View Full Version : C5 Forced Induction/Nitrous
  1. Anyone know whose setup this is?
  2. install boost gauge on novi2000
  3. any info on sts kit step inside
  4. Nitrous with Meth ?????
  5. My trip to Canadian Performance
  6. ECS Turbo Cam Less than 500 Miles On It!
  7. Last Week for Line Locks.........
  8. Broken Idler pulley with Maggie
  9. Boosted 346 w/ AFR 225's cracks 800 RWHP!
  10. ECS Tensioner Question
  11. Who has the FASTEST MPH C5 on the Planet
  12. want to add more shot to direct port zex sys.
  13. Heat Sink with FI
  14. My experience w/CHARLIE at RPM
  15. MadMatt9471
  16. Can P0300 be caused by a Breather on valve Cover?
  17. 4L80e conversion..ready to pull my hair out!!!
  18. poly engine mounts..vibration? anyone with experience?
  19. Whats the LS6 intake worth on a TT
  20. Nitrous rpm activated window switch
  21. Finally Re-Dyno'd the Vette @ RPM Motors By Charlie-Results & Dyno Sheet Inside
  22. Walbro fuel pump
  23. Blow out Seal
  24. Anybody want to see me put a "baby cam" in my car?
  25. RPM Transmissions - HP ratings?
  26. Maggie vs H/C swap?
  27. Watch this guy selling in the For Sale Section!
  28. Removing MAF on A&A Kit--Questions
  29. Methyl Hydrate for ALKY system
  30. What do you Guys think of this Blow Off Valve?
  31. Dynoing this Saturday...
  32. Just changed cam and now....
  33. ECS blower cam through GHLs
  34. 10lb full nitrous bottle free N20 not bottle
  35. Downtime really is lame: P1 rebuild (pics)
  36. Arun@CDNPERF
  37. Mt 315/30/18
  38. Leading Edge Performance IN VEGAS highly recommended!!
  39. Red anodized LS fuel rail kits in stock! $169 shipped.
  40. anyone using interceptor gauge
  41. Turbo Smart BOV Movie! Check this out!
  42. Leading Edge Performance APS TT Install Pics!
  43. Customer service
  44. Are any of you running 19" tires? If so which ones?
  45. nitrous problem...
  46. Best source for injectors?
  47. Coolant Issue
  48. 1000RWHP...FRC vs. Targa????
  49. Twin turbo kit for sale
  50. ON SALE - Turbosmart Dual Port Blow Off Valve
  51. Will this shortblock hold the abuse?
  52. automatic FI z06
  53. Any effects with running a fuel pressure of 43.5psi??
  54. guys who are runing tiel bov
  55. 79# injector 43.5psi VS 58psi and its effects on injector duty cycle..
  56. 79# injector 43.5psi VS 58psi and its effects on injector duty cycle..
  57. So, think your running alot of boost? Try 240 PSI!
  58. any tips on pulling the oil pan with engine in the car??
  59. Running Rich
  60. Any one running the msd timing twister??
  61. Vortech removal form 04 Z06
  62. Gatorback Belt for Maggie?
  63. A SAD day-I have decided to sell my Blown Z06!
  64. ECS vs. A&A
  65. Alkycontrol Rocks
  66. Whats the best way to pull my timing for nitrous use???
  67. New Supporting Vendor - Carbon Fiber Hydrographic Finishing
  68. Selling my blower kit.
  69. Is this the highest dyno'ing SC'd Vette?
  70. Torque Tube Couplings, What's the upgrade?
  71. I'm Doin' It - I'm Going In for the Re-Tune on Friday @ RPM Motors!
  72. Innovate LC-1s back in stock, EFILive special is back too!
  73. AMR H/C 346 goes 10.29 on 100 shot
  74. Wiring help for N20 Setup
  75. Paging AMERICAN HP
  76. Nitrous tuners?
  77. What spark plugs for me?
  78. kenne bell 1/4 mile times in.
