View Full Version : C5 Forced Induction/Nitrous
  1. How do I tell if I have a boost leak?
  2. Tire pressure for R888 on the street?
  3. Procharger Pulley Size?
  4. Where did my boost go???
  5. Procharger Bypass value location
  6. C5 manual transmission special...
  7. C5 traction control bypass
  8. How important are valvesprings to a boosted application?
  9. Routing of heater lines
  10. Only have 511rwhp w/KB Heads help?
  11. Good review of the Magnaflow 16732 catback.
  12. just curious is anyone with a charger running 1:85 rollers?
  13. How can I toggle between 2 tunes easiest?
  14. Lep Dealer For Ais Meth Kits!!!!
  15. Any ECS guys that are going to the nationals this weekend step in
  16. FI heads??
  17. Cat back system
  18. Oil cooler hose question
  19. Anybody running the APS Twin Turbo setup?
  20. Pulling trigger and selling the Maggie
  21. C5 Z06 + Nitrous, Opinions Needed!
  22. Kinda of an odd ECS request...Has anyone replaced
  23. Getting frustrated here in Vegas
  24. Hell Ya!!! 2400 HP hits the Canyons...
  25. 402 with sts stage 3 turbos
  26. Going to the dark side. ( or coming from )
  27. Ecs Equals Honesty
  28. how loud is the vortech race bypass valve?
  29. paging ecs
  30. 3:90 with F/I?
  31. Belts To Buy What And Where
  32. Got Tuned By FLP Lost Power with Meth!!
  33. Upgraded ati bypass valve?
  34. what cam... with a vortech t trim
  35. Almost ready to fire big inch turbo LSx...
  36. Nitrous Fuse Center in Battery Tray
  37. G5x3 Supercharged?
  38. *** ECS STS Twin Turbo into 10s ***
  39. *vid* JAXX + RPM TRANNY = ET!
  40. sts turbo problem 01 z06
  41. Losing fuel pressure, boost a pump maxed out
  42. What will sound more aggressive & Loud, stock Z06 TI or B&B Rt 66 exhaust, h/cam, D1?
  43. 99 C-5 F1C VETTE's teardown pics!
  44. Lingenfelter C5 TT Owners With Upgraded Sway Bars
  45. Julio Alky Nozzle
  46. Need Help On A&A Vortech Install
  47. ATI 8-rib Super Dampner....
  48. Change out springs on Tial Wastegates
  49. Where to get Procharger oil in Columbus, OH
  50. WOT Switch Options
  51. Looking to find Geoff Scrupa
  52. Thanks RPM Transmissions!
  53. Hats off to ECS!!!!
  54. Replacement Lifters
  55. 6 speed scattershield installed !
  56. Anyone Here Running a Stage 1 Procharger?
  57. Thanks to A&A's Service and Support over the last 2 years
  58. Good blower cam spec's
  59. Getting Tuned Tomorrow!
  60. misfire?
  61. NOS or S/C
  62. FPR and BOV
  63. Need some .02
  64. Trailers Empty.................................
  65. Texas Speed Ported oil pump
  66. Will the stock FRC's work with procharger?
  67. My TCI T-Com/RPM 4L65 Conversion/Install.....
  68. NEW CAM installed
  69. A&A Vortech in and it's ****ing Awesome but the stock clutch is sticking!
  70. Help with codes after mods
  71. Fidanza Dual Disk for FI
  72. Glow Shift Gauges
  73. I-Charger ? Anyone heard of it ??
  74. FS: Vortech Race BOV
  75. SPA gauge wire routing through tunnel?
  76. I Need More
  77. Check engine light flashing !!
  78. 4-26-08 ECS Challange Novi 2000 results
  79. Detuned the Novi 2000 for Summer, 763 RWHP [Dyno Video]
  80. Afr# Help ??
  81. C5/C6 Bash Results
  82. Who Sells 85 or 90lb Injectors?
  83. how much power can a ls1 or ls6 block safely handle
  84. Nitrous Guys Please help need advise
  85. Can you pull head off with ARP studs in car?
  86. Canadian Performace Tuned 770rwhp...
  87. how much power can a ls1 or ls6 block safely handle
  88. novi 2000 belt problem
  89. Catch can not catching
  90. Thermostat Change to 160*
  91. grinding noise from a maggie
  92. A&A Supercharger SALE- $800 OFF
  93. R-compound tire temps at highway speeds
  94. shop finaly started install of T-trim
  95. who has painted there maggie?
