View Full Version : C5 Forced Induction/Nitrous
  1. Is this a good turbo cam?
  2. 8 rib
  3. Trans temp with feder well cooler???
  4. Head Unit Velocity Ring
  5. Simply the Best Email Tunes - Based off Current Dyno Testing – and Still only $150
  6. Catch cans....
  7. Big thanks to England Green!!
  8. If I want 550 RWHP, what else will it take?
  9. MAP sensor exchange
  10. Finished & tuned w/dyno #'s! 562/467 (long)
  11. Which textralia clutch do I have?
  12. Bypass valve question
  13. SARD In Tank Fuel Pump 280l/h
  14. Thinking about a backup car...
  15. Vortech SUPER high pitch ...HELP!
  16. Another Happy customer of Beer99C5
  17. It has begun... Out with the old!
  18. Nos line install?
  19. D1SC boost question
  20. Picking up my new 2007 Z06
  21. Pissed off !!!
  22. BAP Wiring
  23. methanol installation
  24. Just when you thougt I ran out of Bad Luck..
  25. FINALLY! An affordable DIY single turbo kit
  26. cool air induction
  27. If you have a supercharger on a stock bottom motor, please step in.
  28. Two alky systems????
  29. Restrictor plate or boost limiting valve?
  30. Stock + Dry Kits Only, Post Your Times
  31. I'm interested in record breaking LOW Dyno #'s!
  32. fuel system help
  33. tronto c5 f/i broken vettes !!!!
  34. Who is running a vacuum pump system?
  35. WTF is going on with my blower drive?
  36. Possibly a dumb question but...
  37. 99 FRC + Ls7 ??
  38. Wanted LS6 stock head
  39. Turbo car will not start
  40. Street/Strip Gear/Converter Combo?
  41. Modified Big HP C5-s what miles are on your modded cars???
  42. Heres a few pics
  43. check out this vette that runs deep 9's on stock motor and 5psi!!!
  44. Just about finished installation - quick Q!
  45. EG Birthday Madness : 44% OFF, Today only!!!!
  46. Time to pulley down!
  47. Best Catch Can???
  48. Does anyone have a crank pinning tool they want to sell?
  49. What is 60 lbs Mototron Injector rated fuel pressure?
  50. Twin Turbo Truck!!
  51. fuel economy and FI?
  52. I need some vortech blower help...Hurry please
  53. My Cayuga Trip
  54. Got Textralia?
  55. Is 500 rwhp much more streetable than 740?
  56. will paxton make a blower like the f1r
  57. Im back ....WOHOOOO!!!!
  58. Catch Can Location?
  59. High Temperature Silicone 4" hose, where to buy?
  60. Going FI, clutch question
  61. Self contained Paxton sc
  62. Heads for boost, valve size???
  63. Braided Hoses
  64. Catch Can Question?
  65. Oil supply - Cerra Turbo?
  66. Maggie intercooler pump wiring question
  67. If you want my Z here it is
  68. pulley size, how much boost?
  69. ECS ProCharger Bracket Installed (Pics Inside)
  70. Z06+STS = Clutch Needed
  71. Just Arrived : New TTiX Turbo's!
  72. Procharger, KEYWAY problem.
  73. Some cool pics from the track!!!!!
  74. FI suspension upgrades?
  75. Belt Tensioner 4 the Maggie - Part 2
  76. Motor swap question........
  77. Using Nitrous for dummies
  78. first time at the track
  79. No more dyno queen!!!!!!
  80. F/I kits that retain stock fan shrouds?
  81. Where do y'all buy all the bling airbridge tubes?
  82. tooshort
  83. tooshort
  84. All kinds of issues I need help on...
  85. ******its Off The Lift! Pics Inside!!!****
  86. oily bumper on Blown 403ci
  87. Car dies when I get on it.
  88. twin turbo thoughts?....get what you pay for?
  89. A little show...A little go... For those who don't look on the Z06 board
  90. Does anyone have this vortech setup?
  91. 858 rwhp 820 rwtq
  92. first time out with the new nitrous kit
  93. Question for SD'd Road Racers
  94. do i have to take of my head unit to replace my belt?
  95. AA Vortech dyno results?
  96. Tuning question: injector flow rate table
  97. 42# Fuel Injectors
  98. nitrous or not ????? advise please
  99. Few pics of Twin Turbo Install
  100. Lb
  101. [FLORIDA] The Michael Holt (WellAdjusted) Memorial car show and poker game
  102. Rich, Lean or OK
  103. Sneak Peek...
  104. F/S tti x kit and forged engine with extras
  105. Debris removal from fuel injectors
  106. taking the plunge - best system for my goal
  107. Rear mounted turbo setups?
  108. nitrous timing tuner needed asap anyone??
  109. STS Turbo Package - Save Up To $1500.00!
  110. Drawbacks to laying radiator down for sc?
  111. 4.0 Reichard Pullie
  112. APS C5 extreme fuel system-1000 RWHP fuel supply for 03/04 model C5
  113. A&A S/C ducting over the radiator
  114. GT 14 cam or GT11 cam for TT Ls1?
  115. So you want to be a big dog.. heres your chance, Asmokegars complete drivetrain F/S
  116. Best cam for F/I??
  117. Valve spring special
  118. Diablo and Nitrous
  119. Maximum RWHP with my ATI 383???
  120. 1200hp 3 staged 160 mph traps Zo6
  121. KB BAP & AEM boost controler installd
  122. MIKE-C5 (Transmission/Torque Converter)
  123. props to rpm, ecs, roadrebel, nick(blown zo6) a&a, vette dr, cartek & all the rest!
  124. 75 shot?
