag Radials.
  162. Roll racing
  163. F/S Nick Williams 102mm Throttle Body
  164. how much boost with 6 bolt heads/block and TTix???
  165. Self contained or not?
  166. 8 rib pulleys
  167. FS: Beer Panels **CHEAP**
  168. Product Update for Kenne Bell (BIG BIG blower coming)
  169. The Breathless Big Mouth Air Intake
  170. SC theory ?
  171. tensioner rubbing
  172. Fastbird's APS Vette Version 2.0 is Done
  173. 3.8 or 3.6 pulley help me decide
  174. Need Pics of Aluminum Radiator Hold Down
  175. LSx hanging tough with the fastest guys in the country
  176. Radiator Hold Down w/ ecs kit???
  177. 60lb motron injectors
  178. ECS Powerglide Conversion
  179. Just need to confirm...
  180. Used TTi Stage X Kit Anyone interested?
  181. Fuel pressure woes!
  182. Most Maggie boost on stock LS1
  183. Cerra Single Turbo Kit, any interest?
  184. Maggie 112 oil leak
  185. Metal supercharger hoses
  186. too big of a cam for supercharger?
  187. Suggestions on break in, no tuner in town..
  188. Your feedback about those tires please...
  189. Selling the LG Motorsport BIG 3 3" on my FI Set-Up!
  190. what are the steps to taping into your oil pan for the vortech system??
  191. About to give up.
  192. Methanol "Alky" Injection
  193. Where do you guys buy your methanol in CA?
  194. More questions
  195. NemesisC5 come in please.........
  196. Flywheel for Spec Stage 3+ Clutch?
  197. Blitz SBC ID II boost controller over boosting
  198. NGK R5724-8 for TT Vette?
  199. Wish I had a Camera !!!!
  200. Small seepage from top of Procharger fill screw
  201. How much more boost going from T trim to YSI?
  202. Lg Motorsports Hood Louvers
  203. Too much cam?
  204. What should my IAT sensor readings be at cruise and WOT?
  205. Anyone know what size belt to use for Procharger 3.7 pulley, with ECS bracket/tension
  206. Finally got my car back
  207. EnglandGreen's new eddy current dyno - shakedown run
  208. TIAL 50mm is noisy as he.. lower rpms out of boost..
  209. A&A Corvette 3.6" 6-Rib Supercharger Pulley for sale
  210. Edelbrock Supercharger for LS-1 ?
  211. Chattering noise from procharger (videos)
  212. How many FI guys upgraded their brakes?
  213. how much power through stock exh?
  214. A&A supercharger kit installer....
  215. FI Hoods
  216. HPM C5 LS7 Dry Sump
  217. Can a clogged cat cause lower engine idle vacuum + higher A/F at idle + run terrible?
  218. Want to add a maggie to highly modified C5, q's
  219. pics of no2 cars
  220. Need new Cats - what are my choices?
  221. Typical symptoms when a fuel pump starts to fail?
  222. '02 C5 ZO6 A&A/T-Trim results inside!
  223. To LSX or LS2
  224. High hp/boost cars...what fuel system you running?
  225. RPM's Tuning Special
  226. Tial BOV spring question and idle surge
  227. Highest Mileage: Orignal FI Block: Stock or Otherwise
  228. 97-98 Rails - Which Line is Which?
  229. looking for a way to track a/f ratio
  230. 3.60 pulley belt size?
  231. something broke
  232. Can i have my vararam hooked up to my vortech supercharger??
  233. HPM LPE Minitub Installation - Part 2
  234. TT or blower for c5r 427?
  235. Fuel pump die instantly?
  236. More advice please
  237. Install pics on ECS fuelsystem?
  238. Procharged C5Z vs C6Z?
  239. Car still running warm
  240. Weird Sound when letting out Clutch
  241. Help me decide? SC???
  242. TQ Tube Bushing Options
  243. What else do i need to install with my vortech supercharger kit??
  244. Big thanks to the folks @ rpm transmissions!!!!!!!!!
  245. question about tune and boost.
  246. Kenne Bell IAT again, again, again
  247. Are supercharger's Nirvana?
  248. I need to find a replacement alternator for my PTK kit. Please help!!
  249. si trim
  250. Meth nozzle mounting in rubber coupler work ok under boost?
