View Full Version : C5 Forced Induction/Nitrous
  1. What the heck is wrong with my car I need help guys.
  2. Drive/Prop Shaft Length
  3. Better To Have Stock Rockers Upgraded Or Buy Aftermarket Rockers?
  4. Anyone have pictures of ported oil pump and/or modded timing cover?
  5. Krank Vent, anyone running this?
  6. Fuel Pressure Gauge Install Question
  7. wtb/ billet idler pullys /where to buy
  8. Props To Nick Yoskin
  9. The Beginning of the Custom Front Mount GT47-88
  10. in car meth storage
  11. Help guys with steering shaft install.
  12. Looking for new McLeod Adjustable Clutch Master Cylinder...
  13. STS Turbo Question
  14. Basic question
  15. How reliable are nitrous cars?
  16. Traps speed question
  17. Torque tube bushing differences /pics of rubbing driveshaft couplers / vibration test
  18. Does to much fuel pressure cause a miss?
  19. Anybody run M/T 315/45/16 darg radial
  20. ccw drag pack and roll on's
  21. Thermostat and/or Housing
  22. HorsePower Sales NOS Install
  23. Any good links for MSD booster install?
  24. Cerra turbo kit.Help.
  25. Any Maggie owners interested?
  26. You guys are rookies. 1009 hp at 2 psi
  27. FI PCV Revisited, What's the next step?
  28. Forged 346 + YSI
  29. LG Big 3 Video
  30. Ran a new best in the 1/4 with a d1 9.63at 145
  31. Norris Motorsports C5 Z06 APS Install for CF Member bikeone
  32. What am I getting myself into
  33. Anyone have Close-up Pictures of Your A&A ProCharger Bracket
  34. Q's about 90mm intake for Maggie
  35. TTi on 99c5, help. Need advice.
  36. Need Advice On Blower Setup/01 ZO6
  37. ECS Methkit
  38. BMW rubber bushings for torque tube are wrong for vette
  39. Is the F1 ProCharger Bracket the same as the P1 Bracket
  40. D1SC 347 Procharger Graph
  41. Smaller pulley for the Maggie
  42. Forged LS3 slowly coming together...
  43. D1 Procharger to Novi 2000=Power Loss?
  44. Procharger Belt Problems
  45. BAP install location?
  46. WTB:Used A&A P1SC ProCharger Bracket - ASAP!
  47. New addition to the family
  48. Drive Shaft Shop...Drive shaft vibration..bad
  49. Just a recomendation...for higher mileage Ls1's
  50. What is the best bang for my buck?
  51. 402/NOS 90mm plate with a lean spike...
  52. Starting nitrous install this weekend & need help ASAP
  53. Intercooler for Magnuson
  54. pull x boost question
  55. Busted Rocker Arm
  56. Drag suspension Setup
  57. pic of the big blower!!
  58. c5 toronto F/I winter show & shine winner !!!
  59. 160*, 170*, 180* Thermostat ? ? ?
  60. best shortblocks for novi2000 on my C5 ?
  61. FI on all stock driveline?
  62. Supercharging experts? heads/cams needed?
  63. Oil catch can help
  64. Thermostat
  65. Who Makes of TT Top Mount Kit??????
  66. Is my set up a candidate for pulley/restrictor option?
  67. MY FI build...
  68. Instructions and parts list for ECS Alky kit?
  69. Advantages of Maggie Torque
  70. Preliminary Dyno #'s from my new F1A/402/AFR225 combo
  71. Gear Suggestions?
  72. STS Question?
  73. California CARB Legal FI
  74. *** My Cartek C5 in new online magazine/photoshoot ***
  75. oil system in Blown LS7 C5
  76. Gauge lighting question?
  77. fuel system returnless to return system
  78. TTiX vs. LPE Stage I on stock LS6
  79. Two questions about going blown.
  80. Smoked my Maggie engine!
  81. Bring Boost on Sooner
  82. Injector brand preference
  83. Anyone else need to borrow my pinning kit?
  84. 160 traps @ atco rental....
  85. my new stroker /no2 look !!!
  86. Pulley change ? Procharger
  87. Thanks to ECS crew
  88. Nano
  89. TT on Ebay ?????
  90. Compstar rod bolt stretch spec???
  91. 11#s on a maggie with a stock bottom end
  92. mototron 60# injectors
  93. My idler pulley disintegrated at the track with an 8-rib setup. Options?
  94. 427 TTI X 943 rwhp 1st pull!!
  95. FJO progressive nitrous mini-controller
  96. Fuel Pressure going up and down??? HELP ME!
  97. NOS Wiring Question
  98. How big of a nitrous shot do i need to go from 11.00 to 10.00 ?
  99. dyno results 125 dry shot
  100. Update on Supercharger project
  101. TTiX + Forged 347 Will Equal????
  102. Will this work on my car?
  103. Highest boost out of a TTi x kit !!
  104. Powder coated RevX Catch cans!!!!!
  105. NEW Style ECS Bracket for P1SC-1's - I can't find it!
  106. need advice on a clutch
  107. A Pillar Pods
  108. Latest Build at TTi
  109. Cam / Supercharger Compatibility....
  110. MSD Window to NX Throttle Switch HELP
  111. Weight Reduction
  112. LME or Texas speed?
  113. Cerra single turbo and SMC alky
  114. Procharger bypass valve trouble
  115. Super Charger reliability
  116. Best size rear tire for the drag strip ?
  117. Does anyone make tensioners that lock? for a P1SC-1?
  118. Anyone ever sprayed atmospheric air?
  119. Silly question
  120. ****The evolution of tuning at ECS****
  121. nitrous
  122. FI racing ....
  123. tr224r with nitrous?
