- HP Rating on rear end
- PTS/PTK Twin Turbo owners (Poor Customer Service)...
- Thanks Rodney @ RPM Transmission
- Which Walbro for in tank replacement on C6 style fuel system?
- Anybody running 550+ rwhp in a true only-car-daily-driver?
- Vararam+Borla+tune=?rwhp
- 100shot numbers and 1/4 time?
- Cyberdyne digital guages
- Got my Textralia Triple Disc Clutch
- Paging Aps :)
- motor is busted, what can I re-use?
- TT/ Oil Question
- Heat Extractor Hood Installed a Few Shots
- 9 second Ride Along in a 6 speed Supra..
- Vortech Installation
- C6 ZO6 Body on a C5 ?
- Ok... how do you guys get traction?
- EG Goes International - Canadian Supercharged Z!!!!!
- ANNOUNCEMENT!!! NEW* RPM Transmissions converters!!!
- TT vs Supercharger
- Dr. Phil's NA + N20 setup goes Road Racing!
- What's the most power put down by a mostly stock STS set up?
- ATM-2240 Sender Voltages/Pressures for Nitrous Users
- Interesting Dyno results on my 08 Z51 C6
- Belt Squeak...Procharger
- Some food for thought regarding twin screws and pd blowers
- F2 Procharger C5 L92 and E85= 1000+
- Big Thanks to obxfunn!!!
- Shipping tires?
- Most effective vented hood?
- Weldon pumps and controllers?
- Supercharger guages?
- Will shaft rockers clear stock valve covers
- Losing the Dipstick....
- Water Accidents (Funny)
- Accidents Happen
- does procharger require different hood??
- Apsis' C5 Splash Guards (Z Style) Prototype Done, *Pics Shown*
- How Much Torco, and How Much Boost?
- FMIC's...anyone else tried them?
- Dyno Pegged at TTi LSx TTiXYZ!
- Videos From TMP Last Month
- anyone have a similar set up?
- 243 Heads....Will they be OK?
- 2200HP Daily Driver! 0-60 in 1 second...
- are 1.85 roller rockers worth putting on a blown 01 Z06
- another n20 question...
- Turbine welding morons on mx6.com
- LSX Shootout - Who is going?
- thinking of a new shortblock combo...what parts to purchase.
- I know this has been beat to death, but, I'd like some feedback please, oil catch can
- Heads for centrifical
- Maggie Guys Help Needed with Gauges
- EG Needs your Procharger Help!!!
- ATI Performance Products 10 rib wide ProCharger Upgrade Kits?
- Even at 170MPH you have to know where your competition is! [VIDEOS]
- Direct port N2O kit for sale.
- Maggie and KB hood issues
- the latest buzz....3" inch exhaust
- Safe Wet Nitrous Cost
- DART single beehive PSI springs good enough for blown motor with 224/230 .592 lft cam
- STS Twin Turbo Kit
- Need stock radiator cradle
- did my STS turbos get damaged from bad motor?
- Electronic boost controllers?
- Complete 6 speed setup
- Does this sound about right??? **BOOST GURU'S STEP IN**
- STS guys, interested in ZERO lag 6spd or auto??
- Maggie vs. A&A supercharger
- LS6 heads and cam worth it for a Maggie LS1?
- its offical i will be leaving
- Turbo Break-in???
- ***STS Turbos At Amazing Prices!!!***
- Hi everybody
- Mark your calendars
- Let me know if you want to sell new/newer forged LS6 blower shrtblock no longer using
- another fuel issue???
- c5 world cup stats 2007
- ECS Paxton Dyno sheet, stock A4 LS1
- Installed A and A Fuel System...
- Methanol Leak!
- Will a ten rib setup fit a C5?
- How long to get a forged motor built?
- Tested the N20 for the first time yesterday!
- Fast 90 and boost
- Oil Change - Blower Car
- Fealer
- Finally in the 9's with the Z06
- Vararam with Vortech System?
- Anyone running 60lbs injectors?
- Fuel Pressure inquiry
- Mercedes Benz Delusions
- help fuel filter i THINK ???????????????? help
- Anyone making the move ! !
- Sun Viser warning stickers for Hi HP cars
- F/I in the early years.
- Install instructions for P1SC idler pulley repl?
- New fuel pump...
- Sparkplugs Needed
- Correct cam for LS2 with LS3 heads?
- nitrous with a procharger how to ?
- Nitrous Motor
- The Big Dawg...Latest and final results on oem bottom end
- HPM Tuned Nitrous 408 Car Results
- Sneek peak!!
- MPH now direct with DeWitt's Reproductions
- Norris Motorsports Official Grand Re-Opening Dyno/BBQ Sept 29th & Some 1999 Pricing
- Twins Are On The Way
- Turbo Guys, Oil Temp Question
- Well, Dropped the Driveline Gauntlet...
- Seriously thinking about going from an A4 to an MN12 swap.
- How much more power with AFR 205s?
- Compression ratio f/i experts, what's comp on stock LS6 heads and -2cc Diamond Piston
- 402 TTix twin dyno #s !!!!
- ECS cam capabilities
- D1SC Kaboom! !
- 6rib vs 8 rib
- Does the ECS overdrive balancer use the stock AC belt...
- 826 rwhp F1R at 5500rpm, WTF?
- A Few Pics of the New Ride.........
- Any updates on the Eaton TVS...
- A must have for your garage
- 4L60/A4 experts - converter/transmission question
- Boost referenced Fuel Pressure Regulator
- Anyone recognize this catch can...