  125. nick the tin man...
  126. turbo ZO6 (too hot!) any ideas?
  127. Kenne-Bell track times?
  128. Hptuner File
  129. What is the max duty cycle you would run before switching injectors?
  130. STS Is here to put the myths to rest.
  131. NEW PRODUCT: Callaway Honker For The Magnuson Supercharger!
  132. Headers...
  133. Thinking about switching setups
  134. D1SC ECS bracket installation instruction
  135. Adjustable Belt Tensioner 4 the Maggie
  136. Removing MAF screen
  137. Drive Train Question - RPM / Textralia Twin
  138. just some updated pics of the car
  139. Vlbz06 = No Balls
  140. Help with Twin Turbo Alternator Relocation.
  141. Nitrous Reliability
  142. New S/C hood pic's almost a member
  143. Picked up car from ECS today...Brutal
  144. few turbo things FS
  145. Tial big green WG (12psi) springs available
  146. Nitrous guy's, remote fuel cell?
  147. Thanks Karshop
  148. Cost of high horsepower and builds
  149. Transmission??
  150. Supercharged...what next
  151. Nitrous on top of my H/C setup???
  152. '02 Z's fuel pump .... what HP can it handle ?
  153. > 800 RWHP / 800 RWTQ - Easy or Not? What to Expect?
  154. What happened to RJW???
  155. Does anybody have an easy way to check for boost leaks
  156. Any Big HP FI Crowd Try These ?
  157. Help diagnose driveline failure
  158. magnusson & g5x3 ??????
  159. heres a car for Brabus
  160. Using a LPE 100mm MAF on a FI application
  161. Need an alky washer res. cap
  162. Made Your Own Nitrous Bottle?
  163. EG Insane DTE Differential Install Special (Florida & Southeast)
  164. What do you think about my dyno graph?
  165. Fast intake and FI?
  166. Clutch problem
  167. Best Purge sytem?
  168. anyone run these tires w/big fi hp?
  169. Another how much more power will I get question
  170. OEM replacement Off Road Mid Pipe..where did it go?
  171. dumb question... why do we need 02 sensors
  172. unkown engine noise
  173. Kenne-Bell intercooler?
  174. How much power will cats take away on my APS Z?
  175. Tex OZ700 Initial Review
  176. Did I break an output shaft?
  177. Video of Z06 blowing his motor
  178. Back from E.C.S.
  179. A&A JT-trim kit and CDNPERF 402 make 845rwhp!!!
  180. Someone's gonna get a sweet deal on an Innovate LM1 wideband system!
  181. Thinking about going f/i
  182. do it right and make it clean!
  183. How high is the kb vs maggie
  184. Dewitts oil cooler - what to do??
  185. Relay wirinig help needed Thanks
  186. best fuel pump setup for 600 RWHP on a 99.
  187. Guys running the Textraila
  188. ECS Does it again :)
  189. Big thanks to andy @ a and a
  190. New to the S/C world....
  191. Oil Pressure Question
  192. C5 1999 91Kmiles Nitrous?
  193. Just Bought Brand New Sts Turbo Kit For $5,800!!!!!!
  194. Picture of my 3.3 Whipple parts
  195. 1000.00 off the STS C5 C6 kit?
  196. LG Motorsports Header Sweepstakes
  197. Amazing Turbo Fuel Economy ... STS the subject
  198. STS, more power with headers or manifolds?
  199. D1 on stock motor + meth. what do you think ill hit?
  200. TNT Kit
  201. Good, Bad, Ugly STS
  202. Getting the #$@# crank bolt off - 650lb wont do it???
  203. APS C5 twin turbo owners - dyno graph at 7 psi
  204. Should I upgrade to afr 205 heads
  205. The world without 5 lb. nitrous bottles...
  206. Vortech V1 and V2....whats the difference?
  207. Headers only on a supercharged car?
  208. Timing Retard
  209. APS 7psi Dyno Results
  210. traction
  211. 76GTS vs ST80
  212. 16" DOT tire thoughts...
  213. Boost controller mounting
  214. ATI ProCharger and EPP at Super Chevy event this weekend in Indy
  215. Water/ Alky injection info I found
  216. ~550whp DD street tires. what do you recommend?
  217. Where To Buy Methanol in SoCal?
  218. Fuel Pump Question with nitrous kit:)
  219. TTiX Compatibility Question
  220. How to clean a stock P1sc air filter?
  221. Cdn Performance/Rev'NHigh
  222. alky pump
  223. EG Clutch Insanity Special - $1695 installed
  224. Anyone using a Digital Guage for boost and Fuel pressure?
  225. tire and rim combos
  226. Well... She's pretty much done. [PICS]
  227. Water injection -- it's not just for Corvettes anymore.
  228. turbo size
  229. Head/Cam and Nos
  230. X/H pipe
  231. ECS just called! Car is Done!
  232. Glow Shift or Auto Meter Gauges
  233. Mike-c5
  234. Who's On Dope
  235. High HP complete 6 spd changeover
  236. New pics... 02 EB Z w/ KB
  237. Dry shot question
  238. Newb Nitrous ?'s
  239. Help with gauges
  240. ecs Novi supercharger
  241. Boweryboys Turbo C5 IRS Sets a New C5 IRS Best-169.95 MPH w/ 0 traction![VIDEO]
  242. 6 days left and I'm under the gun!!!
  243. Glowshift gauges
  244. Wideband
  245. Who carries 8 rib pulleys in stock?
  246. What kind of HP should I see after A&A setup?
  247. Looking for Maggie FRCs
  248. Triple Gauge Pods
  249. Trans shield, trans blanket
  250. IAT timing tricker