  124. The Million Dollar Race ....
  125. Lets talk L92 heads for FI - would you???
  126. So how are you guys cleaning the ECS Novi 2000 air filters?
  127. First time at the 1/4 with the Novi
  128. Cartek 427 Warhawk w/ cog drive :)
  129. MAF Delete
  130. In with the new, out with the old- should be good pics in this one
  131. Snow Injection
  132. Journey to My TT Vette prototype
  133. Joe's Procharger Graph - Stock '04
  134. Boost with Pulley
  135. Running Temperature
  136. Vortech V2 T-trim impeller speed limitation
  137. Ecs Novi Kit + Lowered Vette?
  138. 1st Pass at the track today, 11's
  139. Stock block guys step in
  140. Please explain crank pinning to me?
  141. Video of C5 Z06 with supercharger + nitrous
  142. Paxton NOVI 2000 Bro's HELP Please ENTER
  143. Newbie Looking For Help In Michigan.
  144. PLEASE post TURBO drag racing videos!!!
  145. meth kit users, who uses windshield washer fluid
  146. Eaton TVS blower on LS9
  147. What size SVO injectors do you guys run
  148. BOV or Bypass Valve on an F1R
  149. Not FI but oh well!
  150. Pics of my supercharged Lingenfelter 2003 ZO6
  151. 90mm snout for 112 maggie
  152. Nitrous Picture Thread
  153. Kenne-Bell retuned in Speed Density
  154. A&A Supercharger Owners Questions
  155. Finally dyno'd the 402 F1A today-some good news, some bad!
  156. VERY Frustrated with EBoost2
  157. Vette Mag/Year One Challenge to the Fastetst Street Corvette
  158. The Toronto Lsx Ripper !!!
  159. Dragon racing supercharger
  160. Pro Charging questions
  161. New TVS blower looking promising
  162. What next ?
  163. Questions about nitrous.
  164. C6 Z06 TTI X Dyno 900/900 Pump Gas
  165. What valve springs with FI
  166. meth ECS pump running when battery voltage is low
  167. anyone or shops having a hard time getting meth?
  168. OK Meth users-Post your HP increase
  169. Thermostat facts.....
  170. considerations for 14psi or more on 10:1 compression
  171. The Vette Doctors-Leading the way into the next generation of tuning!
  172. Finally got it tuned!
  173. Synergy Motorports
  174. My LAPD/RPM Motors Tuned Forged 347 Is Done and The Numbers Are Inside!!!!
  175. Side or front drilling Crank for pins???
  176. nitrous activation question....?
  177. Anyone need a 6 speed mainshaft of half shafts?
  178. ECS Blower Cam
  179. Blower belt question?
  180. Throwing Blower cam "theories"-OUT THE WINDOW!!!!!!!
  181. 700+ ft/lbs Please Step in
  182. Max PSI?
  183. So the car is gone :(
  184. Hooking up the nitrous power system to switched hot.
  185. Looking For Copy of Base Tune for 02 Z06 With a Magnuson Supercharger
  186. 750-800 rwhp on pump gas.. how?
  187. KB vs other blower VS Turbos?
  188. 325/30/19 on C5 Z06 .....Rub???
  189. vararam+s/c=?
  190. nitrous finished ...pics
  191. ***Introducing ECS Parts Sales***
  192. stock LS6 runs 138mph with help of TTiX
  193. Maggie - Hood Hight?????
  194. Quick Question about Meth and AIT Sensor
  195. AIS Installation
  196. Anyone bump their rev limiter up?
  197. **** Blow Off Valve install on my APS TT kit (w/ pics and video)
  198. Nos help please
  199. Engine sputter
  200. a work in progress :)
  201. Scd A4 tranny coolers
  202. Anyone know the flow rate of stock early fuel pump?
  203. How much should meth be used to drop IAT
  204. After New Forged Motor and Only 7 PSI of BOOST! Rear Main Seal Keeps Leaking
  205. A few teaser shot of the upgraded TT ZO6
  206. Paxton Oil Return
  207. Normal Plugs & Nitrous?
  208. when to lift !!!!
  209. NOS Purge Tube Location C5
  210. Tuned and ready for action
  211. Fuel Pressure question/advice
  212. Charlie " The Tuner "
  213. New C5 Z06 Maggie install
  214. Kenne Bell qustion
  215. Dynoed today
  216. methanol kit
  217. methanol kit
  218. NOS - Heading in the right direction?
  219. lapd
  220. LS7 cyclinder walls too thin for boost
  221. How much boost can a NOVI run???
  222. Going NOVI 2000 need advice
  223. Scatt H-Beam Rods?
  224. Valve cover breather
  225. 06 r6 for supercharger
  226. How many of you F/I guys have big stereos?
  227. C5 Carnage
  228. Fuel System Question for APS turbo kit.
  229. 416ci/ECS kit
  230. Who has small prices on big injectors?
  231. Anyone run Stock Catless Stock H-Pipe and FI(Turbos)?
  232. Is this supercharger the same one that is on the new vette?
  233. $40,000 Lesson In Mechanics Lying
  234. Happy With Turbo?
  235. Interesting Lingenfelter C6 Intercooler
  236. APS C5 twin turbo upgrade power figures - 1000 rwhp
  237. Innovate lm1 question.
  238. procharger need info
  239. My FORGED 347 from LAPD Will be Dyno'd Today!
  240. cat question
  241. Gauges necessary for Maggie and nitrous? Stock look?
  242. Anyone running 4:10 gears and Maggie?
  243. will this cam work with s/c
  244. How many running a Iron block?
  245. other intercooler options
  246. Help, did i get the wrong fuel pressure guague?
  247. *****************Cartek Heads and Cam Special*********
  248. Crank pinning kit Drill fixture
  249. Fresh Air Mod
  250. Anyone running Hoosier A6 or R6 on street?
