View Full Version : C5 Forced Induction/Nitrous
  1. Changing TB with s/c
  2. Anyone have a nitrous plate laying around FS?
  3. New Project 408 and GT 42 76 Turbo Rear Mount
  4. Methonal purchase ???
  5. F/I and C5's in retrospect!!!
  6. What kind of "HP" needed to run 9's
  7. Thanks OCC for helping me get to 195 MPH!!!
  8. A&A vortech c-5z
  9. HP and busted drivetrains
  10. ***ENOUGH!!*** please read
  11. What is the best turbo for all out power??
  12. Fuel Pressure still dropping HELP PLEASE.
  13. What TT setup is this?
  14. Corvette Wheelie....(Title changed)
  15. Maggie belt chirp when shifting w/ A4
  16. Narrow cog belts and blowers- how do they work?
  17. Who's got the best price on the TTiX kit??
  18. crankcase presure venting ?
  19. Need single turbo pic
  20. Vortech Dyno Numbers
  21. How much do your F/I monster weigh?
  22. APS twin intercooled twin turbo system - MSRP
  23. McMaster Carr Check Valve... 0.3 psi crack pressure???
  24. Spagetti 4 Two :)
  25. tried a couple of 1/4 mile passes at bg with no luck.
  26. Need a Setrab oil cooler this week
  27. What does it take to hit the 200mph mark
  28. Questions about anti pump-up lifters
  29. Dual Fan Advice ...
  30. KB BAP Users I have a Question
  31. Magnacharger coil covers?
  32. Pics of where your bottles are. NOS
  33. Maybe a Dumb Question
  34. My clutch, did I make a bad choice?
  35. May have blown clutch today...
  36. Opinions Wanted
  37. Next driveline setup...
  38. H/C,N/A going to F/I?
  39. 3 pod guage pillar
  40. 2002 Z06 or 2004 Z16 for my FI Road Racer?
  41. belt blown
  42. Nitrous solenoid question
  43. Killed the Procharger whistle!
  44. Killed the Procharger whistle!
  45. Big Dry Hit's great. "Ultimate PRO Dry" Times/Dyno
  46. Dimensions - Sources for Vortech restrictor plates - need info
  47. Nitrous Cheating?
  48. Which piston? Pick one
  49. 8 Rib belt question
  50. OH NO, funny noise under the hood, need some advice/moral support...
  51. Maggie vs Kenne Bell
  52. Multiple forced induction questions
  53. 03 Autometer Pod Pillar Install Help
  54. How much is too much for my auto?
  55. A different kind of alky injection (or nitrous)
  56. Torco and MY Arizona test...
  57. Column Lock DISASTER AVOIDED!!! A close Call...
  58. Do I need a new fuel pump?
  59. 2006 C5/c6 World Cup To.prediction !!!!!
  60. plugs
  61. New "secret" blower cam....
  62. Approaching the goal line
  63. Question for my fellow F/I brothers...
  64. American HP SIGN FUNDS
  65. Nitrous Express Price Increase!
  66. TNT nitrous kits Vs. Cold fusion kits???
  67. stock block nitrous setups
  68. APS C5 intercooled twin turbo dyno graphs at 7.6 PSI
  69. Another quick oil cooler thought...
  70. Blower Cam
  71. 427 w/ TNT 150 wet shot
  72. I have a MSD 2 bar MAP sensor but..
  73. American Hp Neon Sign
  74. MAF Table question P01514
  75. 347 or 402 ?
  76. NLP Billet PCV Catch Can, $74.95
  77. Twin Turbo LS1 in a BMW.....?.... Pic inside...
  78. Sell me your stock procharger bracket
  79. Sts 1/4 Times Who The Fastest...
  80. Catalytics and FI-they don't mix well!
  81. Will it work?
  82. shaking down the tt 402 at the track
  83. It's the "Hi Mark" thread (mdhmi)
  84. Nitrous
  85. stock pump, no boosters, and still returnless
  86. turbo cam SPECS - OPINIONS.