  96. AFR's went wacko very lean
  97. 105mm Throttle body.
  98. Stumble on accelleration. What does belt slip feel like?
  99. twin turbo's on Warhawk
  100. meth install
  101. Is now a good time to repl torque tube bushings?
  102. My First 2 weeks w/A&A Vortec
  103. need some quick wiring help
  104. Southwest US installer/tuner for an ECS Paxton?
  105. Important Personal notice, Please Read.
  106. Best/Suggestion Meth kit for C5 LS1 Procharger P1SC kit
  107. P1SC torque specs(bolts)
  108. Smoke out oil fill location
  109. RevXtreme Keene Bell billet prototype...
  110. Where to weld wide band bung on stock exhaust?
  111. Sts Oil Return Proposal
  112. Fuel Tight Connections
  113. Fuel pressure regulator ????
  114. M122
  115. Maggie on a Road Coarse
  116. well guys I made the corvette muscle challenge for corvette fever mag
  117. Fuel System solutions... Do I need twin pumps? Thanks in advance
  118. Blower Pulley
  119. gauging interest fully built motor / f1c procharger setup
  120. Tex Clutch Problem, Need Help Again.
  121. Octanium Issue?
  122. How much power will stock main bolts take?
  123. Best place to get Magnuson parts??
  124. Show me your TTI Stage X engine bays
  125. Leaky Rear-End
  126. where do i put this cable?? (novi 2000 install)
  127. tial bov
  128. M&H Drag Radials 345/35R18
  129. PICTURES FROM HIN 2008 SHOW my z06
  130. My trip to Canadian Performance has lead to big changes
  131. P1SC vs D1SC
  132. WTB: 8 Rib Blower Pulley
  133. Squeals Like A Pig
  134. P1SC squeals like a pig(belt squeal)
  135. Can you put a kb on a 98' w/ stock computer
  136. Anyone regret going with meth?
  137. What are the characteristics of a mild blower cam?
  138. 20 or 40 Amp KB BAP?
  139. Chicago Area-Used good condition Tex OZ 700 Clutch with Billet Steel Flywheel!
  140. 335/35's on 17x11 Rims, Fittment/Rubbing Issues?
  141. FS: Parts for DIY Tunnel Port (front plate with mesh)
  142. Spec SuperTwin Clutch for sale...
  143. AFR 225 Heads For Sale NJ
  144. LS7 injectors in LS1?
  145. car always wants to spin out??
  146. Anybody got a Blitz for sale?
  147. removing swaintech coating??
  148. How difficult to change belts on a Procharger?
  149. How to hold the power???
  150. belt removal help on an F1
  151. Joe's (z06fever) New Numbers
  152. TIRES AGAIN!Come on! nitto 555 DRs
  153. P1-SC Tuning
  154. Maggie between 5,500 & 6,000 rpms
  155. Ported Carbon Fiber Fast 90MM Intakes In Stock!
  156. Forced Induction Intake Conversation
  157. Looking For: STS Installation Manual
  158. Help w/ECS meth install??????
  159. Smallest 6 rib pulley w/o slip?
  160. Alternatives to A&A InterCooler
  161. Is there ANY gain from FAST 90 VS LS6?
  162. Removing Pulley on Vortech T-Trim V2
  163. LS Coils
  164. Safe / Normal Oil temps with a Vortech??
  165. 3.8 pulley to 3.6 pulley on A&A?