- Lets See Those Aftermarket Valve Covers
- FUNCOOL get's smashed!
- Anyone have knowledge of ability of RAPID Motorsports to build quality forged LS6?
- cut a tire & rim smokin wtb zo6 oem 10.5
- Gauge Question
- How are scat rods and diamond piston rings for forged LS6 blower motor
- Can oil be leaking out of IC pipe?
- Crank nose or damper failure?
- getting a new kenne bell setup what do u think it will do?
- HP on stock crank
- Employee Pricing Special
- Just a couple shots of the YSi
- Got a new Avatar ;)
- EnglandGreen Cam Package - everything including the Kitchen Sink!!!!
- Oil Fill Cap Breather?
- Why is the majority down on Maggies??? (serious replies please)
- How bout a ride with Mr. Paxton...Vid
- ? on peak reliable boost D1
- no a.c.
- NOS 100hp shot on H & C Reccomendations
- A Few Magazine Shots
- F/S ttix kit with extras and forged engine
- twin intank pump intrest?
- F/I cam experts-Stick with LS6 or 224/230 114 lsa for most power on/off boost?
- PCV Hardware and Routing for Supercharged C5 - Will This Setup Be Effective?
- How much water weter for a C5?
- FRCS for Maggie
- My Ecs Nos Bottle :)
- which cam for most power out of a 408?
- FAST Intake w/ Zex nitrous....anyone done it?
- Zex 250 hp kit
- Come for a ride in Mr. Whipple
- Krank Vent or Catch Can?
- Large things in small holes Lube?
- Procharger?
- curious question
- ***Talk about power under the curve***
- Oil Temps in self-contained SC's as opposed to Oil Pan FED
- Best Filter For Maggie?
- My latest project unveiled...I would like some thoughts.
- Julio from AlkyControl Rocks!!
- ECS Fuel Pump Wiring Q
- Coated Pistons? How long does the coating last?
- Stock 04 Z06 Fuel Pump Max Hp
- Our Carlisle Road Trip
- Do any of you with blowers run oil coolers ( 6-speed )
- Video from Famoso dragstrip
- I'm BAACCKKK!! Thanks Dr. PHIL!!
- Canadian Street Car Nationals C5 Results
- Has anyone sprayed running TT?
- Anyone run this cam with FI?
- Magazine Time
- *** Tornado Hits Corvettes At Carlisle ***
- What is going rate for P1SC
- Eaton supercharger Simulator
- Finally got my new headers!
- I just LOVE this thing!!
- cadillac, LPE w 164 maggie prototype
- Went turbo
- Procharged P1 Neebie at the Track
- RPM Transmissions
- Biggest (in capacity) supercharger system that is CARB certified for C5s?
- Establishing a Sale Price for TT 427 Vette
- Hot Air Ballon
- Anyone have installation instruction for Procharger Stage 2?
- LQ9 6.0L 317 Castings CNC'd BLEW INTAKE PORT OUT !!!
- What should my front O2's be reading
- I want to add a Supercharger. Which brand is best?
- APS Guys Look What a pair of T25 GT3071s can do
- 4 Bolt cylinder vs Boost question
- Next Level Performance (nlp) Bigger, Better, And More High Tech.
- New pic of my engine
- Fuel Pressure Drop
- Anyone W/ Maggie Spraying Nos?
- Turbo selection for a twin set-up.
- You guys are NUTS !!!!
- Z06 Screened Licsense Plate Fresh Air Mod + License plate = ????
- Free Shipping on ATI ProChargers at Exotic Performance Plus!
- CA emissions legal and 650rwhp??
- Which electronic boost controller iR U guys running?
- FI / Roadracing / Cooling Issues
- Questions for the turbo guys
- Procharger P1SC-II Question
- Norris Motorsports New Location and Grand Re-Opening ideas
- Vortech (factory kit) throwing belt???
- Power gains from 1 5/8" to 1 3/4" headers??
- Help! Need a LS1 edit file
- IAT sensor...
- Any Canadians from the GTA and Ottawa area in Carlisle this weekend?
- What C5 Twin-Turbo are kits available??? (besides APS)
- APS C6 ZO6 twin turbo system pics and install instructions
- Almost Done!! What should I expect??
- TTP Built LSx 427ci Twin Turbo Longblock..
- Vortech Superchargers On Sale! Special Discounts Through 8/28!
- Chambered Exhaust vid...teaser
- BEAT THE HEAT! Meziere Water Pumps Quick Sale
- Well It's Alive
- Does methanol have a shelf life?
- Where is OBXFUNN??? (forging 346 with KB...)
- Hood Gasket
- Guys what is making my mass air flow go out?
- Quik Z06 Is A Genius
- 402 twin turbo mistake ? HELP!!!!!
- LS7 Titanium Rods for FI?
- Opinions On my Proposed Nitrous Set-up Please
- RPM/Dr. Phil and the tiger
- need advice
- Textralia OZ700 Group Purchase Special
- Coil Question/Part #
- Catch can and supercharger ??
- Supercharger & PCV system, What works?
- Column Lock Problems Gone Forever!!! @ Carlisle This Week!
- Tigershark exhaust f/s in parts
- Turbo Size vs Exhaust Size
- Supercharger Recommendation
- wango tango
- newbie question
- ECS Saved my car :)
- procharger...a do it youself job??
- ARGH... My first non-fuel related problem!
- Need Spark Plug and wire Help!!
- Air-to-Air vs. Air-to-Water intercoolers
- My dyno run today
- Another day at the track today
- PLEASE HELP ME FI GUYS! car won't run right