  87. RPM Transmissions is closing the doors
  88. Anyone here using Lucas Synthetic oil??
  89. First post...First z06...First supercharger ??
  90. How is bOOst changed in the Paxton ECS kit?
  91. wet 100 shot + modded Z06 = tuning necessary?
  92. A&A setup cutting the 6th rib off the belt
  93. is there much of a market for a used forged 346
  94. Trade 15lb NOS bottle for a 10lb
  95. How strong is a stock IRS?
  96. Geoff Skorupa Per Tech Center
  97. Mdhmi Fingers Broken????
  98. a and a vortech kit? plz step inside. ques.
  99. How are these Sts systems holding up
  100. 1st gen P-1 belt slip issues/bracket opions?
  101. anyone go to Byron IL for fastest street car shoot out and wheel stander contest???
  102. How much to have exhaust heat wrapped? STS
  103. need help: tnt wide open throttle sw. instruction
  104. Deburring a new block???
  105. So many oil cooler options, which ones work?
  106. What kind of shot of nitrous?
  107. Dyno numbers on new setup
  108. Narrowed down the choices...asking final advice
  109. Digital or analog gauges?
  110. Procharger 1/4 times
  111. How many miles are too many for a Magnuson?
  112. Hit every goal I had this year: 9’s baby!!!!!!!!!!!!
  113. Procharger.
  114. Anyone running bigger injectors on a Maggie
  115. 2002 Z06 supercharged or not?
  116. Ripped 2 Teeth out of my Ring & Pinion at Buttonwillow... {VIDEO}
  117. Getting closer...
  118. A & A Helps Again
  119. Your 700---800rwhp Vette Is Slow
  120. what kind of spark plugs for f/inductions?
  121. How long have you been F.I. before you had problems?
  122. BAP insatll
  123. d1sc overheating roaad race/meth inj?
  124. Fuel System Question
  125. what does sandbagging meen
  126. PLEASE give me your input and thoughts on my vette
  127. kENNE BELL VS MAGGIE
  128. lets talk slushboxes and TT
  129. Catch can install behind Procharger
  130. Post your quick ET for S/C and stock bottom end
  131. D1SC Pulley ??
  132. engine is out of the car, will it help TTIX install
  133. Whats Better
  134. Anyone upgrade their fuel supply line?
  135. What's the real cost of going the twin turbo route?
  136. Kenne Bell....So much power..so little road
  137. * EG is now a Supporting Tuner!!!! *
  138. Please post pics of your dry shot...
  139. "Honey I need to call Jose...I broke turbo and need new ones"
  140. A4 Transmission Running Hot after Vortech Install
  141. First kit PTK/PTS Dyno Results
  142. FJO Racing equipment discount
  143. any new bigger injector on the horizon?
  144. Cartek
  145. Second Round 364 D1SC @ 10psi
  146. well, its officially for sale (TT Z06)
  147. Looking for FL/GA based FI/NO2 car folks
  148. SuperCharger Question Please....
  149. What is the Gas milage you guys are getting?
  150. Paging Chris or Doug@ECS and all the fast centri 6 speed cars.
  151. Aluminum vs. Iron Block
  152. C5R 427ci twin turbo ...DONE...finally.Custom Meth install
  153. Who had best prices on Siemens injectors?
  154. Best tires and rims????? For street and strip....
  155. first impressions...ls2 402 with twin t-76's
  156. Times with NX?
  157. I'mmmmmm Baaaaack *American_HP*
  158. ATI ProCharger Super Sale!
  159. Which way to go...
  160. Pics of APS TT Install
  161. Reichard Racing Pulley?
  162. Need a pic of an installed TTiX
  163. Where to buy "LS1 Supercharged" fender badge
  164. What's normal Fuel Pressure?
  165. solid axle what does it take to put one in
  166. Where to get IAT relocation kit?
  167. Alki kit..... YES or NO???????
  168. Man I really don't want to do this!!!!!!
  169. I think i may have found the problem with my procharger Over heating issue
  170. Formula? Boost vs HP gain??
  171. Dyno - Unlocked Convertor Question
  172. MAF Breakage?
  173. Big Thank You to the crew at RPM!!!
  174. Need a quick tip on dual disk clutch install
  175. -Any Centri 6 spds in the 10's? Hell Yah!!!!