  166. Any good word on Big Mouth Air Dams?
  167. What KB BAP pressure sending unit did you select?
  168. Anyone running a BAP + harness with stock fuel pump?
  169. How will ECS blower cam work with TTix kit?
  170. Video: 2008 Turbo Tech Spring Dyno Day
  171. 408
  172. Mike-C5 Welcome Back
  173. Racetronix harness routing suggestions please
  174. In Car mount for Camera
  175. Bird Of Prey "Talon" clutch ROCKS!!!
  176. my buield is done
  177. Twin gauge A-Pillar recommendations please
  178. Instructions/tips for replacing the rear end output shaft
  179. lg big 3' cat back ###s
  180. Anyone used the new NX dry shot system?
  181. Who here does autocross or road racing with a S/C car?
  182. anyone using hoosier r6?
  183. Procharger P1SC results
  184. Please input
  185. Used Procharger Head units
  186. New EG Website - Constructive Comments?
  187. Nick Yoskin..inside
  188. More power needed, what route to choose?
  189. Holy crap Doug and Chris!
  190. I think I have a headgasket problem!
  191. What does a big HP forced induction car really pick up by loosing cats?
  192. 10 Rib Issues
  193. How often do you change your NGK TR6's?
  194. Hoosier A6's on the highway at speed?
  195. any Supercharger sales?
  196. Need help Having problems with boost
  197. Maggie and what to break under 11.0?
  198. Nitrous users MSD TPS/RPM Activation Switch
  199. What head fastners are you using poll?
  200. ECS meth kit install w/a Maggie
  201. The Sleeper is Supercharged
  202. Picts of my trip to Canadian Performance
  203. Need Help choosing a Converter?? tti car
  204. APS TT, out of curiosity
  205. APS kit vs. TTiX kit????
  206. Fuel Presure Drop
  207. My new F1-A head unit
  208. It's Alive!
  209. Heads upgrade on a Maggie
  210. ECS Kit
  211. Low mile z06 and 10,000 cash for FI
  212. Twin Garrett Turbos
  213. Atlanta Performance & Fabrication Tune ??
  214. What am I not understanding about aftermarket regulators?
  215. Tial Bov Owners Please Chime In ! ! !
  216. RPM Cam only Procharged Z06
  217. Pulled the trigger
  218. ECS maggie hd tensioner, springloaded one
  219. any shops near Springfield MO. ??
  220. What will adding Blower Cam after addition of Maggie do to my 1/4 times?
  221. ECS venting-I need pics
  222. decided to make my own supercharger
  223. Any One Running a "TIMING TUNER" with N2O
  224. Need Racetronix intructions for '04 install with MSD BAP
  225. ECS Procherger Install Instructions
  226. A Quick 800rwhp@5000 rpm run.
  227. Twin Turbos with Darton wet sleeves
  228. Nitrous Retail Locations
  229. Oil breather solutions....
  230. Need Help!!
  231. video of my kenne bell z06 going down the track
  232. 1st drive after s/c install. Lots of questions
  233. Single turbo's, who's got pictures?
  234. TT traditional mount or rear mount????
  235. Centri SC or Turbo for street car???
  236. Supercharger
  237. *****need Help Making Decision *****
  238. Boost a pump ?
  239. A&A Vortech Kit with LS2 Throttle body
  240. need FI AIR pump help
  241. Lay the radiator face down. Need pic's.
  242. What do you guys know about the Kenne Bell's for our cars?
  243. Header wrap smoking & Turbo Smart boost valve.
  244. McCLound Twin Disc Clutch-What is the rwhp rating?
  245. S/C and auto tranny
  246. New F/I owner, some questions
  247. CLutch Vendors and those who sell Texralia Twin Disc please enter!
  248. OK 750+rwhp guys-I need street friend twin disc street friendly clutch to hold power!
  249. Hit the dyno, good news on everything looking good bad news on clutch!
  250. It's DONE! Thanks EG for the A&A Vortech Install