  79. APS car misfiring
  80. Roll cage through DASH pictures(need them)
  81. C5 vert 6speed goes 9.81 at 139.5 at PINKS ALL OUT
  82. BAP Fuel Pressure question.
  83. LG Big 3, where can I buy them?
  84. Should I keep my shorties?
  85. Question for those who drag race
  86. NOVI 2000 help
  87. stupid turbo/supercharger question
  88. Washer tank level with meth?
  89. NOS Tank Paint Job COMPLETED!!
  90. Is a non-progressive Methanol Injection system worth the investment?
  91. Anyone have a boost-a-pump failure?
  92. TTP Built Boost Warhawk Motor
  93. What Size Pulley?
  94. What fuel system are you running?
  95. Ram VDS clutch?
  96. Mickey Thompson Et Street Dr's Any Input?
  97. Any Chance of a TVS Maggie?
  98. Looking for a C5 Corvette ATI Procharger bracket!
  99. sell my car for ZR-1?
  100. 800 Rwhp@5200 Rpm At 13lbs Of F1R Boost!!!!!
  101. Mikec-5
  102. 8 or 10 rib systems?
  103. Fichtners Spring Special Is Back!
  104. T-Trim or S-Trim
  105. I just want 135 more HP or so......Maggie???
  106. Stock motor Novi with cam makes 625RWHP SAE
  107. Guestimate my RWHP!
  108. Belt for a 8 rib Pulley System
  109. Anyone have a Whipple of Kenne Bell on a 99?
  110. Cartek Forged 427, Ysi Head Unit ,a&a Fuel Sytem?
  111. 416ci/ECS Paxton pics
  112. Came across some trash talk about Vettes in Other FI FORUM
  113. Long shot, any Lingenfelter experienced...
  114. Oil Breather Caps
  115. Cooling for rear-mount (STS style) BB Turbos?????
  116. MCM Supercharger Hood
  117. DET strut brace help
  118. Meth injection nozzle ??
  119. Tranny work with F/I?
  120. Anyone Interested in a 3.7" Reichard Racing Pulley?
  121. New ECS Avatars
  122. any c5 fi w/19" run 9's?
  123. Spy pictures of the C5 twin centri prototype
  124. Added Weight of Maggie S/C Package
  125. Which clutch to get?
  126. ECS Novi2000 car results
  127. APS TT 10 lbs stock bottom goes 9's
  128. Fresh Air Mod
  129. Recommeded Clutch for 600+rwhp?
  130. billet pulley combo !! 6&8 rib available
  131. Aftermarket fuel rails?
  132. ECS Desktops
  133. I'm jumping in!!
  134. Difference between Vortechs kits and A&A's
  135. Procharger has its first "Procharger Bracket Challenge"
  136. LSx 511 Boosted
  137. 90 mm Billet Throttle Bodies!!
  138. APS Twin Turbo Daily Driver?
  139. LS6 intake throttle bracket thread size??
  140. *** All Pro Cylinder Heads ***
  141. TWIN CENTRIS! Who's got them?
  142. New combo
  143. How much horsepower and torque can a stock bottom end ls6 car take Q/A
  144. Super Cars What the ????
  145. Best Syn. Oil for Supercharged Motors
  146. IATs after a burnout.
  147. 3 pillar pod
  148. Car came back from tuner. Sad,Sad,Sad
  149. Supercharger whine
  150. Mike-c5
  151. N20 Plate kit
  152. Novi 2000 vs Procharger D1 Graph Inside
  153. So... Clutches?
  154. Oh No!!!!!! Supporting Vendor Status????What Where They Thinking-lol!!
  155. stock driveline strength?
  156. 2002 C5 coupe w/nitrous
  157. Help me diagnose a drivetrain problem
  158. Kenne Bell or Procharger?
  159. procharger blow off valve question
  160. nos info needed
  161. Happy Easter ...
  162. Any turbo guys with loud exhaust close to Sanfran?
  163. LG 3" Exhaust help please
  164. ATTN: FLATOUT *** CLEAR YOUR PM BOX Please
  165. Got my MOJO back today.
  166. FREE NOS Kit from Nitrous Outlet
  167. Going on deployment tomorrow!!!
  168. Compression Test and LeakDown Test results.....Opinions ??
  169. P1518? Wtf
  170. ALL PRO LS7 6 Bolt Heads!! WOW!!!!
  171. Best model year Z to modify?
  172. Good blower cam
  173. ECS intercooler core size?
  174. power source
  175. Turbosmart Blow-Off Valves ON SALE!!!
  176. Spark plug options?
  177. racetronix 42# injectors
  178. wheres the best place to put you zex nozzle?