  176. MSD 8969 Digital Window Switch Wiring
  177. What cam to go with?
  178. Where do you put your bottle?
  179. Vortech SQ sound clip
  180. Kenny Bell
  181. New Supercharger??
  182. STS Methanol kit wiring
  183. Sts Turbo Airbridge ?
  184. SEMA SEMA SEMA & other vendor news...
  185. LS1 & LS2 Bare Block, Side by Side Comparison <Pics>
  186. c-5 zex kits worth the xtra$
  187. Gain with LS6 intake
  188. whats better for the street/roadrace 402 STS or 346TTIX
  189. Ed Potter's no longer at LPE
  190. Darton strokers and boost??
  191. "and man i thought mine were small!!!"
  192. 20lbs of boost & 400+ Cubes = BOOOM?
  193. What is the PN for the 2 bar map sensor to run boost?
  194. Magnuson Supercharger Price Increase
  195. Procharger Oil?
  196. "Stealth" tires?
  197. illumination wire
  198. East vs. West Z06 vs. Mustang
  199. Car runs better with MAF unplugged!
  200. Nitto 305/35-18 or 335/30-18 ???
  201. G-force transmissions
  202. lets talk turbos!
  203. KaaaaBoom....
  204. 5200 rpm redline??? PLEASE HELP
  205. combustion theory (at idle)
  206. If cost is not a concern - strongest LS2 forged Pistons???
  207. For all Canadian( Toronto) C5/C6 owners
  208. Wideband Guages
  209. +146rwhp, +180rwtq
  210. Driving impressions on recent mods, and Meet the New Torco Girl!{Video}
  211. **american Hp Update***
  212. Muffler Choices for STS
  213. *Long time no see guys!!! Remember me?? *
  214. *Long time no see guys!!! Remember me?? *
  215. Question for Vortech Guys.
  216. Auto Gauge Fuel Pressure Gauge
  217. Those with Blowers LG Pro 1 3/4 Vs. Kooks 1 7/8
  218. Defi Gauges?
  219. Anyone have any pics of their bottles mounted?
  220. Video A Ptk/pts C5 Turbo
  221. Questions about going FI on a stock C5....
  222. Mallory window switch.. not working. HELP!
  223. Anyone have pics of the TTiX intercooler?
  224. S/C Novice- Please Forgive Ignorance
  225. How much hp can the internals withstand?
  226. Oil gone bad???
  227. c6 a6 6 spd wit padd shift auto conversion
  228. Best tires for 383 A4 A&A kit
  229. Video 427 vs. carrera gt sick....
  230. Mods help
  231. Where do I sign up for the 700 Club!! Thank You Orange County Corvette!!!{Dyno Graph}
  232. Santa came early this year - STS kit...
  233. Santa came early this year - STS kit...
  234. 4 solinoid, direct port problem PLEASE HELP
  235. kenne bell pulley and idler help!!
  236. Supercharger home install
  237. Can I use milled AFR heads with blower?
  238. How much extra headroom does a BAP give you
  239. P1SC with 4.10 Pulley
  240. H2o2 / ASC Methanol / Nitromethane blend - for water/alcohol injection systems
  241. STS update finally
  242. Conversion Help to install a 97-98 return setup on a 02
  243. Electrical Engineer(types) / DC system experts inside
  244. Transmission Woes... Suggestions?
  245. New Dyno numbers
  246. Please help
  247. Base turbos or upgraded gt32 for STS and a 402/408
  248. Thinking about nitrous .. your thoughts please
  249. Vari-cool controller + ECS meth kit pump?
  250. Does the full A-pillar gauge pod replace the factory