  179. Those with STS
  180. How much boost? 15,16,17#'s
  181. *** 1007-RWHP and 1053 RWTQ / Cartek 402 Single Turbo ***
  182. Tpis headers from 01. work well with FI?
  183. C5 torque tube shortening help
  184. What is holding me back?
  185. Sneak Peek - 10-Rib Conversion on ECS Novi 2000 Kit
  186. Single turbo on.Car is overheating.
  187. Exclusive photo's of the new home of The Vette Doctors...nice digs for sure
  188. I am joining the family. A new A&A Vortech kit on it's way!!!!!!
  189. A&A After 15K Miles
  190. OK... this is probably qualifies as the dumb question for today in this section...
  191. ECS Turbo Technology Stage X or APS installed in C5 - in the North East
  192. Why are FI cars slow?
  193. 100mm PowrMax Maf
  194. Do i have to pull my timing with a 100hp shot of wet with a hp tune.
  195. New Supporting Vendor!!
  196. Finally joined the club. C5 Z06
  197. Cheap tricks for FI stock motor.
  198. Cam HELP
  199. Whats the stock fuel pump good for?
  200. aps twin turbo question?
  201. Jeff Creech is at it again!!! Carolina Auto Masters
  202. Need help hooking up a ignition powerd nitrous power feed.
  203. Best place to buy Procharger?
  204. what power will this motor make? Turbo
  205. Looking for a Supercharger!
  206. How is this cam for turbo?
  207. 75-125 WET Shot what should I expect?
  208. Rad fan wiring question
  209. Spraying a P1SC?
  210. C6 McLeod and release bearing clearance
  211. 2008 is here !!! post your f/i c5 vids
  212. Supercharger Madness!!!!!!
  213. I got my Z back!!
  214. MSD Wires
  215. Need some help TTiX Troubleshooting
  216. ECS Dyno Video
  217. Threaded IAT in Manifold
  218. Another Nitrous Noob Question
  219. RPM Hardened Output Shaft
  220. Help..misfire on one cylinder and tried everything
  221. Guys with Textrailia OZ700 - What clutch hydraulics are you running?
  222. New Dry system considerations
  223. Has any one hooked up switch on the temp sensor to turn of the Spark time for nitrous
  224. TVS on LSx motor video
  225. Best hearders for 17# boost ls6 383? Kooks, LG, Am Racing, etc???
  226. How many have relocated your intake air temp sender?
  227. Burst knock
  228. Ontariovette's 427 F1R build up: OPERATION TOP SPEED!!!!!!!
  229. New ECS idlers in testing..
  230. Blower cam advice needed
  231. Who is running APS turbo's C5
  232. What Piston Rings to Run / Gaps? TT Set-up
  233. Procharger Rattle/noise
  234. Little help with Procharger Air Filter
  235. NX Direct Port FS
  236. Does Anyone Have a EXTRA ProCharger Offset Coupling? - Pic Inside!
  237. hey you procharger dealers
  238. FI Performance Custom Floor Mats **** C5 FI Owners Step Inside
  239. 900+rwhp/900+rwtq! And more to come!!!!!!
  240. Need inputs guys
  241. Bad bearing on P1SC..what are my options?
  242. Began Blowshield install...
  243. Procharger and overheating questions. Is this common?
  244. SPA Gauge, Boost reading problem.
  245. Fan temps
  246. Drain back for turbo.
  247. YEAH! SWEEEET! A&A Bracket Showed Up! It's Installed! It's All Good!
  248. Show those Bottles!!!
  249. AIR pump question.
  250. Any forseen issues with an Iron 408?
